Restore backup?
what2be
Eureka, CA, USA
C?ID=598147
I completed a full vehicle backup in .hex format but I see no way to restore it. Even if i need to restore a single adaptation, how is this done?
The only reference i can seem to find is this:
Restore can only be done from the new "adphex-[whatever].csv" file format, so obviously one must make a Raw Hex map before one can Restore Adaptations from it. Note: The Restore functionality may not work on control modules that use the ancient KW1281 protocol.
It has be done one module at a time. Select Single Controller Address, put in the Address, and check the box for Restore Adaptations. When you click [Go], you'll be prompted for the name of the file to restore from.
