Headlights not working AFS error and some more errors
Jonathan1977
South Africa
C?ID=589658
Hello All
Let me start at the beginning.....I few months back I took my first generation 2005 VW Touareg 5.0 V10 TDI to a "reputable air con service centre" due to my airconditioner not cooling (this was after the Dealership said that they cannot work on my vehicle). This guy told me I need to replace my aircon pump and radiator. So I got these replaced and when I went to fetch my car all of a sudden it was full of errors which were previously not there. and my Airconditioner is still not working.
Now to add to the dliemma I have no front lights as well! After buying 2 fake vcds interface cables (which I thought were genuine) I finally struck gold with the 3rd cable. I have run a full diagnostic which indicated short to ground on the left hand side, which led to me removing the headlights. I discovered the 2 short headlight looms were perished and have since repaired them.
I now have the right hand side indicator working and a small bulb(maybe park bulb not sure?) but still nothing on the left hand side.
If someone can maybe point me in the right direction as well as help me to get the communication going again it would be great.
Here is my latest scan:
Thursday,03,October,2024,14:58:49:37818
VIN: WVGZZZ7LZ6D014293   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D014293   Mileage: 176470km-109653miles
   Part No SW: 070 906 016 AA    HW: 028 101 148 1
   Component: V10 5,0L EDCG000AGMª6189
   Coding: 0010575
   Shop #: WSC 31414 000 00000
   VCID: 4FFFA0127BC417D2961-5160
   VINID: 9E65EAAAA1DCA865000440890CEFF16FD9
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -  - Intermittent
                    RPM: 651 /min
                    Torque: 150.1 Nm
                    Voltage: 13.53 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BM
   Component: AL 750 6A           0592
   Coding: 0012328
   VCID: 7AA921C690C6627A11F-5160
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D23EADAC168954274D-5160
   Part No SW: 3D0 909 137     HW: 5WK 470 22
   Component: 05 Kessy            6700
   Revision: 67005514    Serial number: VWZ3Z0E3369500
   Coding: 0147688
   VCID: 64957FBE0242848ADB3-5160
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77AF38F2A3D47F126E1-5160
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 L
   Component: CLIMAtronic 2+2     4018
   Subsystem 1 - Part No: 7L6 907 049 D
   Component: CLIMAtronic FOND    0400
00711 - Left Footwell Flap Positioning Motor (V108)
00445 - Loss of Refrigerant
                    Temperature: 82.0°C
                    RPM: 608 /min
                    Absolute Pres.: 5.0 bar
                    Load: 94.0 %
                    Temperature: 18.0°C
                    Temperature: 22.0°C
                    Temperature: 56.0°C
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111868
   VCID: 47CF883293B4CF92DE1-5160
00967 - Left Turn Signals
            007 - Short to Ground
01494 - Bulb for Parking Lamps; Left (M1)
01495 - Bulb for High-Beams; Left (M30)
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª6189
   Coding: 0010575
18315 - Engine Databus
            P1907 - 000 - ECU<->ECU Communications Fault - Intermittent
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
16482 - Intake Air Temperature Sensor 2 (G299)
            P0098 - 000 - Signal too Low - Intermittent
                    Torque: 442.4 Nm
                    Voltage: 11.48 V
                    Temperature: 130.5°C
                    Temperature: 11.7°C
                    Temperature: 14.4°C
16626 - Manifold Pressure / Boost Sensor 2 (G447)
            P0242 - 000 - Signal too High - Intermittent
                    Torque: 442.4 Nm
                    Voltage: 11.55 V
                    Bin. Bits: 00001111
                    Absolute Pres.: 173.4 mbar
                    Absolute Pres.: 2590.8 mbar
19792 - Control Module 2 for Turbocharger(s)
            P3336 - 000 - Missing Message(s) - Intermittent
                    Torque: 442.4 Nm
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Absolute Pres.: 2182.8 mbar
18156 - Transmission Control Unit
            P1748 - 000 - Programming Error - Intermittent
                    Torque: 331.8 Nm
                    Voltage: 11.70 V
                    Bin. Bits: 00001100
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 251322BA49F83D820CD-5160
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40DD932EB69AF8AA1FB-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881 B
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007721
   Shop #: WSC 05147 996 88872
   VCID: 372FF8F2E354BF12AE1-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 C
   Component: Standheizung E1MAC
   Coding: 0000030
   VCID: 3631F5F6E45E461AB57-5160
01177 - Engine Control Unit
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 52110 004 1048576
   VCID: 70BD03EEC6BA282AAFB-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5FD0D28BE44752261-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 01657 996 62726
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 K
   Component: 34 HSG              4105
   Coding: 0000081
   VCID: 44D59F3EA282E48A3B3-4B14
   Subsystem 1 - Part No: 7L0 959 701 L
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 L
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719
   Subsystem 6 - Part No: 7L6 951 171
   Component: B  Innenraumsensor  0020
Address 47: Sound System        Labels:
   VCID: 55F3527A5C086D025CD-5160
   Note: Excessive Comm Errors
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000009
   Shop #: WSC 63354 003 1048576
   VCID: 78AD3BCEAECA706A67B-5160
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
8 Faults Found:
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 226
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 226
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 226
                    Fault Status: 11100101
                    Reset counter: 226
02071 - Local Databus
                    Fault Status: 00101110
                    Reset counter: 123
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 88
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 88
                    Reset counter: 123
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00208933
   Shop #: WSC 31414
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392BFECAD540A962585-5160
00437 - Rear Right Inner Parking Aid Sensor (G335)
            014 - Defective
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
   Component: FSE_275x        H18 0020
   Revision: 00000001    Serial number: 00000000253650
   Coding: 0000211
02503 - Output Wire to Radio
                    Reset counter: 12
                    Time Indication: 15
End----------(Elapsed Time: 08:52, VBatt start/end: 12.4V/12.3V)-----------
Jonathan1977
South Africa
C?ID=589658
Update:
I found a blown fuse on the LHS fuse box 10A , replace and now I have indicators working on all corners. Im thrilled! now just the lights. Question.... will I need to run a new diagnostic now? ....to see if the short to ground error disappears?
Jonathan1977
South Africa
C?ID=589658
So I ran another diagnostic , the faults remain the same. But at least all my indicators work now... progress even though its small !
Jonathan1977
South Africa
C?ID=589658
Thursday,03,October,2024,16:50:28:37818
          37 39 3C 46 47 55a 56 57 64 65 68 69 6C 6D 6E 75 76 77
   Coding: 0010575
                    RPM: 651 /min
                    Torque: 150.1 Nm
                    Voltage: 13.53 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
   Coding: 0012328
   Coding: 0022786
   Coding: 0147688
                    Temperature: 82.0°C
                    RPM: 608 /min
                    Load: 94.0 %
                    Temperature: 18.0°C
                    Temperature: 22.0°C
                    Temperature: 56.0°C
   Component:                     3001
   Coding: 0111868
   Coding: 0010575
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 442.4 Nm
                    Voltage: 11.48 V
                    Temperature: 11.7°C
                    Temperature: 14.4°C
                    Torque: 442.4 Nm
                    Voltage: 11.55 V
                    Bin. Bits: 00001111
                    Torque: 442.4 Nm
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Torque: 331.8 Nm
                    Voltage: 11.70 V
                    Bin. Bits: 00001100
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
   Coding: 0012354
   Coding: 0000032
   Coding: 0007721
   Coding: 0000030
   Coding: 0000006
   Coding: 0015521
   Coding: 0000081
   Coding: 0000009
   Coding: 00000255
   Coding: 00000255
8 Faults Found:
            000 - - - MIL ON
                    Reset counter: 226
            000 - - - MIL ON
                    Reset counter: 226
            000 - - - MIL ON
                    Reset counter: 226
                    Reset counter: 226
                    Reset counter: 123
                    Reset counter: 88
                    Reset counter: 88
                    Reset counter: 123
   Coding: 0000855
   Coding: 00208933
   Shop #: WSC 31414
            014 - Defective
   Coding: 0000211
                    Reset counter: 12
                    Time Indication: 15
End----------(Elapsed Time: 08:50, VBatt start/end: 12.3V/12.2V)-----------
02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - MIL ON
02234 - Right Headlight Power Output Stage (J668) 004 - No Signal/Communication - MIL ON
The main Headlight Range module at address 55 can't talk to the headlights themselves. Check wiring, connections, and voltage supply there.
Jonathan1977
South Africa
C?ID=589658
@Uwe I have repaired the short wiring looms behind the headlights and they are definitely connecting now as the indicators(flashers) have power which they previously didnt have. Is there somewhere else I may be overlooking?
Jonathan1977
South Africa
C?ID=589658
Righto hi peeps
More success , one more fuse was blown and now I have a LHS headlight working as well. I am going to check all the fuses lol maybe theres another blown one. I will run a fresh diagnostic a bit later in the day
Jonathan1977
South Africa
C?ID=589658
Hello everyone
So I have success! All lights are working. I ended up following the Ross tech Wiki which pointed me in the right direction and once I went through all the fuses I now have lights and all!
I ran a new diagnostic but am still getting short to ground faults even though it works ... quite strange. My next mission is to figure out why the airconditioner is not cooling as it should.
Here is the latest diagnostic:
Friday,04,October,2024,15:08:50:37818
VIN: WVGZZZ7LZ6D014293   Mileage: 176510km-109678miles
   Coding: 0010575
                    RPM: 651 /min
                    Torque: 150.1 Nm
                    Voltage: 13.53 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
   Coding: 0012328
   Coding: 0022786
   Coding: 0147688
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Temperature: 82.0°C
                    RPM: 608 /min
                    Load: 94.0 %
                    Temperature: 18.0°C
                    Temperature: 22.0°C
                    Temperature: 56.0°C
02597 - Rear Left Upper Body Vent Motor (V315)
   Component:                     3001
   Coding: 0111868
8 Faults Found:
02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)
   Coding: 0010575
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 426.6 Nm
                    Voltage: 7.14 V
                    Bin. Bits: 00001111
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
                    Torque: 442.4 Nm
                    Voltage: 11.48 V
                    Temperature: 11.7°C
                    Temperature: 14.4°C
                    Torque: 442.4 Nm
                    Voltage: 11.55 V
                    Bin. Bits: 00001111
                    Torque: 442.4 Nm
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Torque: 331.8 Nm
                    Voltage: 11.70 V
                    Bin. Bits: 00001100
                    Torque: 221.2 Nm
                    Torque: 0.0 Nm
   Coding: 0012354
   Coding: 0000032
   Coding: 0007721
   Coding: 0000030
   Coding: 0000006
   Coding: 0015521
   Coding: 0000081
   Coding: 0000009
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X017
   Coding: 00000034
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
                    Reset counter: 123
                    Reset counter: 150
                    Reset counter: 150
                    Reset counter: 123
   Coding: 0000855
   Coding: 00208933
   Shop #: WSC 31414
            014 - Defective
00436 - Rear Left Inner Parking Aid Sensor (G334)
            014 - Defective
   Coding: 0000211
                    Reset counter: 12
                    Time Indication: 15
End----------(Elapsed Time: 08:55, VBatt start/end: 12.1V/12.1V)-----------
siLc
Tallinn, Estonia
C?ID=330192
You don't have to look far.
If you're having many cases of faulty wiring, then it would be worth to check the condition of wiring of G65 (pressure sensor of AC refrigerant circuit).
Jonathan1977
South Africa
C?ID=589658
@siLc I recently replaced the aircon pump and they regassed the AC so I tend to believe the problem is elsewhere. The wiring or the sensor is a good place to start. Now just to find the location of it. Were experiencing a heatwave this week in South Africa and a working AC would be nice!
Jonathan1977
South Africa
C?ID=589658
So I thought I would show you guys some pics of the Touaregs headlight short wiring loom.
I cant believe that the mechanic thought that it was ok to install this loom like this
I cut the wires one by one slipped heatshrink over the exposed areas and soldered the wires back together
After completing all the wires the same way I wrapped with a material loom tape, The loom is slightly stiffer than the original. But it works.
The finished product:
Thanx for looking!
"I'm a mechanic, not an electrician!"
I can't wait for people like that to start "fixing" EVs. :facepalm:
BadViking
C?ID=330893
It may be that the garage you took the vehicle to turned the ignition on while headlights and sensors were unplugged. Clearing all the codes will give you a fresh start. Those wire looms looked horrible. There may be many more looms in similar condition.
Jonathan1977
South Africa
C?ID=589658
So the mission to sort out the Air conditioner continues, I have searched the net flat but cannot seem to find any info on where the high pressure sensor location is. Every time I look it takes hours to remove parts and then .....nothing
Oh well .. the search continues
