2012 Q7 Need longcoding for ABS Module.
what2be
Eureka, CA, USA
C?ID=598147
2012 Q7 TDI Prestige
So before I bought VCDS I backed up the modules with OBDeleven, but when I went to restore the longcode for the brake module, it gave me a error. So... after I bought VCDS, I found a tutorial for VCDS on coding a ABS module and it all seemed straight forward other than the part where I need the original long code because the one in the OBDeleven backup is only 7 digits and worthless.
BTW, the car is currently in a crank no start condition after I replaced 2 glow plugs and 2 abs wheel sensors and the fuel filter.
Tuesday,01,October,2024,19:57:33:32476
VIN: WA1VMAFE7CD003066   License Plate: OCT 1 8PM
Mileage: 296760km-184398mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 69 6D 6F 72 76
VIN: WA1VMAFE7CD003066   Mileage: 296760km-184398miles
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401     HW: 4L0 907 401 D
   Component: 3.0TDI FSA    H18 0009
   Revision: 54H18---    Serial number:                CVN: 5B6F114CD45710C1755A2113
   Coding: 2A2A4012253600050000
   Shop #: WSC 27985 004 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401 002008
   ROD: EV_ECM30TDI0114L2910401_002.rod
   VCID: 61987DF911CE47C2305-8034
   VINID: 9D10667515951D35000030061896D2B1F1
10 Faults Found:
14625 - Glow Plug Control Module (J179)
          P0683 00 [00100111] - Electrical Malfunction
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 ∞C
                    Intake air temperature: 18 ∞C
                    Voltage terminal 30: 11.800 V
                    Glow-control unit: activation voltage: 0 mV
                    Glow_period_control_unit_ground_offset_voltage: 0 mV
                    Glow-control unit: calculated glow voltage: 0 mV
                    Glow_period_control_unit_energy_integrator_calculated_value: 0.0 V≤s
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 0
                    Glow cycles upon reaching temperature threshold-Bits 0-7: 18
                    Glow status-Bits 0-7: 0
                    Glow status-Bits 0-7: 80
                    Co EOM st Op Mode Short-Bits 0-7: 0
5368 - Relay for Low Heater Output
          P302C 00 [00100111] - Short to Ground
          [Low heat output relayShort circuit to Ground (GND)]
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Shut-off timer: last engine shut-off time: 2 s
                    Control module temp.: max. value: 62.2 ∞C
                    Mean injection quantity: 0.00 mg/stroke
                    Ambient temperature: 15.5 ∞C
                    Control Module temperature: 26.5 ∞C
5369 - Relay for High Heater Output
          P302D 00 [00100111] - Short to Ground
          [High heat output relayShort circuit to Ground (GND)]
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [00100111] - Intermittent
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Control Module temperature: 26.6 ∞C
                    EGR_governor_deviation: 750.0 mg/stroke
                    Inj Ctl q Curr: 0.00 mg/stroke
                    Standardized air flow ratio: 3.9999
                    Air mass at air mass meter 1: 0.0 kg/h
                    Actual charge pressure: 1008 hPa
4873 - Exhaust Gas Recirculation Cooling Valve Control Circuit
          P2426 00 [00100111] - Short to Ground
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Voltage terminal 30: 11.820 V
9760 - Switch-Over Valve for EGR Cooler
          P148F 00 [00100111] - Electrical Malfunction
          [exh.gas recirc. cooler switch-over valve 2Electrical malfunction]
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
9490 - Engine Oil Pressure Regulation
          P06DB 00 [00100111] - Short to GND
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
5301 - Throttle Actuator Control Circuit
          P2100 00 [00100111] - Open Circuit
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Throttle valve adapter: specified value: 95.00 %
                    Throttle valve adapter: actual value: 100.00 %
                    Throttle valve adapter: status-Bits 0-7: 0
                    Throttle valve adapter: status-Bits 0-7: 7
5307 - Throttle Valve Actuator Control System
          P2101 00 [00100111] - Malfunction
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:16
9127 - Actuator Module for Turbocharger 1
          P00AF 00 [10100111] - Stuck
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:16
                    Charge Pressure Actuator: activation: 5.00 %
                    Charge air pressure actuator: acknowledgment: -4.82 %
                    Turbocharger boost control: offset closed: 0.00 %
                    Turbocharger boost control: offset open: 0.00 %
                    High press turbocharger actuator: actual uncond volt value: 258.8 mV
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 S    HW: 0C8 927 750 S
   Component: AL1000 AISIN  001 3408
   Serial number:                CVN: 44BD1086
   Coding: 001378
   ROD: EV_TCMAL991031_002_AU56.rod
   VCID: 3C26EC8DD6EC4A2A433-8068
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H22001
   Coding: 0033809
   Shop #: WSC 31414 790 00001
   VCID: 280E20DD3EF4F68A37B-807C
                    Fault Status: 01100101
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:12
                    Count: 128
                    Count: 4353
                    Count: 8215
                    Count: 43264
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:14
                    Count: 128
                    Count: 4353
                    Count: 197
                    Count: 43008
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401893047
   Coding: 0000135
   Shop #: WSC 44055 001 1048576
   VCID: 251029E949E6EBE20CD-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AJ
   Revision: 00---026    Serial number: 00000030208767
   Coding: 0004A036
   VCID: 251029E945E6EBE20CD-8070
   Subsystem 1 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           0012461892
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 D    HW: 8K0 959 772
   Serial number:           0012461828
   Coding: 070000
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
                    Temperature: 23.0∞C
02874 - Control Module 2 for Central Convenience (J773)
                    Fault Status: 01101000
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E8216C5DC90E8BABD7-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH43 0230
   Revision: 07H43000    Serial number: 0038QD09VDZ9
   Coding: 0014131
   VCID: 2B04DFD12F02DD92DA9-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME180D265AK
   Subsystem 3 - Serial number: 6342QSME180D2C78R
   Subsystem 4 - Serial number: 6352QSME195E225AP
   Subsystem 5 - Serial number: 6362QSME685C2972T
   Subsystem 6 - Serial number: 63734SME315C3C7CD
   Subsystem 7 - Serial number: 63834SME045B217E3
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H07000    Serial number: 90025111660484
   Coding: 0012242
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 984 R    HW: 4L0 920 984 R
   Component: KOMBIINSTR.   H22 0411
   Revision: 00000000    Serial number: LMZ04009C
   Coding: 8BD664040900CF05020205
   VCID: 42DA9275B4883CDA09F-8016
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M11819012B
   Coding: 00C303
   VCID: 3D20E189CD76432274D-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790354551
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:13
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 7
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AB
   Revision: 00---010    Serial number: 00000000293140
   Coding: 0000006
   VCID: 688E60DDFE74368AF7B-803C
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:17
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:22
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000013015459
   Coding: 00581B00000011110000
   VCID: 323AC2B504288C5A99F-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E02D6C51C10A8BAFD7-807A
   Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ˇ
   Subsystem 4 - Serial number: 912704ˇ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000012886533
   Coding: 011F57205E40440004
   VCID: 48CE805D92B4168AD7B-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H11 0120
   Revision: 0120 ---    Serial number: 01556943850000
   Coding: 3569693
   VCID: 382EF09DEE54660AA7B-806C
Address 47: Sound System
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005190106726
   Coding: 0758477
   VCID: 231437F147D215D2629-8076
                    Fault Status: 11101101
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:13
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.90 V
                    Temperature: 15.0∞C
                    (no units): 0.0
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:13
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.90 V
                    Temperature: 15.0∞C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000095857
   Coding: 0012001
   VCID: 5EE246052C30783A0D7-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000013387741
   VCID: 47CC83619FAA19F2DE1-8012
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:12
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
Address 56: Radio
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000013005192
   Coding: 010E57204040230004
   VCID: 46D28E6598A000FA257-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000156551204
   Coding: 0200000000000000
   VCID: 3138CDB9012EB742E05-8064
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861CCDEA8C1AAA933-8038
   Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ˇ
   Subsystem 4 - Serial number: 1A0268ˇ
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 118895293-----
   Coding: 0003595
   VCID: 26122EE534E0E0FA057-8072
   Component: J_245_EE16_SKB10H11 0220
   Component: J_394_EE16_SKB10H11 0220
   Component: J_392_EE16_SKB10H11 0220
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:12
01512 - Control Module for Sliding Roof
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:12
02906 - Control Module for Sliding Roof; Rear (J392)
                    Reset counter: 205
                    Mileage: 296768 km
                    Date: 2024.10.01
                    Time: 19:36:12
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000013005343
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37361123701717
   Coding: 0231266
   VCID: 2A0ADAD520F8C49A21F-807E
End----(Elapsed Time: 02:02, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Heres my obdeleven backup of the brakes:
OBDeleven vehicle history log
Date: 2024-09-28 12:16:13
    Car: Audi
    Year: 2012
    Body type: SUV
    Engine: CATA  kW ( hp) l
    Mileage: 184398 mi
    Backup
        01 Engine
        System description: 3.0TDI FSA
        Software number: 4L2910401
        Software version: 0009
        Hardware number: 4L0907401D
        Hardware version: H18
        Backup name: Engine
        Long coding
        Adaptations
            Idle RPM correction
                    0.0 1/min
            Injector 1 correction value
                    BAAB8EF
            Injector 4 correction value
                    8RZ1BSF
            Injector 3 correction value
                    AAAD75G
            Injector 6 correction value
                    AISK8SF
            Injector 2 correction value
                    81ILBNF
            Injector 5 correction value
                    ASAWCWG
            Particle filter initialization
                    0 Tkm
            Fuel line filling
            Service regeneration of particulate filter while driving
            Particulate filter statistics
                    00
            Adaptation for metering quantity measurement
                    04
            Production mode
                    000000
            Protective function
                    Enabled
        Mileage: 184398 mi
        Date: 2024-09-07 17:30:21
    Backup
        02 Transmission
        System description: AL1000 AISIN
        Software number: 0C8927750S
        Software version: 3408
        Hardware number: 0C8927750S
        Hardware version: 001
        Backup name: Transmission
        Long coding
            001378
        Mileage: 184398 mi
    Backup
        03 Brakes
        System description: ESP ALLRAD MK25E1
        Software number: 4L0910517A
        Software version: 0130
        Hardware number: 4L0614517A
        Backup name: Brakes
        Long coding
            3427376
        Adaptations
            Channel 10: 1
            Channel 42: 1
            Channel 43: 1
            Channel 44: 1
            Channel 45: 1
            Channel 55: 1
            Channel 58: 1
            Channel 90: 1
        Mileage: 184398 mi
        Date: 2024-09-07 17:30:22
Pics of my old abs pump.
https://1drv.ms/i/s!Apx_WUw5m-YYtY89Vp7LAohizUWwYw?e=JUFD9l
Boki Ar
Arandjelovac, Serbia
C?ID=57300
How did you enter, in what way: 0033809
Have you tried it: 3427376
EuroX
Northern NJ USA
C?ID=208579
First things first, have you verified the unit installed is the correct replacement for the original?
Original part number was 4L0614517L. If you verified that this is the correct replacement I can provide coding for a small fee. Note there is no long coding on this vehicle. You should be able to code the abs unit based on pr codes for this vehicle.If it's urgent feel free to reach out.
what2be
Eureka, CA, USA
C?ID=598147
PM Sent
Jef
HQ
From PL24:
So it looks like this came factory with 4L0 910 517 M. When I search our records for that part number, tons of hits, lots of them 2012 models.
But when I search the currently installed part number, 4L0 910 517 A, well... tons of hits for 2007.... me thinks this post is relevant.
Get the correct ABS module installed and then we can get this sorted out.
EuroX
Northern NJ USA
C?ID=208579
Coding sent.
