2011 Audi A7 Diesel - ABS Module
caspianautocare
Dublin, USA
C?ID=394780
Hi, the ABS light, traction control light, tpms light are on. Replaced ABS module but not able to reprogram it. Got service refuse code: 7F 2E 13,
Tuesday,01,October,2024,16:36:07:22871
VIN: WAUWMAFC3EN078365   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
          5F 62 6C 6D 72 8F 90 AC
VIN: WAUWMAFC3EN078365   Mileage: 207193km-128743miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0016
   Revision: 58H14---    CVN: FC1A821BB09F27B738D3FF8238D3FF82C7A35307
   Coding: 1A2A4012052601050000
   Shop #: WSC 59024 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401N 002016
   ROD: EV_ECM30TDI0114G0907401N_002.rod
   VCID: 2E0518A49092D00AFD7-807A
   VINID: 9D19677515930D57801C80C6146E5CC628
          U1113 00 [00100111] - -
                    Mileage: 207193 km
                    Date: 2024.10.01
                    Time: 02:06:01
                    Engine RPM: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.180 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 12
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                    Mileage: 207193 km
                    Date: 2024.10.01
                    Time: 02:06:01
Readiness: 0 0 0 1 1
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1008
   Revision: --H16---    CVN: 13B31F1C
   VCID: 3C2122EC56EE329A433-8068
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 00000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D24F45CDA0CAA51F-806E
0500 - Control Module
          C104A F0 [10000001] - Incorrect VIN
0505 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [VarECUuncoded]
                    Reset counter: 50
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 83
                    Uz: 00
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
   Component: BCM2 2.0      H35 0510
   Coding: 0DAA2046000000000000
   VCID: 7CA1E2EC16EEF29A033-8028
   Serial number: 0213000338685001
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 AQ    HW: 4G0 820 043 AQ
   Component: KLIMA 2 ZONEN H14 0094
   Serial number: 24101300111225
   Coding: 3603201849
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 6E85D8A45012900ABD7-803A
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001645904
   Coding: 06002091063C9FE08100088380003928CF9CD208A6090221000004406000
   VCID: 6FBBC5A057989902B61-803A
   Component: WWS57X 131015  H36 0080
   Serial number:         131016103410
   Coding: 0045F7
   Serial number: 21861572
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 24 10 2013  00000313
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R85PB03
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 3E0803D6000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061329400349
   Coding: A8C303
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFC3D8412C8FF2A05-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003L4MV Dataset Number: 4G8909602D  0004
   Coding: 303145313131303030394A55304C34473853
   VCID: 333309D07BB0FDE2929-8066
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y130000YD3H0
   Serial number: 3575HRB406920N92A0HS
   Serial number: 3585HRB400850MO2HHLO
   Serial number: 3515JRB400E50O3QI8NO
   Serial number: 3525JRB400I50O3QPGL%
   Serial number: 3554VRB400Q50NQODI0A
   Serial number: 3564VRB400Q50NQOCGT.
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20131028000122
   Coding: 000014
   VCID: 303906DC8A26C6FAEFB-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Part No SW: 4G8 920 984     HW: 4G8 920 984
   Component: TDieUsa   Nv  H58 0621
   Revision: 29460233    Serial number: 658141013596021
   Coding: 0BE602060B43D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 73B3C9D03B30BDE2529-8026
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001144337 Dataset Number: 4G8909515G  0063
   Coding: 00CD077D00
   GVL: FDA1E808DE63600F0000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDCCD4442AB4EA59F-8026
   Serial number: 9149371603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 130713000000000004EA
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000079004008
   VCID: 77ABFDC02FC8D1C26E1-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA820579K2 Dataset Number: 4G8909573A  0001
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 363530C468C2E8CAB57-8062
   Component: TSG FA        H03 0507
   Coding: 011F57024E00628002000402
   VCID: 47CB4D001FA86142DE1-8012
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0013947502 Dataset Number: 4G8909852J  0028
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D0CD484AAF4EA99F-8066
   Revision: 00002001    Serial number: 0318000960
   Coding: 0126023A20FAF00580A00A0402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000186562
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO25095915
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA106976000004921708
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93077133
   Component: TSG BF        H03 0507
   VCID: 46D5400418A2784A257-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000860633 Dataset Number: 4G8909522C  0006
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C0112ACA68EA21AD33-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 131021-0002-112
   Coding: 1223A6101002A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D071FA89D94AB12C4D-8078
   Revision: AB001007    Serial number: 156J70D7925574
   Coding: 020007020100000001
   VCID: 2411FA8CCEDE6A5A1B3-8070
   Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 194J%0D7592222
   Coding: 090200040003E1EF45128B3E00000003100001000000000000
   VCID: 2A0D14B4ACFABC2A21F-807E
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD002VBB/
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MJN000K9
   Component: CD-Database  5571
                    Reset counter: 90
                    Mileage: 207193 km
                    Date: 2024.10.01
                    Time: 02:06:01
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H03 0507
   Coding: 010F17024000628002000002
   VCID: 49CF4B3809BC9732C85-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H07---    Serial number: 525 PA8J39G1ER
   Coding: 1080013
   VCID: 2615E084B4E2984A057-8072
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 279300103 Dataset Number: 4G8909541F  0023
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 44D15A0C2E1E4A5A3B3-8010
   Component: TSG HR        H03 0507
   Dataset Number: 4G0909614C  0001
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F03D881ACCFF2E05-8064
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 132000377 Dataset Number: 4G8909571D  0013
   ROD: EV_RDCMA00100.rod
   VCID: 2B0311B0A380A522DA9-807E
End----------(Elapsed Time: 02:26, VBatt start/end: 12.1V/12.1V)-----------
EuroX
Northern NJ USA
C?ID=208579
What coding are you trying to write into the unit?
caspianautocare
Dublin, USA
C?ID=394780
I replaced the abs module on my car. Needed to code the software coding from the original module into the 1 I replaced.
caspianautocare
Dublin, USA
C?ID=394780
How is coding of an ABS module performed?
Westbury, UK
By calculating the corect code for the module and vehicle, entering the code and then carrying out basic settings in the same session.
There are members on here who can calculate the correct code, assuming that the ABS module fitted is a suitable one for the vehicle.
caspianautocare
Dublin, USA
C?ID=394780
The part number on the module I bought matches the one in the car. I copied the code of the module first, then replaced the it with the one I bought. I key in software codes/ values from the original unit when coding, during the coding process, I encountered a service refuse code: 7F 2E 13, and coding was not a success.
Westbury, UK
The reason for that is clear to see, there is a VIN mismatch.
EuroX
Northern NJ USA
C?ID=208579
I would think adaption is needed but it should still code.
2011 Audi A7 Diesel
WAUWMAFC3EN078365
The latent pedant in me objects to characterizing this car as a 2011. ;)
Copy & Paste is much preferable. Please post the scan data you presumably have from before the ABS swap.
Oh, and FWIW, this particular ABS module requires a Security Access before it will accept a coding. VCDS will offer you SA keys for "Coding Enabling" on the Security Access screen.
caspianautocare
Dublin, USA
C?ID=394780
Thanks for your input. I will uploaded the data from the original scan before the swap. Will call tech support for the SA code.
