MK4 Golf PD130 Speed sensor fault?
Jack_warner99
Cambridge, UK
C?ID=592213
Hi Guys,
I've got a fault:
00281 - Vehicle Speed Sensor (G68)
37-10 - Faulty - Intermittent
I had a quick google and it comes up with a sensor for automatic gearbox's but i have a 6 speed manual?
another weird fact (which you will see from autoscan) is that its showing in the auto hvac section
any ideas?
Tuesday,01,October,2024,09:25:08:08566
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVWZZZ1JZ3B150676   License Plate:
          76
VIN: WVWZZZ1JZ3B150676   Mileage: 387160km-240570miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 HJ
   Component: 1,9l R4 EDC 0000SG  1490
   Coding: 00002
   Shop #: WSC 00046
   VCID: 66926F249175DA5AC5F-4B1E
   WVWZZZ1JZ3B150676     VWZ6Z0C0012307
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00046 615 1234567
   VCID: 3436C56C922978CA8BB-5160
            003 - Mechanical Failure
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00046
   VCID: 21183C3838DBFD6270D-518C
            30-00 - Open or Short to Plus
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 00046
   VCID: 221A33343DDDE67A697-5160
   Part No: 1J0 920 926 C
   Component: KOMBI+WEGFAHRS. RB8 V28
   Coding: 05414
   Shop #: WSC 00046
   VCID: 2A0ADB1445ED3E3A217-5160
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00046
   VCID: 70BE097CA3B104EAAF3-5160
   Part No: 1C0 959 799 B
   Component: 1Y Komfortger t HLO 0003
   Coding: 00065
   Shop #: WSC 00046
   VCID: 3632FF6481556ADAB5F-4B1E
   Subsystem 1 - Part No: 1C2959802A
   Component: 1Y T rsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C2959801A
   Component: 1Y T rsteuer.BF KLO 0009
00912 - Window Regulator Switch; Front Left (E40)
            62-10 - No or Incorrect Adjustment - Intermittent
01034 - Electric Window Thermal Protection Active; Driver
            35-10 - - - Intermittent
            27-00 - Implausible Signal
End----------(Elapsed Time: 05:00, VBatt start/end: 12.9V/12.8V)-----------
Tuesday,01,October,2024,09:25:59:08566
Scan: Auto-detect
Function not supported by the gateway.
End----------(Elapsed Time: 00:03, VBatt start/end: 12.8V/12.8V)-----------
Jef
HQ
:confused:
Get some one to test drive the car for you, go into 08-08-001.3 and see if you get a valid reading.
But at the same time, if the HVAC is working fine, I'm not sure how deep I'd dig into this.
Jack_warner99
Cambridge, UK
C?ID=592213
:confused:
I’ll give that a try. But yeah I get what you mean, just abit odd?
Previous owner mentioned the vehicle had an “economic map”
Is it possible it could be a copied and pasted map from an auto pd130 and not even exist in the car?
I wouldn't expect a re-map to affect what fault codes the HVAC throws. However, that HVAC module does want to know the vehicle's speed, but it's unclear to me where it gets the speed information. I'm guessing it should come in the form of CAN messages from the Instrument Cluster.
EuroX
Northern NJ USA
C?ID=208579
Pretty sure all manual transissios in mk4 have a VSS in them and have had that sensor for a very long time going all the way back to the mid 1980's.
I think that's correct. The question then is: What's that VSS connected to? On cars with internal CAN networks (which this is, but pre-2000 ones are not), I would think it's connected to the instrument cluster and the other modules get vehicle speed via CAN messages, but I'm not 100% certain about that.
EuroX
Northern NJ USA
C?ID=208579
I would think direct connection to cluster, ECM and abs for sure if it's got cruise control I would think all of those modules want to know vehicle speed. OP should check wiring diagram.
Jef
HQ
G22, would of been wired up to the cluster... the "GALA" signal.
