Hi all,
I've recently purchase VCDS in an attempt to get to the bottom of my Transporter woes. I have a T6 150hp DSG, and I've had a whole host of engine related issues. Codes below.
P0236 - Turbocharger/supercharger Boost Sensor "A" Circuit.
P2279 - Intake Air System Leak.
P13D6 - Glow plug 3 pressure sensor.
P0401 - EGR flow insufficient detected.
P0402 - EGR Excessive Flow Detected.
P0101 - Mass or Volume Air Flow Circuit Range/Performance Problem
P2279 seems to be the most popular and my most recent full scan is below. Sometimes I get a couple of the above codes come on in tandem with P2279, especially P0402 - EGR Excessive flow. I took it to a local garage who said that they smoke tested and didn't find any leaks but didn't have the ability to delve any deeper. The did also say that the N75 boost control solenoid valve was very hot like it was trying to overcompensate for a boost issue. Swapping that with another sensor produced the same problem.
Based on this and the below scan, what would be my next steps? Many thanks.
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 6168
Revision: 23002001
Coding: 00254014432401090000
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004013
ROD: EV_ECM20TDI03004L906056KE_004.rod
VCID: 7CA62D40D669A41A033-8028
VINID: 9E606AAAA1D8A9A6011431C30CA72635D2
18874 - Leak in Air Intake System
P2279 00 [01100100] - -
Mileage: 167456 km
Date: 2074.01.00
Time: 16:26:44
Engine RPM: 2108.75 /min
Normed load value: 99.6 %
Vehicle speed: 14 km/h
Coolant temperature: 84 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.648 V
Mass airflow sensor 1 bank 1 airflow: raw value: 1309.8 mg/stroke
Standardized air flow ratio: 0.375 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.35 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 2.565 bar
Absolute intake pressure: 102 kPa abs
Mean injection quantity: 30 mg/stroke
Readiness: N/A
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01 CVN: A5BFDF55
VCID: 3D20E0448DF36D1274D-8068
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 60758000000494
Coding: 307E4098656784810C7C0279A68521D379F100
VCID: 3FDC9A4C87FF7F02661-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 10031813470917
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA22748C075B60A2D7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 72BA0378842DE26A59F-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 083181799
Coding: A0FC793A0A61341193284F746CEB8EF40F84710F60CC6D60330400230840
Shop #: WSC 02762 022 1035958
VCID: 2B04DE1C6307F3A2DA9-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 220318 04 47 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 004 0653
Serial number: KU0KU014031880731471
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P
Component: J387__TSG_BT 004 0653
Serial number: KU0KU015031880741532
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29180000502660058103
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 T HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0212
Revision: -------- Serial number: 32931803702960
Coding: 118108
ASAM Dataset: EV_VW75XParkAssis4K 001013
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 43D496BCEB171BE2029-8016
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Serial number: 0803180452AB4F Dataset Number: 7E0114v____ 0009
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361.rod
VCID: 3632FF68A8C5BE4AB57-8062
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK000UT3D Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02164 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
Address 17: Instruments
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042305
VCID: 688E6110B27118BAF7B-803C
Component: IMMO H03 1107
VCID: 6A8A1B18ACFD2AAAE1F-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 L HW: 1K8 035 150 L
Component: MU-E-D-ER 056 7205
Serial number: 06031800011554 Dataset Number: V03935266VJ 0001
Coding: 065700003C00000041111101008000001F0000C60000010001
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 2E02D7085095868AFD7-807A
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B1A73
Shop #: WSC 02762 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Serial number: 75885700001803070CCA
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 303EC9704A21907AEFB-8064
End----(Elapsed Time: 01:54, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
