Hi everyone. took my 2004 Jetta vr6 for emissions testing today and passed as expected. got home and decided I would start troubleshooting my central locking issues so fired up VCDS and found something I wasn't expecting... P1517, P1049, P1527. engine has no signs of any issues. does not idle rough, exhaust sounds perfect, no starting issues, no power issues.. nothing. cleared but still popped tight up on 2nd scan.
I have a couple good 109 relays kicking around so I'm going to swap that tomorrow morning and see if this deals with P1517, but the other two? is there any chance that all 3 could be related in some way? ie. intermittent fault on 109 causing intermittent faults on N318/N205? I find this highly unlikely but not omitting since everything runs fine. I'm trying to find a relationship between all 3 or 2 codes. I plan on doing basic testing both N318/N205 tomorrow as well but expect them to pass as this is an intermittent short with no mechanical to note, so all I can think of is connectors or something in the loom, not sure. I'm hoping someone may have experienced similar or throw me some other ideas/things to check?
thanks in advance
thanks in advance
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWVH69M44M103784 Mileage: 208220km-129381miles
Address 01: Engine Labels: 022-906-032-BDF.lbl
Part No: 022 906 032 DM
Component: MOTRONIC ME7.1.1G 0006
Coding: 00032
Shop #: WSC 00066
VCID: 59FA61D2C1065E5EE4-5184
VINID: 0E69E660625D1047410031C81010C23071
3VWVH69M44M103784 VWZ7Z0D9017398
17925 - Power Supply Relay for ECU
P1517 - 35-10 - Electrical Malfunction - Intermittent
17457 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1049 - 35-10 - Short to Ground - Intermittent
17935 - Camshaft Timing Adj. Bank1 (N205)
P1527 - 35-10 - Short to Ground - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 3424F0665624433617-5184
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0003
Coding: 12340
Shop #: WSC 00066
VCID: 271E172AC7F238AEA2-5160
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 906 J
Component: KOMBI+WEGFAHRSP VDO V55
Coding: 15234
VCID: 3424F0660624433617-5160
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: 70AC3C7632BC3F1633-5160
01304 - Radio
Part No: 1C0 959 799 C
Component: 1H Komfortger·t HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 373EC76A1752A82E32-4B1E
Component: 1H Tırsteuer.FS KLO 0202
Component: 1H Tırsteuer.BF KLO 0202
Component: 1H Tırsteuer.HL KLO 0202
Component: 1H Tırsteuer.HR KLO 0202
27-00 - Implausible Signal
01359 - Internal Central Locking Switch; Passenger Side (E198)
00934 - Electric Window Motor; Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
End----------(Elapsed Time: 05:43, VBatt start/end: 12.7V/12.6V)-----------
