Bringing a MK4 R32 back from the brink
vegetopia
Houston, TX, USA
Hey all. I recently bought a MK4 R32 that was in extremely rough shape. I have just finished rebuilding the engine, doing all the maintenance and refreshing, and bringing the interior back to as close to showroom condition as possible for a 20yr old car. Next up will be bodywork and paint, but that will have to wait a bit. I’ve got a few questions about vcds tweaks and am looking for some insight from the community.
What is the process for being allowed to post new threads?
Thanks,
Jamie
To start..... you can post all you want right in this section. To post in the individual categories, you must be a verified user.
1. You must own/or be using a Legitimate VCDS product ; not sure, post a picture or SN of interface you are using: https://forums.ross-tech.com/index.php?threads/95/
2. Get Verified: https://forums.ross-tech.com/index.php?threads/2601/
3. Post a complete and unedited Auto-Scan: https://forums.ross-tech.com/index.php?threads/101/
4.Note number 1 !
vegetopia
Houston, TX, USA
4.Note number 1 !
Thanks for that!
vegetopia
Houston, TX, USA
Here are the results from the Autoscan:
Saturday,28,September,2024,08:59:55:04973
VCDS Version: 24.7.0.0
VIN: WVWKG61JX4D130428   License Plate:
          76
VIN: WVWKG61JX4D130428   Mileage: 370890km-230460miles
Address 01: Engine        Labels: 022-906-032-BJS.lbl
   Part No SW: 022 906 032 EG    HW: 144 03
   Component: United 6412     G  r&'
   Coding: 0000132
   Shop #: WSC 13107 153 443974
   VCID: 54A98721F4E8223637-5120
   VINID: 9E69DB5C605AA045010C010220050733D9
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 P
   Component: ESP ALLRAD MK60     0101
   Coding: 0023049
   Shop #: WSC 31414 000 00000
   VCID: 3773D0AD455EE92E32-5120
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11200
   Shop #: WSC 31414
   VCID: 21471EF5ABDA879EEC-51B2
   Part No: 1C0 909 605 F
   Component: 17 AIRBAG VW61 0108 0003
   Coding: 12599
   Shop #: WSC 31414
   VCID: 275300EDC5FE79AEA2-5120
   Part No: 1J0 920 927 A
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15230
   Shop #: WSC 03103
   VCID: 295706D5D3EA4FDEB4-5102
   WVWKG61JX4D130428     VWZ7Z0C8766712
01177 - Engine Control Unit
            64-10 - Not Currently Testable - Intermittent
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31414
   VCID: 70E12BB130B07E1633-5120
01304 - Radio
01324 - Control Module for All Wheel Drive (J492)
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 UM
   Component: HALDEX 151  ECC     0002
   VCID: 7F03F88D7DEE116EBA-4B00
   Part No: 1C0 959 799 C
   Component: C7 Komfortger·t HLO 0003
   Coding: 00064
   Shop #: WSC 31414
   VCID: 3773D0AD155EE92E32-4B00
   Component: C7 Tırsteuer.FS KLO 0202
   Component: C7 Tırsteuer.BF KLO 0202
01389 - Tailgate Open Switch (F124)
            27-00 - Implausible Signal
00849 - S-contact at Ignition/Starter Switch (D)
            25-10 - Unknown Switch Condition - Intermittent
End-------------------------(Elapsed Time: 04:20)--------------------------
vegetopia
Houston, TX, USA
My problem is with the Immobilizer III:
My original key works fine, starts the engine, gives me no immobilizer fault, warning, or light. All good.
As for my replacement key (bought on eBay, new aftermarket replacement), it will start the car but I receive the immobilizer warning and flashing light on the cluster. However the engine is not shutting off, so I take that to mean the immobilizer has indeed defeated by United Motorsports when I sent in my ECU for performance tuning.
Is there a way to use this new key and not be constantly harangued by the cluster that the immobilizer has been activated?
When I go into vcds to code the new key via instruments, login, adaptation, channel 21 and try to change the new value to “2” I receive “error” in the test value box.
Here is an image of measuring blocks 22, 23, and 24:
Here is channel 21 in adaptation before changing the "new value":
And here is channel 21 with the error:
Yep.
I do not think you can match a key to a car that has had an immo-defeat in the ECU.
Immo-defeat the cluster as well? @EuroX or @Jetta 97 ....?
vegetopia
Houston, TX, USA
Thanks for all the replies! I intend to send in the haldex controller to United Motorsports as well, for performance tuning, in the future. Easiest thing would probably be to send the ecm back to them at the same time and have them reenable the immobilizer.
Unless the consensus is it’s better to leave immo defeated?
Also, what is “the dump” from the cluster?
Boki Ar
Arandjelovac, Serbia
C?ID=57300
A dump is the memory content from the instrument cluster, usually in hexadecimal notation.
Look like this:
vegetopia
Houston, TX, USA
Ah ok I see, so not something I would have access to myself without vagtacho or something of that nature.
On a 20 year old car? I'd leave it disabled.
Is that just because they’re prone to being problematic as it is, so why risk it? Seemed to be working fine otherwise…
My thought for well over 20 years has been that immobilizers have left more people stranded, in need of a recovery, than they have prevented thefts. Are they hugely problematical? No. Would I disable the immo in one of my cars without a good reason? No. But if I had a 20 year old car that was already disabled, would I re-enable it? Also, no.
I don't recall what the Mk.4 "R" cluster looks like. Is the flashing immo thing just a simple light or is it it something in the cluster's display? If it's a simple light, a bit of disassembly and some black electrical tape over it will make it invisible. ;)
I could live with the startup warning. I don't think I could live with the constant blinking light. LED-ectomy, or black electrical tape would be the DIY solution. Some (dis)assembly required.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
With immobilizer delete you can not program key regular way with VCDS, On Immobilizer 3 Generation key has to see ECU and Cluster(Immobilizer) to be ON and pair to be able to finish programing.
I can help you but you will need to send me cluster and keys .
For more info send me message.
vegetopia
Houston, TX, USA
I'll make a plan for moving forward in the next few weeks and will message you if I decide to send the cluster off. Thanks!
