Seat Tarraco 2019, 2.0tdi, DSG DQ500 - Clutches dissengage too late
evisceratum
Romania
C?ID=530930
Hi, I am following you for about 2 years. Bought the car in 2022 at 50000km. Now it has 87000km. I experienced from the begining that the full stop of the car is somewhat abrupt, when I try to stop at stop light, I have to press too hard on the brakes for the clutches to disengage, so the result is a more of a sudden stop. The complain is the lack of confort. No other modification on the vehicle as I am aware of, and no other problems with the DSG.
The Tarraco has a known problem in the programming of the ABS module, in which trows a error for the seat bucke for the rear passanger left, when it senses a contact problem, but the vehicle trows error on the dash referring to no SOS communication and airbag. So all other codes in the scan is referring to this and a episode in which I drove in heavy rain and the ACC sensor lost vision. And also, air quality sensor, no comment about obvious VAG error.
Saturday,08,June,2024,10:45:04:13606
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: VSSZZZKNZKW022989   License Plate:
Chassis Type: KN-SE37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 18 19 22 2B 36 3C 42 44 4B
          52 5F 6C 6D 75 A5 D6 D7
VIN: VSSZZZKNZKW022989   Mileage: 84359km-52418miles
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 RA    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 6580
   Revision: B4H26---    CVN: 67810D0537C5C2A218229D33
   Coding: 0125003A03661D083000
   ASAM Dataset: EV_ECM20TDI01104L906026RA 004004
   ROD: EV_ECM20TDI01104L906026RA.rod
   VCID: 7AADFEBCEC5C0BBA617-802E
   VINID: 9A38EAAAA6DEA9B9C0082248249CA8AC8B
   Part No SW: 0DL 300 013 A    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 3004
   Revision: 00H06V07    CVN: FEA4B5CE
   ROD: EV_TCMDQ500021.rod
   VCID: 2809F4F44270492A473-807C
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 61339000001093
   Coding: 22046A9A50220B6E8780070862CC4844560AD0E1E0461275386250F4F2A94B0B00402E64121A03102F5E833B485266E4
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 79AFE1B0E95A00A268D-802C
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 114
                    Mileage: 83148 km
                    Date: 2024.05.20
                    Time: 15:10:36
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6102161230 Dataset Number: V03935259QH 0007
   Coding: 132C0C0707
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34358DB168A72721-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11699896
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5FJ 907 044 G    HW: 5FJ 907 044 G
   Component: AC Automat    H35 4702
   Revision: 20K10000    Serial number: 00000B01352759
   Coding: 0000010420411101110510400010152A
   ASAM Dataset: EV_ACClimaPrehVW37X 002026
   VCID: 44D14044DE188D4A4BB-8010
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 95587628
   Humidity sensor: exterior:
   Subsystem 3 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [00001000] - Internal System Fault
                    Fault Frequency: 37
                    Reset counter: 134
                    Mileage: 83142 km
                    Date: 2024.05.20
                    Time: 09:56:09
                    Outside temperature: 18.5 °C
                    Voltage terminal 30: 13.2 V
                    System run time-Engine running time: 253 s
                    Air quality status: Malfunction
328964 - Motor for Front Air Distribution Flap
          B1091 71 [00001000] - Actuator Stuck
                    Reset counter: 127
                    Mileage: 84247 km
                    Date: 2024.06.03
                    Time: 15:04:57
                    Voltage terminal 30: 13.1 V
                    Inside temperature: 27.8 °C
                    Outside temperature: 21.0 °C
                    Front air distribution flap: actual value: 83
                    Front air distribution flap: actual value: 100.0 %
                    Air distribution door front - Specified value: 78
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 01001913803524 Dataset Number: V03935279BR 0012
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA1F8A4E668358A73B-8028
   Subsystem 1 - Part No SW: 5NB 955 119 A    HW: 5NB 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 LL 190425  033 0372
   Serial number: 00000001904180303834
   Coding: 0FC5FD
   Component: RLHS  052 0107
   Serial number: SBY19M05D17H21M10S20
   Coding: 0089DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 BQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000030041920240576
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417619142 Dataset Number: V03935259QF 0007
   Coding: 0271167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 51FF7910116A68E2F0D-8004
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Dataset Number: V03935280GB 0005
   Coding: 320067C35CFF8728749C814580508700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 42DD465CC40C837A797-8016
196741 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FCTSEN_BLOCKAGE]
                    Reset counter: 113
                    Mileage: 83330 km
                    Date: 2024.05.24
                    Time: 20:05:55
                    Voltage terminal 15: 12.7 V
                    Control Module temperature: 41 °C
                    Vehicle speed: 13.63 m/s
                    Longitudinal acceleration: -0.13 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
196746 - Sensor for Automatic Distance Control
          [FCTSEN_OBJ_NOT_MEASURED]
                    Reset counter: 118
                    Mileage: 83332 km
                    Date: 2024.05.24
                    Time: 21:12:18
                    Voltage terminal 15: 13.0 V
                    Control Module temperature: 31 °C
                    Vehicle speed: 14.16 m/s
                    Longitudinal acceleration: 0.09 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
   Serial number: 28041941351048 Dataset Number: V03935261HC 0004
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382924B492D0D9AAD73-806C
   Part No SW: 5Q0 959 655 BN    HW: 5Q0 959 655 BN
   Component: AirbagVW21    007 0403
   Serial number: 003FHR59NHUH Dataset Number: V03935290DU 0001
   Coding: 98CCC0C0000000005C5400CF004800540065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0D47A560CDD20C02545-8058
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 5NB857705C0140T01384
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 5NB857706C0140T01677
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: 35700000000F32CC8C3$
   Subsystem 4 - Part No SW: -----------    HW: 480 002 105 19
   Serial number: 35800000000D7644FB3-
   Subsystem 5 - Part No SW: -----------    HW: 480 402 105 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001B4F03BAC4A88K
   Subsystem 6 - Part No SW: -----------    HW: 480 402 105 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B2F051DB18653
   Subsystem 7 - Part No SW: -----------    HW: 480 402 105 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B8F03BAC6B69U
9454633 - Safety belt switch 2nd row passenger side
          B1044 29 [10001000] - Signal Implausible
                    Mileage: 84348 km
                    Date: 2024.06.07
                    Time: 07:42:06
   Part No SW: 5FJ 920 790     HW: 5FJ 920 790
   Component: KOMBI         616 1701
   Coding: 04A46E1FFF8C00080088720B1001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 55F78D00258204C22C5-8000
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 J    HW: 5Q0 963 272 J
   Component: STH-MQB       008 0080
   Coding: 1309
   VCID: 3D2735A0BDF2FC82045-8068
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000724029
   Component: GW MQB High   442 4368
   Revision: --------    Serial number: 0009668324 Dataset Number: V03935279TF 0009
   Coding: 030500F40F086A00E913225C9A0F00010001070000000000000000000000
   GVL: 01C63C000800060040DC80008006CC0000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C2ECA014571ACDF-803A
   Generator:
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5FJ 959 537 A    HW: 5FJ 959 537 A
   Component: E221__MFL-PR6  H01 0130
   Serial number: 000000000H1212190419
   Coding: 012000
   Serial number: 5825361405
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00002.05.19 Dataset Number: v1260x015G0 0000
   Coding: 0101
   VCID: 4CC16864F648450A83B-8018
   Serial number: 19000139797010
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 333313988BB63AF2E21-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0007SE228409
   Coding: 0018000000000500018480808180000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000515973275  Dataset Number: V03935259PW 0005
   Coding: 50014500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 A    HW: 2Q0 907 685 A
   Component: HRE3_Kl15_Slv  H05 0052
   Serial number: 00000515853369
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SED06855 Dataset Number: V03935259PX 0007
   Coding: 003F1B20D200040000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000030385063
   Coding: 310000
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Dataset Number: V03935294RD 0001
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 49CF5170F93A5022B8D-801C
   Component: FCM MQB Low   002 0345
   Serial number: 07051911604858 Dataset Number: V03935259Q  0006
   Coding: 000000070900065207000940000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 35372D8085C224C2CC5-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SE50250A Dataset Number: V03935259QA 0008
   Coding: 003F1320DE00040000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000030444875
   Coding: 290000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-HGH2.clb
   Part No SW: 5F0 035 043 K    HW: 5F0 035 043
   Component: MU-H-N-EU     H55 1447
   Serial number: A679E0KB008080 Dataset Number: V03935302JV 0001
   Coding: 04231601FF0000005111000100080A002F0401E401A004009E
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 2517FDC0356254427C5-8070
   Subsystem 1 - Part No SW: 5FJ 919 605 A    HW: 5FJ 919 605 A
   Component: ABT_Std-2_Nav  H56 8130
   Serial number: SEZ6ZHW1400636
   Subsystem 2 - Part No SW: V03 959 806 CB    HW: -----------
   Component: ECE 2024  --- 0350
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 GG    HW: -----------
   Component: Gracenote2  --- 1021
          B201A 00 [00001001] - -
                    Reset counter: 85
                    Mileage: 83137 km
                    Date: 2024.05.20
                    Time: 09:47:53
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: MDUE613/Main
   Dataset Number: V03935277G  0006
   Coding: 0673010122002017000040
   VCID: 392F21B0A9DAC0A228D-806C
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8 Dataset Number: V03935259QE 0006
   Coding: 3D08
   VCID: 48C95474E230A92AA73-801C
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------    Dataset Number: V03935266D  0009
   Coding: 04230601EA761A0D0100040200356003804600
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW37.rod
12866049 - Databus
          [Airbag: Error value received]
                    Reset counter: 94
                    Mileage: 84348 km
                    Date: 2024.06.07
                    Time: 07:42:06
                    Voltage terminal 30: 13.3 V
   Part No SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0451
   Serial number: 03051915P21128 Dataset Number: V03935296ZP 0001
   Coding: 030307060000040000222354C152A50098000E20002080
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 41DF4950C10A986260D-8014
   Part No SW: 992 941 571 AC    HW: 992 941 571 A
   Component: LED1L         H08 9201
   ROD: EV_LLPGen3LKEBODPO68X_001_SE37.rod
   VCID: 6393A3D87BD6EA72521-8036
   Component: LED1R         H08 9201
End----------(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.1V)-----------
So the question is: can I do a something regarding the late clutch release to stop more gratiously at the stopsign, or I will have to contact a tuner.
I made some mods like classic ones: to view the fan speed on the climatronic indicator when in AUTO, dynamic startup assistant, direct acceleration/throttle response, enable DRL in headunit, refuel quantity in driving data, etc.
The vehicle came with rear DRL activated continuously.
Thanks in advance!
Dr Sheldon
Windsor UK
C?ID=334979
Try an Adaptation - In the absence of a DTC, Keep this non Intrusive !
Perhaps also consider getting the software in this transmission updated to version 3005...?
evisceratum
Romania
C?ID=530930
Thank you for fast response. I will try adaptation first, flashing a transmission is a complicated thing around here.
