A6 allroad level control coding
mm1953
C?ID=273289
Hi. someone help with level control coding.regards mike
mm1953
C?ID=273289
Hi.dont use my diagnostic laptop online as such how do i post autoscan tried to copy and paste but does not want to know could not see a attachment icon.regards Mike
davisev5225
Democratic People's Republic of Commifornia, USA
C?ID=263265
That blue text in Jef's reply is a clickable link with instructions for how to run an autoscan and post the results here. If you need to get the data from an offline machine to an online one, I'd suggest using a thumb drive and Notepad (.txt file).
mm1953
C?ID=273289
Thursday,26,September,2024,18:26:37:08193
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WAUZZZ4G2EN172370   License Plate: YD64WUC
Mileage: 193652km-120329mi   Repair Order: dsmith
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 3B 42 44 46 52 53 5F 62
          69 6D 72 47
VIN: WAUZZZ4G2EN172370   Mileage: 193652km-120329miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0003
   Revision: 53H41---    CVN: 94BF393E
   Coding: 32254012053609020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401Q 001004
   ROD: EV_ECM30TDI0114G0907401Q.rod
   VCID: 31347F2671AB5A92E0D-8064
   VINID: 9D196AAAA1170957811C20C700CBE2FF9D
   Part No SW: 4G9 927 156 E    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H02 0003
   Revision: --H02---    CVN: 0000C41E
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3720413E9FCF84A2AE9-8062
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 27A6DF05E465FBA0EB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A26580AACDD99CA517-806E
0055 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [ComScl_PDU_Fahrwerk_02_Timeout]
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.16
                    Time: 15:54:17
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BA
                    Uz: 9C
0629 - Tire Pressure Warning
          C102D 00 [00001001] - -
                    Reset counter: 82
                    Mileage: 193644 km
                    Date: 2024.09.26
                    Time: 17:59:46
                    VzRef: 4D
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 30
                    Uz: BE
0702 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
          [SCL_FA_Niveau_Druck_HL_Error]
                    Reset counter: 120
                    Mileage: 193590 km
                    Date: 2024.09.11
                    Time: 09:47:50
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 16
                    Uz: B2
0706 - Function Restriction due to Faults in Other Modules
          [SCL_FA_Niveau_Druck_VL_Error]
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.16
                    Time: 15:25:45
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 1A
                    Uz: 9D
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Coding: 01B93046000000000000
   VCID: 74BAB632CEB92FBA4BB-8020
   Serial number: 0214000106677009
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 03061400111558
   Coding: 36A2000821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 6882D24282F1DB5AF73-803C
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001756680
   Coding: 690020018034A7E00F04088300005F5F0F9D670827080301000004406000
   VCID: 6FB0B95EA79F0C62B69-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140425  H37 0080
   Serial number:         140508135302
   Coding: 0045F7
   Serial number: 22719710
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AT    HW: 4G0 941 531 AT
   Component: E1 - LDS  H07 0044
   Serial number: 05 06 2014  00001351
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 8C58CE27000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061415502325
   Coding: 09C30C
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71B4BF26B12B1A92A0D-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00J6SFK Dataset Number: 4G0909602H  0002
   Coding: 3032343631334E303537554A305234473053
   VCID: 363E4C3A98C57DAAB5F-8062
   Serial number: 3575HRB405B2LFGO4OL7
   Serial number: 3585HRB405V2LPPIBP5X
   Serial number: 3515JRB400652KI8M1UF
   Serial number: 3525JRB400452KI8D9E/
   Serial number: 3554VRB401452KIAG8LN
   Serial number: 3564VRB401452KIABQ2I
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NEU0001R
   Coding: 000435
   VCID: 3822420292518BDAA73-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 23 05 2014  E0014519
   Part No SW: 4G9 920 950 K    HW: 4G9 920 950 K
   Component: MDieGb        H43 0411
   Revision: 27460259    Serial number: 658220514592059
   Coding: 23A7200813412600010600
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3822420292D18BDAA73-806C
   Part No SW: 4G5 907 468 C    HW: 4G5 907 468 B
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001399534 Dataset Number: 4G0909515H  0067
   Coding: 00CD077D00
   GVL: FDA3E800D86560010000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 353C4B3685C376B2BC5-8060
   Serial number: 7094803403
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140331000000000000D9
6151 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [00001001] - No Communication
          [Lost Communication With Instrument Panel Cluster (IPC) Control Module]
                    Reset counter: 80
                    Mileage: 193590 km
                    Date: 2024.09.11
                    Time: 09:47:49
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 27 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2E0E645A6095456AFDF-807A
358155 - Relay for Ride-Height Compressor
          C1038 12 [00001000] - Short to Plus
                    Fault Frequency: 14
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.19
                    Time: 09:38:02
          C10C8 00 [00001000] - -
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.23
                    Time: 12:34:56
367877 - Ride Height Not Learned
          C1044 00 [00001001] - -
                    Reset counter: 80
                    Mileage: 193596 km
                    Date: 2024.09.18
                    Time: 18:09:39
266752 - Control module not coded
          U1013 00 [00001001] - -
                    Reset counter: 80
                    Mileage: 193596 km
                    Date: 2024.09.18
                    Time: 18:09:39
38144 - No End-of-Line Programming
          B2013 00 [00001001] - -
          [keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
                    Reset counter: 80
                    Mileage: 193596 km
                    Date: 2024.09.18
                    Time: 18:09:39
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8207FMTY Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47C031FEEFAFF422DE9-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0022612596 Dataset Number: 4G0909852K  0030
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 3236702A74AD618A997-8066
   Revision: 00002001    Serial number: 0336994682
   Coding: 013F0622A0B930008120090420010F4F0000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 80
                    Mileage: 193590 km
                    Date: 2024.09.11
                    Time: 09:50:58
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 80
                    Mileage: 193590 km
                    Date: 2024.09.11
                    Time: 16:08:44
   Component: TSG BF        H03 0507
   Coding: 011C16004C01620002080002
   VCID: 46DE3CFAE8A5ED2A25F-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001088718 Dataset Number: 4G0909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0C63566D933E72C45-8078
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101050001615B67081B060301010000010000
   VCID: 2700917E4FEF14223E9-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464E%0E2663962
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NF3000FN
                    Reset counter: 80
                    Mileage: 193590 km
                    Date: 2024.09.11
                    Time: 09:47:49
03405 - Bass Loudspeaker
                    Fault Status: 00101011
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.16
                    Time: 09:51:57
                    Voltage: 11.60 V
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49C437C6F9BB0252C8D-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00008200415007
   Coding: 0109080000000000
   VCID: 71B4BF26B1AB1A92A0D-8024
02778 - Locking Bolt Contact Switch (F355)
                    Reset counter: 120
                    Mileage: 193596 km
                    Date: 2024.09.16
                    Time: 09:38:33
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Fault Frequency: 14
                    Reset counter: 59
                    Mileage: 171360 km
                    Date: 2023.02.18
                    Time: 16:05:42
02562 - Trailer; Brake Lamps
                    Fault Status: 11101010
                    Reset counter: 80
                    Mileage: 193596 km
                    Date: 2024.09.16
                    Time: 10:06:51
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 155401186 Dataset Number: 4G0909541D  0027
   Coding: 097205C011
   ROD: EV_HDSGAu571_AU57.rod
   Component: TSG HR        H03 0507
End----------(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.2V)-----------
Address 34,4G0 907 553 F,recoded (Long Coding),from,000000,to,000011,(00000/000/00000),
Address 34,4G0 907 553 F,recoded (Long Coding),from,000000,to,000011,(12345/123/12345),
HI.autoscan for level control coding.regards Mike
davisev5225
C?ID=263265
You're unfortunately out of luck, you'll have to bring this one into a VW dealer or other service station that has online ODIS access. This goes far deeper than mere coding, your module needs to be reflashed with an appropriate data set for your car.
                    Reset counter: 80
                    Mileage: 193596 km
                    Date: 2024.09.18
                    Time: 18:09:39
mm1953
C?ID=273289
thank you.I have a way forward now.regards Mike
