AUDI A3 8VS 1.4 CZEA THROTTLE POSITION SENSOR (G69) P0122, P0222,P2106,P1545
Crs autos
Croydon, UK
C?ID=513440
Hoping somone can point me in the right direction with this please? any help is much appreciated:)
Thursday,26,September,2024,15:04:39:41213
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
Dealer/Shop Name: CRS AUTOS
Workshop Code: 210 12345 000001
VIN: WAUZZZ8V3F1079021   License Plate: AK64TNU
Mileage: 293442km-182336mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: WAUZZZ8V3F1079021   Mileage: 293442km-182336miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BL    HW: 04E 907 309 AB
   Component: 1.4l R4 TSI   H21 8235
   Revision: R6H21---    CVN: 043D658A
   Coding: 02250032232401082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906027BL 001007
   ROD: EV_ECM14TFS01104E906027BL.rod
   VCID: 6FB0BCDAA71703A2B69-803A
   VINID: 9D196AAAA2260D60401C900204472564F0
2670 - Throttle Position Sensor (G69)
          P0122 00 [10100111] - Signal too Low
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:03
                    Engine RPM: 2176.00 /min
                    Normed load value: 16.5 %
                    Vehicle speed: 58 km/h
                    Coolant temperature: 65 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.465 V
                    Mass flow through throttle valve: 1.4 kg/h
                    Mean injection time: 0.895 ms
                    Engine operating condition: Deceleration
                    Engine operating condition-Test_Program_Channel 87: 9
2674 - Angle Sensor 2 for Throttle (G188)
          P0222 00 [10100111] - Signal Too Low
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:03
2734 - Throttle Valve Actuator Module (J338)
          P2106 00 [11100101] - Power Limited due to Malfunction
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:02
                    Engine RPM: 2178.00 /min
                    Normed load value: 41.2 %
                    Mass flow through throttle valve: 57.7 kg/h
                    Mean injection time: 2.206 ms
                    Engine operating condition: Idle
2748 - Throttle Valve Controller
          P1545 00 [11100101] - Malfunction
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:02
Readiness: 0110 0001
   Part No SW: 0CW 300 047 E    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5203
   Revision: 00043014    Serial number: CU501410106470 CVN: 0000AFDA
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 3D2C5692BDFBA132745-8068
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 62734000000771
   Coding: 13F18AA2242712750177060241C429C851244880608294F2022100788208
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 215
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:02
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 0
                    Mileage: 293438 km
                    Date: 2024.09.15
                    Time: 23:00:25
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000473616
   Coding: 03100004000000011000000000001100
   VCID: 323675AE74A56E4A997-8066
   Humidity sensor: exterior:
   Serial number: FB480E47000000000001
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011429500947 Dataset Number: 8V0909514K  0081
   Coding: 07041842C24102FD03804004B11007A80000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DAC9692FD7B6132345-8028
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 141025  041 0585
   Serial number:         141027085748
   Coding: 0A47F7
   Serial number: 23360004
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AJ    HW: 8V0 941 531 AJ
   Serial number: 28 08 2014  00001023
   Serial number: 000000000ZY1426126A1
   Serial number: 00000000000060836860
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001001] - Open or Short to Plus
                    Reset counter: 215
                    Mileage: 293438 km
                    Date: 2024.09.15
                    Time: 23:00:33
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.3 V
                    Outside temperature: 17.5 °C
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [00001001] - Open or Short to Plus
                    Reset counter: 215
                    Mileage: 293438 km
                    Date: 2024.09.15
                    Time: 23:00:33
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
11786 - Bulb for Rear Left Fog Light
          B12C7 15 [00001000] - Open or Short to Plus
                    Reset counter: 0
                    Mileage: 293438 km
                    Date: 2024.09.15
                    Time: 23:10:46
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
12042 - Bulb for Rear Right Fog Light
          B12C8 15 [00001001] - Open or Short to Plus
                    Reset counter: 215
                    Mileage: 293438 km
                    Date: 2024.09.15
                    Time: 23:00:33
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.3 V
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231428700235 Dataset Number: 8V0909526D  0039
   Coding: 0000040011
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_AU37.rod
   VCID: 3B28588AA3EFAF024A1-806E
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR02ARG0 Dataset Number: 8V0909602D  0008
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 0052EF668A890CDA5F3-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 35767000000B6D44711W
   Subsystem 2 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 35867000000210547117
   Subsystem 3 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3516502C91811BA27200
   Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3526502B51860BA3F2AJ
   Subsystem 5 - Part No SW: -----------    HW: 480 400 409 14
   Serial number: 3556502A9175A8D5331F
   Subsystem 6 - Part No SW: -----------    HW: 480 400 810 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B518166A0E0EF
   Subsystem 7 - Part No SW: -----------    HW: 480 400 810 14
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B518166A1E227
   Subsystem 8 - Part No SW: -----------    HW: 480 000 210 14
   Serial number: I0M80000000A62986115
   Subsystem 9 - Part No SW: -----------    HW: 480 000 210 14
   Serial number: I0N8000000057DC8611G
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 21101408490768
   Coding: A018
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7CAA9B96E661683A03B-8028
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [00011000] - Signal Implausible
                    Reset counter: 1
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:02:24
                    Operating time: 494901 min
                    Terminal 30 power supply: 14.6 V
                    Vehicle speed: 10 km/h
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 8V0 920 971 C    HW: 8V0 920 971 C
   Component: KOMBI         H02 4291
   Coding: 27A41908238026000100E8001000000000000000
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 29091410801541 Dataset Number: 8V0909515F  0060
   Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
   GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71B4BAA2B1231552A0D-8024
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 17 10 2014  D0048439
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001410212788
   Serial number: 28101406071277 Dataset Number: 8V0909872F  0031
   Coding: 00108E204001040000001002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 42D6256EC405DECA097-8016
   Component: EPS_MQB_ZFLS  125 1061
   Dataset Number: 8V0909852K  0021
   Coding: 8103
   VCID: 43D8206ADB1FD7C2021-8016
22276 - Databus
          [KFC_MOTOR_11 Botschaft - SNA-Check]
                    Mileage: 293441 km
                    Date: 2024.09.26
                    Time: 14:00:03
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 14.25 V
                    Temperature: 32.0 °C
                    KFC: 57
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 14.33 V
                    uAdSensI_SwitchedKl30_xdu16: 14.33 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Serial number: 01111406070137 Dataset Number: 8V0909873F  0031
   Coding: 001086204001040000001002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 41D42A62C103C5D210D-8014
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F02510144210 Dataset Number: 8V1909545D  0040
   Coding: 01730101FF00000021111101000A00002F0004060100010006
   ASAM Dataset: EV_MUStd6C3PASE 002010
   ROD: EV_MUStd6C3PASE.rod
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY3074VP
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000005091400020071
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 09101403111208 Dataset Number: 8V0909897D  0018
   Coding: 000086204001040000001002
   ROD: EV_DCURearDriveMAXKLO.rod
   VCID: 44DA2376DE11D0FA3BB-8010
   Component: TSG HBFS      020 0028
   Serial number: 09101403111210 Dataset Number: 8V0909896D  0018
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 12.5V/12.3V)-----------
Problem with the wiring to the throttle body, or a bad throttle body.
Crs autos
Croydon, UK
C?ID=513440
Changed throttle body same issue. Checked continuity from body to Ecu and all there. Wiggle the wires next to the plug on the body and it causes issues but can’t see anything wrong with the terminals or wires. Cut back the loom slightly separated each wire narrowed it down to one wire. Ignition off then on and then it’s a different wire that when you wiggle problem happens. Not sure if the housing is cracked maybe but might end up just making a new loom for it straight to the Ecu to try eliminate it.
Crs autos
Croydon, UK
C?ID=513440
now changed loom going from body to Ecu. Still got signal low faults
