Swap cluster automatic to manual vw bora 2009
brunoeh
Pirate
Walking the Plank
Brazil
I changed the car's cluster to one with an on-board computer, and installed a dashboard that was from an automatic car, my car is manual, then the automatic gears appear on the dashboard, how do I change this?
Westbury, UK
There are many different electronic configurations in a 2009 Bora, in the absence of a working crystal ball you need to post an Auto-Scan to help us to help you.
Ziddywerks
Northern NJ USA
C?ID=208579
Probably just a coding change is needed.
Tharkhold
Canada
C?ID=311665
Are you certain it's not the 'recommended gear selection' that shows up?
A lot of clusters will show the recommended gear for manual cars; I forget if the option is on or off by default; some will even show you the gear you are in as well... If "P", "R", "N", "D" show up, well of course that's very different.
Are the gears shown the ones your are engaged in, or are they different? (Possibly with an up/down arrow right above/below the number)
Edit: also noticed you were not verified... you should get that done for proper VCDS support ;)
siLc
Tallinn, Estonia
C?ID=330192
"Bora 2009" for the Brazilian market is apparently a Mk4 platform vehicle. There was no recommended gear display in a Mk4.
brunoeh
Pirate
Walking the Plank
Brazil
Há muitas configurações eletrônicas diferentes em um Bora 2009. Na ausência de uma bola de cristal funcional, você precisa postar um Auto-Scan para nos ajudar a ajudá-lo.
Removed.   Data from a hacked/cracked copy of VCDS-Lite is is not acceptable in Ross-Tech's forum.
  • Disagree
brunoeh
Pirate
Walking the Plank
Brazil
Tem certeza de que não é a "seleção de marchas recomendada" que aparece?
Muitos clusters mostrarão a marcha recomendada para carros manuais; esqueci se a opção está ativada ou desativada por padrão; alguns até mostrarão a marcha em que você está... Se "P", "R", "N", "D" aparecerem, bem, é claro que isso é muito diferente.
As marchas mostradas são as que você está usando ou são diferentes? (Possivelmente com uma seta para cima/baixo logo acima/abaixo do número)
Editar: também notei que você não foi verificado... você deve fazer isso para obter suporte VCDS adequado;)
No meu caso, as marchas do câmbio automático não deveriam aparecer, mas quando ligo, as marchas aparecem e somem, eu só queria tirar as marchas do painel, desculpem meu inglês ruim
brunoeh
Pirate
Walking the Plank
Brazil
"Bora 2009" para o mercado brasileiro é aparentemente um veículo de plataforma Mk4. Não havia display de marchas recomendado em um Mk4.
My car is a VW Bora MK4.5 and I installed the dashboard from a Golf GTI which has an on-board computer, the dashboard was from an automatic car, my car is manual
brunoeh
Pirate
Walking the Plank
Brazil
Provavelmente só é necessária uma mudança de codificação.
Não sei como fazer essa codificação para deixar o painel como um carro manual
