Polo airbag fault
vagcars69
C?ID=413796
I have a problem with below airbag fault. Airbag module has been replaced due to internal checksum fault. Installed a second hand module and adapted with odis. All faults cleared. Started the car next and faults repapered. They appear again after a day or so.
There is no passenger airbag light on it. It has also been successfully adapted with odis and removed component protection so it should match the vehicle ok.
Tuesday,24,September,2024,14:55:57:45700
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWZZZ6RZGY******   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY******  Mileage: 69601km-43248miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 AT    HW: 04E 907 309 AB
   Component: R4 1.4l TFS   H23 9073
   Revision: R6H23---    CVN: E7E3428E
   Coding: 01190012232419080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TFS01104E906027AT 001010
   ROD: EV_ECM14TFS01104E906027AT.rod
   VCID: 76B5E299484C15FA75F-8022
   VINID: 9E69EAAAA1A2A97A420431811C504F993B
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08507061160129
   Coding: 23DD48858B2433C3091A106A0058C412D1CC9008000ACB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
   VCID: 372B2F9D0FC6ACF2AE9-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1602011B-0599 Dataset Number: 6C0032v____ 0012
   Coding: 200100001000000000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1F1BE73D8736F4B2469-804A
262914 - Refrigerant Pressure
          B10AB F0 [00001101] - Too Low
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098004356 Dataset Number: 6C0063V____ 0317
   Coding: 030008404253005B0FA44080B107038800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 30391481EAA87BCAEF3-8064
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU005011660050886
   Coding: 1400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU014121553481154
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY16008241K
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033987513
   Subsystem 5 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU026011660264952
   Coding: 1400A0
   Subsystem 6 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU025011660256314
   Coding: 0400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00C 002 0380
   Revision: --------    Serial number: 003TH002R2TN Dataset Number: V03935228DW 0583
   Coding: 88C0C000000000005C000000008800000000
   Shop #: WSC 31414 790 50316
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2D36A93CD4B19A517-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 822 801 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00AD1FACCA152FE
   Subsystem 2 - Part No SW: -----------    HW: 410 823 001 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A91FACC62903+
   Subsystem 3 - Part No SW: -----------    HW: 442 153 101 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00BD1F9D265336R
   Subsystem 4 - Part No SW: -----------    HW: 442 153 101 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00AF1F9D261229Q
9629952 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 00 [10001000] - -
10487296 - Control Module Does Not Match Vehicle
          B2006 00 [00001000] - -
          [ECU does not fit to vehicle configuration]
Address 17: Instruments (J285)       Labels:| 6C0-920-KOM-V1.clb-SRI3
   Part No SW: 6C0 920 940 C    HW: 6C0 920 940 C
   Component: KOMBI         201 1420
   Coding: 272409002180260001082A001000000000000000
   VCID: 2411E8D1AE50D76A1BB-8070
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098004356 Dataset Number: 6C0067V____ 0043
   Coding: 030100046F0A560071000000000000010001010000000000000000000000
   GVL: 01403C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 6597B5D5E5EAEE62CC5-8030
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H03 0102
   Serial number: 29150002211450105464
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 53027909072821437975
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001000] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
8531970 - Quiescent Current
          U1406 00 [00001000] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CG250367 Dataset Number: 6C0074V____ 0548
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E85CAF9301C2D3ABDF-803A
   Part No SW: 3Q0 035 820 A    HW: 3Q0 035 820 A
   Component: MU-S-D-ER     H24 0245
   Serial number: VWZAZ2S8198150 Dataset Number: 5G0CV1v____ 0001
   Coding: 02620000BE00000051111101008808001F0100C60120010001
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 270BFFDDDF663C723E9-8072
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H53 1031
   Serial number: VWZ8Z9SKU00JHE
          U1101 00 [00001000] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
End------(Elapsed Time: 00:48, VBatt start/end: 14.6V/14.6V, udsna)--------
AINils
Germany (AIB)
C?ID=56975
As this controller use dataset for configuration (you can see that information in dataset), I think it came from different car which different equipment. So dataset is for a car with a light for passenger light
vagcars69
C?ID=413796
Possibly but I can recall it had the same fault with the old module. Old module was corrupt and I was unable to clear the faults.
Also this been adapted with odis so I assume it would download dataset automatically?
Jef
HQ
6C0 959 655 J has at least 6 versions (index codes). The car in the Auto-Scan needs 6C0 959 655 J 10C.
On older generation airbag modules, the soft coding was mathematically tied to the index code so it was pretty easy to know what was what from the Auto-Scan. I'm not aware of any way to figure out the index code of the currently installed airbag module... but I suspect it is not "10C".
Soft coding looks decent, I find 30 examples of it so it seems plausible.
iichel
Netherlands, Operation Market Garden
C?ID=284912
the only way is to find the vin of the donor. but i think as long as hw/sw matches, odis will do the right dataset/coding?
Westbury, UK
Ass u me = ass of you & me
Adapting is not the same as dataset writing, you need to find the correct dataset and download it to the module.
The scan with the new module shows the dataset number
If you have a scan with the old module that will show the correct dataset number.
AINils
Germany (AIB)
C?ID=56975
No only if you use "Controller exchange" function or if there is dataset fault in controller in guided fault. Mostly these controller like Airbag need SVM for new dataset
vagcars69
C?ID=413796
Tried the function controller exchange but it refused as 'current module is coded to the car'
