VW Transporter T28 Startline 2018 coding various retrofits Tailgate/MFSW/Audio
Hoopdub
Pontypridd, South Wales, UK
C?ID=168295
Greetings. Over the past 12 months I have been upgrading a few things on my Transporter T6, it is a basic Startline model. I consider myself a capable basic user of VCDS when it comes to using it for running faults but when it comes to coding I'm pretty useless. I have fitted a tailgate in place of the original barn doors, including running in the extra wiring for the locking to work, for the heated rear screen and reversing camera. I didn't want to keep the rear wiper so I removed that and didn't need to run any wiring for it. New LED tail lights. I have managed to code it as far as getting the things to work (not the camera as yet) but I have also created some fault codes.
I have also fitted a multi function steering wheel. Again I have had a go at coding it and it seems to work fine.
I did have a Discovery Media unit upgrade fitted and coded, but the unit decided to die after a couple of months, so I now have an Alpine after market media unit.
Sorry for the long intro but details count right :D
Having tried to get things working myself I have fallen into the trap and caused additional problems as I've gone along. Classic.
I have somehow managed to erase 3 subsystems from the BCM, 1. the front drivers door module. 2. the passenger door module. 3. the MFSW module. Also I now have fault codes relating to improper coding.
Here is the newest scan with various faults on various modules. Any help correcting these would be very much appreciated.
Sunday,22,September,2024,18:35:08:24488
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ7HZJH134300   License Plate: T28 TYP
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 56 61 0B
VIN: WV1ZZZ7HZJH134300   Mileage: 250780km-155827miles
Address 01: Engine (2D2D2-CXGA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 JS    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4044
   Revision: 23002001
   Coding: 00114014430401090000
   Shop #: WSC 02762 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056JS 004004
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 074B97751FA8CEB21E9-8052
   VINID: 9E606AAAA1D8A9A6010C40C000460D17F7
Readiness: N/A
   Revision: 00000000    Serial number: 60438000000740
   Coding: 517E4098256584828A780276A48221E679F100
   VCID: 3FDB4F9507F84672669-806A
   Serial number: 29011813470065
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F29140728F7A2DF-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 73B3D3A57B30D212521-8026
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 037180296
   Coding: E0A439380A212011002809742C2B8CD40F00708F60464D703304003B0800
   Shop #: WSC 02762 534 156453
   VCID: 2B030BC5E300CAD2DA1-807E
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.13.
                    Time: 02:02:26
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.13.
                    Time: 02:02:26
                    Mileage: 250781 km
                    Date: 2019.02.13.
                    Time: 02:02:22
04194 - Vehicle Status with Under-Voltage
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.13.
                    Time: 02:02:22
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231801701002
   Coding: 00800D
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BFD9AD012CE002A0D-8024
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [00001001] - Open Circuit
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2024.09.22.
                    Time: 02:57:50
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 0702180442AE37 Dataset Number: 7E0114v____ 0009
   Coding: 00004000FE1779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 36352AB128C2873AB5F-8062
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK000C4DN Dataset Number: 7E0003V____ 0905
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02164 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D27359D0DF45462745-8068
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 450B000300
   VCID: 3A2D3E811CDA635A517-806E
10486016 - Control module
          B2001 00 [00001001] - Incorrect software version
          [BAP: Steuerger t falsche Softwareversion]
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2024.09.22.
                    Time: 02:02:22
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042300
   VCID: 6889B4C9327621CAF73-803C
   Component: IMMO          H03 1107
   VCID: 6A8DCEC12CFA13DAE17-803E
Address 56: Radio
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 02762 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 75885700001802050D5E
End----(Elapsed Time: 01:01, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Here is a scan I took a few days after I bought the van before I started ruining it.
Wednesday,16,August,2023,17:05:46:24488
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH134300   Mileage: 248310km-154292miles
   Revision: 23002001
   VCID: 074B97751FA8CEB24E1-8052
Readiness: N/A
   VCID: 3FDB4F9507F84672361-806A
   Coding: 01
   VCID: 7EA5F29140728F7A7D7-802A
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B3D3A57B30D212029-8026
   Coding: E0A4303A0A212031002009742C2B8C540F00708F60464D60330400220800
   Shop #: WSC 02762 534 1564538
   VCID: 2B030BC5E300CAD28A9-807E
   Subsystem 1 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU007021880382056
   Coding: 1400B1
   Subsystem 2 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU005021880361125
   Coding: 0400A1
   Coding: 10800D
   VCID: 71BFD9AD012CE002F05-8024
   VCID: 36352AB128C2873AE57-8062
   VCID: 3D27359D0DF4546224D-8068
   Coding: 450B010300
   VCID: 3A2D3E811CDA635A01F-806E
   Revision: B9082001
   Coding: 042305
   VCID: 6889B4C9327621CAA7B-803C
   VCID: 6A8DCEC12CFA13DAB1F-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 03021800010230 Dataset Number: V03935266VJ 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E0502D1D092BFFAAD7-807A
   Coding: 030B7A73
End----------(Elapsed Time: 01:11, VBatt start/end: 12.4V/12.3V)-----------
dnoermann
C?ID=358118
You have no scan with retrofittet MFSW at that point where it still worked ?
Did the "Door Control Modules" disapear after the MFSW retrofit ?
Anyhow there are some wrong Instructions out there even from the Sellers, regarding MFSW retrofit on the T6.
So in your case the Lin Bus (1 Wire communication Bus) from MFSW and the Door Modules is not working.
They are all connected to the same Lin Bus.
Probably you Shorted or Grounded that Lin Bus while regtrofitting.
Or the Cable got errores after the retrofit because of tension or movement.
Check that Cable first.
BCM only complaines Coding because Lin Bus is coded but no configured Devices found ....
Hoopdub
C?ID=168295
Thank you for the reply. ive just had a look back through the scan logs to see if i could find any with the mfsw working. i think i may have found some. posted below.
I will go out and check the LIN wiring when i get home.
riday,17,May,2024,18:55:29:24488
VIN: WV1ZZZ7HZJH134300   Mileage: 250570km-155696miles
   Revision: 23002001
   VCID: 074B97751FA8CEB2169-8052
Readiness: N/A
   VCID: 3FDB4F9507F846726E9-806A
   Coding: 01
   VCID: 7EA5F29140728F7A25F-802A
   Revision: 00001002
   Coding: 0000000003
   VCID: 73B3D3A57B30D2125A1-8026
   Coding: E0A4303A0A212031002809742C2B8C550F00708F60464D70330400220840
   VCID: 2B030BC5E300CAD2D21-807E
   Coding: 1400B1
   Coding: 0400A1
   Subsystem 3 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000826340058201
   Coding: A4FFFF
   Coding: 30800D
   VCID: 71BFD9AD012CE002A8D-8024
   VCID: 36352AB128C2873ABDF-8062
   VCID: 3D27359D0DF454627C5-8068
   Coding: 450B000300
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 3A2D3E811CDA635A597-806E
                    Reset counter: 70
                    Mileage: 250578 km
                    Date: 2024.05.17
                    Time: 18:52:57
   Revision: B9082001
   Coding: 042300
   VCID: 6889B4C9327621CAFF3-803C
   VCID: 6A8DCEC12CFA13DAE97-803E
Address 56: Radio
   Coding: 030B7A73
End----------(Elapsed Time: 01:16, VBatt start/end: 12.2V/12.1V)-----------
Tuesday,17,September,2024,19:07:03:24488
Scan: 01 03 04 08 09 10 13 15 17 19 25 56 61 6C 0B
6C-Back-up Cam. -- Status: Cannot be reached 1100
   Revision: 23002001
Readiness: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: E0A439380A210012002809742C2B84D50F00708F60464D70330400230840
   Subsystem 1 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Coding: A4FFFF
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.08.
                    Time: 00:39:10
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.08.
                    Time: 00:39:10
   Coding: 30800D
1380 - Internal Fault
          B200F F0 [00001000] - Unknown Error Elaboration
          [FAULT_ADC_VZ_BELOW_RADAR_OPERATION_LIMIT]
                    Reset counter: 124
                    Mileage: 250781 km
                    Date: 2024.09.14.
                    Time: 18:28:21
                    Control Module temperature: 19  C
                    Voltage terminal 15: 6.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 124
                    Mileage: 250781 km
                    Date: 2024.09.14.
                    Time: 18:28:21
                    Voltage terminal 15: 8.8 V
1072 - Databus
          [FAULT_BCM_BRAKELIGHT_FAIL]
                    Reset counter: 124
                    Mileage: 250781 km
                    Date: 2024.09.07.
                    Time: 18:58:53
                    Voltage terminal 15: 10.5 V
   Coding: 450B000300
                    Reset counter: 70
                    Mileage: 250578 km
                    Date: 2024.05.17.
                    Time: 18:52:57
   Revision: B9082001
   Coding: 042300
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2019.02.08.
                    Time: 00:24:60
Address 56: Radio
   Coding: 030B7A73
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 124
                    Date: 2019.02.07.
                    Time: 06:38:60
Address 6C: Back-up Cam.
End-----(Elapsed Time: 01:10, VBatt start/end: 10.0V/9.9V. VIgn 9.8V)------
Thanks again for the reply, very much appreciated.
dnoermann
C?ID=358118
Ah :)
As i said there are a lot Coding/Installations out there for the T6.
So the coding you had with working MFSW is
The last 40 Means that you enabled the second Lin Bus in BCM and that you connected the MFSW there.
This is needed for CCS and ACC on MFSW.
So this means that you first should change the coding.
At least change last byte to 40, but you could try changing the compleete coding.
Because somehow you messed the First Lin Bus still ...
If all works after that, than its not the cabling.
With that configuration you have
Lin Bus 1 for the Doors
Lin Bus 2 for the MFSW
By the Way since your Car does have the ACC Sensor already, but only enabled for Frontassist.
ACC Retrofit is not mutch work from that point.
Only get the MFSW with ACC Buttons and i can enable your Radar for ACC.
Hoopdub
C?ID=168295
Yes the front radar is only for collision assist on my T6. I have had it activate a few times when it shouldn't have, almost sending me through the windscreen :D
I don't want cruise control, so I didn't get an MFSW with the CCS buttons. I CCS on my other vehicle (Ford Kuga/Escape) but I never use that either, it's not something I have ever really wanted to use :D
With regards to the last byte on long coding of the BCM. The option says something like when sounder input is used instead of door input Either pin T73b/36 (sounder) or T73b/17 (door control circuits).
I have been racking my brain all night trying to remember if I used 17 or 36. Logically I must have used 36 as my van has no alarm, so wouldn't have a sounder leaving pin 36 empty. But I can not remember, so I am going to have to remove the BCM and double check this before I can confirm on VCDS coding either way.
I did manage to get the MFSW subsystem to re appear in the BCM. I did this by checking the box for Radio in the CAN installation list. once the rain stops i will head out, check the pin config for MFSW install and run some more scans.
Thanks again for your help.
Hoopdub
C?ID=168295
Successful morning today. I stripped the bcm and wiring out to check/confirm I'd run the mfsw LIN wire to 36. Confirmed. I also found why I'd lost comms with the door modules, bent pin 17 on the BCM!! :-)
Coding wise, I managed to clear the fault in 09, 04194 undervoltage. I reset the stored values in adaptation channels 50, 51, 52 and that has worked.
I haven't refitted the BCM as yet. I am hoping that with the door module comms reinstated it may clear the fault in 17 Instruments relating to incorrect software.
As soon as i have done it i will post results and related scans.
Hoopdub
C?ID=168295
Scan with only the instruments 17 fault. I've been googling the fault and it could be related to component protection? If that is true could it be related to when I fitted an upgrade MIB unit that had the CP "removed". I have since removed that unit as it failed. I now have an Alpine head unit.
Monday,30,September,2024,18:55:16:24488
   Revision: 23002001
   VCID: 074B97751FA8CEB21E1-8052
Readiness: N/A
   VCID: 3FDB4F9507F84672661-806A
   Coding: 01
   VCID: 7EA5F29140728F7A2D7-802A
   Revision: 00001002
   Coding: 0000000003
   VCID: 73B3D3A57B30D212529-8026
   Coding: E0A439380A212011002809742C2B8CD40F00708F60464D703304003B0840
   VCID: 2B030BC5E300CAD2DA9-807E
   Coding: 1400B1
   Coding: 0400A1
   Coding: A4FFFF
   Coding: 00800D
   VCID: 71BFD9AD012CE002A05-8024
   VCID: 36352AB128C2873AB57-8062
   VCID: 3D27359D0DF4546274D-8068
   Coding: 450B000300
   VCID: 3A2D3E811CDA635A51F-806E
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2024.09.30.
                    Time: 00:03:36
   Revision: B9082001
   Coding: 042300
   VCID: 6889B4C9327621CAF7B-803C
   VCID: 6A8DCEC12CFA13DAE1F-803E
Address 56: Radio
   Coding: 030B7A73
End----(Elapsed Time: 01:13, VBatt start/end: 10.8V/10.7V. VIgn 10.7V)-----
Westbury, UK
                    Date: 2024.09.30.
                    Time: 00:03:36
I doubt it's related to CP as it's the software version in 17 it's complaining about.
What's the backstory behind the instruments?
Hoopdub
C?ID=168295
The instruments are original, when I got the van in August 23 the fault wasn't there. The fault with the instruments has only reared its head since I started changing the audio and altering the coding to suit. I did notice though that the Instruments long coding when I got the van had TPMS checked, the van does not have TPMS (as far as I can tell) so I have since unchecked that option. The fault remains in both checked and unchecked options of TPMS so I'm assuming its not that.
here's the advanced ID info on the instruments
Monday,30,September,2024,09:58:45:24488
VCDS Version: Release 24.7.1 (x64)
Control Module Part Number: 7E0 920 970 S
  Component and/or Version: KOMBI         H03 1107
           Software Coding: 450B000300
            Work Shop Code: WSC 02762
Advanced Identification/FAZIT
     Identification: VDD-024
     Date: 16.02.18
     Manufacturer number: 1901
     Test stand number: 3797
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Programming Status: 00000000
     Flash Date: 00.00.00
Software
     BAP: 01.05.02
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 7E0 920 970 S
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A05733
Car Info
     Chassis Number: WV1ZZZ7HZJH134300
VCDS Info:
       Labels: 5K0-920-XXX-17.CLB-SRI1
Westbury, UK
Have you tried unticking 56 in the installation list of 19?
Hoopdub
C?ID=168295
yes, it throws up more fault codes (instrument one remains also). and strangely still looks for radio 56 on auto scan. another strange thing I've noticed on auto scan is the very last module it tries to com with, 0B Sec Air Heating, i don't have, isn't checked and still searches for it every time.
Scan with 56 unchecked
Tuesday,01,October,2024,10:48:56:24488
56-Radio -- Status: Not registered 0001
   Revision: 23002001
Readiness: N/A
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 1400B1
   Coding: 0400A1
   Coding: A4FFFF
   Coding: 00800D
   Coding: 450B000300
                    Reset counter: 84
                    Mileage: 250781 km
                    Date: 2024.10.01.
                    Time: 15:56:59
   Revision: B9082001
   Coding: 042300
                    Mileage: 250781 km
                    Date: 2019.02.22.
                    Time: 15:56:59
Address 56: Radio
   Coding: 030B7A73
End----(Elapsed Time: 01:15, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
I think i may just leave it as it is. The fault in the instruments does not throw up an EML so ignoring it may be the only option, although annoying, I'd much rather a full list of OK than one Malfunction :D
Westbury, UK
When you don't select a chassis type the Auto-Scan initially interrogates 19 for the Installation List, so I wonder if the problem isn't the tick for 56 but one of the modules being coded for Sec Air Heating?
Hoopdub
C?ID=168295
Could still be Can Gateway related, i can't get into Coding ii as it requires an access code that i can't find online.
You're never going to get this vehicle completely free of faults with an aftermarket radio in it. They seem to have learned to listen on the CAN bus for the messages they need, and the Gateway is aware they are present, but they don't send back all the messages needed to make the Gateway and possibly some of the other modules happy.
Hoopdub
C?ID=168295
Yes agreed, thinking about it the head unit does have a CAN interface with it to retain most of the original functions sonit makes sense.
dnoermann
C?ID=358118
i suspect it's related to the alpine radio
iichel is right.
Cluster complaines that BAB Protocoll issue.
BAB is german "Bedien und Anzeige Protocoll".
This is because the Alipine Radio is communicating in a newver Version to the Cluster.
If you diconnect the Alpine Radio this error must beclearable, just to do a verification of this.
