- Sep 17, 2024
- 18
- 0
- Cambridge, UK
- C?ID=592213
Hi guys,
So i just bought a fixer upper gt tdi. when i bought it i noticed the window wouldnt open or close and was open a fraction. today i took off the inner door skin to inspect the regulator and noticed the cable had come off of a pulley and caused the issue. so i put it all back together after mending it expecting it to work and i was met with some really weird results.
So one thing to note is by the look of it the previous owner installed a new window regulator. when i opened the door skin i noticed the window wasnt even attached to the regulator properly.
So basically i go to close the window all the way and the window switch does nothing then boom, down is up, up is down, sometimes no response atall. i checked codes and looked at measuring blocks and when i hit the window switch the computer is reading a whole load of different inputs.
Something else i should add is iv noticed interior lights dont come on when i open either doors and vcds always detects the doors as closed. So im wondering if these issues could be related or if they could be seperate issues, and im wondering what might fix the window issues mainly. I imagine the lights not coming on would due to the door lock module on the divers side. I had similar issues with my gti and when i replaced the module it was fixed. But i didnt have these wierd window issues.
I should also add in the codes it mentions the passenger side switch. But from investigating there is no noticable issues with the passenger side window or either switches for it so im wondering why it might be indicating a fault even after clearing codes.
Here is my scan:
Thanks ahead guys!
Here is my scan:
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 926 C
Component: KOMBI+WEGFAHRS. RB8 V28
Coding: 05414
Shop #: WSC 00046
VCID: 2A0ADB1445ED3E3A217-5160
WVWZZZ1JZ3B150676 VWZ6Z0C0012307
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00046
VCID: 70BE097CA3B104EAAF3-5160
Part No: 1C0 959 799 B
Component: 1Y Komfortger t HLO 0003
Coding: 00065
Shop #: WSC 00046
VCID: 3632FF6481556ADAB5F-4B1E
Subsystem 1 - Part No: 1C2959802A
Component: 1Y T rsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C2959801A
Component: 1Y T rsteuer.BF KLO 0009
00912 - Window Regulator Switch; Front Left (E40)
End----------(Elapsed Time: 05:04, VBatt start/end: 12.4V/12.4V)-----------
Thanks ahead guys!
