Particulate filter reset
Scottie11
C?ID=592103
Hi I am changing the DPF in an Audi A4 3.0 tdi how do I reset the values to get it out of limp mode
Dr Sheldon
Windsor UK
C?ID=334979
Look in Basic Settings or Adaptations - It is there - not difficult to find,
Please post an Auto-Scan so people can see what ECU this car has and what software is in it. There have been at least three generations of 3.0 TDI and they're not all the same.
Scottie11
C?ID=592103
Hi looking for help to reset the DFP values in 2008 Audi 3.0 A4 TDI which has gone into limp mode. Attaching an auto scan. I have cleaned the DPF and tried following video instructions but am unable to gain access to some of the tabs that are necessary to do this. Some of them are greyed out or I am told "error channel unavailable" Anyone able to help as bought the VCDS thinking it would enable me to do this? I noticed in some of the videos that they are using an older version of the VCDS some are version 17 or 20 our version is 24.
Thanks in advance
Saturday,28,September,2024,18:59:26:03668
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WAUZZZ8K88A030292   License Plate:
Mileage: 172140km-106962mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 37 42 46 47 52 53 56 62
          72 77
VIN: WAUZZZ8K88A030292   Mileage: 172140km-106962miles
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401 F    HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0004
   Revision: --H01---    CVN: 5F3BA505
   Coding: 0104002C180F0018
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30LTDIA5 A02004
   ROD: EV_ECM30LTDIA5_A02.rod
   VCID: 2E02D70E7097A03AFDF-807A
   VINID: 9D196AAAA21B2084400C0089085F973D8A
5188 - Particulate Filter (Bank 1)
          P242F 00 [10100111] - Restricted/Clogged
                    Mileage: 172148 km
                    Date: 2024.09.28
                    Time: 17:16:38
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 11.340 V
                    Engine speed: 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Field regeneration status-Bits 0-7: 00000000
                    Field regeneration status-Bits 0-7: 10000000
                    Particul.filter diff.pressure: -6 hPa
                    Exh t Adap TP Flt Us: -270.0 °C
                    Exhaust gas vol.flow particulate filter: 0.0 m³/h
                    Distance since last regeneration: 0 m
5189 - Particulate Trap Bank 1
          P2002 00 [00100111] - Efficiency Below Threshold
                    Mileage: 172148 km
                    Date: 2024.09.28
                    Time: 17:16:38
   Part No SW: 8K0 907 379 Q    HW: 8K0 907 379 Q
   Component: ESP8 quattro  H04 0170
   Coding: 1B0500
   VCID: 47CC82AAFFAD1172DE9-8012
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Coding: 031100
   VCID: 303EC9766A23B6CAEF3-8064
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000008029017
   Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000007380008
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 N    HW: 4E0 035 729
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 329BU087544824
   Coding: 0000002
   Shop #: WSC 00861 210 82411
   VCID: 44D695A6C29B3A6A3BB-8010
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000050798
   Subsystem 3 - Serial number: 0120.02.080000000100010294ÿ
   Subsystem 4 - Serial number: 010294ÿ
   Part No SW: 8T2 820 043 M    HW: 8T2 820 043 M
   Component: KLIMA 3 ZONEN H05 0120
   Revision: D0000000    Serial number: 0121.02.080832
   Coding: 36040000
   VCID: 3C26ED46B66B42AA43B-8068
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 18
                    Reset counter: 127
                    Mileage: 172136 km
                    Date: 2024.09.21
                    Time: 14:54:59
   Part No SW: 8K0 907 063     HW: 8K0 907 063
   Component: BCM1 1.0      H21 0253
   Revision: 01021001    Serial number: 00000000007740
   Coding: 690040B10014A7010001000000005F5F001D020800000141000000
   VCID: 6C861D06868B122A93B-8038
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180208  H05 0060
   Serial number: SWFBIE 0000244
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10068572
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000303080098
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 11
                    Reset counter: 127
                    Mileage: 172148 km
                    Date: 2024.09.28
                    Time: 09:55:00
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H42 0390
   Revision: 00042001    Serial number: AUZ5ZBH4572970
   VCID: 2B04DE1A4F05D512DA1-807E
   Part No SW: 8K0 919 475 B    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0010
   Revision: 11001001    Serial number: 75330805916396
   Coding: 000003
   VCID: 382EF15682536E8AA73-806C
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD13J0D-   Dataset Number: 8K0909602C  0010
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C26ED46B6EB42AA43B-8068
   Serial number: 6334MSME2A216B0EJ
   Serial number: 6344MSME2A22025A7
   Serial number: 6352QSME560F1D15N
   Serial number: 6362QSME560F2E49X
   Serial number: 63732SME5768211F1
   Serial number: 63832SME57662515.
   Component: Lenks.Modul   H11 0012
   Revision: --------    Serial number: 90315HBQ0000A
   Coding: 000012
   VCID: 3D20E042AD714BA2745-8068
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H14 0216
   Revision: 00200000    Serial number: 7BY10F338
   Coding: 2F04090002002600010000
   VCID: 3138CC726129BFC2E0D-8064
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 127
                    Mileage: 172148 km
                    Date: 2024.09.28
                    Time: 09:37:13
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E08220838D
   Coding: 000003
   Shop #: WSC 09999 999 999999
   VCID: 44D695A6CE9B3A6A3BB-8010
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 18006D57020208
                    Reset counter: 127
                    Mileage: 172148 km
                    Date: 2024.09.25
                    Time: 21:37:41
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 333BL087544820
   Shop #: WSC 00861 210 95080
   VCID: 303EC9766623B6CAEF3-8064
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000006891582
   Coding: 011002204001410001
   VCID: 40DE99B6DA83264A1F3-8014
   Revision: 00002001    Serial number: 0109657610
   Coding: 011B062200390440002001
   Component: DWA-Sensor  H02 0030
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34871000856703
   Coding: 020101
   Shop #: WSC 12336 024 394758
   VCID: 3FDC9A4AA77D59B2669-806A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000006881000
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 10000000004863
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336BS087540738
   Coding: 0000001
   VCID: 2E02D70E7C17A03AFDF-807A
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000006876764
   Coding: 010002204001210001
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000006856611
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005105967
   Coding: 0010920
   VCID: 2A0ADB1E40FFCC1A217-807E
End----(Elapsed Time: 01:46, VBatt start/end: 11.4V/11.4V. VIgn 11.5V)-----
Jef
HQ
Basic Settings IDE00467-Resetting of learned values of particle filter
Keep in mind that information you find online was accurate for the car it was made for, doesn't mean it will work for your car. VCDS version 17 or version 24 doesn't matter.... thing are the way they are because of the car itself, not the scan tool.... be it VCDS or ODIS at the dealer. Please see Setting realistic expectations.
Scottie11
C?ID=592103
How can you reset the soot mass calculated using the VCDS I have tried various ways to get into it but am unable.
Scottie11
C?ID=592103
Hi wondering if anyone can help followed the instructions for emergency Particle Filter Regeneration on the WIKI and the following came up when I entered the coding 10016 to start the regeneration
" The coding you entered is the wrong length. Length must be the same as the original coding or an even number of hexadecimal characters"
Any help appreciated.
Mike@Gendan
Swansea, UK
C?ID=57030
Did you try what Jef posted?:
