Code p0491 and u3501 shoud i be worried?
   #21
superglue9009
Long Island, NY, USA
C?ID=596758
Is there any other way to clear CEL without clearing the DTC codes?
Thanks!
   #23
superglue9009
C?ID=596758
allow the system to self clear after sufficient self checks
How long does it take for this to happen, few hours, days... and also any specific parameters needs to be met? Engine idling, driving few miles etc...
Thanks!
   #24
Thanks!
Yes to all of the above.
Different driving cycles and conditions of different things.
FF data gives you an idea of how many cycles are left until it clears once you've addressed whatever the issue causing it was.
Unlearning counter according OBD: 27
superglue9009
C?ID=596758
Thank you for your fast reply!!
The reason I was asking this
I have dropped off the car to the dealership to diagnose the problem ( I have tried all of the testing that you guys suggested and everything was working fine) they came back with a carbon buildup, and also they did not address the issue just clear the CEL without clearing DTC. Code P0491 is still there after the scan with vcds. No CEL on dashboard. They had my car for 2-3 hours.
   #26
Look at your FF data... is the counter dropping or not?
   #27
superglue9009
C?ID=596758
This is the scan before going to the dealer.
Wednesday,25,September,2024,19:42:58:15386
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.5
VIN: 3VV4B7AX8MM067871 License Plate: 9.25
Mileage: 110367km-68578mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 36 39 3C 42 44 47 4B
          52 5F 6C 6D 75 A5 BB BC CA D6 D7
VIN: 3VV4B7AX8MM067871 Mileage: 110367km-68578miles
29-Left Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTEA) Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115 F HW: 06L 907 309 B
   Component: R4 2.0l TFSI H31 0002
   Revision: 1DH31000 CVN: 50917987
   Coding: 012A00122466012FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00452
   ASAM Dataset: EV_ECM20TFS01183A907115F 001004
   ROD: EV_ECM20TFS01183A907115F.rod
   VCID: 290825E8997AE3E228D-807C
   VINID: 0E698448746821D74018720704C0D5FB53
7654 - Secondary Air Injection System: Bank 1
          P0491 00 [10101111] - Insufficient Flow
                    Mileage: 110287 km
                    Date: 2024.09.25
                    Time: 17:39:31
                    Engine RPM: 1213.00 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 27 C
                    Intake air temperature: 22 C
                    Voltage terminal 30: 14.300 V
                    Engine status: COENG_RUNNING
superglue9009
C?ID=596758
After the dealer visit scan
Saturday,28,September,2024,13:59:40:15386
VIN: 3VV4B7AX8MM067871 License Plate: 9.28.24
Mileage: 110459km-68636mi Repair Order:
VIN: 3VV4B7AX8MM067871 Mileage: 110459km-68636miles
39-Right Light -- Status: Malfunction 0010
          P0491 00 [01101000] - Insufficient Flow
                    Mileage: 110287 km
                    Date: 2024.09.25
                    Time: 17:39:31
No, frequency is increasing.... Like I said, if the issue isn't fixed, it won't go away...
   #31
superglue9009
C?ID=596758
I understand now that frequency will rise till I fix the problem., I'm CEL free for now
Let me rephrase my question
How the dealer was able to clear the CEL so quickly without clearing DTC codes?
My car was at the dealership for about two hours and they did not add any extra miles
   #33
superglue9009
C?ID=596758
Thank you sir !!
That make sense just found one for 10k lol
   #34
Westbury, UK
Thank you sir !!
That's only the start with ODIS - there are LARGE annual fees and lots of hoops to jump through.
   #36
Contradictions do not exist. Whenever you think you are facing a contradiction, check your premises. You will find that one of them is wrong.
superglue9009
C?ID=596758
No offense, but you can barely use VCDS.... for what purpose are you even looking up ODIS?
None taken!!
I was simply looking for some answers when comes to clearing CEL using VCDS regardless of addressing the issue/ fixing the problem
   #38
Use the Generic OBD-II function in VCDS tell us what (if any) fault codes show under Mode 3, Mode 7, and Mode 10 (the last might be called Mode 0A now).
