Ignition must be on to do an Auto-Scan, and since a 2000 Caddy won't have a CAN Gateway you must manually select the chassis type from the pulldown list.
Cheers Dave,
That sorted it ok. I hadn't previously needed to use the dropdown list.
I see it worked for me for Auto Scan and returned the result below
Am I right in thinking it was only able to detect addresses 1,3,15,25 & 41, showing results for just 25 & 41?
And is there a way to access the individual modules?
Thursday,19,September,2024,16:25:42:22976
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 24.7.0.0 (x64) HEX-V2 : 0.4643.4
Chassis Type: 9U - VW Caddy Pickup (1997 > 2002)
Scan: 01 03 15 25 41
Address 25: Immobilizer Labels: 1H0-953-257.lbl
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0Y5311620 V00
Coding: 02400
Shop #: 13765
VCID: 2A0D056DD5EAB55A217-12C4
Address 41: Diesel Pump Labels: 028-906-125.lbl
Part No: 028 906 125 B
Component: Saugdiesel FIA V01
VCID: 1373B88962601492F21-4B5C
01266 - Glow Plug Relay (J52)
31-10 - Open or Short to Ground - Intermittent
01050 - Glow Plug Monitoring
01204 - Engine Temperature Sensor (G27)
End----(Elapsed Time: 01:08, VBatt start/end: 14.4V/14.4V. VIgn 0.0V)------
