2004 Audi A8 Air Suspension help please
   #42
BostonSlaya
Rhode Island
C?ID=240768
Can somebody please help on how to read the measurements properly? Maybe in easier terms? Thanks. what does 97 + 2 mm stand for? Thanks
The image you linked is too small to be legible.
Jef
HQ
Looking at the photo, while squinting and using diet root beer goggles, this is what you are looking at:
  • Audi
  • A8/A8L
  • 2004-2008
  • Suspension, Wheels, Steering
  • 40 - Removal and Installation
  • Upper Control Arms
Pictures "A40-0477" and "A40-0478".
To that end, I show the following:
Dimension - a - = 87 plusminus 2 mm
Dimension - b - = 73 plusminus 2 mm
87mm, give or take 2mm, thus 85mm to 89mm is acceptable.
73mm, give or take 2mm, thus 71mm to 75mm is acceptable.
So when installing the upper control arm links, when you put a straight edge across the top of the strut, there be between (X) to (Y) mm distance between the straight edge and the end of the upper control arm.
   #46
BostonSlaya
Rhode Island
C?ID=240768
  • Audi
  • A8/A8L
  • 2004-2008
THANKS that explains everything! Thanks sorry about the picture I'm so sorry about that.
BostonSlaya
Rhode Island
C?ID=240768
Ok I fixed my suspension!!!I replaced both front struts, all upper control arms, both lower control arms, links, sway bar bushings and the driver side level sensor.
After everything was complete I calibrated my suspension and all was good there..... After I ran a scan and I'm now getting some new codes???? So confusing one is control module is coded incorrectly and the CP code! I got a code like this after a MMI update and took it to Audi and they cleared it up because my radio was not working.... My music is in fact still working (Good thing) but it's crazy that this came up with the code..... I know my front end was in the air for a couple weeks but thought it would clear itself.. Any ideas? Also I cannot for the life of me figure out how to post my Autoscan in a drag down menu so if Uwe would help that would be awesome...
Wednesday,16,December,2015,11:19:33:14758
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WAUML44E74N017518   License Plate:
Mileage: 88300km-54867mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38 42
          46 47 4F 52 53 56 61 62 72 76
VIN: WAUML44E74N017518   Mileage: 88300km-54867miles
38-Roof Electronics -- Status: OK 0000
Address 01: Engine        Labels: 077-910-560-BFM.lbl
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0CD531019
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 1F4DDD45CE847AC64F-804A
Readiness: 0010 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0027237
   Coding: 0000002
   VCID: 2447D2A9E7E2591E12-8070
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0007597
   Shop #: WSC 23435 000 00000
   VCID: 224BD4B1FDF6572E60-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0CD531019
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58BFB659EB2ACDFE4E-800C
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 S    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 346IP047514325
   Coding: 0000103
   VCID: 326B24F1AD16C7AE90-8066
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000097794
   Subsystem 3 - Serial number: 0113.11.130000000100010015ÿ
   Subsystem 4 - Serial number: 010015ÿ
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000033347
   Coding: 1151313
   VCID: 5ABBAC519526DFEE78-800E
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO15122003065A000000000168ÿ†89
   Subsystem 5 - Serial number: 000168ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO18122003065A00000000
   Subsystem 7 - Serial number: 65A000000000072ÿ
00066 - Rear Right Footwell Heater (Z43)
                    Reset counter: 174
                    Mileage: 88308 km
                    Date: 2015.12.15
                    Time: 18:23:09
                    Voltage: 13.30 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A5B3C9185C68F6E28-807E
   Subsystem 1 - Part No: 4E1 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 02313
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Serial number: AUZ5ZBC1016260
   VCID: 1C37EA49DF9261DEAA-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7E2009013
   VCID: 285FC6999BCABD7E3E-807C
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 65C18FADAC586016C5-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3CD006664
   Coding: 0000232
   Shop #: WSC 65537 000 00032
   VCID: 5CB7AA499F1221DE6A-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C0111AE
   Coding: FCFE5FCC1B2904
   Shop #: WSC 07228 444 53694
   VCID: 2643C8A191DEAB0E0C-8072
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
   Part No SW: 4E0 910 158     HW: 4E0 919 158 A
   Component: KLIMA-STG. FOND 015 0210
   Revision: 00000014    Serial number: 00000000013996
   Coding: 0000000
   VCID: 61C99BBDB8700C3639-8034
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   Shop #: WSC 22145 444 54027
   VCID: 2541CFADECD8A01605-8070
   VCID: 55A1BF6DBC38F09655-FFFE
No Faults Found
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H42 1100
   Revision: 00000000    Serial number: 355LL037514310
   VCID: 387F16D94B6A2DFEAE-806C
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000332500063
   Coding: 0004021
   VCID: 1D31E74DC48868D65D-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0042525
   VCID: 5EB3A041890E33CE04-800A
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312110112
   Coding: 0065150
   VCID: 275DC5A596D4B20637-8072
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel      H06 0060
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H02 0020
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 175
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 224 C    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0470
   Revision: Dev_D01     Serial number: 00000000655399
   Coding: 0000000
   VCID: 1E33E041C98E73CE44-804A
            000 -  -
                    Reset counter: 173
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 173
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000030051
   Coding: 0010111
   Subsystem 1 - Serial number: VK4978T078WE
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM005 0110
   Coding: 0042525
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 23435 444 58960
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0630
   Revision: 00000000    Serial number: 304CE047583230
   Coding: 0000002
   Shop #: WSC 06802 176 59446
   VCID: 31692BFDA810FCB6E9-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 A    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0230
   Revision: 00000000    Serial number: 00000004980755
   Shop #: WSC 07212 444 82777
   Subsystem 1 - Part No: 000 915 105 DL
   Component: von VA0  310314E04K
   Coding: 303030393135313035444C5641303331303331344530344B
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM003 0100
   Coding: 0000013
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0000013
   VCID: 5DB1A74D840828D61D-8008
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000335600021
   Coding: 0001208
   VCID: 2149DBBDF8F04C3679-8074
End-------------------------(Elapsed Time: 03:31)--------------------------
   #48
Looks like your Audi Amp has lost its mind. Try a coding it to 0000016 with non-zero values for WSC, Importer, and Equipment Number.
BostonSlaya
Rhode Island
C?ID=240768
So if I'm correct I'm gonna put just 16 on the workshop code 16 on the importer number and 16 on equipment number and when you say non-zero value I assume you mean just put the number 16 with no zeros correct ???thanks for all your help
   #50
Jef
HQ
From this:
Coding: 0000000
To this:
Coding: 0000016
Shop #: WSC 54321 444 12345
Note that the actual numbers listed in the WSC really don't effect the operation of a control module. Control modules want to know what dealer is doing the coding. New car dealers have a Work Shop Code, a 5 digit value and that info is stored in the scan tools back in the service department. In the US of Freedom A market, the Importer is 444. And shops can have several scan tools, thus different Equipment numbers.
BostonSlaya
Rhode Island
C?ID=240768
OK I did the coding and looks like one is gone but the CP one is still there.. Weird because nothing was there before I left my car front up in the air for a little over a week while waiting for parts and now I have the CP showing up.. The radio works fine thank god lol...
Here is a new complete scan after the coding..
Friday,18,December,2015,08:16:37:14758
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Mileage: 88440km-54954mi   Repair Order:
VIN: WAUML44E74N017518   Mileage: 88440km-54954miles
38-Roof Electronics -- Status: Malfunction 0010
   Coding: 0007773
   VCID: 1F4DDD45CE847AC668-804A
Readiness: 0010 1001
   Coding: 0000002
   VCID: 2447D2A9E7E2591E35-8070
   Coding: 0263168
   VCID: 58BFB659EB2ACDFE69-800C
   Coding: 0000103
   VCID: 326B24F1AD16C7AEB7-8066
   Coding: 1151313
   VCID: 5ABBAC519526DFEE5F-800E
                    Reset counter: 178
                    Mileage: 88445 km
                    Date: 2015.12.17
                    Time: 21:28:15
                    Voltage: 13.10 V
   Coding: 0111113
   VCID: 2A5B3C9185C68F6E0F-807E
   Coding: 00000030
   Shop #: WSC 02313
   VCID: 1C37EA49DF9261DE8D-8048
   VCID: 285FC6999BCABD7E19-807C
   Coding: 0530707
   Coding: 0012241
   VCID: 65C18FADAC586016E2-8030
   Coding: 0000232
   VCID: 5CB7AA499F1221DE4D-8008
   VCID: 2643C8A191DEAB0E2B-8072
   Coding: 0263168
   Coding: 0000000
   VCID: 61C99BBDB8700C361E-8034
   Coding: 0015510
   VCID: 2541CFADECD8A01622-8070
   VCID: 55A1BF6DBC38F09672-FFFE
No Faults Found
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H42 0570
   Revision: 00000000    Serial number: 355LS037511437
   VCID: 35611FED5C78D09692-8060
   VCID: 1D31E74DC48868D67A-8048
No Faults Found
   Coding: 0042525
   VCID: 5EB3A041890E33CE23-800A
   Coding: 0065150
   VCID: 275DC5A596D4B20610-8072
                    Reset counter: 178
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
   Coding: 0000016
   VCID: 1E33E041C98E73CE63-804A
                    Reset counter: 173
   Coding: 0010111
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T078WE
   Coding: 0042525
   Coding: 0000002
   VCID: 31692BFDA810FCB6CE-8064
   Coding: 0000013
   Coding: 0000013
   VCID: 5DB1A74D840828D63A-8008
   Coding: 0001208
   VCID: 2149DBBDF8F04C365E-8074
End-------------------------(Elapsed Time: 03:25)--------------------------
   #52
BostonSlaya
Rhode Island
C?ID=240768
From this:
To this:
Thanks for your help, I was able to get one code cleared, I did set up a new autoScan for some more help if that's ok thanks
   #53
BostonSlaya
Rhode Island
C?ID=240768
Can anyone help me on my previous post? Thanks
   #54
BostonSlaya
Rhode Island
C?ID=240768
So I need a little help and guidance please. After a full scan the one posted above is identical to the one now. I'm getting nothing new. My question is for convenience I purchased a obd wireless called carista. After a scan I'm getting the following I have never seen.
02005- coding pin
01479- headrest adjustment sensor (G129)
Givers for backrest adjustment, drivers seat (G230)
Why isn't anything coming up on vcds but is on Carista?
Thanks.
Please post a current scan from VCDS.
BostonSlaya
Rhode Island
C?ID=240768
I'm sorry should have known lol
Monday,25,January,2016,09:26:44:14758
Mileage: 90460km-56209mi   Repair Order:
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 25 28 34 36 37 38 42 46
VIN: WAUML44E74N017518   Mileage: 90460km-56209miles
   Coding: 0007773
   Coding: 0000002
   Coding: 0007597
   VCID: 224BD4B1FDF6572E47-8076
   Coding: 0263168
   Coding: 0000103
   Coding: 1151313
                    Reset counter: 240
                    Mileage: 90426 km
                    Date: 2016.01.24
                    Time: 23:55:25
                    Voltage: 13.40 V
   Coding: 0111113
   Coding: 00000030
   Shop #: WSC 02313
   Coding: 0530707
   Coding: 0012241
   Coding: 0000202
   Coding: 7CFE5FCC1B2104
   Coding: 0263168
   Coding: 0000000
   Coding: 0015510
No Faults Found
   Coding: 0004021
02138 - Control Circuit for Front Right Interior Lights
                    Fault Status: 01101100
                    Reset counter: 240
                    Mileage: 90424 km
                    Date: 2016.01.25
                    Time: 00:01:00
00211 - Control Circuit for Rear Illumination Lights
                    Reset counter: 240
                    Mileage: 90424 km
                    Date: 2016.01.25
                    Time: 00:05:00
   Coding: 0000540
   Coding: 0065278
                    Reset counter: 240
                    Mileage: 193858 km
                    Date: 2011.08.15
                    Time: 01:50:33
   Coding: 0000016
                    Reset counter: 240
                    Mileage: 90426 km
                    Date: 2016.01.24
                    Time: 22:33:15
   Coding: 0010111
   Coding: 0000540
   Coding: 0000002
   Component: von VA0  310314E03L
   Coding: 303030393135313035444C5641303331303331344530334C
   Coding: 0004108
   Coding: 0000012
End-------------------------(Elapsed Time: 03:13)--------------------------
   #57
BostonSlaya
Rhode Island
C?ID=240768
I also have a full scan from carista if you would like me to post it. I cannot wait until your upgrade option on your wireless interface.
   #58
You have some wonkiness:
No Faults Found
  [B]or a communication error occurred[/B]
[B]Cannot be reached[/B]
What happens when you try to access 36 directly?
BostonSlaya
Rhode Island
C?ID=240768
It never allows me to get into the module. I will say I did the scan while driving because it was the only time I had. I get the same errors though.
Well, that's where those "missing" faults are. Now the question is, why can't VCDS access that module?
