Resolved ABS coding 08 rabbit with a twist
Resolved
Jamesr
Canada
C?ID=109567
Hi! I have been brought a car that has had the ABS module replaced by the owner. The coding from the original module does not work. Part number is not correct. I was wondering if there is a code that could make the part work anyways. In the scan at the end is the original ABS coding. and I think third module reading from the bottom is the new(used) ABS module. Thanks for any help!!
Wednesday,18,September,2024,08:57:37:46012
VCDS Version: 24.7.0.0  HEX-NET2 CB: 0.4643.5
Dealer/Shop Name: reuber car care
VIN: WVWCA71K09W140532   License Plate: BREAKER
Mileage: 255469   Repair Order:
                Address 56: Radio       Labels: 1K0-035-161.lbl
Control Module Part Number: 1K0 035 161 D    HW: 1K0 035 161 D
  Component and/or Version: Radio DE2       018 0021
           Software Coding: 0040401
            Work Shop Code: WSC 01357 011 00200
                      VCID: 20128B3956C8D8CA7F3-8074
00871 - Bass Speaker Front Right (R23)
00856 - Radio Antenna
Address 56: DTCs cleared
                Address 44: Steering Assist       Labels: 1Kx-909-144-G2V3.clb
Control Module Part Number: 1K1 909 144 M
  Component and/or Version: EPS_ZFLS Kl.069 H08 1901
           Software Coding:
            Work Shop Code: WSC 00000 028 00001
                      VCID: 353C4A6DF94A4D62BC5-8060
00625 - Vehicle Speed Signal
                    Mileage: 254060 km
                    Temperature: 36.0°C
                    Voltage: 12.50 V
                    Voltage: 12.30 V
Address 44: DTCs cleared
                Address 42: Door Elect, Driver       Labels: 1K0-959-701-MIN3.clb
Control Module Part Number: 1K0 959 701 M    HW: 1K0 959 701 M
  Component and/or Version: Tuer-SG         006 1219
           Software Coding: 0001205
                      VCID: 38224359EE58B00AA73-806C
00109 - Left Mirror Turn Signal Lamp (L131)
Address 42: DTCs cleared
                Address 19: CAN Gateway       Labels: 1K0-907-530-V3.clb
Control Module Part Number: 1K0 907 530 Q    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H07 5063
           Software Coding: E9817F060002020002
                    Fault Status: 00110100
                    Reset counter: 129
                    Mileage: 254079 km
                    Time: 00:00:43
Address 19: DTCs cleared
                Address 17: Instruments       Labels: 1K0-920-xxx-17.lbl
Control Module Part Number: 1K0 920 854 T    HW: 1K0 920 854 T
  Component and/or Version: KOMBIINSTRUMENT VDD 1222
           Software Coding: 0007303
            Work Shop Code: WSC 01357 067 57207
                      VCID: 3C2A5F49DA609C2A43B-8068
                    Reset counter: 129
                    Mileage: 254079 km
                    Time: 00:00:42
Address 17: DTCs cleared
                Address 16: Steering wheel       Labels: 1K0-953-549-MY8.lbl
Control Module Part Number: 1K0 953 549 BN    HW: 1K0 953 549 BN
  Component and/or Version: J0527           051 0101
           Software Coding: 0000022
                      VCID: 7F5068458BF64732269-802A
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 16: DTCs cleared
                Address 15: Airbags       Labels: 1K0-909-605.lbl
Control Module Part Number: 1K0 909 605 AB    HW: 1K0 909 605 AB
  Component and/or Version: 6L AIRBAG VW8R  034 8000
           Software Coding: 0013900
                      VCID: 6C8AAF09EA80CCAA93B-8038
01312 - Powertrain Data Bus
            004 - No Signal/Communication - Intermittent - MIL ON
Address 15: DTCs cleared
                Address 09: Cent. Elect.       Labels: 3C0-937-049-30-H.lbl
Control Module Part Number: 3C8 937 049 E    HW: 3C8 937 049 E
  Component and/or Version: Bordnetz-SG     H54 2602
           Software Coding: 138D8F214004150047140000001400000038770B5C000100000000000000
           Additional Info: 1K1955119E  Wischer 041008 021  0501
                      VCID: 33387475F73E5352921-8066
01501 - Bulb for Blinkers; Rear Left (M6)
                    Fault Status: 00101100
                    Reset counter: 139
                    Mileage: 255306 km
                    Voltage: 13.65 V
                    Reset counter: 139
                    Mileage: 255306 km
                    Voltage: 13.55 V
                    Reset counter: 139
                    Mileage: 255306 km
                    Voltage: 14.30 V
                    Reset counter: 139
                    Mileage: 255306 km
                    Voltage: 14.30 V
                    Reset counter: 139
                    Mileage: 255306 km
                    Voltage: 14.30 V
                    Fault Status: 00101010
                    Reset counter: 139
                    Voltage: 12.80 V
Address 09: DTCs cleared
                Address 08: Auto HVAC       Labels: 1K0-820-047.lbl
Control Module Part Number: 1K0 820 047 HN    HW: 1K0 820 047 HN
  Component and/or Version: Climatic PQ35   142 1111
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 77A08065A3C67F726E9-8022
            009 - Open or Short to Ground
Address 08: DTCs cleared
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
  Component and/or Version: ESP MK60EC1   H31 0121
           Software Coding: 00000000000000000000000000000000000000
            Work Shop Code: WSC 00066 000 00000
                      VCID: 7BA89C5593EE5B120A1-802E
                    Fault Status: 00100101
                    Reset counter: 129
                    Mileage: 254591 km
                    Count: 2
                    Count: 28672
                    Count: 212
                    Count: 39936
                    Count: 65280
                    Count: 256
                    Reset counter: 89
                    Mileage: 254591 km
                    Count: 16391
                    Count: 24576
                    Count: 195
                    Count: 43776
                    Count: 65280
                    Fault Status: 01100101
                    Reset counter: 89
                    Mileage: 254591 km
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 39936
                    Count: 65280
                    Count: 256
                    Reset counter: 89
                    Mileage: 254591 km
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 39936
                    Count: 65280
                    Count: 256
                    Reset counter: 89
                    Mileage: 254591 km
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 39936
                    Count: 65280
                    Count: 256
Address 03: DTCs cleared
                Address 01: Engine       Labels: 07K-906-055-CBT.clb
Control Module Part Number: 07K 906 055 Q    HW: 07K 906 055 M
  Component and/or Version: 2,5l R5/4V      G   9970
           Software Coding: 0000071
            Work Shop Code: WSC 93363 999 13827
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 254591 km
                    Time: 20:42:09
                    RPM: 1313 /min
                    Load: 20.4 %
                    Temperature: 57.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 12.192 V
Address 01: DTCs cleared
Gateway Installation List:  3Q0 907 530 AG
Control Module Part Number: 1K0 907 379 CD    HW: 1K0 907 379 AD
  Component and/or Version: ESP MK60EC1   H35 0120
           Software Coding: 113B400D492600FA881002E7921B00413000
            Work Shop Code: WSC 32346 002 1048576
                      VCID: 76BE8D61A8CC067A75F-8022
01130 - ABS Operation
                    Fault Status: 01101000
                    Reset counter: 85
                    Mileage: 254071 km
                    Count: 4608
                    Count: 125
                    Count: 50191
                    Count: 517
                    Reset counter: 125
                    Mileage: 254075 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 8212
                    Count: 44032
                    Reset counter: 128
                    Mileage: 254079 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 8213
                    Count: 44544
                    Count: 1
                    Fault Status: 01101100
                    Reset counter: 0
                    Mileage: 255469 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 272
                    Count: 43776
                    Count: 512
                    Count: 21760
Address 03,1K0 907 379 BJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,113B400D492600FA881002E7921B00413000,(00066/000/00000),
Address 03,1K0 907 379 BJ,recoded (Long Coding),from,00000000000000000000000000000000000000,to,113B400D492600FA881002E7921B00413000,(00066/123/12345),
Jamesr
Canada
C?ID=109567
Wednesday,18,September,2024,11:33:18:46012
VIN: WVWCA71K09W140532   License Plate: BREAKER2
Mileage: 255460km-158735mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWCA71K09W140532   Mileage: 255460km-158735miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0H93ND8CL
   Coding: 0000071
   Shop #: WSC 93363 999 13827
   VINID: 9E69D344705B0099C1100143082EFE7A65
Readiness: 0110 0101
   Revision: 00H31001
   Shop #: WSC 00066 000 00000
                    Reset counter: 103
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 43520
                    Reset counter: 103
                    Mileage: 255469 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 43520
                    Reset counter: 103
                    Mileage: 255469 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 43520
                    Reset counter: 103
                    Mileage: 255469 km
                    Count: 3
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 43520
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Revision: 00H54000    Serial number: 00000008918239
   Component: Wischer 041008 021  0501
   Coding: 00038805
   Shop #: WSC 01357
                    Reset counter: 143
                    Mileage: 255469 km
                    Voltage: 12.00 V
                    Reset counter: 143
                    Mileage: 255469 km
                    Voltage: 12.05 V
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C4PA+
   Coding: 0013900
   Subsystem 1 - Serial number: 6332MSME4132124B%
   Subsystem 2 - Serial number: 6342MSME3C342A71E
   Subsystem 3 - Serial number: 6352QSME350B193AJ
   Subsystem 4 - Serial number: 6362QSME180C0A38K
   Subsystem 5 - Serial number: 63727SME195F2C63D
   Subsystem 6 - Serial number: 63827SME1960533A+
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Coding: 0000022
   Part No SW: 1K0 920 854 T    HW: 1K0 920 854 T
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0H93ND8CL
   Coding: 0007303
   Shop #: WSC 01357 067 57207
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 021008F1000899
   Component: IMMO            VDD 1222
   Shop #: WSC 32346 002 1048576
   Component: Tuer-SG         006 1219
   Coding: 0001205
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103083F6D04058FB0080F0488FC80
   VCID: 71B4BE7DCDA22142A0D-8024
   Component: Tuer-SG         006 1203
   Coding: 0001204
   Shop #: WSC 01279 785 00200
   VCID: 3924465DD552A90258D-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74BAB769B2B0146A4BB-8020
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       018 0021
   Revision: 00018000    Serial number: VWZ4Z7H6376864
   Coding: 0040401
00875 - Treble Speaker Front Right (R22)
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1305
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
End----------(Elapsed Time: 01:20, VBatt start/end: 12.3V/12.2V)-----------
JMR
Romania
C?ID=432218
So what was the original coding and the original part number if you have that available please ,post it
Jamesr
Canada
C?ID=109567
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Try: 113B400D492600FA881002E7921B0041300000
Jamesr
Canada
C?ID=109567
Great guys!! Seem to have accepted the coding. I am going to do the latitude and steering angle calibration. Wondering how you determined what coding to try? Thanks!
Jamesr
Canada
C?ID=109567
Seems to be working well!! Thanks so much Boke Ar. Im looking forward to learning more about the programming and coding so I can help instead of just ask for help!! :)
Waxing pedantic here: This is not an "08". 2008 cars didn't use MK60EC1 ABS systems.
This is corroborated by the VIN: WVWCA71K09W140532. That's clearly a 2009.
Jamesr
Canada
C?ID=109567
I used the build date 10/08 usualy means 2008. My bad. I guess thats why we get a vin in the scan :) Learning is fun!!
Nah, the model year change-over typically happens over the summer and the next model year cars hit dealers' lots by September at the latest.
Jamesr
Canada
C?ID=109567
obvously your correct. :) Any way I could learn more about the coding and how to determine what coding will do what? Thanks for your help all
For your ABS? Study the user-developed label files linked in the first post of the following thread:
For the rest of your Mk.5, start here:
