- Sep 17, 2024
- 10
- 1
- Seattle, WA, USA
- C?ID=597598
Hi-
I'm new to VWs but I'm an experienced auto tech. I did some work on my friend's 2012 Golf TDI that involved disconnecting the battery and rocking the engine around.
After the work was completed, I reconnected the battery and went to start the car - nothing! Start button does NOTHING, dash does not light up. Battery is fully charged and connections are good, high beams are bright. Also, the horn does not work. All fuses in both boxes have continuity and look fine.
There is power at the OBD port, but VCDS will not communicate with any modules during an auto-scan.
I suspect the BCM (J519) has failed somehow since all of these things that don't work get power through it. I'm going to try replacing that, but even if it solves the major problems I understand that I will have to re-code it somehow. Is there any way to get the values off the old BCM?
Also open to other diagnosis ideas - I'm kind of at a dead end. I appreciate any help you guys can give.
Thanks!
Thanks!
