- Jan 9, 2020
- 12
- 7
- Sofia, Bulgaria
- C?ID=30121
Hello friends i want to change some adaptation parameters of audi q7 2023 i have done some lci models without problem but this one wants a security accsess i cant see any SFD option in it so can you help im triyng to do USA to EU conversation of rear tail lights
Tuesday,17,September,2024,12:57:42:05211
VCDS Version: 24.7.0.0 (x64) HEX-NET CB: 0.4643.4
Chassis Type: F7-AU73 (4KL)
Scan: 01 02 03 09 13 15 16 17 19 36 3C 42 44 46 50 52 5F 61 65 6D
75 81 A5 BB BC C4 CA CC CF D6 D7 DE
VIN: WA1LXBF77RD008265 Mileage: 326km-202miles
50-Seat Adj. 3rd row -- Status: OK 0000
BB-Door Rear Drv -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: Malfunction 0010
Address 01: Engine (J623-DCBD) Labels: None
Part No SW: 4M0 907 559 AB HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0001
Revision: B8H11000 CVN: 0E77C01C920C9DE15334E24B45E2F776F806D8F9
Coding: 2A2A00122566010E74286000000000000000000000000000
Shop #: WSC 31414 039 00001
ASAM Dataset: EV_ECM30TFS0114M0907559AB 001001
ROD: EV_ECM30TFS0114M0907559AB.rod
VCID: 77BEF052CED91F2EF2-8022
VINID: 9D105CA125871E250000808614BA475F62
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 AA HW: 95B 965 501 AA
Component: V544KJS1 H13 0110
Serial number: 20231029060604081032
42452 - Voltage Supply 1 for Control Module
U3501 00 [01100101] - Too Low
Mileage: 326 km
Date: 2024.09.03
Time: 21:51:50
Engine RPM: 1201.50 /min
Normed load value: 11.4 %
Coolant temperature: 31 °C
Intake air temperature: 23 °C
Ambient air pressure: 950 mbar
Voltage terminal 30: 10.740 V
Engine status: COENG_RUNNING
Readiness: 1110 0101
Part No SW: 4M0 927 158 EE HW: 0D5 927 156 P
Component: 0D5 30TFSINAR H06 0002
Revision: --H06--- CVN: 61490975D85BE3D8
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011.rod
VCID: 7BB6EC62F2F13B4E96-802E
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AB HW: 0D7 321 281 D
Component: V552 ATFP H02 0623
Serial number: 2311031210
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M6 907 379 AK HW: 4M6 907 379
Component: ESP9 Premium H08 0914
Dataset Number: 4M0909504BB 0002 CVN: B0DD5C95
Coding: 2814310B93580012E2F43A8914288CD0C91A0048472F5C91
ASAM Dataset: EV_ESP9BOSCHCMP 005023
ROD: EV_ESP9BOSCHCMP_005_AU73.rod
VCID: 06408D96B93376A6F9-8052 SFD
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 NE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H11 0775
Dataset Number: 4M1909514P 0040
Coding: 07000363E0291CCD070C57889CEE9C38130B37D10406009701001A0019331C01086309020010000000000100000300181002000004010104000000000000000000
Shop #: WSC 31414 051 00001
ASAM Dataset: EV_BCM1BOSCHAU651 020007
ROD: EV_BCM1BOSCHAU651_020.rod
VCID: 7EB0E576E1E32E66B1-802A
Subsystem 1 - Part No SW: 4M8 955 119 B HW: 4N1 955 119
Component: J400FRWISCH 052 0997
Serial number: 904753F0302329201212
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 22460222X81A955555B0
Coding: 02005E
Subsystem 3 - Part No SW: 4K1 941 501 N HW: 4K1 941 501 N
Component: E1 - LTM H07 0060
Serial number: 21S21.11.2300302299
Subsystem 4 - Part No SW: 4N0 907 410 D HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600400Z00ES02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR130082323310969
Subsystem 6 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H09 0210
Serial number: WA165400000144152781
Coding: 0A0100
405507 - Functional Limitation due to Energy Management
B10CD 00 [00001000] - -
[Function limitation due to energy management system]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:35
average_Voltage_terminals: 11.30 V
Outside air temperature sensor-Outside air temperature on CAN: 17.00 °C
interior_temperature: 18.50 °C
Vehicle speed: 0.00 km/h
66661 - Control Module for Roof Electronics
U1165 00 [00001001] - No Communications
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:29
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 T HW: 4K0 907 561
Component: LRR4R H14 0720
Dataset Number: 4M0909863AE 0005
Coding: D764877458082C00000060E00000083A4A1246484401409E97
ASAM Dataset: EV_ACCBOSCHAU65X 002039
ROD: EV_ACCBOSCHAU65X_AU73.rod
VCID: 41CA5E8AD09D919E8C-8014
Address 15: Airbags (J234) Labels:. 80A-959-655.clb
Part No SW: 4M0 959 655 AF HW: 4M0 959 655 AF
Component: AirbagVW33 H02 4428
Serial number: 00384M00M2R2 Dataset Number: 4M0909602DA 0006
Coding: AEFCFCC000C00000A0F0003FF20D410000C5
Shop #: WSC 31414 184 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 003003
ROD: EV_AirbaVW31SMEAU65x_003_VW53.rod
VCID: 7F4E1872E6E9276EBA-802A SFD
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2052
Serial number: 4M0857705AJ298X01344
Coding: 882003
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2052
Serial number: 4M0857706AJ264X00524
Coding: 882003
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H15 0022
Serial number: IBH0000D23000LHING0U
Coding: 303237
Subsystem 4 - Part No SW: ----------- HW: 480 001 111 23
Serial number: 357000000009B2E42C6W
Subsystem 5 - Part No SW: ----------- HW: 480 001 111 23
Serial number: 35800000000971C42C6Q
Subsystem 6 - Part No SW: ----------- HW: 480 031 011 23
Component: SideSensor_Dr 002 0149
Serial number: 351004C00721A2806B5Y
Subsystem 7 - Part No SW: ----------- HW: 480 031 011 23
Component: SideSensor_Pr 002 0149
Serial number: 352004C0043D6E40EECO
Subsystem 8 - Part No SW: ----------- HW: 480 030 910 23
Component: FrontSensor_D 002 014A
Serial number: 355004C009ED1A207B2C
Subsystem 9 - Part No SW: ----------- HW: 480 030 910 23
Component: FrontSensor_P 002 014A
Serial number: 356004C0037454F0DC8F
8 Faults Found:
1064450 - Databus
[NWD: 0x3C1 BCM_Taster_01 Message counter error]
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
9442857 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 29 [10001001] - Signal Implausible
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
9629993 - Indicator Lamp for Passenger Airbag Enabled
B12F1 29 [00001000] - Signal Implausible
Mileage: 326 km
Date: 2024.09.03
Time: 21:05:49
9769769 - Text Indicator Lamp for Front Passenger Airbag
B1513 29 [10001001] - Signal Implausible
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
9635157 - Control Module for Front Right Belt Tensioner
B1305 55 [00001001] - Not Configured
Mileage: 326 km
Date: 2024.09.03
Time: 21:05:47
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [10001001] - Resistance Too High
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:27
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [10001001] - Resistance Too High
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:27
9438746 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1A [10001001] - Resistance Too Low
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:27
Part No SW: 4N0 907 129 PC HW: 4N0 907 129 PC
Component: Lenks.Modul H03 0011
VCID: 014A9E8A901D519ECC-8054
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 890 J HW: 4K0 920 890 G
Component: FBenUSA------ H29 0265
Dataset Number: 4N1909525G 0029
Coding: 13C657D56E88CF050280E3609800030008403000
ASAM Dataset: EV_DashBoardAU65X 002039
ROD: EV_DashBoardAU65X_002_AU73.rod
VCID: 35223A5A94552D3E20-8060
9582602 - Video Cable for Information Electronics 1
B13B9 01 [00001000] - Electrical Failure
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
16777018 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
16777026 - Control unit for information electronics 1
[MFL_Jokerfunktion_0x34 communication error bap_error_timeout heartbeat]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
16777030 - Control unit for information electronics 1
[BAP_TEL2_0x29 communication error bap_error_timeout heartbeat]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
16777058 - Control unit for information electronics 1
[BAP_OnlineFunctions_0x2A communication error bap_error_timeout heartbeat]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
Part No SW: 4KL 907 468 M HW: 4KL 907 468 L
Component: Gateway H06 0025
Serial number: 14F11420218001 Dataset Number: 4M0909515AG 0129
Coding: 02030001000406405496000000590132DC1A000010000000090000CE04030000
Shop #: WSC 00228 006 1048576
GVL: F1593C000800000002DCC8008000C800100C2010000000000000000000006700
ASAM Dataset: EV_Gatew31xUNECE 005014
ROD: EV_Gatew31xUNECE_VW53.rod
VCID: 5AF889E65D0B2246ED-800E SFD
Subsystem 1 - Part No SW: 4M8 951 523 J HW: 4M8 951 523 J
Component: J453 MFL H07 0004
Serial number: 20231020094913 31089
Subsystem 2 - Part No SW: 8S0 915 181 D HW: 8S0 915 181 D
Component: J367-BDMHella H01 2361
Serial number: 8792203206
Subsystem 3 - Part No SW: 4M8 419 508 B HW: 4M8 419 508 B
Component: J1158 KLR H14 0012
Serial number: 00000000000000261121
Coding: FFFFFF
10 Faults Found:
131826 - Ethernet Module for Information Electronics 1
U1645 00 [00001000] - No Communication
[Timeout_Node_0xF2_zr2_DiagAdress_005F]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:50
131829 - Ethernet Module for Information Electronics 1
[Timeout_Node_0xF5_zr_DiagAdress_005F]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:50
262727 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[BAP_Timeout_ConnectionManager]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:49
528144 - 12V Electrical System
C11CB F0 [00001000] - Lowring Not Possible
Mileage: 326 km
Date: 2024.09.03
Time: 21:52:15
8519683 - Energy Management Active
U140B 00 [00001000] - -
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
EM_vehicle_state: 02 10
Static current shut-off stage: Deactivation stage 2
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
8519684 - 12V Electrical System
C11CB 01 [00001000] - Electrical Failure
Mileage: 326 km
Date: 2024.09.03
Time: 21:52:00
12-Volt Vehicle electrical system: malfunction status: Stage 1
8519685 - 12V Electrical System
Mileage: 326 km
Date: 2024.09.03
Time: 21:52:03
12-Volt Vehicle electrical system: malfunction status: Stage 2
9502755 - 48V System
C124E F0 [00001001] - Locked after Crash Active
[Airbag_CrashTyp_Historie_Hard]
Fault Frequency: 12
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
48V activation restriction-Airbag control module: active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: not active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
48V activation restriction-Electrical compressor: not active
16711991 - Ethernet Databus Branch 2
U122D 00 [00001000] - No Communication
[Ethernet_databus_no_communication_port_2]
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
Ethernet counter checksum error: branch 2: 0
Ethernet counter connection interruptions: branch 2: 1
16712374 - Unknown Error Code
U17A0 00 [00001001] - -
[Filter_is_not_active]
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:26
Part No SW: 4K0 959 760 HW: 4K0 959 760
Component: MEM-FS 011 0071
Serial number: 00000514900153 Dataset Number: 4M0909856H 0033
Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
VCID: 73A6C442DAA1730ECE-8026
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 AM HW: 4N0 907 566 A
Component: MRR_HR H28 0588
Dataset Number: 4M1909535C 0007
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001022
ROD: EV_RearRadarS1DelphAU651.rod
Part No SW: 4M8 959 793 P HW: 4M8 959 793 P
Component: TSG FS 015 0401
Serial number: 0000512139245 Dataset Number: 4M0909872N 0042
Coding: 005D8B005200108000012032
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001023
ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
VCID: 53E664C23AE1130E2E-8006
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:30
Part No SW: 4N0 909 144 H HW: 4N0 909 144 D
Component: EPS_MLBEVO2BS H24 0512
Dataset Number: 4M0909852BB 0004
Coding: B0000101010001
ASAM Dataset: EV_SteerAssisUNECEAU651 001003
ROD: EV_SteerAssisUNECEAU651.rod
VCID: 35223A5A94552D3E20-8060 SFD
Part No SW: 8W1 907 064 EP HW: 8W1 907 064 EP
Component: BCM2 MLBevo 050 0628
Dataset Number: 4M0909501BA 0005
Coding: 01341E004FB100C0650BA0046C01980203034000810426502F0400040F04803F001E06810100350200000000000000000000
ASAM Dataset: EV_BCM2HellaAU736 021020
ROD: EV_BCM2HellaAU736.rod
VCID: 0F6EA8B2D64937EE4A-805A
ID - sensor:
Subsystem 1 - Part No SW: 4N0 959 754 AM HW: 4N0 959 754 AM
Component: ID-Geber H11 0237
Serial number: 4624000041337026
Subsystem 2 - Part No SW: 5Q0 951 177 C HW: 5Q0 951 172 C
Component: Sensor, DWA 006 0501
Serial number: 0000000000000Q3D5852
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000003870745
Subsystem 4 - Part No SW: 80A 962 243 HW: 80A 962 243
Component: GEB.F.Heckoef H17 0911
Serial number: 40322115
641537 - Bulb for Left Brake Lamp / Turn Signal
B1333 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:51:38
Supply voltages-Terminal 30 power supply: 11.345 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.359 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.372 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 17 04 F8
light_freeze_frame: 11111111 11111111 11111111 11111111
641793 - Bulb for Right Brake Lamp / Turn Signal
B1334 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:51:38
642049 - Bulb 2 for Left Brake Lamp / Turn Signal
B1335 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:51:38
642305 - Bulb 2 for Right Brake Lamp / Turn Signal
B1336 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:51:38
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4K0 959 760 G HW: 4K0 959 760 G
Component: MEM-SR3 011 0072
Serial number: 00000513859990 Dataset Number: 4M0909467E 0022
Coding: FF041020F1000000000F000000000900000021210900000000000000440000
Shop #: WSC 31414 054 00001
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
VCID: 3A382966BD4BC246CD-806E
Part No SW: 4M8 959 792 P HW: 4M8 959 792 P
Component: TSG BFS 015 0401
Serial number: 0000512385028 Dataset Number: 4M0909873N 0042
Coding: 005D8B005E00108000012030
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001023
ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
VCID: 52E861C605FB1A0625-8006
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 4M2 035 092 G HW: 4M2 035 092 B
Component: MU-TP-NS-US 045 4014
Serial number: GRO-63315.11.23 Dataset Number: 4M8909545S 0023
Coding: 15360010804020000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU38.rod
VCID: 2D12123A7C0565FE58-8078 SFD
Multimedia System 1:
Subsystem 1 - Part No SW: 4M8 919 605 M HW: 4M8 919 605 M
Component: DU AU536 Top H41 0060
Serial number: INX00108092300150521
Subsystem 2 - Part No: V03 959 808 FS
Component: MIB3_NA_ 0936
Compact disc data bank:
Component: Gracenote2 3008
Multimedia System 5:
Subsystem 4 - Part No SW: 4N0 919 603 M HW: 4N0 919 603 M
Component: DU AU651 Bot H41 0060
Serial number: INX00124082300170337
Volume Control 1:
Subsystem 5 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00008323000159877023
Media socket:
Subsystem 6 - Part No: 4N1 035 736
007 0007
Digital Sound System Control Module 2:
Subsystem 7 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: HHA-07325.10.2334860
9463827 - Rear Right Treble Speaker
B1068 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 317 km
Date: 2024.08.13
Time: 02:42:17
Voltage terminal 30: 11.9 V
9681683 - Microphone for Vehicle/Ambient Noise
B13BB 13 [00001001] - Open Circuit
Reset counter: 0
Mileage: 318 km
Date: 2024.08.16
Time: 00:00:04
Voltage terminal 30: 12.1 V
1637 - Interface for External Media
U11B8 00 [00001000] - No Communications
[USB - communication error]
Fault Frequency: 31
Mileage: 317 km
Date: 2024.08.13
Time: 03:32:19
Voltage terminal 30: 11.6 V
Interface for external media: status: Open circuit
1537 - Supply voltage
U1011 00 [00001000] - Voltage too Low
[Supply voltage - lower limit value not reached]
Mileage: 326 km
Date: 2024.08.22
Time: 22:31:09
Voltage terminal 30: 7.3 V
0021 - Functional Limitation due to Energy Management
[Function restriction via shutoff stage Q2]
Mileage: 326 km
Date: 2024.09.03
Time: 20:45:46
Voltage terminal 30: 11.2 V
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 E HW: 4N0 915 105 E
Component: BMS_48V_LiIon H06 0113
Dataset Number: 4N0909480A 0006
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU37.rod
VCID: 2C141F3E471F6CF64F-8078
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000238321 Dataset Number: 4M0909850B 0010
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 2F2E0832760917EE6A-807A
Part No SW: 4KE 959 107 B HW: 4KE 959 107 B
Component: HDSG-Modul H08 0342
Revision: -------- Serial number: A2-C765-4921-9 Dataset Number: 4M0909541Q 0040
Coding: 0020
ASAM Dataset: EV_DeckLidCONTIAU536 001006
ROD: EV_DeckLidCONTIAU536_VW42.rod
VCID: 45C24A9AC4B5BDBEB0-8010
Part No SW: 4KE 035 283 L HW: 4KE 035 283 E
Component: CB_H_NAR 043 0595
Serial number: A971J0PS416410 Dataset Number: 4K0909612N 0026
Coding: 01E0E0F9C04080F6F0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_AU58.rod
VCID: 45C24A9AC4B5BDBEB0-8010 SFD
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4N1 713 041 H HW: 4N1 713 041 C
Component: GSM-LL H10 0084
Revision: 0L0D5012 Serial number: 23091989355036
ASAM Dataset: EV_GSMWaehlZFAU736 001018
ROD: EV_GSMWaehlZFAU736_AU72.rod
VCID: 2B161C2242116BCE46-807E
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4K4 907 117 P HW: 4K4 907 117 B
Component: zFAS Var C H10 0394
Dataset Number: 4M1909466S 0029
Coding: 0201820000000000003BD60000F4050E139F5200000000D8000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000018D8008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 004016
ROD: EV_ZFASAU516.rod
VCID: 3C342F7EB77FFC76DF-8068
282656 - Video Cable for Information Electronics 1
Reset counter: 53
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:25
2117740 - Control unit for information electronics 1
[ServiceInitialConnectionFail_ETH_Update_EDR]
Reset counter: 53
Mileage: 326 km
Date: 2024.09.03
Time: 21:02:36
Ethernet signal quality: good: link available
Part No SW: 4M8 959 795 P HW: 4M8 959 795 P
Component: TSG HFS 015 0401
Serial number: 0000512667387 Dataset Number: 4M0909897N 0042
Coding: 004D89000000108040002020
ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001023
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 55E29ADA34150D3EC0-8000
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:30
Component: TSG HBFS 015 0401
Serial number: 0000512659671 Dataset Number: 4M0909896N 0042
ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001023
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Reset counter: 0
Mileage: 326 km
Date: 2024.09.03
Time: 21:01:30
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 663 B HW: 4K0 959 663 B
Component: DCDC_GEN_2 H26 0501
Serial number: DC23453000509 Dataset Number: 4M0909475J 0027
ASAM Dataset: EV_DCDC48VFLEXAU581 005014
ROD: EV_DCDC48VFLEXAU581_005_AU49.rod
VCID: 373E30528E59DF2E32-8062
Address CA: Sunroof (J245) Labels:* None
Part No SW: 4K8 907 594 AA HW: 4K0 907 594
Component: SAD_STG_1 010 0010
Dataset Number: 4M0909469M 0003
Coding: 228040053602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
Address CC: Starter-Generator (C29) Labels:* None
Part No SW: 4N1 903 028 HW: 4N1 903 028
Component: BSG-HP1-65 H18 0562
Serial number: 27112300030154 Dataset Number: 4M0909490A 0003
Coding: 20000400000000
ASAM Dataset: EV_Start48VAU651 002007
ROD: EV_Start48VAU651_002.rod
VCID: 699AA62A886DB9DE74-803C
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H28 0588
Dataset Number: 4M1909468C 0007
Coding: 0FDC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001022
ROD: EV_RearRadarS2DelphAU651.rod
Part No SW: 4K0 941 591 CJ HW: 4K0 941 591 C
Component: LMS_MLBevo H20 0147
Dataset Number: 4M0909471F 0018
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 79BAF66AF8CD095E84-802C
Dataset Number: 4M0909472F 0018
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Dataset Number: 4N0909485A 0007
Coding: 400000
VCID: 2306F4022AC1A38EFE-8076
0512 - Supply voltage
[Powersupply_lower_limit_exceeded]
Mileage: 326 km
Date: 2024.08.22
Time: 22:30:39
0515 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[Powersupply_lower_limit_exceeded-Functional_restrictions]
Mileage: 326 km
Date: 2024.08.22
Time: 22:31:20
End----------(Elapsed Time: 02:21, VBatt start/end: 13.6V/13.6V)-----------
