Golf R 7.5 exhaust flaps open on start, want closed.
Golfy86
Adelaide, Australia
C?ID=594961
Hi all
fairly new to this but anyone point me in the right direction of how to close exhaust flaps on start up as they are always open even when in eco ? stage 3 with full Invidia exhaust, would this have been set when tuned.
Westbury, UK
Since you have a non-OEM tune the first place to ask is the tuner.
  • Agree
Dr Sheldon
Windsor UK
C?ID=334979
Please Post an Autoscan please
Golfy86
Adelaide, Australia
C?ID=594961
Autoscan as per below
Tuesday,17,September,2024,18:31:12:48979
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVWZZZAUZJW219895   License Plate: SEF53M
Mileage: 64837km-40287mi   Repair Order: CHRIS B
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C 42
          44 47 4B 52 5F A5 A9 D6 D7
VIN: WVWZZZAUZJW219895   Mileage: 64837km-40287miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: CFD66791
   Coding: 092500122466050B3004
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47CC8310FF260102DE9-8012
   VINID: 9E69EAAAA465A9A9C204920914323156A6
15148 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
          P0219 00 [01100000] - -)
15007 - Valve for Fuel Metering (N290)
          P0089 00 [01100000] - Inadequate Performance
17178 - Databus
          U1123 00 [00100000] - Received Error Message
Readiness: 0010 0001
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1402
   Revision: 00H06V07    CVN: CDA1BEBA
   ROD: EV_TCMDQ381061.rod
   VCID: 21183D8831421F3270D-8074
   No subsystems:
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 60568000000701
   Coding: 01FA93A154212175477F070960C86980C92A84E2E0069677384250B8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 035457008B9EED22421-8056
8364 - Databus
          [FCAN: RCTA_01 is received with invalid checksum]
                    Reset counter: 180
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:52:59
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0473394892 Dataset Number: V03935252RD 0001
   Coding: 032C0C
   VCID: 3C26ECFCB6E052DA43B-8068
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012001420010000110500001210142A
   VCID: 6D8011B8BD1A0B52845-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 7311005601     Dataset Number: V03935273ND 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084E402CB2B8CE7A173-805C
   Component: WWS    180212  042 0551
   Serial number:         180219181151
   Component: RLHS  047 0105
   Serial number: SAY18M03D06H19M57S02
   Coding: 00A8DD
   Serial number: 000000000ZY180373UD1
   Serial number: 00000000000099839929
   Sunroof control module:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001Z5PUO00000
   Coding: 181901
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 111
                    Mileage: 63883 km
                    Date: 2024.08.11
                    Time: 09:39:04
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.4 V
                    Outside temperature: 17.0  C
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018053 Dataset Number: V03935270DP 0001
   Coding: 0471155811
   VCID: 4BC4BF20E34EE562FA1-801E
13688835 - Databus
          [Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 126
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:53:00
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Dataset Number: V03935274RY 0001
   Coding: 330067C15DFFC728949C810580400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E22E6F4A0FC40CA6DF-806A
   Serial number: 16021841350689 Dataset Number: V03935231PP 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382EF0EC82D87EFAA73-806C
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    005 0336
   Serial number: 003VWR3YSYAU Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C000000008800000065
   VCID: 09484528A9B2B77208D-805C
   Left seat belt tensioner:
   Serial number: 34169677E07031820693
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E06031851600
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 503 18
   Serial number: 357000000007D991FB2$
   Subsystem 4 - Part No SW: -----------    HW: 480 000 303 18
   Serial number: 35800000000D6744CC2X
   Subsystem 5 - Part No SW: -----------    HW: 480 400 603 18
   Serial number: 3510001C9291EE3307FD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 803 18
   Serial number: 3520001C9294E954A57F
   Subsystem 7 - Part No SW: -----------    HW: 480 400 803 18
   Serial number: 3550001C1291EE746514
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 25021804220749
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3195
   Coding: 27AD301E7F88000801886B0B5401000080000000
   VCID: 2A0ADAA44C74DC6A217-807E
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 126
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:53:06
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 126
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:52:59
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007553710 Dataset Number: V03935272LR 0001
   Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
   GVL: 01D63C100000060040DC80000000CC0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180000241280078066
   Coding: 2DFFFF
   Serial number: 5577576804
131662 - Lane change assistant control module
          U1045 00 [00001001] - No communication
          [Timeout Knoten 0x4E / 3C - Steuerger t f r Spurwechselassistent]
                    Reset counter: 126
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:53:02
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
   Serial number: HA1-00009.02.18 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4CC6BC3CE640E25AF3B-8018
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 223
                    Mileage: 64373 km
                    Date: 2024.08.27
                    Time: 20:13:52
0658 - Sensor for Swivel Module Position
          C11F6 29 [00001000] - Signal Implausible
                    Fault Frequency: 19
                    Reset counter: 216
                    Mileage: 61663 km
                    Date: 2024.04.29
                    Time: 16:02:18
   Revision: 00000000    Serial number: 18000072517009
   Coding: 5D00000000000000
   VCID: 3436C4DC9EB09A9A8BB-8060
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0023
   Serial number: Y0006RBL18677
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3D20E1F8ADFA5BD2745-8068
          U1400 00 [00001000] - -
          [Funktionseinschr nkung durch Unterspannung --> funktionelle Einschr nkungen aufgrund vor bergehender Unterspannung in der Versorgung.]
                    Reset counter: 220
                    Mileage: 64338 km
                    Date: 2024.08.25
                    Time: 19:01:49
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Reset counter: 223
                    Mileage: 64026 km
                    Date: 2024.08.15
                    Time: 08:51:02
   Component: HRE_Master    H12 0080
   Serial number: 0471466022 Dataset Number: V03935258DF 0001
   Coding: 00000000
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0080
   Serial number: 0471515917
266752 - Control module not coded
          U1013 00 [00001001] - -
          [Control unit - not coded]
267520 - invalid data record
          B2005 00 [00001001] - -
          [Control Unit - Invailed dataset]
267776 - Data Set Implausible
          B2012 00 [00001000] - -
          [Control Unit - Implausible dataset]
   Serial number: 230218EBM14789 Dataset Number: V03935273TN 0001
   Coding: 003F1220D201048000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D49700CB1E2D22021-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019546463
   Coding: 0D0000
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: V03935278PA 0001
   Coding: 91170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B24EFE0B3EE55E24A1-806E
24320 - Steering
          C10AC 07 [00001001] - Mechanical Failure
          [Belastungsz hler hat 99%  berschritten Belastungsz hler hat 100% erreicht]
                    Reset counter: 144
                    Mileage: 42546 km
                    Date: 2021.07.16
                    Time: 15:03:12
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.25 V
                    Temperature: 40.0  C
                    KFC: 5F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 14.44 V
                    uAdSensI_SwitchedKl30_xdu16: 14.41 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01VU31 Dataset Number: V03935259RT 0001
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI_VW37.rod
   VCID: 2E02D6B4709CB04AFDF-807A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 28021810800518 Dataset Number: V03935262LP 0001
   Coding: 000000050100165606204F01020000000000000000000000000000000000
   VCID: 72BA02C4A424D4AA597-8026
66824 - Databus
          [LCM_DKL_L_defekt_Fehler received error value]
                    Reset counter: 199
                    Mileage: 64108 km
                    Date: 2024.08.17
                    Time: 17:56:28
   Serial number: 040218EB340748 Dataset Number: V03935273TS 0001
   Coding: 003F1020DE01048000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 42DA9204D404242A097-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019789724
   Coding: 150000
   Part No SW: 5NA 035 045 B    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1161
   Serial number: A849B0JS021165 Dataset Number: V03935273RD 0001
   Coding: 027310080000000051510002000808001F0107F601200402DF
   VCID: 372CF3D08FC67182AE9-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H51 9130
   Serial number: VWZ6ZJV0515305
   Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Compact disc data bank:
   Component: Gracenote2  --- 4012
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 126
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:53:17
                    Voltage terminal 30: 15.0 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 13021812K10073 Dataset Number: V03935273UR 0001
   Coding: 0003070000000101000223548150A90088000E300040
1122649 - Databus
          [Timeout_SWA_01]
                    Reset counter: 184
                    Mileage: 61395 km
                    Date: 2024.04.16
                    Time: 07:53:01
                    Control Module temperature: 13  C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    Voltage terminal 15: 11.2 V
                    mid: 02 0B
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 180216203107
   VCID: 2F3CCBB07796B942F69-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 3928F5E8B9D267F258D-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
0832 - Static Cornering Light
          C119A F6 [00101000] - Over-Temp Protection Active
                    Reset counter: 0
                    Mileage: 42013 km
                    Date: 2021.05.16
                    Time: 05:58:25
End----------(Elapsed Time: 02:20, VBatt start/end: 12.0V/12.0V)-----------
