Resolved Need help with P0405 fault
Resolved
tango54464
Sharpsburg, GA, USA
C?ID=592492
Hello everyone :
I'm in need of some help with a p0405 fault . My car is a 2012 Audi A3 tdi with a 2.0 cbea engine. I removed and cleaned the High pressure
EGR G212/N18 valve . erased the fault code , performed a reset and adaptation . drove approximately 30 mi. car sat all day , started it
and fault returned. Replaced valve with a salvaged valve from a 2012 VW Jetta TDI wagon . performed everything again . fault returned.
Reinstalled original valve no help fault returned . this past Thursday 09/12/2024 removed original valve , found and cleaned three different
ground points ( two on frame rail by left headlight and one in left plenum ) I had .3 ohms from pin 3 on G212 connector to ground .
reinstalled salvaged valve and performed a reset and adaptation of both the high pressure and low pressure valves , went for a 100 mi.
drive no issues . started car this morning fault returned . I hope someone can point me in the right direction . Also is sensor 1 the high pressure or low
pressure valve .
Saturday,14,September,2024,07:56:13:34579
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WAUBJAFM8CA095943   License Plate:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
          77
VIN: WAUBJAFM8CA095943   Mileage: 217390km-135079miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number: AUX7Z0KNFNS08E
   Coding: 0050078
   Shop #: WSC 37874 005 1048576
   VCID: 2C06DD3F8A03465AD3B-8078
   VINID: 9D195269159D2134402452440C26F5275C
001029 - EGR Sensor 1
               P0405 - 000 - Signal too Low - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 62
                    Mileage: 217206 km
                    Date: 2024.09.13
                    Time: 07:22:05
                    RPM: 1081 /min
                    Speed: 5.0 km/h
                    Voltage: 14.14 V
                    Lambda: 92.3 %
                    Lambda: 0.8 %
                    Voltage: 0.000 V
                    Bin. Bits: 00010000
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9432
   Revision: 05551213    Serial number: 00001111100284
   Shop #: WSC 06314 000 00000
   VCID: 26122F1794EF7C0A05F-8072
   Revision: 00H31001
   Coding: 1150400F492B00FF881402E8921C0042BF0C00
   VCID: 7BA42E6333ED11E20A1-802E
                    Reset counter: 123
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:09
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 50688
                    Count: 252
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000758      Serial number: 8P0820043BN
   VCID: 79A8346B35D123F218D-802C
   Part No SW: 8P0 907 063 Q    HW: 8P0 907 063 Q
   Component: BCM PQ35  M   110 0719
   Revision: AJ110667
   Coding: 6E000A0FA01336E4287241E00000054D401A60AA104DC128E40008800040
   Shop #: WSC 32005 003 1048576
   VCID: 42DA93871487A02A097-8016
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:40:45
                        Term 15 Off
                    Voltage: 14.30 V
                        Term 50 Off
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0604808
   Coding: 0000100
   VCID: 3632FF57444F0C8AB5F-8062
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:19
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003FC001LNTI Dataset Number: 8P0909602N  0004
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 50FEA9CFCA6B42BA8F3-8004
   Subsystem 1 - Part No SW: 8P0 959 339 E    HW: 8P0 959 339 E
   Component: BF-Gewichtss.  H04 0040
   Serial number: 5850000R11A26012HC
   Serial number: 3572DRB40000E31CA28-
   Serial number: 3582DRB40000E32928F/
   Serial number: 35128RB40000671EFD4Z
   Serial number: 35228RB40000671E18AN
   Serial number: 35547RB4000067B57C2U
   Serial number: 35647RB4000067B55E0T
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014042
   VCID: 46D28F9734AF9C0A25F-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 983 D    HW: 8P0 920 983 D
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 224NK002002621
   Coding: 0272288
   Shop #: WSC 42507 002 1048576
   VCID: 3B24EE637F6DD1E24A1-806E
00003 - Control Module
                    Fault Status: 01100101
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:08
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 231111F1001569
   Coding: 352102
   VCID: 3A2AEB677C57E8EA517-806E
   Revision: D0H02002    Serial number: AUX7Z0KNFNS08E
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001205
   VCID: 49C884AB25B17372C8D-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 232    3305
   Revision: 00H22000
   Shop #: WSC 01814 444 28888
   VCID: 372CF2534345F582AE9-8062
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158124255897
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001205
   VCID: 4ACABBA720B7786AC17-801E
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H05 0293
   Revision: 00H05000    Serial number: AUZ1Z3L2601481
   Coding: 0750112
   VCID: 73B4064317BD59A2521-8026
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001168
   Shop #: WSC 06314 000 1012544
   VCID: 42DA93871887A02A097-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001168
   VCID: 43D49683079DA922021-8016
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005160593
   Coding: 0001277
End----------(Elapsed Time: 01:34, VBatt start/end: 14.2V/14.1V)-----------
Dr Sheldon
Windsor UK
C?ID=334979
pressure valve .
Easiest way is to unplug one and get the Info from the Open Circuit DTC - or look on ERWIN !!
You have mentioned replacing "Valves" about a million times yet the DTC says "SENSOR" SIGNAL TOO LOW"
What is wrong ? Do you not like that Description of the DTC ?? -
Shall we raise a petition for Audi to re write it ?? Be easier to read it as is and adhere to it !!
My point being : Look and absorb the meaning behind the text of the DTC, it is often logical and correct before charging in blindfold !!
tango54464
Sharpsburg, GA, USA
C?ID=592492
thanks for the reply Sheldon , I understand the sensor signal is too low . that is why i swapped the egr valves
. the the egr has a built in potentiometer in the cap of it. 5v is going to the motor of it to open and close the
valve. i was hope for some sort of guidance .
Dr Sheldon
Windsor UK
C?ID=334979
Looking at the WD you do indeed have 2 EGR's - Both work in a similar way - Both have 5 wires - Two thicker and 2 Thinner wires - 1.0mm and 0.5mm to be precise in your car.
There are 2 parts to that EGR Valve
  1. The Motor.
    That will be run by the 2 Thicker Wires - Wired Direct to ECU -
    As a rule Ignition on one wire will be at Battery Voltage - The other will Provide a PWM signal - You cannot measure PWM on a simple Voltmeter.
    The job of the Motor is to open the Valve - the reason behind the PWM is so that it can open it a little or a lot and anything in between.
    Often it is pushed opened against a spring so by lowering the PWM signal and using the spring to close it is the theory !
  2. The Sensor - It is a Position Sensor
    That is a 3 wire affair
    1. 5v power to the Sensor
    2. Earth to the sensor
    3. Signal from the sensor - That will tell the ECU what exact position the Valve is in.
(So 5v is not operating the Motor in that EGR - It could not !! 5V could not light up a small bulb in your car)
If you are certain that 5v and Earth are consistent at the sensor then the signal wire should read somewhere about 0.5v and 4.5v depending on the Valve Position - Out side of those voltages .5 & 4.5 is DTC Territory.
When you Switch the Ignition on many ECU's will command the Valve(s) fully Open and Closed looking at the sensor response as a plausibility check.
However your DTC is set at :
RPM: 1081 /min
Speed: 5.0 km/h
Voltage: 0.000 V
I wonder what that 0.000v refers to ?
You now would want to operate that EGR through its complete range of motion and monitor sensor feedback voltage looking for glitches.
I am sure there will be an OUTPUT Test for both EGR's in VCDS and quite likely you can look at the Feedback Voltage as the Valve is operated. You may catch it that way but not always - The Valve is shot open and closed Fast - So fast that you can miss a glitch !! That is a reason behind thousands of Mis Diagnosed Faults - That is not common to VCDS or Audi - They all do it that way !!
So go explore Output tests in VCDS and what feedback data from the sensor can be displayed.
( @Uwe - is it possible in VCDS to run an OUTPUT test and Graph the MVB ??)
Hopefully that sorts your conundrum !!
If not then post again and we shall dig deeper - Get a bit more Geeky !!
tango54464
Sharpsburg, GA, USA
C?ID=592492
  1. The Motor.
ok thank you sheldon . i will try that tomorrow . i might pull the valve again and back probe the pins while running the ouput
test to see if i am getting signal voltage back to ecu. thanks again .
tango54464
Sharpsburg, GA, USA
C?ID=592492
So disassemble my original valve , and with help from coworkers we were able to bench test it . We seperated the potentiometer from the
Motor . Pin 1 is 5v in , pin 3 is ground and pin 5 is signal voltage out . Pins 2 and 6 are to the motor. We were able to tape 4 aaa batteries together
For 5.87 volts supply . Used jumpers on pins 1 & 3 then had a fluke meter between pins 3 & 5 while manually turning the potentiometer was able
To vary the voltage 0v to 5v supply . Reassembled everything supplied a seperate 5v power suppy to the motor to open the valve. While actuating the motor
And 5v supply to the potentiometer got zero volt output on pin 5 . I'm thinking when it is assembled it is'nt making good contact internally.
Needless to say i will be buying a new valve . Sorry for the winded explanation .
tango54464
Sharpsburg, GA, USA
C?ID=592492
Friday,27,September,2024,11:49:12:34579
          77
VIN: WAUBJAFM8CA095943   Mileage: 218240km-135608miles
   Coding: 0050078
                    Fault Frequency: 44
                    Mileage: 218234 km
                    Date: 2024.09.27
                    Time: 11:28:23
                    RPM: 1265 /min
                    Speed: 9.0 km/h
                    Voltage: 14.06 V
                    Lambda: 84.4 %
                    Lambda: -0.8 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 1
   Revision: 00H31001
                    Reset counter: 142
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:09
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 50688
                    Count: 252
   Revision: AJ110667
   Coding: 00DD13
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:40:45
                        Term 15 Off
                    Voltage: 14.30 V
                        Term 50 Off
                    Reset counter: 142
                    Mileage: 218234 km
                    Date: 2024.09.27
                    Time: 00:00:02
                        Term 15 Off
                    Voltage: 17.75 V
                        Term 50 Off
   Coding: 0000100
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:19
   Coding: 0014042
   Coding: 0272288
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:08
   Coding: 352102
   Coding: 0001205
   Revision: 00H22000
   Coding: 0001205
   Coding: 0750112
   Coding: 0001168
   Coding: 0001168
   Coding: 0001277
End----------(Elapsed Time: 01:36, VBatt start/end: 14.1V/14.1V)-----------
just installed a new EGR valve from an Audi dealer . I cleared the fault , reset the valve and performed the adaptations
Before I installed the valve i hooked up my meter , turned the koeo and had 5v to the valve assumed all was good and installed
the valve . does anyone have any ideas as to where to from here ?
Dr Sheldon
Windsor UK
C?ID=334979
Yes
Believe your initial Diagnosis to such a level that will conclude that the replacement is faulty !! Is Possble
Or doubt you diagnosis and do it properly this time !
That is EXACTLY how I do it !
tango54464
Sharpsburg, GA, USA
C?ID=592492
So the egr valve is new from the stealership , so do you have any real suggestions . Due to the way it is installed i am not
Able to back probe pins 3 and 5 to see output voltage and at this time i was not able to gain access to the ECM in order
To probe it for reference voltage and ground . On pin 3 I have .3 ohms to chassis ground so i don't have a open for the ground.
Dr Sheldon
Windsor UK
C?ID=334979
Ok sheldon do you have any real suggestions
Indeed I do !!
Saturday night here - Long Week - tired - whiskey -chill
Will respond at some point Sunday !!
tango54464
Sharpsburg, GA, USA
C?ID=592492
update to p0405
Thursday,10,October,2024,18:55:48:34579
          77
VIN: WAUBJAFM8CA095943   Mileage: 218630km-135850miles
   Coding: 0050078
   VCID: 2C06DD3F8A03465AD33-8078
000403 - Fuel Pressure Sensor (G247)
               P0193 - 000 - Short to Plus - MIL ON
                    Fault Status: 11100000
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:14:57
                    Voltage: 12.24 V
                    Inj. Quantity: 0.0 mg/str
                    Temperature: 34.2 C
                    Temperature: 27.0 C
                    Temperature: 24.3 C
009572 - Turbocharger Boost Control Position Sensor Circuit
               P2564 - 000 - Signal too Low - MIL ON
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:14:57
                    Voltage: 12.24 V
                    Temperature: 30.0 C
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 0.000 V
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:14:57
                    Voltage: 12.24 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
001158 - Exhaust Gas Recirculation Sensor 2
               P0486 - 001 - Electrical Malfunction
                    Fault Status: 01100001
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:14:57
                    Voltage: 12.24 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
001592 - Throttle Body Actuator Bank 1 (J338)
               P0638 - 000 - Implausible Signal - MIL ON
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:18:26
                    Voltage: 12.24 V
                    Lambda: 99.4 %
                    Bin. Bits: 00000000
Readiness: 0 0 0 1 1
   VCID: 26122F1794EF7C0A057-8072
   Revision: 00H31001
   VCID: 7BA42E6333ED11E20A9-802E
                    Reset counter: 113
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:09
                    Count: 2
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 50688
                    Count: 252
   VCID: 79A8346B35D123F2185-802C
                    Fault Status: 01101000
                    Reset counter: 113
                    Mileage: 218634 km
                    Date: 2024.10.06
                    Time: 00:05:09
   Revision: AJ110667
   VCID: 42DA93871487A02A09F-8016
   Coding: 00DD13
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:40:45
                        Term 15 Off
                    Voltage: 14.30 V
                        Term 50 Off
                    Reset counter: 142
                    Mileage: 218234 km
                    Date: 2024.09.27
                    Time: 00:00:02
                        Term 15 Off
                    Voltage: 17.75 V
                        Term 50 Off
   Coding: 0000100
   VCID: 3632FF57444F0C8AB57-8062
                    Reset counter: 83
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:19
   Component: Airbag AU1042 H09 Airbag AU1042 H09 02500250
   ROD: N/A
   VCID: 50FEA9CFCA6B42BA8FB-8004
   Subsystem 2 - Serial number: 3572DRB40000E31CA28-
   Subsystem 3 - Serial number: 3582DRB40000E32928F/
   Subsystem 4 - Serial number: 35128RB40000671EFD4Z
   Coding: 0014042
   VCID: 46D28F9734AF9C0A257-8012
   Coding: 0272288
   VCID: 3B24EE637F6DD1E24A9-806E
                    Mileage: 217206 km
                    Date: 2024.09.12
                    Time: 00:25:08
   Coding: 352102
   VCID: 3A2AEB677C57E8EA51F-806E
   Coding: 0001205
   VCID: 49C884AB25B17372C85-801C
   Revision: 00H22000
   VCID: 372CF2534345F582AE1-8062
            000 - - - MIL ON
                    Battery Volts: 12.4 V
                        PD
                    Temperature: 25.0 C
                    Count: 2
                    Steering Angle: 0.00
                    Count: 1
                        SteerAng n.Init
   Coding: 0001205
   VCID: 4ACABBA720B7786AC1F-801E
00936 - Electric Window Switch in Front Passenger Door (E107).
   Coding: 0750112
   VCID: 73B4064317BD59A2529-8026
   Coding: 0001168
   VCID: 42DA93871887A02A09F-8016
   Coding: 0001168
   VCID: 43D49683079DA922029-8016
   Coding: 0001277
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.2V)-----------
so I found a broken wire for the egr valve ( the 5v signal wire going back to the ecm ).
put car back together and car ran fine for a day , next morning got a flashing glow plug light .
got a p0638 fault for the throttle module . found another bad wire going to a coolant temp sensor.
checked continuity on the two wires from the temp sensor to the T14 connecter , had .2 ohms on
both wires pins 13 and 11. checked continuity on the for pins from the throttle module j338 to
the T14 connecter and had good continuity of .2 ohms . put car back together , now have the 5
fault codes listed adove and a no start condition . while cranking got an alert on the instrument
cluster stating stop engine low oil pressure .
Does anyone have any suggestions .
Where both of these broken wires in the same area/spot?? If so, it sounds like you found a area that may have been pinched or damaged by a accident (?) or corrosion ; open up that a area of the harness (?) and look for more damage. Any evidence or history of water damage/ingress or accident damage (severed harness) other???
A 2012 MY is quite new for broken wires , any history?
Sounds like you are pretty handy with the DVOM meter.... consider connecting the "load pro" (forum recommended) from Amazon to your meter ; it is a safe way to verify continuity (with some load or current flowing through the individual wire. It is easy to be fooled without loading the wire with some current.
tango54464
Sharpsburg, GA, USA
C?ID=592492
Thanks for the reply Stefdds . The broken wires were about 5" apart . I think i have probably disturbed the oil pressure switch in the
Process of messing with the harness . I can't open up the harness any further due access . It is to the point that I think I just need
To replace it .
tango54464
Sharpsburg, GA, USA
C?ID=592492
Update to p0405 fault . I'll try to be brief . I had a no start condition which turned out to be another broke wire to the cam position sensor , i repaired it , all
Continuity checks were good . Then got a new fault for the crank position sensor along with the original p0405 , p0193 , p0638 . So $3000.00 later had the
local audi stealership replace the engine harness and crank position sensor. Parts were about $570 and 13hrs labor @ $190 an hr.
Glad to hear you were able to sort it out; congratulations! Pricey, but you won't be sorry.
Would like to see some pictures and a fresh Auto-Scan when you get a chance!
