Volkswagen Passat B6 ABS
adwar
Poland
C?ID=381462
Hi, I've got problem with Passat B6, ABS light is on, coding error. Car originally was with Automatic transmision, someone has changed to manual. TCU is uncoded in Gateway...
Friday,13,September,2024,13:53:56:21580
VCDS Version: 24.7.0.0 (x64)  HEX-NET CB: 0.4643.4
Dealer/Shop Name:
VIN: WVWZZZ3CZ7E060170   License Plate:
Mileage: 278060km-172778mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ7E060170   Mileage: 278060km-172778miles
02-Auto Trans -- Status: Not registered 0011
   Part No SW: 06F 906 056 FB    HW: 06F 906 056 EK
   Component: MED9.5.10       G00 9162
   Revision: --H03---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 6E90D56B79C349E621-803A
   VINID: 9E69EAAAA0D3A87540180047001ADF7ED4
Readiness: 1110 0001
   Part No SW: 09G 927 750 S    HW: 09G 927 750 S
   Component: AQ 250 6F           0746
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 41CA5ED718DD869E8C-8014
8 Faults Found:
00258 - Solenoid Valve 1 (N88)
01236 - Shift Selector Locking Solenoid (N110)
17104 - Transmission Output Speed Sensor (G195)
            P0720 - 012 - Circuit Malfunction - MIL ON
                    Fault Status: 10101100
                    Reset counter: 44
                    Date: 2004.01.01
17099 - Transmission Input Speed Sensor (G182)
            P0715 - 012 - Circuit Malfunction - MIL ON
                    Reset counter: 44
                    Date: 2004.01.01
00293 - Multi-function Switch (F125)
                    Fault Status: 10100100
                    Reset counter: 44
                    Date: 2004.01.01
01045 - Tiptronic Switch (F189)
                    Reset counter: 44
                    Date: 2004.01.01
00300 - Transmission Fluid Temp. Sensor (G93)
                    Reset counter: 44
                    Date: 2004.01.01
                    Fault Status: 00101101
                    Reset counter: 0
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667442264
   Coding: 0046478
   VCID: 3228011BAD7B2D0605-8066
                    Fault Status: 01101000
                    Reset counter: 220
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:37
                    Reset counter: 220
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:53:56
Address 08: Auto HVAC        Labels: 3C0-907-044.clb
   Part No SW: 3C0 907 044 AA    HW: 3C0 907 044 AA
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 608CBB53B317EF96A3-8034
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000005604310
   Coding: E08C0F0700041A00000A00000F00000000095D435C0000
   VCID: 302C0B13A3771F1673-8064
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 05311
                    Fault Status: 01101100
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
00156 - Control Circuit for Windshield Washer Pump
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 04 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2P8EHC27
   Coding: 0012340
   VCID: 2D121267B44572FE58-8078
   Subsystem 1 - Serial number: 6332MSME0E7A7D5A
   Subsystem 2 - Serial number: 6342MSME0F3E233F
   Subsystem 3 - Serial number: 6351HTS6OLLM8763
   Subsystem 4 - Serial number: 6361HTS6QLLE6PB3
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C9953507P
   Coding: 0000212
   VCID: 2E10156BB94309E661-807A
   Part No SW: 3C0 920 870 P    HW: 3C0 920 870 P
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0034000    Serial number: 00000000000000
   Coding: 0000105
   Shop #: WSC 80093 222 69422
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C0651106CC
   Coding: 3DFD0C04C22002
   Shop #: WSC 05311 123 12345
   VCID: 210AFE57F89DA69EEC-8074
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:53:55
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    IMMO         038 0367
   Revision: 00038000    Serial number: VWZCZ000000000
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2801
   Coding: 0000183
   VCID: 373E300F4619C82E32-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 3326041F5261240E0E-8066
   Component:    KSG PQ46 ELV 038 0455
   Coding: 0091020851030E763804941570084F0B603C00
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0000182
   VCID: 383C33334B07C7563B-806C
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
                    Reset counter: 5
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:34:52
                    Voltage: 14.08 V
                    Count: 224
Address 56: Radio        Labels: None
   Part No: 1k0 035 186 p
   Component: Radio GR0       015 0019
   Revision: 0001500S    Serial number: VWZ2Z2E1253870
   Coding: 0040400
   VCID: 73A6C41F12E1640ECE-8026
   Part No: 3C9 959 703
   Component: Tuer-SG         021 2507
   Coding: 0000144
   VCID: 70ACCB1363F75F1633-8024
   Part No: 3C9 959 704
   Coding: 0000144
   VCID: 71AACE1768FD561E3C-8024
End----------(Elapsed Time: 01:07, VBatt start/end: 12.4V/12.4V)-----------
adwar
Poland
C?ID=381462
Now, there is error.
Friday,13,September,2024,14:40:41:21580
Dealer/Shop Name: FHU WARCAR Jaworzno
VIN: WVWZZZ3CZ7E060170   License Plate: PASSAT
   Coding: 0000072
   Coding: 0046481
                    Reset counter: 220
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:40:38
                    Reset counter: 220
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:40:38
                    Reset counter: 220
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:40:37
   Coding: 00063445
   Shop #: WSC 05311
   Coding: 00208933
   Shop #: WSC 05311
                    Fault Status: 00101100
                    Reset counter: 6
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
01049 - Supply Voltage Term 50
                    Fault Status: 01111100
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:03:00
                    Voltage: 10.65 V
   Coding: 0012340
   Coding: 0000212
   Coding: 0000105
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:03:07
   Coding: 0000183
   Coding: 0000182
   Revision:   013
   Coding: 0000012
02442 - Function Lamp in Control Head
                    Fault Status: 00101001
                    Reset counter: 5
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:03:12
                    Voltage: 14.18 V
                    Count: 65
                    Fault Status: 11101101
                    Reset counter: 221
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:34:52
                    Voltage: 14.08 V
                    Count: 224
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:18, VBatt start/end: 12.3V/12.3V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
There is still work to be done on the coding of everything, given that the automatic has been replaced by a manual gearbox.
Of course, there is also work to be done on the electrical installation.
  • Agree
Tharkhold
Canada
C?ID=311665
Tagged for interest.
Damn now im curious.
Where does the 'automatic transmission' option appear outside in the installation list in the gateway? (hard coded in some ECUs?, ABSs, what else)
Gateway doesn't have it listed, but car is still looking for it and lists a part number along with errors.
Jef
HQ
I search our records for that part number and hit after hit, coded for automatic transmission..... past history has shown that it is possible that a car that came with an automatic transmission will have a different ECM and ABS part number over a car with a manual transmission.
0046478 = B58E = 2.0l FSI BLR/BVY/BVZ [PR-T58] & 6-Speed Manual [PR-G0K]
0046481 = B591 = 2.0l FSI BLR/BVY/BVZ [PR-T58] & 6-Speed Automatic [PR-G1A]
Coding: 0046478
I search our records for that ABS coding... this thread, here... the only example found.
Address 01: Engine
This is a rare part number, you and two other examples. The other 2 examples, manual transmissions. One example is an email and the other is a forum post.
With these 2 other examples, same ECM part number and coding. ABS part numbers and coding is different:
Part No SW: 3C0 614 095 S (forum post)
Part No SW: 3C0 614 095 P (email)
The forum post one, the ABS coding was wonky, but ended up using 0030094 (758E). And in the email, coding was 0013710 (358E).
From what I can tell, 0013710 coding would work. Will Part No SW: 3C0 614 095 S accept it?
adwar
Poland
C?ID=381462
Thanks for help. I had to give the car back to the customer, and it will coming back to me soon.
adwar
Poland
C?ID=381462
0013710 coding doesn't work...
Car came to me from another workshop I changed only ECU, old ECU has 06F906056FC, car original has automatic transmision but some change on manual and flash ECU with 06F906056FB firmware. Gateway has decoded TCU but shows error...
Monday,04,November,2024,10:01:50:21580
VCDS Version: 24.7.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WVWZZZ3CZ7E060170   License Plate: SJ-97158
Mileage: 278430km-173008mi   Repair Order:
VIN: WVWZZZ3CZ7E060170   Mileage: 278430km-173008miles
   Coding: 0000072
   VCID: 6E90D56B79C349E629-803A
004128 - Fuel Pressure Regulation
               P1020 - 001 - Control Range Exceeded - Intermittent
                    Fault Status: 00100001
                    Mileage: 278380 km
                    Date: 2024.10.04
                    Time: 10:04:53
                    RPM: 720 /min
                    Load: 29.8 %
                    Temperature: 74.0°C
005123 - EGR System
               P1403 - 008 - Regulation Deviation - Intermittent
                    Mileage: 278381 km
                    Date: 2024.10.04
                    Time: 10:43:33
                    RPM: 1080 /min
                    Load: 51.0 %
                    Speed: 7.0 km/h
                    Temperature: 87.0°C
008569 - Bank 2; System Too Lean off Idle
               P2179 - 001 -  - MIL ON
                    Fault Status: 11100001
                    Mileage: 278383 km
                    Date: 2024.10.04
                    Time: 11:25:33
                    RPM: 2240 /min
                    Load: 50.6 %
                    Speed: 52.0 km/h
                    Temperature: 73.0°C
008567 - Bank 1; System Too Lean off Idle
               P2177 - 001 -  - MIL ON
                    Mileage: 278384 km
                    Date: 2024.10.04
                    Time: 11:26:44
                    RPM: 2280 /min
                    Load: 54.1 %
                    Speed: 53.0 km/h
                    Temperature: 69.0°C
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
                    Fault Frequency: 15
                    Mileage: 278389 km
                    Date: 2024.10.09
                    Time: 09:10:32
                    RPM: 720 /min
                    Load: 29.8 %
                    Speed: 12.0 km/h
                    Temperature: 37.0°C
Readiness: 0000 0101
   Coding: 0013710
   VCID: 3228011BAD7B2D060D-8066
02543 - Vacuum Sensor for Brake Booster (G483)
                    Reset counter: 222
                    Mileage: 278438 km
                    Date: 2024.10.15
                    Time: 10:00:02
                    Reset counter: 222
                    Mileage: 278438 km
                    Date: 2024.10.15
                    Time: 09:59:57
                    Reset counter: 222
                    Mileage: 278438 km
                    Date: 2024.10.15
                    Time: 09:59:57
   VCID: 608CBB53B317EF96AB-8034
                    Reset counter: 7
                    Mileage: 278154 km
                    Date: 2024.09.14
                    Time: 00:44:55
   VCID: 302C0B13A3771F167B-8064
   Coding: 00063445
   Shop #: WSC 05311
   Coding: 00208933
   Shop #: WSC 05311
                    Reset counter: 6
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
                    Reset counter: 223
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
                    Reset counter: 223
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 21:46:00
                    Voltage: 13.85 V
                    Reset counter: 223
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:03:00
                    Voltage: 10.65 V
   Coding: 0012340
   VCID: 2D121267B44572FE50-8078
   Coding: 0000212
   VCID: 2E10156BB94309E669-807A
   Coding: 0000105
   VCID: 210AFE57F89DA69EE4-8074
                    Fault Frequency: 138
                    Reset counter: 223
                    Mileage: 278064 km
                    Date: 2024.08.26
                    Time: 22:03:07
   Coding: 0000183
   VCID: 373E300F4619C82E3A-8062
00100 - Drivers Interior Locking Button (E308)
   VCID: 3326041F5261240E06-8066
00896 - Trunk Lock Unit (F256)
                    Reset counter: 222
                    Mileage: 278085 km
                    Date: 2024.09.01
                    Time: 20:24:30
   Coding: 0000182
   VCID: 383C33334B07C75633-806C
   Revision:   013
   Coding: 0000012
                    Reset counter: 7
                    Mileage: 278432 km
                    Date: 2024.10.15
                    Time: 09:58:46
                    Voltage: 14.08 V
                    Count: 236
                    Reset counter: 7
                    Mileage: 278360 km
                    Date: 2024.09.28
                    Time: 11:22:18
                    Voltage: 11.70 V
                    Count: 65
02430 - Left Parking Brake Motor (V282) Resistance to Movement
                    Fault Status: 00110011
                    Reset counter: 7
                    Voltage: 13.46 V
                    Count: 18
                    Reset counter: 7
                    Mileage: 278376 km
                    Date: 2024.10.04
                    Time: 10:29:16
                    Voltage: 11.90 V
                    Count: 224
   Coding: 0040400
   VCID: 73A6C41F12E1640EC6-8026
   Coding: 0000144
   VCID: 70ACCB1363F75F163B-8024
   Coding: 0000144
   VCID: 71AACE1768FD561E34-8024
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.0V)-----------
EDIT: when ECU is disconnect there isn't errors in ABS so probably the problem is wrong ECU.
