- Aug 10, 2016
- 4,034
- 4,445
- Netherlands, Operation Market Garden
- C?ID=284912
Hey guys, wondering if you could help me out on some coding stuff.
I'm going from a 5Q0 46-byte ABS ECU to a 47-byte ABS ECU. I'm doing some tests to get the coding right.
Why? Well because I can and I think I need it for my drift diff: https://forums.ross-tech.com/index.php?threads/40192/
Passat with 47-byte coding: https://forums.ross-tech.com/index.php?threads/27278/
When you go from 46 to 47, I think it needs:
- two zeroes after byte 32
- byte 30 is slightly different, most seen: 4A
- perhaps change byte 26 from 50 to 55 for 2022+?
So I had some codes tried out:
0FEC6B8F5420236D477C070440CC69F0D62AC4E2E00296753842508842A949000000000012121212B835351919323200 rejected
0FEC6B8F5420236D477C070440CC69F0D62AC4E2E00296753842508842A84A080000010312121212B435351919323200 rejected
0FEC6B8F5420236D477C070440CC69F0D62AC4E2E00296753842558842A84A080000010312121212B435351919323200 rejected
Factory ABS:
current SW:
Target ECU:
full scan:
Yes my engine is in surgery mode
0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200 Factory coding
0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200 Current coding
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 coding to be
Factory ABS:
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
Shop #: WSC 00015 115 00001
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 79AF10A5095BB703ACC-802D
current SW:
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 FM HW: 5Q0 614 517 AH
Component: ESC H62 0755
Shop #: WSC 30389 123 56831
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 015F7845618BEFC258D-8055
Target ECU:
Part No SW: 5Q0 614 517 EH HW: 5Q0 614 517 BR
Component: ESC H82 0107
Revision: 00000000 Serial number: 60499000000723 Dataset Number: 8V0909504AD 0065
Coding: 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_038_VW48.rod
VCID: 7BA30AAD036785120A1-802F
full scan:
Friday,13,September,2024,12:39:50:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3CZJEx25658 License Plate:
Mileage: 194819km-121054mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42
44 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7
VIN: WVWZZZ3CZJEx25658 Mileage: 194819km-121054miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: B7DB7878
Coding: 091D003A2476050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259J.rod
VCID: 313FE88591ABBF42E0D-8065
VINID: 9E69EAAAA0D3A9A54008518520274044B7
19 Faults Found:
20646 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 00 [00100111] - Malfunction / Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:10
Engine RPM: 0.00 /min
Coolant temperature: 13 °C
Intake air temperature: 17 °C
Voltage terminal 30: 11.171 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 102 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
TTIP_MES_LS_UP[1]: -2048.0000 °C
TEG_DYN_LS_UP[1]: 13.4750 °C
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [00100111] - Signal too High
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:12
T_AST_SAE: 0 s
FAC_TPS_1_SAE: 16.406250 %
FUP_H_SAE: 2960.0 kPa
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [00100111] - Implausible Signal
Mileage: 194819 km
Date: 2024.09.13
Time: 12:31:29
Voltage terminal 30: 11.074 V
T_AST_SAE: 0 s
FUP_H_SAE: 2990.0 kPa
15376 - Fuel Pressure Regulator Valve (N276)
P2294 00 [10100111] - Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
ECU_STATE: ENG_STOP
High-pressure system: status: VCV_OPEN
STATE_CRK_STST: CRK_STST_PAS
TFPA: 11 °C
TFU_HPP: 9.00 °C
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [10100111] - Implausible Signal
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:54
Voltage terminal 30: 11.230 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor: 4.9902 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 0.00 %
Charge air pressure control valve activation pulse duty factor: -18.25 %
Charge air pressure control valve voltage: position closed: 4.3604 V
STATE_BPA[0]: AD
19875 - No Communication with ABS Brake Control Module
U0121 00 [10100111] - -
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
TEMP_CAT_UP_1_SAE: 13.5 °C
T_ES: 2880 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
15015 - Turbocharger Bypass Valve Control Circuit
P0033 00 [00100111] - Malfunction / Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
T_AST_SAE: 0 s
21266 - Implausible Data Received from ABS Control Module
U0415 00 [00100111] - -
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
Voltage terminal 30: 11.152 V
T_ES: 2880 min
15270 - Camshaft Timing Adj. Bank1 (N205)
P1528 00 [00100111] - Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
T_AST_SAE: 0 s
FUP_H_SAE: 2970.0 kPa
15267 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
P1050 00 [00100111] - Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
T_AST_SAE: 0 s
15381 - Cam Adjustment Actuator A; Cylinder 1
P11A1 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CAM_VCP[EX_1]: 0.000 °
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
T_SWI_VVL_ACR: 0.0 ms
NR_CYL_FIRST_VVL_SWI: 0
15383 - Cam Adjustment Actuator A; Cylinder 3
P11A9 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15384 - Cam Adjustment Actuator A; Cylinder 4
P11AD 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15382 - Cam Adjustment Actuator A; Cylinder 2
P11A5 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15401 - Cam Adjustment Actuator B; Cylinder 1
P11A3 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15403 - Cam Adjustment Actuator B; Cylinder 3
P11AB 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15404 - Cam Adjustment Actuator B; Cylinder 4
P11AF 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15402 - Cam Adjustment Actuator B; Cylinder 2
P11A7 00 [00100111] - Elec. Malf. or Open Circuit
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
CTR_VVL_LIH_DEAC: 0
CTR_VVL_LIH_ACT: 0
CTR_VVL_SWI_DC: 0
15423 - Turbocharger Boost Control Position Sensor Circuit
P2565 00 [10100111] - Signal too High
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve activation pulse duty factor: 0.00 %
STATE_BPA[0]: OPM
Readiness: 1110 0000
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5297
Revision: 06454104 Serial number: TFK01706160335 CVN: 000099EF
Shop #: WSC 05311 115 00065
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222AA3B-8049
P1734 00 [00000010] - -
21221 - No Communications with Parking Brake Control Module
U0128 00 [00001011] - -
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
16 Faults Found:
0107 - ABS Hydraulic / Return Flow Pump
C1077 01 [10001001] - Electrical Failure
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:17
0195 - Control module not coded
U1013 00 [10001001] - -
[ECU marked as Not Configured because vehicle ID is invalid]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
C1017 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
C1079 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
0279 - Brake Pressure Sensor 1
C107A 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
0283 - Brake Pressure Sensor 1
C107A 01 [10001001] - Electrical Failure
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
0295 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
0398 - Control Module Incorrectly Coded
U1014 00 [10001001] - -
[Vehicle equipped with vacuum sensor but no vacuum sensor coded]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
8279 - Engine Control Module Incorrectly Coded
P1612 00 [10001001] - -
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
8280 - Engine Control Module Incorrectly Coded
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
8286 - Databus
U1123 00 [10001001] - Received Error Message
[FCAN: MO_Timeout_ESP signal is invalid]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
8292 - Control Module Incorrectly Coded
[FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
8306 - Databus
U1122 00 [10001001] - Implausible Message
[FCAN: Unplausible VIN number]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:12
8311 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[FCAN: Damper not coded but Fahrwerk_01 message received]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [00001001] - -
[FCAN: Coding of ESP and TSK does not fit together]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
32848 - Control Module for Electric Parking Brake
C10E2 F1 [10001001] - Switches/Motors Detected
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0577965047 Dataset Number: V03935321YJ 0001
Coding: 1F20200723
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48C9A56102311E8AD73-801D
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8001216
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 B
Component: Sitzmemory H05 0024
Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
Coding: 001000020000050081C481808080000000008181000000F400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3C21C9B146E9422A43B-8069
Part No SW: 3G8 907 044 T HW: 3G8 907 044 T
Component: Climatronic H10 0221
Coding: 12020024104411011115500D0018592A
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 3E25C3B950F5503A6DF-806B
Air quality sensor:
Humidity sensor: exterior:
Subsystem 3 - Part No SW: 11A 907 049 A HW: 11A 907 049 A
Component: E265 KPH SH H02 0183
Serial number: G04S01.11.2100972191
Coding: FFFFFF
655621 - Temperature Sensor for Rear Left Seat
B1113 15 [00101111] - Open or Short to Plus
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Control Module Voltage: 11.000 V
655623 - Temperature Sensor for Rear Right Seat
B1114 15 [00101111] - Open or Short to Plus
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
B10CD 00 [00101111] - -
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
CAN input signal(s) status-Back-up lamp: OFF
Blower reduction: No switch-off: no reduction
Part No SW: 5Q1 937 084 B HW: 5Q1 937 084 B
Component: BCM MQBAB HO H44 0512
Serial number: 02102311001826 Dataset Number: V03935381P 0001
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW37.rod
VCID: 3829D5A172D16E0AA73-806D
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0F4DFD
Serial number: 22181601X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 3G8 941 633 HW: 3G8 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 19 04 2017 10000901
Subsystem 4 - Part No SW: 5Q0 951 172 A HW: 5Q0 951 172 B
Component: Sensor, DWA 005 0403
Serial number: 000000000ZL23010051V
Serial number: 00000000000070188699
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0158736
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0096892
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0145994
Subsystem 9 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0146336
Part No SW: 5QA 919 298 L HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0074
Serial number: 000308417617172 Dataset Number: V03935315EN 0001
Coding: 8A79267951
ASAM Dataset: EV_EPHVA2CAU3700000 009055
VCID: 59EF7025A99B970278D-800D
12658704 - Databus
[Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
13637420 - Databus
[Bremsensteuergerät - ESP_05.ESP_Bremsdruck - Fehlerspeicher auslesen]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
13637426 - Databus
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Dataset Number: V12345678AA V315
Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW41.rod
VCID: 47CBA65D0F2F11F2DE9-8013
10 Faults Found:
2056 - Databus
[FAULT_BPRESSURE_FAIL]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
Control Module temperature: 43 °C
Voltage terminal 15-Voltage: 11.0 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
0828 - Databus
[FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
0822 - Databus
[FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
1054 - Databus
[FAULT_TIMEOUT_EPB_01]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:35:17
Control Module temperature: 42 °C
Voltage terminal 15-Voltage: 11.2 V
1140 - Databus
[FAULT_TIMEOUT_VZE_01]
Reset counter: 250
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
2126 - Databus
[FAULT_TSK_ROAD_SLOPE_FAIL]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:10
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 25061741350001 Dataset Number: V03935290WM 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD0A549DB770258D-806D
336909 - Databus
[Bremsensignale - Fehlerspeicher auslesen]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Part No SW: 3Q0 959 655 CP HW: 3Q0 959 655 CP
Component: Airbag VW21 006 0721
Revision: -------- Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
Coding: 98FCC0C0008000005C5400CF000800000065
VCID: 0E45537920D580BADDF-805B
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Serial number: 3G1857706G0185R01460
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Serial number: 357000000000507D3628
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Serial number: 358000000008D140C62J
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Serial number: 3510091305210000000U
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Serial number: 352002F2F52100000009
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Serial number: 3550040279610000000%
7 Faults Found:
10487296 - Control Module Does Not Match Vehicle
B2006 00 [10001000] - -
[ECU does not fit to vehicle configuration]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
1049093 - Databus
[NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
1049094 - Databus
[NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
1049095 - Databus
[NWD: 0x101 ESP_02 error value ESP_Gierrate]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
1052421 - Databus
[NWD: 0x106 ESP_05 error value ESP_Bremsdruck]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:09
9466624 - Crash Signal
B1073 00 [10001000] - -
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
B13BC F2 [10001001] - No function
Mileage: 194819 km
Date: 2024.09.13
Time: 12:31:10
Part No SW: 5Q0 953 521 KT HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0265
Revision: FF035035 Serial number: 20170828500092 Dataset Number: V03935250KY 0001
Coding: 8410
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
Part No SW: 3G0 920 791 D HW: 3G0 920 791 C
Component: KOMBI 406 4191
Coding: 07AD0898FE8C000C01887F0F3001000080000000
Shop #: WSC 00046 000 00000
VCID: 2A0DFFE9BC7DCC9A217-807F
16776967 - Databus
[EPB_02 keine Kommunikation]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 H
Component: STH-MQB 008 0080
Coding: 9309
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 C
Component: GW MQB High 518 5502
Serial number: 06071710802132 Dataset Number: V03935278KN 0001
Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
Shop #: WSC 00046 123 12345
GVL: 01DE3C0008000600C0FC80000006CC0010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 7F5BFEBD177F9932269-802B
Generator:
Component: 4-00-03-00-04
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218123222100161
Coding: 2D0B00
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
66304 - Databus
U1124 00 [00001000] - Additional Installations Detected
[Mehrverbau CAN]
Reset counter: 250
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Terminal 30 power supply: 11.0 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [00001001] - Warning Triggered
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
Coding: 0601
VCID: 4CC199711649F2AAF3B-8019
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BF2885512BFF42A0D-8025
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
Coding: 001000020000150081C481808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000591782366 Dataset Number: V03935345YL 0001
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000606636104
2240558 - Databus
[databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:08
2240515 - Databus
[databus error value received - ESP_02 - ESP_QBit_Gierrate]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
Coding: 00359A20D200028200011000
VCID: 4ACD9F691C3DEC9AC17-801F
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5082
Dataset Number: 8V0909852AA 0001
Coding: 93070000
Shop #: WSC 00015 115 00319
ROD: EV_SteerAssisMQB_015.rod
19204 - Databus
[ESP_02 Botschaft - SNA_Check]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Motor status: 00
Supply voltage: 11.00 V
Temperature: 25.0 °C
KFC: 4B
KFA: 00 04
Freeze frame conditions: 7F
uioUdNotFilt_xdu16: 11.08 V
uAdSensI_SwitchedKl30_xdu16: 11.04 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
19460 - Databus
[ESP_05 Botschaft - SNA-Check]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Motor status: 00
KFC: 4C
KFA: 00 04
uioUdNotFilt_xdu16: 11.05 V
uAdSensI_SwitchedKl30_xdu16: 10.99 V
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233 Dataset Number: V03935339UR 0001
Coding: 000000060100035207007F010A0000000000000000000000000000000000
VCID: 72BD2789542DC45A597-8027
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
13706046 - Databus
[LV_Abblendlicht_li_def received error value]
Reset counter: 250
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
13706047 - Databus
[LV_Abblendlicht_re_def received error value]
Reset counter: 250
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:05
13705999 - Databus
[Kamera_FDD_Funktionsstatus_Fehler received error status]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:36
13706000 - Databus
[Kamera_FDD_Eigenblend_Guete received error status]
Reset counter: 210
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
Coding: 00359020DE00028200011000
VCID: 49CFA065193BE782C8D-801D
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_006_VW37.rod
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174 Dataset Number: V03935259HF 0001
Coding: 0100000202000000
VCID: 42DDB749240D34DA097-8017
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG069231 Dataset Number: ----------
Coding: 01840200E70F200004314817
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0265
Revision: -------- Serial number: 31344982200000 Dataset Number: V03935262CS 0001
Coding: 02A8
ROD: EV_DeckLidCONTIAU736_VW48.rod
VCID: 46D5AB59082508FA25F-8013
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 D HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1421
Serial number: E80320003220200 Dataset Number: V03935411EY 0001
Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
VCID: 3635DB9978C5987AB5F-8063
1135140 - Databus
[APS_03_US_Fehler_HS]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
1135139 - Databus
[APS_03_US_Fehler_VS]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:07
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Mileage: 194819 km
Date: 2024.09.13
Time: 12:30:06
Part No SW: 5Q0 959 595 L HW: 8W1 959 595 D
Component: TSG HFS005 0350
Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
Coding: 000490200100028000001000
Component: TSG HBFS005 0350
Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: V03935218DJ 0001
Coding: 208040748202
VCID: 372BD69D7FCF6172AE9-8063
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16753B191805787A95F-8043
Component: LED1R H09 0003
End----(Elapsed Time: 02:37, VBatt start/end: 11.2V/11.4V. VIgn 11.4V)-----
