- Dec 5, 2014
- 3,794
- 1,023
- Windsor UK
- C?ID=334979
What I cannot understand is the CanH and CanL at the OBDII. with key off, I have 10.8v on BOTH Can wires (obviously not good) With Key ON, I get 12v on BOTH can lines. I wanted to know which side of the circuit the voltages are coming from, so I removed (de-pinned) both CanH and CanL at the OBDII and rechecked voltages on the Can wires at the OBDII. Voltages remain the same. So I re-pinned the OBDII and read voltages again with key ON and OFF and at the same time as reading voltages, I disconnected the J533, voltages go away. So I have to assume the voltages are getting on the Can wires from the J533.
Pins 6 & 14 at the DLC are connected directly to the J533 pins 9 & 19
And you cannot measure voltages on those lines
First it is a Digital Data - you will need a scope
Second, unless you got a diagnostic tool connected and communicating you wont see what a lot !!
