Really need some help, throttle body and tuning issues!
Dr Sheldon
Windsor UK
C?ID=334979
are you able to describe how to diagnose any of these problems? Only been working on cars for a year or so..
Youre an absolutely lovable rogue !! Take that as a complement !!
   #102
Dr Sheldon
Windsor UK
C?ID=334979
Yes and have done so all week as have others here
You are not listening , reading , absorbing the help
Now you are merging other forums in - Complicating !!
You are at 100mph - not possible to keep up with you !!
Answer is not for a week or so - I have been off for a bit - but back at work Monday, Dont be a stranger !
   #103
Ziddywerks
Northern NJ USA
C?ID=208579
You need to get a factory repair manual located the affected sensor and check wiring to those sensors or check for coolant ingress into those harnesses. End of story. This thread is way to long for the problem your experiencing.
   #105
lakoe
Nebraska, USA
C?ID=581491
i messaged a shop and explained every thing in a very long email, and they said they cant get me in till october 17th unfortunately, so im emailing around and hopefully i can find someone else for earlier.
   #106
B8boi
California, USA
C?ID=530730
You need to be sure the throttle body pigtail is pinned properly. I had the APR one and 034 released their file and i just had to swap the ends if 2 wires. Not redo the whole thing. Problem is, if your messed up some wiring maybe shorted a fuse or circuit in ECu.
so check the wiring pigtail against what 034 says. Throttle body could have taken a shit too, so maybe try a replacement hemi throttle body.
So if youre sure its not the pigtail and the throttle body is good. A way to diagnose is to use VCDS to log the values the ecu reads from the sensors and see where the fault may lie. Go to the 01-engine control module, and go to the basic settings menu and go to the line that states "Check throttle valve adaptation". DONT CLICK GO YET. Click show measuring data and Then you can create a log of measured values and watch what the throttle valve does during he check. Check off which values you want to log, and then click GO next to check throttle valve adapt...... Then you can go a step further and open and close the throttle body by hand and see the measured values and which sensor may be malfunctioning.
So:
1) BE SURE SURE SURE PIGTAIL IS GOOD
2) BE SURE SURE SURE THROTTLE IS GOOD
3) VCDS LOG ADAPTATION CHECK OF THROTTLE BODY
4) VCDS LOG THROTTLE BODY BEING MOVED BY HAND
Those results should help isolate which electronic component may be your issue.
Ive attached a text converted throttle body checking file from alldatadiy. it has images for placement of the connector pins but i cant easily attache those but you should be able to count the pins and follow text instruction to do the checks. Good luck. Message me direct and i can email the file if you see fit.
THROTTLE VALVE CONTROL MODULE, CHECKING
Throttle Valve Control Module, Checking
Observe all safety precautions: => [ Safety Precautions ] See: Computers and Control Systems > Technician Safety Information > Generic Scan Tool
View clean working conditions: => [ Clean Working Conditions ] See: Computers and Control Systems > Technician Safety Information > Generic Scan Tool
Use only gold-plated terminals when servicing any component with gold-plated electrical harness connector terminals.
For wiring diagrams, component locations, and connector views, Refer to the applicable wiring diagram. Special tools, testers and auxiliary items required
♦   multimeter.
♦   Wiring diagram.
Test requirements
♦   The Motronic Engine Control Module (ECM) (J623) fuses OK.
♦   Battery voltage at least 12.5 volts.
♦   All electrical consumers such as, lights and rear window defroster, switched off.
♦   Vehicles with automatic transmission, shift selector lever into position "P" or "N".
♦   A/C switched off.
♦   Ground (GND) connections between engine/transmission/chassis OK.
♦   Throttle valve must not be damaged or dirty.
♦   Coolant Temperature at least 80° C.
Function
Throttle valve operation occurs by an electric motor ( Throttle Drive (for Electronic Power Control (EPC)) (G186) ) in the Throttle Valve Control Module (J338). It is operated by the Motronic Engine Control Module (ECM) (J623) and the Throttle Position (TP) Sensor (G79) / Accelerator Pedal Position Sensor 2 (G185).
The Throttle Valve Control Module (J338) is made up of the following components:
♦    Throttle Drive (for Electronic Power Control (EPC)) (G186)
♦    Throttle Drive Angle Sensor 1 (for Electronic Power Control (EPC)) (G187)
♦    Throttle Drive Angle Sensor 2 (for Electronic Power Control (EPC)) (G188)
The Throttle Valve Control Module (J338) cannot be serviced separately and must be serviced as a unit. Test procedure
-  Perform a preliminary check to verify the customers complaint. Refer to => [ Preliminary Check ] See: Computers and Control Systems > Scan Tool Testing and Procedures > Preliminary Check
Start diagnosis
-  Connect the scan tool.
-  Switch ignition on.
-  Using the scan tool, check the throttle valve position (absolute) at idle stop:
3 to 25%
-  Slowly depress the accelerator pedal to Wide Open Throttle (WOT) stop while observing the percentage display. The percentage display must increase uniformly.
-  Using the scan tool, check the throttle valve position (absolute) at Wide Open Throttle (WOT) stop:
84 to 97%
-  End diagnosis and switch ignition off.
If the specified values are not obtained:
-  Remove the Throttle Valve Control Module (J338) far enough so that the electrical connector terminals are reached.
-  Disconnect the Throttle Valve Control Module (J338) electrical harness connector
Checking resistance
-  Using a multimeter, check the Throttle Drive (for Electronic Power Control (EPC)) (G186) at the Throttle Valve Control Module (J338) terminals 1 to 3 for resistance.
Specified value: 1.0 to 5.0 ohms (at 20° C)
If the specification was not obtained:
-  Replace the Throttle Valve Control Module (J338). Refer to appropriate service manual.
If the specification was obtained:
-  Check the voltage supply of the Throttle Valve Control Module (J338) to the Motronic Engine Control Module (ECM) (J623).
Checking voltage supply and wiring
-  Switch the ignition on.
-  Using a multimeter, check the Throttle Drive Angle Sensor 1 (for Electronic Power Control (EPC)) (G187) at the Throttle Valve Control Module (J338) electrical harness connector terminals 1 to 6 for voltage.
Specified value: at least 4.5 V
-  Switch the ignition off.
Checking wiring
If the manufacturers test box is being used, perform the following step.
-  Install the test box.
If the manufacturers test box is not being used, perform the following step.
-  Remove the Motronic Engine Control Module (ECM) (J623). Refer to appropriate service manual.
-  Using a multimeter, check the Throttle Valve Control Module (J338) at electrical harness connector terminals to the Motronic Engine Control Module (ECM) (J623) electrical harness connector T60 terminals for an open circuit according to the wiring diagram.
J338     —->MOTRONIC ECM J623 T60 TERM ECU CONNECTOR
1—--> 28       2—---> 14       3—-15          4—-13     5—---30        6—29
Specified value: 1.5 ohms max.
If the specification is not obtained:
-  Check the wiring for a short circuit to Battery (+), or an open circuit.
-  If necessary, repair the faulty wiring connection.
-  Check the electrical harness connector for damage, corrosion, loose or broken terminals. If no malfunction is detected in the wiring and if the voltage supply was not OK:
-  Replace the Motronic Engine Control Module (ECM) (J623). Refer to appropriate service manual. Final procedures
After the repair work, the following work steps must be performed in the following sequence:
1. Check the DTC memory. Refer to => [ Diagnostic Mode 03 - Read DTC Memory ] See: Computers and Control Systems > Scan Tool Testing and Procedures > Diagnostic Mode 03 - Read DTC Memory.
2. If necessary, erase the DTC memory. Refer to => [ Diagnostic Mode 04 - Erase DTC Memory ] See: Computers and Control Systems > Scan Tool Testing and Procedures > Diagnostic Mode 04 - Erase DTC Memory.
3. If the DTC memory was erased, generate readiness code. Refer to => [ Readiness Code ] See: Computers and Control Systems > Monitors, Trips, Drive Cycles and Readiness Codes > Readiness Code.
lakoe
Nebraska, USA
C?ID=581491
So:
Thanks for the reply man! only reason i started messing around with more than just the image that 034 sent is because i did what they said and sent them a picture to confirm and they said i had the wiring correct and to try to swap 2 more wires and that it helped a couple other customers and it also did not work so ive tried basically every wiring configuration (related to what has helped others) with every flash that relates to me and none of it has worked.
The "check throttle valve adaptation" is the same as a TBA i believe and it also fails when i select go due to "safety reasons" just like the 034 TBA says. it is due to those 3 codes mentioned previously.
I did email 034 and brought up to the idea of buying their super duper TB and replacing my APR one and seeing if that fixes everything and i can go back to ignoring these sensor codes, but they said only problem is that theres a chance the new TB will also need a TBA performed and then im back to square one: solving the codes. so I still might try it and then if it still doesnt work ill just return the 034 TB.
I even tried opening the intake and starting the car with the rough idle and manually opening the Throttle valve and it didnt actually make the engine clear up..
I also tried putting the pigtail back to how it came from apr and putting the tune to "stock flash" and car still didnt run and TBA still didnt work.
The logging via VCDS manually opening is very smart and ill try that along with some more of your ideas today! I appreciate the response, id love to figure this out myself and not have to bring it to a shop.
   #108
lakoe
Nebraska, USA
C?ID=581491
Im gonna try to get to testing today, but i had the idea again to buy 034 TB and they say that part of their installation process is a TBA but I feel like a lot of people install TB and its plug and play and they dont need to do a TBA afterall. is this worth a shot?
   #109
Ziddywerks
Northern NJ USA
C?ID=208579
Sounds like someone is still throwing money out the window to me.
   #110
lakoe
Nebraska, USA
C?ID=581491
well if it didnt work i would return it, its worth a shot. i have a month till my shop date and ill try anything to get it fixed myself.
   #111
B8boi
California, USA
C?ID=530730
No. Not worth the shot. You have to do TBA on the stock throttle body as well. The throttle body potentiometer can vary from batch to batch so thats why its done. Your issue is arising from a wiring harness continuity issue or and ecu internal component issue. If you're ambitious you can check the wiring with a multimeter per the manual instruction i posted
   #112
lakoe
Nebraska, USA
C?ID=581491
Little update, a friend has a IE dongle and for some reason the IE TBA ignored the codes and it successfully adapted the TB, but still even with the correct wiring and flash. same rough idle.
   #113
Dr Sheldon
Windsor UK
C?ID=334979
Sorry to pee on your fire but - Really dont think so !!
Someone or something is blowing wind up your shirt !!
Lets see a new scan !!
   #114
lakoe
Nebraska, USA
C?ID=581491
the 2 throttle body codes went away and throttle body started making noise while turning on the igntion, and opening doors, etc.
   #115
Dr Sheldon
Windsor UK
C?ID=334979
Scan Please !!
   #116
lakoe
Nebraska, USA
C?ID=581491
Scan Please !!
heres a scan with no clearing of codes and after messing around troubleshooting.
Tuesday,10,September,2024,16:37:30:52143
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUGGAFR7DA057847   License Plate:
Mileage: 92430km-57433mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 03 05 06 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 77
          A9
VIN: WAUGGAFR7DA057847   Mileage: 92430km-57433miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: 176B466C
   Coding: 1A190014052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 38293F3F62DF313AA73-806C
   VINID: 9D19575D15A21D44401472041CA6AC82C5
6518 - Throttle Position Sensor (G69)
          P0123 00 [10101111] - Signal too High
                    Mileage: 92429 km
                    Date: 2024.03.13
                    Time: 00:22:01
                    Engine RPM: 3422.00 /min
                    Normed load value: 71.0 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 96  C
                    Intake air temperature: 54  C
                    Voltage terminal 30: 13.405 V
                    Engine speed: actual: 3360 /min
                    MAF_ENVD: 1067.62350 mg/stroke
                    Coolant temperature (unfiltered): 89.25  C
                    Engine: operating status: PL
                    V_TPS_1_ENVD: 4.74609 V
                    STATE_LS_ENVD[1]: 2
6523 - Throttle Actuator (J338)
          P1565 00 [00100000] - Lower Stop not Reached
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:54
                    Engine RPM: 0.00 /min
                    Intake air temperature: 65  C
                    Voltage terminal 30: 12.288 V
                    V_TPS_1_ENVD: 1.03516 V
                    V_TPS_2_ENVD: 4.04297 V
                    Coolant temperature (unfiltered): 96.00  C
                    TIA_AM_SCHA: 64.50  C
                    Battery voltage: 12.289063 V
                    Vehicle speed: actual: 0 km/h
10935 - Neutral Gear Sensor
          P15A0 00 [00101111] - Electrical Malfunction
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Voltage terminal 30: 12.187 V
                    Engine speed: actual: 192 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 67.50  C
                    Engine: operating status: ST
                    Gear: 0
16719 - Gear Reconition Sensor
          P181C 00 [00101111] - Implausbile Signal
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Battery voltage: 11.273438 V
13827 - Gear Reconition Sensor
          P181B 00 [00101111] - Electrical Malfunction
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
Readiness: 1000 0100
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 281D18
   Shop #: WSC 06325 000 00000
   VCID: 04519BCF6E17A5DA7BB-8050
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0012
                    Hex Value: 0xB999
                    Hex Value: 0x0000
                    Fault Status: 00101101
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x20A2
                    Hex Value: 0x001A
                    Hex Value: 0x0299
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H12 0633
   Coding: 0F804000000000000000
   VCID: 015F92DB7105B0F250D-8054
   Serial number: 2313000006909016
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000050868877
   Coding: 00037025002C00000000
   Shop #: WSC 25745 004 1048576
   VCID: 45D746CB25AD5CD22C5-8010
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01070220130781
   Coding: 6602228000
   VCID: 392F3A3B5955283258D-806C
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:12:59
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000042330002
   Coding: 26000015863CAFC00000484300003D0D0F1C138822090221000008000000030100000000000000
   Shop #: WSC 06325 123 12345
   VCID: 76B5F10728CB874A75F-8022
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250113  H15 0080
   Serial number: SWF13010255079
   Coding: 00F511
   Serial number: 20953171
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000003101130098
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4H9B02
   Serial number: 2C698F86000000000001
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD91CPP+   Dataset Number: 8T0909602N  0004
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD75F70C33B3AAC17-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R120000BXLX
   Serial number: 6334MSME7775503CJ
   Serial number: 6344MSME766261428
   Serial number: 6352QSME542C3C7CY
   Serial number: 6362QSME172915429
   Serial number: 63732SME192C2F4CD
   Serial number: 63832SME75292348/
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130207000699
   Coding: 000016
   VCID: 4FFB64E3F7D19682969-801A
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Component: KOMBIINSTR.   H35 0556
   Revision: 00100000    Serial number: UUZ45F52E
   Coding: 8B9501000301D705020000
   VCID: 4BC370F303C9AAA2FA1-801E
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V1312481DD
   Coding: 80C303FF00
   VCID: 48C94FFF12BF41BAD73-801C
   Serial number: 9543419001
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000050133415
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F59187C80BE74A55F-8002
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H55 0702
   Revision: 00000002    Serial number: 0000189650 Dataset Number: 8T0909852M  0025
   Coding: 100000000001
   Shop #: WSC 40859 004 1048576
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 3FDB542347F10602669-806A
   Revision: 00002001    Serial number: 0300715232
   Coding: 0106029A00FA404580B0003200000000
   Shop #: WSC 06324 000 00000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000631652
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 37
                    Mileage: 92399 km
                    Date: 2024.03.13
                    Time: 12:38:31
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:05:36
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:06:08
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T1 035 223     HW: 8T1 035 223
   Component: DSP Prem      H05 0040
   Revision: 00005001    Serial number: 94803010306001
   Coding: 0203010302
   VCID: 6C81D36F66874D9A93B-8038
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F7968BD50DEC525C5-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000222103
   ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000002    Serial number: AUZ5Z6M1848649
   Coding: 040300020104850043D9070801
   VCID: 43D358D32B9962E2021-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:11:21
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:04
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005298879
   Coding: 0010370
   VCID: 3E2529274C7B0F0A6DF-806A
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130110201093
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDCD1744239B6A597-8026
End----------(Elapsed Time: 01:40, VBatt start/end: 13.9V/14.0V)-----------
Thursday,12,September,2024,15:02:52:52143
                Address 01: Engine       Labels: 06E-907-551-CGW.clb
Control Module Part Number: 8K5 907 551 E    HW: 4G0 907 551 A
  Component and/or Version: 3.0l V6 TFSIH07 0004
           Software Coding: 1A190014052600060000
            Work Shop Code: WSC 06208 000 00000
              ASAM Dataset: EV_ECM30TFS0218K5907551E 001004 (AU48)
7 Faults Found:
6516 - Throttle Valve Controller
          P1545 00 [01100000] - Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:01
                    Coolant temperature: 27  C
                    Intake air temperature: 30  C
                    Voltage terminal 30: 11.984 V
                    Engine speed: actual: 0 /min
                    Coolant temperature (unfiltered): 27.00  C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
          P0123 00 [10100101] - Signal too High
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    V_TPS_1_ENVD: 4.72656 V
                    STATE_LS_ENVD[1]: 0
6536 - Throttle Actuator (J338)
          P1579 00 [00100101] - Adaptation Not Started
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:03
                    V_TPS_2_ENVD: 0.74219 V
                    TIA_AM_SCHA: 30.00  C
                    Battery voltage: 12.085938 V
6522 - Throttle Body (J338)
          P1559 00 [00100100] - Fault in basic settings
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:50:31
                    Battery voltage: 12.187500 V
          P15A0 00 [00100101] - Electrical Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    Gear: 0
          P181C 00 [00100101] - Implausbile Signal
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
          P181B 00 [00100101] - Electrical Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
Readiness: 1110 1101
Monday,30,September,2024,15:22:48:52143
          A9
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
   Revision: --H07---    CVN: 750551C3
   VCID: 38293F3F62DF313AA7B-806C
8 Faults Found:
          P1545 00 [01100101] - Malfunction
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:31:11
                    Coolant temperature: 43  C
                    Intake air temperature: 31  C
                    Engine speed: actual: 1248 /min
                    MAF_ENVD: 81.70588 mg/stroke
                    Coolant temperature (unfiltered): 42.75  C
                    Engine: operating status: IS
                    Engine load: 12.500000 %
6519 - Throttle Position Sensor (G69)
          P0122 00 [10101101] - Signal too Low
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:31:10
                    Coolant temperature (unfiltered): 29.25  C
                    V_TPS_1_ENVD: 1.42578 V
                    STATE_LS_ENVD[1]: 0
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:33:37
                    Coolant temperature: 41  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 12.390 V
                    V_TPS_2_ENVD: 0.00000 V
                    TIA_AM_SCHA: 30.75  C
          P1559 00 [01100000] - Fault in basic settings
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:50:51
                    Coolant temperature: 39  C
                    Coolant temperature (unfiltered): 27.75  C
                    TIA_AM_SCHA: 29.25  C
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [01100101] - -
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:00:33
                    Engine RPM: 994.00 /min
                    Normed load value: 25.1 %
                    Voltage terminal 30: 11.780 V
                    Engine speed: actual: 1024 /min
                    MAF_ENVD: 348.61176 mg/stroke
                    Engine load: 25.000000 %
          P15A0 00 [00101101] - Electrical Malfunction
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:31:11
                    Gear: 0
          P181C 00 [00101101] - Implausbile Signal
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:31:11
          P181B 00 [00101101] - Electrical Malfunction
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:31:11
Readiness: 1100 0100
   Coding: 281D18
   VCID: 04519BCF6E17A5DA7B3-8050
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0012
                    Hex Value: 0xB999
                    Hex Value: 0x0000
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x20A2
                    Hex Value: 0x001A
                    Hex Value: 0x0299
                    Hex Value: 0x0000
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0012
                    Hex Value: 0xB999
                    Hex Value: 0x0000
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Hex Value: 0x0000
                    Hex Value: 0x00A0
                    Hex Value: 0x000C
                    Hex Value: 0xE394
                    Hex Value: 0x0000
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x20A2
                    Hex Value: 0x001A
                    Hex Value: 0x0299
                    Hex Value: 0x0000
   VCID: 015F92DB7105B0F2505-8054
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   VCID: 45D746CB25AD5CD22CD-8010
   Coding: 6602228000
   VCID: 392F3A3B59552832585-806C
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:12:59
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:38
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
                    Temperature: 27.0 C
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:42
                    Temperature: 27.0 C
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:44
   VCID: 76B5F10728CB874A757-8022
   Coding: 00F511
   Coding: 02005D
8 Faults Found:
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
02258 - Door Opener Transmitter
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
03608 - Humidity Sensor in Fresh Air Intake Duct
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:40
                    Fault Status: 00100101
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:44
   VCID: 4ACD75F70C33B3AAC1F-801E
   Coding: 000016
   VCID: 4FFB64E3F7D19682961-801A
   VCID: 4BC370F303C9AAA2FA9-801E
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
   Coding: 80C303FF00
   VCID: 48C94FFF12BF41BAD7B-801C
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01312 - Powertrain Data Bus
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:32:35
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 78
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:00:01
                    Bin. Bits:    00000
                    Voltage: 12.30 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
   Revision: 00000000
   Coding: 020302
   VCID: 56F59187C80BE74A557-8002
   VCID: 3FDB542347F10602661-806A
9 Faults Found:
            014 - Defective
                    Reset counter: 38
                    Mileage: 92399 km
                    Date: 2024.03.13
                    Time: 12:38:31
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:05:36
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:06:08
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:34
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 20:27:38
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.21
                    Time: 21:17:39
                    Reset counter: 78
                    Mileage: 92431 km
                    Date: 2024.03.22
                    Time: 03:13:07
                    Reset counter: 78
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:54:05
   Coding: 0203010302
   VCID: 6C81D36F66874D9A933-8038
   VCID: 55F7968BD50DEC525CD-8000
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                    Reset counter: 38
                    Mileage: 92430 km
                    Date: 2024.03.24
                    Time: 00:04:20
                    Voltage terminal 30: 13.6 V
                    Internal Fault ID: 188
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: applied
   VCID: 43D358D32B9962E2029-8016
   Component: Display
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:11:21
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 78
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:04
   Coding: 0010370
   VCID: 3E2529274C7B0F0A6D7-806A
   VCID: 72BDCD1744239B6A59F-8026
End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
Monday,30,September,2024,15:23:30:52143
Gateway Installation List:  8R0 907 468 L
   #118
lakoe
Nebraska, USA
C?ID=581491
Looks great....
all of the codes besides the obvious three go away once cleared and TBA is completed, they're from moving around the wires on the TB harness.
   #119
lakoe
Nebraska, USA
C?ID=581491
just got it running today! ended up switching to jackal motorsports Stage 2+ tune and buying a jackal throttle body harness and it all works now.. No TBA needed with the new tune/harness
   #120
B8boi
California, USA
C?ID=530730
All throttle bodies need adaptation some may do it automatically. It was probably the bum harness.
