Really need some help, throttle body and tuning issues!
lakoe
Nebraska, USA
C?ID=581491
Hey guys, got a 2013 Audi s5 with basically FBO and currently has a APR upgraded throttle body and apr tune, tried switching to a 034 motorsports tune and was having trouble and found out when using a APR TB with the 034 tune i have to repin some wires for the TB so i did so and then final step was to readapt the throttle body and then enjoy my tune, but instead the adaptation continues to fail with the 034 motorsports app so I tried swapping some more wires they said sometimes work and nothing, tried how APR had the wiring originally and it still wont adapt even on the stock ECU map. So finally just now i tried to to a readapt with VCDS and still nothing it says the same message. "Failed for safety reasons" In the rosstech video it mentions possible causes for this message including
-Dirty throttle body
-Low voltage (mine is 11.9 while ignition on only which) (11.5 minimum he says)
-Cable adjustment issue
-Wiring harness issue
-Faulty throttle body
-Faulty ECM
So im just very confused and dont have many ideas left besides buying a 034 motorsports throttle body harness... When i start the car it runs very very very rough and doesnt drive so i really need some help here!
Ziddywerks
Northern NJ USA
C?ID=208579
How about a auto scan. No crystal ball in stock currently.
lakoe
Nebraska, USA
C?ID=581491
Gotcha sorry haha! The 3 that im referring to are the bottom three engine codes that will pop up immediately after clearing DTCs
Tuesday,10,September,2024,16:37:30:52143
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUGGAFR7DA057847   License Plate:
Mileage: 92430km-57433mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 03 05 06 08 09 15 16 17 19 2E 36 42 44 46 47 52 53 56 77
          A9
VIN: WAUGGAFR7DA057847   Mileage: 92430km-57433miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: 176B466C
   Coding: 1A190014052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 38293F3F62DF313AA73-806C
   VINID: 9D19575D15A21D44401472041CA6AC82C5
6518 - Throttle Position Sensor (G69)
          P0123 00 [10101111] - Signal too High
                    Mileage: 92429 km
                    Date: 2024.03.13
                    Time: 00:22:01
                    Engine RPM: 3422.00 /min
                    Normed load value: 71.0 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 96  C
                    Intake air temperature: 54  C
                    Voltage terminal 30: 13.405 V
                    Engine speed: actual: 3360 /min
                    MAF_ENVD: 1067.62350 mg/stroke
                    Coolant temperature (unfiltered): 89.25  C
                    Engine: operating status: PL
                    V_TPS_1_ENVD: 4.74609 V
                    STATE_LS_ENVD[1]: 2
6523 - Throttle Actuator (J338)
          P1565 00 [00100000] - Lower Stop not Reached
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:54
                    Engine RPM: 0.00 /min
                    Intake air temperature: 65  C
                    Voltage terminal 30: 12.288 V
                    V_TPS_1_ENVD: 1.03516 V
                    V_TPS_2_ENVD: 4.04297 V
                    Coolant temperature (unfiltered): 96.00  C
                    TIA_AM_SCHA: 64.50  C
                    Battery voltage: 12.289063 V
                    Vehicle speed: actual: 0 km/h
10935 - Neutral Gear Sensor
          P15A0 00 [00101111] - Electrical Malfunction
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Voltage terminal 30: 12.187 V
                    Engine speed: actual: 192 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 67.50  C
                    Engine: operating status: ST
                    Gear: 0
16719 - Gear Reconition Sensor
          P181C 00 [00101111] - Implausbile Signal
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Battery voltage: 11.273438 V
13827 - Gear Reconition Sensor
          P181B 00 [00101111] - Electrical Malfunction
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
Readiness: 1000 0100
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 281D18
   Shop #: WSC 06325 000 00000
   VCID: 04519BCF6E17A5DA7BB-8050
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0012
                    Hex Value: 0xB999
                    Hex Value: 0x0000
                    Fault Status: 00101101
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x20A2
                    Hex Value: 0x001A
                    Hex Value: 0x0299
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H12 0633
   Coding: 0F804000000000000000
   VCID: 015F92DB7105B0F250D-8054
   Serial number: 2313000006909016
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000050868877
   Coding: 00037025002C00000000
   Shop #: WSC 25745 004 1048576
   VCID: 45D746CB25AD5CD22C5-8010
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01070220130781
   Coding: 6602228000
   VCID: 392F3A3B5955283258D-806C
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:12:59
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000042330002
   Coding: 26000015863CAFC00000484300003D0D0F1C138822090221000008000000030100000000000000
   Shop #: WSC 06325 123 12345
   VCID: 76B5F10728CB874A75F-8022
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 250113  H15 0080
   Serial number: SWF13010255079
   Coding: 00F511
   Serial number: 20953171
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000003101130098
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4H9B02
   Serial number: 2C698F86000000000001
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD91CPP+   Dataset Number: 8T0909602N  0004
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD75F70C33B3AAC17-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R120000BXLX
   Serial number: 6334MSME7775503CJ
   Serial number: 6344MSME766261428
   Serial number: 6352QSME542C3C7CY
   Serial number: 6362QSME172915429
   Serial number: 63732SME192C2F4CD
   Serial number: 63832SME75292348/
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130207000699
   Coding: 000016
   VCID: 4FFB64E3F7D19682969-801A
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Component: KOMBIINSTR.   H35 0556
   Revision: 00100000    Serial number: UUZ45F52E
   Coding: 8B9501000301D705020000
   VCID: 4BC370F303C9AAA2FA1-801E
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V1312481DD
   Coding: 80C303FF00
   VCID: 48C94FFF12BF41BAD73-801C
   Serial number: 9543419001
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000050133415
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F59187C80BE74A55F-8002
   Part No SW: 8K0 909 144 Q    HW: 8K0 909 144 L
   Component: RCevo         H55 0702
   Revision: 00000002    Serial number: 0000189650 Dataset Number: 8T0909852M  0025
   Coding: 100000000001
   Shop #: WSC 40859 004 1048576
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 3FDB542347F10602669-806A
   Revision: 00002001    Serial number: 0300715232
   Coding: 0106029A00FA404580B0003200000000
   Shop #: WSC 06324 000 00000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000631652
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 37
                    Mileage: 92399 km
                    Date: 2024.03.13
                    Time: 12:38:31
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:05:36
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:06:08
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T1 035 223     HW: 8T1 035 223
   Component: DSP Prem      H05 0040
   Revision: 00005001    Serial number: 94803010306001
   Coding: 0203010302
   VCID: 6C81D36F66874D9A93B-8038
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F7968BD50DEC525C5-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000222103
   ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000002    Serial number: AUZ5Z6M1848649
   Coding: 040300020104850043D9070801
   VCID: 43D358D32B9962E2021-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:11:21
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:04
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005298879
   Coding: 0010370
   VCID: 3E2529274C7B0F0A6DF-806A
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130110201093
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDCD1744239B6A597-8026
End----------(Elapsed Time: 01:40, VBatt start/end: 13.9V/14.0V)-----------
Thursday,12,September,2024,15:02:52:52143
                Address 01: Engine       Labels: 06E-907-551-CGW.clb
Control Module Part Number: 8K5 907 551 E    HW: 4G0 907 551 A
  Component and/or Version: 3.0l V6 TFSIH07 0004
           Software Coding: 1A190014052600060000
            Work Shop Code: WSC 06208 000 00000
              ASAM Dataset: EV_ECM30TFS0218K5907551E 001004 (AU48)
7 Faults Found:
6516 - Throttle Valve Controller
          P1545 00 [01100000] - Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:01
                    Coolant temperature: 27  C
                    Intake air temperature: 30  C
                    Voltage terminal 30: 11.984 V
                    Engine speed: actual: 0 /min
                    Coolant temperature (unfiltered): 27.00  C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
          P0123 00 [10100101] - Signal too High
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    V_TPS_1_ENVD: 4.72656 V
                    STATE_LS_ENVD[1]: 0
6536 - Throttle Actuator (J338)
          P1579 00 [00100101] - Adaptation Not Started
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:03
                    V_TPS_2_ENVD: 0.74219 V
                    TIA_AM_SCHA: 30.00  C
                    Battery voltage: 12.085938 V
6522 - Throttle Body (J338)
          P1559 00 [00100100] - Fault in basic settings
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:50:31
                    Battery voltage: 12.187500 V
          P15A0 00 [00100101] - Electrical Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    Gear: 0
          P181C 00 [00100101] - Implausbile Signal
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
          P181B 00 [00100101] - Electrical Malfunction
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
Readiness: 1110 1101
</> tags added - Jef
Click on how to and post an autoscan properly please, so we can read it without more brain damage... it's near the end of the week and some of us have incurred a lot of it already.... have mercy
code tags
Ziddywerks
Northern NJ USA
C?ID=208579
Please code wrap. As far as wiring to the throttle body I don't see why it would need to be repinned unless instructed to do so by 034 or arp with their cookie cutter tunes.
lakoe
Nebraska, USA
C?ID=581491
Please educate me !! Why ??
Im not entirely sure but 034 says you have to swap around 2 of the wires and the readapt to make it work with their tune..
lakoe
Nebraska, USA
C?ID=581491
i see, makes more sense. Thanks for letting me know!
          A9
                    Mileage: 92429 km
                    Date: 2024.03.13
                    Time: 00:22:01
                    STATE_LS_ENVD[1]: 2
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:54
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Gear: 0
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:16:46
   Coding: 281D18
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0012
                    Hex Value: 0xB999
                    Hex Value: 0x0000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Hex Value: 0x0000
                    Hex Value: 0x20A2
                    Hex Value: 0x001A
                    Hex Value: 0x0299
                    Hex Value: 0x0000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Coding: 6602228000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:12:59
   Coding: 00F511
   Coding: 02005D
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Coding: 000016
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Coding: 80C303FF00
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
                    Bin. Bits:    10111
                    Voltage: 12.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: 00000000
   Coding: 020302
            014 - Defective
                    Reset counter: 37
                    Mileage: 92399 km
                    Date: 2024.03.13
                    Time: 12:38:31
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:05:36
                    Reset counter: 37
                    Mileage: 92409 km
                    Date: 2024.03.13
                    Time: 13:06:08
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:00
   Coding: 0203010302
   Component: Display
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:11:21
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 77
                    Mileage: 92428 km
                    Date: 2024.03.13
                    Time: 00:13:04
   Coding: 0010370
7 Faults Found:
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:01
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    STATE_LS_ENVD[1]: 0
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:03
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:50:31
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    Gear: 0
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
                    Mileage: 92431 km
                    Date: 2024.03.15
                    Time: 00:49:00
lakoe
Nebraska, USA
C?ID=581491
needing repinning from 034 since its an APR ultra charger not there super duper throttle body lol
OK... so if you're trying to run "stock", go back and unfac whatever butchering you did on the stock TB.
We have no idea what you did, or re-wired, or if it was done as per whatever instructions, etc.
Once wiring is per OEM WD spec, you should be able to clear codes, run output tests, readapt.... if the TB is functioning.
Ziddywerks
Northern NJ USA
C?ID=208579
Any hardware change requires a retune. I would verify it was pinned correctly to begin with using wiring diagram.
lakoe
Nebraska, USA
C?ID=581491
I have a APR upgraded TB and was on a APR tune with the wires exactly how they came from APR, then i switched to 034 and they said to use the APR TB i need to repin so i did, and then i tried to readapt the TB and it doesnt work, and if i tried to start my car im guessing the TB stayed closed when its supposed to be open and it would run very very rough. So I needed to use my car so i tried to repin the wires exactly how they were before and flash the ecu to stock tune and TB is still messed up and still wont readapt and the car doesnt run.
lakoe
Nebraska, USA
C?ID=581491
ive got the APR repinning diagram and can confirm with that and memory that it is now in the original APR wiring diagram as I had it when the car ran fine before switching tunes. I believe my problem is those three codes that pop up everytime I clear DTC's. My cars previous owners says when he isntalled the JHM short shifter that those three codes are normal and that its normal. I believe that VCDS and 034 tools for readapting the TB see that there is codes and cancel for "safety" without trying. I also emailed JHM and showed them the codes and the message that my previous owner sent me about it being normal and they said its impossible for a short shifter to cause codes and that hes lying.. or misinformed
Sounds like you should be on ARP and\or 034 support forums, not VCDS or VAG... you know, since you're not working with either one of those.....
Ziddywerks
Northern NJ USA
C?ID=208579
Contact supplying vendor for support.
lakoe
Nebraska, USA
C?ID=581491
Im on here because I tried running a vcds TB test and it also failed so I wanted to see what you guys thought.
lakoe
Nebraska, USA
C?ID=581491
I dont see whats wrong with that, the VCDS wont run the adaptation even with the wiring pinned in the OEM way it came on the stock tune so excluding all tuning problems this is still a problem im having with my car that involves VCDS so I was coming here for help... My car wont even run anymore so I cant make sure the coolant temp is where it needs to be and I had the battery charging as well and still no adaptation.
heres a video of me trying to start the car to warm up the coolant so i can adapt the TB
No, it's not VCDS that won't do it, it's your ECU that won't do it. What faults do you currently have in the ECU?
