Resolved VCDS-Mobile does not find ASAM dataset for engine control unit
Resolved
tuxo
Finland
C?ID=437592
Hi,
After engine control unit software update VCDS-Mobile can't find ASAM data anymore (Laptop VCDS still works fine as you can see from below scans).
Engine software was updated by dealer
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 8W0 907 401 E    HW: 059 907 309 F
   Component: 3,0l V6 TDI   H23 0003
   Revision: C7H23---
   Coding: 122A403A0366050324380000000000000000000000000000
   Shop #: WSC 17675 002 1048576
   ASAM Dataset: EV_ECM30TDI0118W0907401E 001003
   ROD: EV_ECM30TDI0118W0907401E.rod
   VCID: 3924468939A4D47388D-806C
to:
Address 01: Engine (J623-CRTC)       Labels: None
   Part No SW: 8W0 997 401     HW: 059 907 309 F
   Component: 3.0TDI MD1    H23 0001
   Revision: C7H23---    CVN: 6A05BFD14F8B6DFBB866C2ADB866C2AD
   Coding: 122A403A0376050325380000000000000000000000000000
   Shop #: WSC 52025 005 1048576
   ASAM Dataset: EV_ECM30TDI0118W0997401 001001
   ROD: EV_ECM30TDI0118W0997401.rod
   VCID: FDAC1299ED0CA852C45-81A8
   VINID: 9D196AAAA584A184401C3041181518BBEC
Shaun
Please try switching your interface to the beta channel as described in your other thread here: https://forums.ross-tech.com/index.php?threads/45219/post-367434
Then try the autoscan with mobile again and see if it has coverage for this updated module. You might need to check for updates again after doing the new scan to download the asam info.
tuxo
Finland
C?ID=437592
Switching to beta channel and running update solved the issue.
ASAM data is now found for this control unit.
