Resolved I lost abs module long code. 2015 Golf (MK100ESP)
Resolved
dsmith
C?ID=98542
I had a weak battery on my 2015 Golf. I had a check engine light for a P3044 Fuel pump short circuit the car was still running ok. The next day I got a new battery and put it in and realized that I had left the key in running the battery completely dead. When I started it up I had tire pressure light on Check engine and traction control. I hooked up the Vag and started clearing codes I didn't do an autoscan. I went to the abs module adaptation and returned it to factory settings and wiping out the long code. I had never done an autoscan on this car before which I realize now was a big mistake. Any ideas where I can get the long code for the abs on this car?
Wednesday,11,September,2024,10:25:12:18930
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VW217AU0FM005024   License Plate: 2015 GOLF
Mileage: 364970km-226781mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 47 52 5F 75
VIN: 3VW217AU0FM005024   Mileage: 364970km-226781miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 D    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---    CVN: 32D5A190
   Coding: 091A00122424000F0000
   Shop #: WSC 00066 790 00221
   ASAM Dataset: EV_ECM18TFS0208V0906264D 001004
   ROD: EV_ECM18TFS0208V0906264D.rod
   VCID: 3D273B4A4DF531C2745-8068
   VINID: 0E69C204746501674000500210EDCBDE79
17178 - Databus
          U1123 00 [00101111] - Received Error Message
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:01:17
                    Engine RPM: 809.75 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 82  C
                    Intake air temperature: 41  C
                    Voltage terminal 30: 13.535 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 0010 1101
   Part No SW: 09G 927 749 D    HW: 09G 927 749 D
   Component: AISIN AG6 G3  109 2866
   CVN: A3B683DE
   Coding: 010200000C000000000000000000000000000000
   Shop #: WSC 00066 790 00145
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 3A2D30565CDB06FA517-806E
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 50874000000236
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D14EAE2E1F400A3BB-8010
9 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:44
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:43
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:43
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:43
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:43
0297 - Steering angle sensor
          B1168 16 [00001000] - Voltage Too Low
                    Reset counter: 36
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:43
4161 - Coding invalid
          U10DA 00 [00001000] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 252
                    Mileage: 364970 km
                    Date: 2024.09.09
                    Time: 00:51:27
8290 - Coding Not Possible
          U10BC 00 [10001001] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:48
8306 - Databus
          U1122 00 [10001001] - Implausible Message
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:09:48
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   VCID: 3635246668C3E29AB5F-8062
          B10CD 00 [00001000] - -
                    Reset counter: 36
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:00:19
                    Voltage terminal 30: 10.6 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 3
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86581203140042 Dataset Number: 5GM063v____
   Coding: 001018464041826969E44000001407001000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 43D34DB22B114732021-8016
   Component: WWS    140222  042 0581
   Serial number:         140425000941
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M02D19H21M11S07S7
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO27491210
   Coding: 181801
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM005ALE Dataset Number: 5GM003V____ 0026
   VCID: 51FF77FAE16DA5A280D-8004
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  005 0016
   Serial number: IBH0000J140000NSJX01
   Coding: 303335
   Subsystem 2 - Part No SW: -----------    HW: 480 002 603 14
   Serial number: 357000000008D4247F0P
   Subsystem 3 - Part No SW: -----------    HW: 480 002 703 14
   Serial number: 358000000006E4057F0O
   Subsystem 4 - Part No SW: -----------    HW: 480 400 702 14
   Serial number: 3510002A311D1522127G
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
   Serial number: 35200029B107DB44C356
   Subsystem 6 - Part No SW: -----------    HW: 480 400 303 14
   Serial number: 3550002BF12F6290D17B
   Subsystem 7 - Part No SW: -----------    HW: 480 400 303 14
   Serial number: 3560002BF12F6295609B
          B13BC F2 [10001001] - No function
                    Mileage: 364970 km
                    Date: 2024.09.09
                    Time: 00:43:30
   Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 28031404220896
   Coding: 0410
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 79AFEF5A195DCDE218D-802C
   Part No SW: 5G0 920 961 B    HW: 5G0 920 961 B
   Component: KOMBI         254 2210
   Coding: 0BB4190A2180CF0502086800000000
   VCID: 290FFF1AA97DBD6228D-807C
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:44:00
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:04:38
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 22031410001661 Dataset Number: 5G0067v____ 1613
   Coding: 0101000820085900EF000008180F00000001000000000000000000000000
   Shop #: WSC 00066 790 07026
   GVL: 01503C0000000000400C00008000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3E253C4640F32ADA6DF-806A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H14 0101
   Serial number: 29140000021070044045
   Coding: 29FFFF
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:43:55
                    Terminal 30 power supply: 8.4 V
                    Terminal 15: On
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 100114060500KF Dataset Number: V03935203WX 0005
   Coding: 003003200000040000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Serial number: 00000000000001879811
   Coding: 011000
65548 - Supply voltage
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:45:16
589829 - Window Regulator; Rear Driver side
          B131F F5 [00001000] - Supply Voltage too Low
                    Fault Frequency: 47
                    Reset counter: 36
                    Mileage: 363511 km
                    Date: 2024.07.16
                    Time: 15:37:10
   Component: EPS_MQB_ZFLS  122 1043
   Dataset Number: 5GM074V____ 0203
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF47BA310D552210D-8014
12288 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung]
                    Fault Frequency: 234
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:48:32
                    Motor status: 00
                    Supply voltage: 5.50 V
                    Temperature: 32.0  C
                    KFC: 30
                    KFA: 00 01
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 5.47 V
                    uAdSensI_SwitchedKl30_xdu16: 5.46 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 37
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:04:34
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.50 V
                    Temperature: 39.0  C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 13.64 V
                    uAdSensI_SwitchedKl30_xdu16: 13.63 V
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1EC400YQQ0 Dataset Number: 5GM050v____ 0009
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001005
   ROD: EV_AMPMst11CALPI.rod
   VCID: 6393AD328BD12732221-8036
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 100114060500TX Dataset Number: V03935203WY 0005
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Serial number: 00000000000001842041
   Coding: 191000
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:45:27
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 253
                    Mileage: 363956 km
                    Date: 2024.08.01
                    Time: 09:09:05
589845 - Window Regulator; Front Passenger side
          B1320 F5 [00001000] - Supply Voltage too Low
                    Reset counter: 36
                    Mileage: 363511 km
                    Date: 2024.07.16
                    Time: 15:37:10
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B00604141387 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300000000000021220002001800001F0100340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491AE2E8EDF200ADBB-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50027X
7 Faults Found:
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:45:13
                    Voltage terminal 30: 8.3 V
          U1400 00 [00001000] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Fault Frequency: 18
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:44:12
                    Reset counter: 208
                    Mileage: 229156 km
                    Date: 2019.03.20
                    Time: 16:23:53
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
0009 - Antenna for Satellite Radio
          B10F4 13 [00001000] - Open Circuit
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 08:48:35
                    Voltage terminal 30: 10.8 V
                    Satellite radio tuner status-SDARS Flash Regional code: Delivery_State_for_FPO
6163 - Display Module 1 for Multimedia System
          B1297 F5 [00001000] - Minimum Supply Voltage Not Reached
                    Reset counter: 36
                    Mileage: 364961 km
                    Date: 2024.09.09
                    Time: 14:47:18
                    Voltage terminal 30: 6.9 V
                    Multimedia System 1-System condition: OFF
                    Multimedia System 1-Operating hour counter: 0 H
                    Multimedia System 1-Minutes: 0 min
                    Multimedia System 1-Battery voltage: 0.0 V
                    Multimedia System 1-Highest measured temperature: 70  C
                    Multimedia System 1-Temperature: 48  C
                    Multimedia System 1-Dimming: 100 %
          U1111 00 [00001001] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:05:04
                    Voltage terminal 30: 13.1 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 252
                    Mileage: 364960 km
                    Date: 2024.09.09
                    Time: 00:05:07
                    Voltage terminal 30: 14.0 V
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Dataset Number: 561098V____ 0403
   ROD: EV_OCULowMQB.rod
   VCID: 025D88B6748B8E3A497-8056
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 252
End----------(Elapsed Time: 01:18, VBatt start/end: 12.1V/12.1V)-----------
You've had VCDS for many years. Check your Logs and Scans folder for older scans from this car that have the ABS coding you need.
dsmith
C?ID=98542
I checked both laptops that I have used and have no scans for this car saved.
EuroX
Northern NJ USA
C?ID=208579
If you don't have an old log and need correct coding. I can provide correct coding for a small fee if you need this expedited.
Jef
HQ
So you did IDE00498-Resetting of all adaptation values? Did VCDS give you any warning about doing that?
dsmith
C?ID=98542
I chose to reset all to factory default it didn't warn me. How much will it cost for the code?
Jef
HQ
IDE02325-ENG114972-Reset to factory setting-Routine Control Option? I want to pin down what you did because VCDS can pop up warnings of "DON'T DO THIS" kind of thing.
DrPeter
16.4905° S, 151.7375° W
Hi there,
If I had guess the ABS coding should be:
01FA6AA1242009710077020281C7298056249000408194B400430050C002
(one value out of a possible 5.4 quintillion quintillion) ;)
Hope this helps,
drpeter
dsmith
C?ID=98542
I didn't get a warning for resetting to factory settings.
Jef
HQ
OK... let see if Peter's suggestion gets a lot of issues sorted out.. if so, maybe you can confirm what you selected to make things wonky. I would like confirmation so that the higher level nerds at Ross-Tech can put in a warning to help prevent the next person from doing this.
EuroX
Northern NJ USA
C?ID=208579
Above coding is correct per vin.
dsmith
C?ID=98542
It took the code you sent me. I need to go through and clear out all the modules but I am out of time today.
dsmith
C?ID=98542
The code for the abs module worked! Thank You for the help! I got the ABS, Airbag and steering end stops etc. all cleared out and I have a good scan now. I learned a valuable lesson and will never not autoscan any of the cars I work on before making changes!
