2014 SQ5 Hatch release rear button without key
ninethree2cc
Minnesota USA
C?ID=258688
Hi,
I have a 2014 SQ5 B8.5.
The rear hatch works fine, but the default behavior seems odd and I am wondering if there is a way to modify this using VCDS.
By default, I can open the hatch with the rear button- Only if the fob is in my pocket.
With the vehicle unlocked, I can open all doors without the key, but the rear hatch requires the keyfob to be in my pocket/near the bumper for the rear button to work.
I am not sure why this default behavior is what it is, maybe has something to do with the "kick to open" feature that my car does not have installed.
ninethree2cc
Minnesota USA
C?ID=258688
Wow... Sorry about that... Here's a recent autoscan.
Saturday,27,July,2024,09:59:47:63181
VCDS Version: 24.7.0.0 (x64)  HEX-NET CB: 0.4643.4
VIN: WA1LGCFP0EA032473   License Plate: SQ5
Mileage: 227880km-141598mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72 A9
VIN: WA1LGCFP0EA032473   Mileage: 227880km-141598miles
Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---    CVN: 8B77F6E0
   Coding: 2A2A0034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
   ROD: EV_ECM30TFS0218R0907551G.rod
   VCID: BC34BC77379DEA765F-80E8
   VINID: 9D105C5D35A00154400C21070CFC0D08DE
6003 - Left Engine Mount Solenoid Valve (N144)
          P1571 00 [01101101] - Short to Plus
                    Fault Frequency: 89
                    Mileage: 226238 km
                    Date: 2024.07.15
                    Time: 16:29:31
                    Engine RPM: 1535.00 /min
                    Normed load value: 31.0 %
                    Vehicle speed: 64 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.218 V
                    Engine speed: actual: 1216 /min
                    MAF_ENVD: 174.30588 mg/stroke
                    Coolant temperature (unfiltered): 90.75 °C
                    Engine: operating status: PL
                    Engine load: 19.921875 %
                    Vehicle speed: actual: 15 km/h
22107 - Exhaust Pressure Control Valve
          P0475 00 [01101101] - Electrical Malfunction
                    Mileage: 226235 km
                    Date: 2024.07.15
                    Time: 16:24:51
                    Engine RPM: 1318.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 26 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.476 V
                    Engine speed: actual: 1024 /min
                    MAF_ENVD: 87.15294 mg/stroke
                    Coolant temperature (unfiltered): 99.00 °C
                    Engine: operating status: IS
                    Engine load: 6.640625 %
                    Vehicle speed: actual: 0 km/h
   Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1002
   Revision: --H16---    CVN: F1D544F1
   VCID: FDB271736C07237E28-80A8
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
   Component: ESP8 quattro  H09 0030
   Coding: 301D0801
   Shop #: WSC 06335 123 12345
   VCID: 8B562FAB2AB31DCE26-80DE
   Part No SW: 8K0 907 064 HP    HW: 8K0 907 064 GP
   Component: BCM2 2.0      H13 0641
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 854219930CD76BBE70-80D0
   Subsystem 1 - Part No SW: 8K0 959 754 BP    HW: 8K0 959 754 BP
   Serial number: 0513000056996008
   Serial number: 0213000288782009
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 211
                    Mileage: 226235 km
                    Date: 2024.07.15
                    Time: 16:24:43
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01220820131786
   Coding: 6601228000
   VCID: B93AA56330AFDF5E44-80EC
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000661766001
   Coding: 26000096863CAFE0010048C300003D0D0F98C608A2090221000008004400010200040034000000
   VCID: FAB87A6F752914460D-80AE
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130723  H11 0050
   Serial number: 90243014130718103219
   Coding: 01DD13
   Serial number: 21635056
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000108131156
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R743102
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 9F0802C6000000000001
01543 - Parking Aid Warning Chime (H15)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 222
                    Mileage: 226591 km
                    Date: 2024.07.25
                    Time: 17:31:03
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB0951/   Dataset Number: 8R0909602B  0021
   Coding: 30373431343230303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C7DED39B7E5BB9AEC2-8092
   Serial number: 6334MSME7D1131188
   Serial number: 6344MSME7D0253509
   Serial number: 6352QSME33364778I
   Serial number: 6362QSME2C36106CK
   Serial number: 63732SME203A3648Z
   Serial number: 63832SME5C390C58B
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MHO000KU
   Coding: 000037
   VCID: C8DCD0A77B45B6D6CB-809C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 C    HW: 8R0 920 982 C
   Component: KOMBIINSTR.   H35 0564
   Revision: 00400000    Serial number: R+A325VAF
   Coding: 0B9722000B01D705020000
   Shop #: WSC 06342 123 12345
   VCID: BB36BF6B3A93ED4E56-80EE
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z138020167
   Coding: 80C103FF00
   VCID: CCD4ECB76F3D5AF6EF-8098
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 30206319541461798589
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000068758953
   Coding: 00581B00000000000000
   VCID: C2C8C28F5D799C8615-8096
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0312807343 Dataset Number: 8R0909535E  0019
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: BFCECB7B268BF16E7A-80EA
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0312771985
   Coding: 010211
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000069455882
   Coding: 011D13205E00440004
   VCID: CFEEFBBB9E2B61EE8A-809A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H38 0510
   Revision: 00001000    Serial number: 0005740762 Dataset Number: 8R0909852J  0022
   Coding: 100000010000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: C5C2D9934457ABBE30-8090
   Revision: 00002001    Serial number: 0312967469
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000709207
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813018895603
   VCID: AD128133F4E773FED8-80F8
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Fault Status: 00101011
                    Fault Frequency: 20
                    Reset counter: 7
                    Voltage: 12.40 V
                    Temperature: 21.0°C
                    Temperature: 22.0°C
                    Bin. Bits: 00000100
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000071688225
   VCID: CED0E6BF992168E681-809A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000317812 Dataset Number: 8R0909522A  0002
   ROD: EV_ParkiBrake_AU48.rod
   VCID: B93AA56338AFDF5E44-80EC
   Revision: AB001007    Serial number: 156H50D7837842
   Coding: 020007010000000001
   VCID: A4046417A72DB2B607-80F0
   Part No SW: 8R1 035 664 D    HW: 8R1 035 664 D
   Component: H-BN-NA       H40 0738
   Revision: --------    Serial number: 203HW0D7526136
   Coding: 1A0200060205A1FF55028B4E00000403F40000020000000000
   VCID: B73EA35B06BBC92EB2-80E2
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130GY0D2799331
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001594623
   Component: CD-Database  5298
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000069838424
   Coding: 010C13204000240004
   VCID: C6C0DE9F7151A0A639-8092
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J36A12O
   Coding: 1020010
   VCID: B4249457D7CD223697-80E0
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000069844349
   Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 130612200376
   VCID: BA38BA6F3DA9D4464D-80EE
End----------(Elapsed Time: 02:34, VBatt start/end: 11.9V/12.0V)-----------
