Hello all,
I am deleting the 3rd Row in my wife's Q7 to gain some much needed sub cargo floor storage. The necessary parts were ordered from overseas since all 4M Q7s in the USA are sold with a 3 row. The conversion was very simple and took me ~3 hours working slowly, I'm a competent wrencher but work like a sloth.
I'm hoping to get some guidance on coding to remove the dash warning light for the 3rd row being unconnected. The electronic buttons to raise/lower the 3rd row are also blinking red.
I quickly looked at the coding and adaptation options in the 3rd Row module and under adaptations there were some "transport mode" and "service mode" options. I don't need full/proper coding, if I can get the error warnings removed from the dash/MMI I will be happy even if there are error codes still in the module. I just don't want to see them!
The Q7 is our first Audi and I come from BMWs where I have history with retrofits and coding. If this was a BMW I would unplug the module for the 3rd row, and via coding remove the 3rd row form the Vehicle Order, maybe change a setting in another module, then save the updated VO to the 2 primary modules and default all remaining modules to learn the new VO.
I'm not sure what the process is for the Audi. My Auto Scan is posted below under the photos.
Thanks for any support!
Evan
Evan
Sunday,08,September,2024,07:57:36:36215
VCDS Version: 24.7.0.0 (x64) HEX-NET CB: 0.4643.4
VIN: WA1VAAF74JD002884 License Plate:
Mileage: 165001km-102526mi Repair Order:
Chassis Type: F7-AU73 (8W6)
Scan: 01 02 03 06 08 09 15 16 17 19 28 29 36 39 3C 42 44 46 47 50
52 5F 6C 6D 81 82 A5 BB BC CA CF D6 D7
VIN: WA1VAAF74JD002884 Mileage: 165001km-102526miles
50-Seat Adj. 3rd row -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4M0 907 551 A HW: 06E 907 425
Component: 3.0l V6 TFSI H10 0005
Revision: --H10--- CVN: 2AE646AC
Coding: 2A2A00320526010D74280000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
ROD: EV_ECM30TFS021_AU73.rod
VCID: 2D12287A7C9C49FE58-8078
VINID: 9D106645158711A50000220810B04F1726
Readiness: 0000 0100
Address 02: Auto Trans Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 L HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1006
Revision: --H05--- CVN: 228D7428
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 3D32183AACFCD97EE8-8068
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Dataset Number: 4M0909504M 0003 CVN: ACFBEF4F
Coding: 28AA149C30A20A9891A6589900815292E6269A14280C50891A004A49676459
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K_AU73.rod
VCID: 45C270DAC42C91BEB0-8010
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M1 959 760 B HW: 4M1 959 760 B
Component: MEM-BFS 008 0031
Serial number: 00000261000783 Dataset Number: 4M0909866C 0016
Coding: 001410000000B0A10060010101010000110000171700171700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 383C092E83DEFC563B-806C
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4M0 907 182 HW: 4M0 907 182
Component: N477 VB1 BFSv H06 0030
Serial number: SJ800126051740258021
Coding: B72F00
Valve block 2 in front seat passenger side:
Subsystem 2 - Part No SW: 4M0 907 182 A HW: 4M0 907 182 A
Component: N478 VB2 BFSv H06 0030
Serial number: SJ80012705171147014A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AB HW: 4M0 820 043 AB
Component: Klima Zone 4 H52 0100
Coding: 6608090C55480111106C0280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 6582905A64ECB1BE50-8030
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001591165
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 88319FA880PAG0MUFU02
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 4M0909514S 0053
Coding: 02500363E0081CCD050F571958AE9CB911033D01900000000000000020001A0108690122025709
VCID: 0248ABC695826686D5-8056
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 170429 044 0893
Serial number: 90115300401711901008
Coding: 1BC7F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20277332X81A955547A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 25 04 2017 00925982
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z0FLQ02
Coding: 350000
Garage door opener control head:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170515090457 00062
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE116031723610801
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 4M0 947 135 CP HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00294369
Subsystem 8 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0080
Serial number: WA127940000034022196
Coding: 0A0100
Subsystem 9 - Part No SW: 4M0 925 301 K HW: 4M0 925 301 K
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000125020
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DH14201634
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DH14400639
Subsystem 12 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DH14201631
Subsystem 13 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DH14400644
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4M0 959 655 F HW: 4M0 959 655 F
Component: Airbag10.44 H02 0104
Serial number: 003UM000THDS Dataset Number: 4M0909602AK 0001
Coding: AECCFCC000800000A0F00033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005.rod
VCID: 3E301F36A1FAC266F1-806A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705K0159R00413
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706K0158R01739
Coding: 88001B
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J170007CIVJ0V
Subsystem 4 - Part No SW: ----------- HW: 442 060 805 17
Serial number: 3577Y009D2439D24B131
Subsystem 5 - Part No SW: ----------- HW: 442 061 105 17
Serial number: 3587Y00AB2439D252380
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 005 17
Serial number: 3517700B12694CA1F2EO
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 005 17
Serial number: 3527700B12694CA62337
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 405 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C12630161A1C.
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 405 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C12630165217T
Part No SW: 4M0 907 129 GM HW: 4M0 907 129 GM
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 014AA4CA90847D9ECC-8054
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 890 C HW: 4M0 920 890 C
Component: FBenUSA H18 0370
Coding: 01E600C12888CF05022369601800000008000000
ROD: EV_DashBoardAU736_AU73.rod
VCID: 302C310E6BAE241673-8064
Part No SW: 8W6 907 468 E HW: 8W6 907 468 E
Component: Gateway H42 0116
Revision: 6B020002 Serial number: 0286B772217602 Dataset Number: 4M0909515L 0080
Coding: 03010001000006405407000000590030CC1A0007100000000175078E10000000
GVL: 01503C0C0800000040FC08000002C800100C2000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003092
VCID: 4CD445FEE74660F66F-8018
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20170605083359 00323
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0236654004
8531970 - Quiescent Current
U1406 00 [00001000] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Reset counter: 206
Mileage: 164941 km
Date: 2024.09.05
Time: 19:40:32
Total static current-current total quiescent current: 118 mA
Total static current-Total time quiescent current exceeded: 1.0 H
EM_vehicle_state: 00 00
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 D HW: 4M0 919 158 D
Component: Klima Zone 2 H52 0103
Coding: 000000000000000100840080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 3620071689CA0A2629-8062
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78BCC92EC35E3C56FB-802C
Component: MEM-FS 008 0031
Serial number: 00000261000782 Dataset Number: 4M0909856C 0018
Coding: 001C1B000000B0A10000010101010000110000171700171700000000000000
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H06 0030
Serial number: SJ800126051740258086
Coding: BF2F00
Valve block 2 in front seat driver side:
Component: N476 VB2 FSv H06 0030
Serial number: SJ800127051711470153
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: -------- Dataset Number: 4M0909535L 0015
Coding: 0E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0125
Serial number: 0000259993292 Dataset Number: 4M0909872G 0031
Coding: 005D9B005E001080000920B0
ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
VCID: 43C66EC2CA18AF8E9E-8016
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0005
Serial number: 0000884300 Dataset Number: 4M0909852P 0002
Coding: 90000001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 34243D1E9FB6183617-8060
Part No SW: 8W0 907 064 DD HW: 8W0 907 064 DD
Component: BCM2 MLBevo 019 0366
Dataset Number: 4M0909501H 0064
Coding: 01341E00492100C0650BA0006E01180203024000810004502F0400000F04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
Subsystem 1 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000069774028
Subsystem 2 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94215876
Part No SW: 4M0 035 223 C HW: 4M0 035 223
Component: MIB2_amp_PD H03 0440
Serial number: 00000000034102 Dataset Number: 4M1909510E 0011
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 2306CE422A588F8EFE-8076
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M1 959 760 G HW: 4M1 959 760 G
Component: MEM-SR3 008 0016
Serial number: 00000260419786 Dataset Number: 4M0909467C 0015
Coding: FF041020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
524346 - Indicator Light 3 for Seat Backrest Adjustmemt; Left
B1609 13 [00101000] - Open Circuit
Reset counter: 210
Mileage: 165001 km
Date: 2024.09.07
Time: 17:32:11
524347 - Indicator Light 3 for Seat Backrest Adjustmemt; Right
B1612 13 [00101000] - Open Circuit
Fault Frequency: 44
Reset counter: 210
Mileage: 165001 km
Date: 2024.09.07
Time: 17:32:11
532544 - Limit Switch for Seat Brackrest Adjustment; Left
B1620 11 [00101001] - Closed
Reset counter: 170
Mileage: 165001 km
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0125
Serial number: 0000261388774 Dataset Number: 4M0909873G 0031
ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
VCID: 42C86BC6D502A68695-8016
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M1 035 880 A HW: 4M1 035 880
Component: MU-P-LNS-US 034 1118
Serial number: A724F0HB021925 Dataset Number: 4M0909545K 0042
Coding: 013706020000000053220002041A00102F001BE501700904FE
VCID: 2B162662428847CE46-807E
Subsystem 1 - Part No SW: V03 959 803 AF HW: -----------
Component: NAR 2020 --- 0076
Multimedia System 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9HJ404E9G
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 31051700000000000687
Compact disc data bank:
Component: Gracenote2 --- 3012
2562 - Navigation System
B126C F0 [00001001] - Navigation Database Faulty
Reset counter: 166
Mileage: 164941 km
Date: 2024.09.05
Time: 17:39:53
Voltage terminal 30: 12.0 V
Reset counter: 166
Mileage: 164941 km
Date: 2024.09.05
Time: 17:39:53
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG017906 Dataset Number: 4M1909460H 0022
Coding: 02350602BA0FA10038404004
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
VCID: 3522001A94CC013E20-8060
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31392086600000 Dataset Number: 4M0909541G 0025
Coding: 0030
VCID: 48DC79EEF33E8CD64B-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 E HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 20170530001311
ROD: EV_GSMWaehlZFAU736_AU72.rod
VCID: 271EDA525E6063AEA2-8072
Address 82: Head Up Display (J898) Labels:| 4M0-919-617-V1.clb
Part No SW: 4M0 919 617 B HW: 4M0 919 617 B
Component: HeadUpDisplay H29 1640
Coding: 2A01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU73.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H14 0042
Dataset Number: 4M0909466L 0042
Coding: 0407030600000201022023A2A50000B400F0C020C000
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
VCID: 2F2E327276903BEE6A-807A
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0125
Serial number: 0000259865838 Dataset Number: 4M0909897G 0030
Coding: 004D9B0000001080400820A0
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
Component: TSG HBFS 005 0125
Serial number: 0000259865748 Dataset Number: 4M0909896G 0030
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Dataset Number: 4M0909469G 0015
Coding: 2A8000053602
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3A381326BDD2EE46CD-806E
Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 33263E029AB81F0E0E-8066
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset Number: 4M0909471D 0012
ROD: EV_LEDModLeftMELCOAU736_AU73.rod
VCID: 1660E796E90AEA2609-8042
0272 - Databus
[can message LED_Soll_Fktx missing]
Reset counter: 166
Mileage: 164941 km
Date: 2024.09.05
Time: 16:52:36
Component: LED1R H09 0003
Dataset Number: 4M0909472D 0012
0272 - Databus
Reset counter: 166
Mileage: 164941 km
Date: 2024.09.05
Time: 16:52:36
End----------(Elapsed Time: 02:43, VBatt start/end: 11.9V/11.9V)-----------
