Backup light brightness - 06 Jetta Mk5
solakian
C?ID=122873
I have read that there is a way to adjust the backup light brightness with VCDS. I believe it can be adjusted through the Central Electric module under the Security Access section. However, Security Access requires a code that I have been unable to locate.
* Can someone provide the code required to access the Security Access section of the Central Electric module?
* Can someone provide information about adjusting the brightness of the backup lights?
Westbury, UK
Without an Auto-Scan to show how your particular Jetta is equipped it's only going to be guesswork, so please post an Auto-Scan
solakian
C?ID=122873
Auto-Scan attached. Please help
Thursday,29,August,2024,13:03:01:48708
VCDS Version: 24.7.0.0 (x64)
VIN: 3VWRT71K76M750179   License Plate: 08-29-24
Mileage: 251369mi   Repair Order: after clear
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K76M750179   Mileage: 404540km-251369miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E3108382
   Coding: 0050071
   Shop #: WSC 00066 000 00000
   VCID: 63CF5290A2EBFC8EBE-8036
   VINID: 0E69E290705B1C674714004724DABCC94B
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71E328D868175E1E3C-8024
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70E52DDC631D571633-8024
            013 - Check DTC Memory
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000226923
   Coding: 14010E234004180000140000001400000008730B5C
   Shop #: WSC 07207 444 82788
   VCID: 2A51FFB485416DC6BD-807E
   Subsystem 1 - Component: Fehler Lin-Slave 01
10 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 12.35 V
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 11.85 V
                    Fault Status: 01101100
                    Reset counter: 28
                    Voltage: 12.80 V
                    Reset counter: 28
                    Voltage: 12.80 V
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 12.00 V
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 12.35 V
02071 - Local Databus
                    Reset counter: 28
                    Mileage: 404545 km
                    Voltage: 14.20 V
                    Fault Status: 00101010
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 12.00 V
                    Reset counter: 68
                    Mileage: 404545 km
                    Voltage: 12.00 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 28
                    Mileage: 404545 km
                    Voltage: 14.20 V
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 39 AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD03ETTS
   Coding: 0013113
   VCID: 3973D0F870E7D65EC4-806C
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0C776228F
   Subsystem 3 - Serial number: 6342MSME0C77682FT
   Subsystem 4 - Serial number: 6351HSME09026024X
   Subsystem 5 - Serial number: 6361HSME09004826/
   Subsystem 6 - Serial number: 63727SME0851530B-
   Subsystem 7 - Serial number: 63827SME08515C260
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
            014 - Defective - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
00591 - Seat Belt Switch; Driver (E24)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78F515FC0B6D0F56FB-802C
   Part No: 1K0 920 952 L
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023207
   Shop #: WSC 07207 444 54372
   VCID: 336FE2D0528B2C0E0E-8066
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105B128D68
   Coding: 3D3F0B40071002
                    Reset counter: 28
                    Mileage: 404545 km
                    Time: 00:05:50
01304 - Radio
                    Reset counter: 28
                    Mileage: 404545 km
                    Time: 00:05:54
   Component: IMMO            3HL 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 3669DBC441F9392629-8062
01340 - Mirror Adjustment Switch
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3261E7D4AD91250605-8066
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74ED21CC17056B36D7-8020
00123 - Outside Warning Light/Door Exit Light; Rear Right
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 3777D6C046F3C02E32-8062
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 3163E8D8A8971E1E7C-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5BF4A8B4AF7AFE58-8078
End-------------------------(Elapsed Time: 01:47)--------------------------
What do you have in MVB 006 of the CECM at address 09 with the car in reverse? Fields 2 and 3 should show the percentage of activation of the left and right backup lights respectively, however I don't see anything in that module that allows for changing it.
solakian
C?ID=122873
Key on, Engine off - R & L backup lights = 100%
Key on, Engine on - R & L backup lights = 82%
solakian
C?ID=122873
Several other forums have suggested that adjustment of this value can be found in 09 CECM under Security Access. Security Access requires a code, the code provided on almost all sites is 31347. I tried this code but it doesn't work on my system. I recently found two other possible codes for the CECM, 20107 & 42013.
I'm not sure how many times I can enter the wrong code before creating an even bigger problem, so I have not tried either 20107 or 42013.
So what it's doing there is backing off the brightness to compensate for the increased voltage when the engine is running; something like 14V vs. 12V.
I guarantee you that if an adjustment exists, it is not "found under security access". And adjustment to an Adaptation channel or Coding could conceivably require a Security Access first, but I've never seen anything that does in that particular CECM, nor is there any documented Security Access code for it.
solakian
C?ID=122873
If there's any truth to what others have posted on the internet (dubious at best), the parameters are listed in the Security Access > select Adaptations > scroll to "Leuchte 28RFL LC11 dimming AB 28" and "Leuchte 29RFL RA64 dimming AB 29". The values range up to 127%. Apparently Leuchte is German for light.
Is there a way you can confirm the existence of these parameters?
I have tried all 3 suggested codes, none worked.
That's for an MQB / Mk.7 BCM and is not at all applicable to your Mk.5 CECM.
