Hi,
I've done the work, search all the forums, but couldn't get an answer to the problem.
It's a golf 7 1.4T DSG.
We only added the Cruise control buttons, the car had already MFSW.
We used the Ross Tech guide, did the wiring and coding, but finished with an error we couldn't fix.
Error 17149 - P1647 Check coding of ECU's on Powertrain Data bus
This is the Scan.
Thanks a lot in advance for the help.
Best, Alex.
This is the Scan.
Wednesday,04,November,2015,16:01:38:38795
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.1.0
Data version: 20150904
Dealer/Shop Name: 1234567890
VIN: 3VWVB6AU0FM101241 License Plate: G7 EZEQUIEL
Mileage: 1536km-954mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: 3VWVB6AU0FM101241 Mileage: 1536km-954miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 G HW: 04E 907 309 A
Component: 1,4l R4 TSI H11 7862
Revision: WAH11---
Coding: 01250032232405080000
ASAM Dataset: EV_ECM14TFS01104E906016G 002011
ROD: EV_ECM14TFS01104E906016G.rod
VCID: 26434C905970860E07-8072
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [038] - -
Mileage: 1536 km
Date: 2015.11.04
Time: 15:34:09
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 047 E HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5220
Revision: 00043014 Serial number: CU501504176738
Shop #: WSC 00066 790 00087
ROD: EV_TCMDQ200021_AU37.rod
VCID: 3D7183FCACE625D676-8068
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 51335000000069
Coding: 01FA6AA12420116D0079060441C4298056248800608294F200 210030C002
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 479DE114FE3A7F06DC-8012
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 HW: 5GM 907 044
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020004200100011005000000101400
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 01093F0C909E813652-8054
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AC HW: 5Q0 937 086 AC
Revision: -------- Serial number: 86581004151853
Coding: 00001842C24102FB0BA44080B1040308100000000000000000 0000000000
Shop #: WSC 00066 790 00206
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7BF54DE4F272EBE608-802E
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150411 043 0581
Serial number: 150608073737
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y15M04D23H13M44S44
Coding: 90A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150481DSH
Serial number: 00000000000062013725
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331511300666
Coding: 0031051011
ROD: EV_EPHVA18AU3700000_SK48.rod
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6M00UREV
VCID: 4189FF0CD01E413612-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 304 15
Serial number: 3576700000092C88B31$
Subsystem 2 - Part No SW: ----------- HW: 480 001 304 15
Serial number: 358670000006BA88B311
Subsystem 3 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3516502991A87865B30D
Subsystem 4 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 35265029B1A8786232AE
Subsystem 5 - Part No SW: ----------- HW: 480 401 404 15
Serial number: 3556502991A878611167
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150409400037
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8DF9F4A6EA37C664-806A
Part No SW: 5G1 920 740 HW: 5G1 920 740
Component: KOMBI 243 4270
Coding: 07A419082180000800082A001000000000000000
VCID: 63C515846AC2332620-8036
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2203
Revision: -------- Serial number: 30041510001048
Coding: 030100042F085700EF0002481C0F0001000105000000000000 0000000000
Shop #: WSC 00066 790 07029
ROD: EV_GatewConti.rod
VCID: 71E96FCCA03E91B6A2-8024
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H17 0103
Serial number: 29150001705890075353
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 6472296203
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 190515060507T2
Coding: 003A02208000040000001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 408FFA08DB14483E1D-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001280071
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
ROD: EV_SteerAssisMQB.rod
VCID: 4385F504CA02532600-8016
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 190515060507BU
Coding: 003A02208E00040000001000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001235966
Coding: 090000
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 041 0421
Serial number: V1C01604151643
Coding: 02730000FF00000021220001001800001F0100040100010001
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 275D41945E7A9F063C-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9RS2093J0
End-------------------------(Elapsed Time: 03:36)--------------------------
Best, Alex.
