Making ESP/ESC Sport Mode the default at start
A4X4
Madison, WI, USA
C?ID=912
2018 Audi RS3
I would like to the ESC setting on start to be Sport Mode (normally one press from default setting).
Thanks for any help.
Sunday,08,September,2024,12:55:31:33590
VCDS Version: 24.7.0.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: WUABWGFF8J1905421   License Plate:
Mileage: 30815km-19147mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 6C BB BC CF D6 D7
VIN: WUABWGFF8J1905421   Mileage: 30815km-19147miles
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H22 0004
   Revision: 53H22000    CVN: 3CAF5420
   Coding: 0A250032242600053620
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D2C55292DF99D82745-8068
   VINID: 9E54529D759621A04900510204756A24F7
10537 - EVAP System Temp Sensor
          P2026 00 [00100000] - Signal too Low
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07    CVN: D08BFA4E
   VCID: 2E0E6265F09F761AFDF-807A
   Part No SW: 8V0 614 517 E    HW: 8V0 614 517 C
   Component: ESC           H25 0625
   Revision: 00000000    Serial number: 63617000000164
   Coding: 2EAA6B7DD4990BAE89950B6681926974D62BD091D0819636024150D4828812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   VCID: 3B285B3133ED93B24A1-806E
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0466533460 Dataset Number: 8V0909577F  0012
   Coding: 030C0C
   VCID: 3C2A582D36E3948A43B-8068
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001447205
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D22CDD5A0BF06A1F3-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 8260DC0900PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001801400554 Dataset Number: 8V0909514AA 0012
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065EFAC538AF1E5A65F-8052
   Component: WWS371 171214  043 0585
   Serial number:         171218105417
   Coding: 0A47F7
   Serial number: 21141529X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 17 09 2017  00000391
   Serial number: 00000000000039740361
   Sunroof control module:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST001XHDZR00000
   Coding: 101F00
          B1263 01 [00001001] - Electrical Failure
                    Reset counter: 20
                    Mileage: 27647 km
                    Date: 2024.07.14
                    Time: 11:10:20
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.2 V
                    Outside temperature: 28.5 °C
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418918011 Dataset Number: 8V0909526J  0062
   Coding: 0470155011
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 4BC80BF1634D2332FA1-801E
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       211217059 Dataset Number: 8V0909554H  0001
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 45DC3DC94529D5422C5-8010
   Serial number: 003GCR09UB5R Dataset Number: 8V0909602R  0002
   Coding: 9DCCFCC0008000005000001AC24800000065
   VCID: 47C037C17F25C752DE9-8012
   Left seat belt tensioner:
   Serial number: 34230167A11011841079
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A17011851468
   Coding: 333135
   Subsystem 3 - Part No SW: 5C6 959 339 C    HW: 5C6 959 339 C
   Component: BF-Gewichtss.  H10 0047
   Serial number: 694000000000001PP6UK
   Coding: 303439
   Subsystem 4 - Part No SW: -----------    HW: 480 000 712 18
   Serial number: 35700000000F320DB53O
   Subsystem 5 - Part No SW: -----------    HW: 480 000 701 18
   Serial number: 35800000000A18FC5A2-
   Subsystem 6 - Part No SW: -----------    HW: 480 400 801 18
   Serial number: 3510001B328DFC73A37I
   Subsystem 7 - Part No SW: -----------    HW: 480 402 212 17
   Serial number: 3520001A7284E2D5668A
   Subsystem 8 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3550002B7252D870617+
   Subsystem 9 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3560002B7252D8763295
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17011804401594
   Coding: 2018
   VCID: 0D4CC5E95DD96D02245-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
   Component: FBenUSA       H16 0066
   Coding: 006D18533B88CF050204EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   Component: GW MQB High   518 5323
   Serial number: 13011810523828 Dataset Number: 8V0909515Q  0089
   Coding: 03010004340860005B00802EB80B00000001010000000000000000000000
   GVL: 01D63C0000000600404C00000002CC0000040000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3822443D02DBB8AAA73-806C
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20180109202248 21567
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 0378336404
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00030.10.17 Dataset Number: v1260x015G0 0000
   Coding: 0601
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   VCID: 4DCC05E99D592D02E45-8018
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   Dataset Number: 8V0909519D  0006
   VCID: 42D626D55407E27A097-8016
   Revision: 00000000    Serial number: 17000393368010
   Coding: 5D00000000000000
   VCID: 343A700D1EB35CCA8BB-8060
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 8V0909520D  0006
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------    Dataset Number: 8V0909535G  0006
   Coding: 040002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   Serial number: 031217EL133513 Dataset Number: 8V0909872J  0040
   Coding: 005F1B205C00048000000002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D823D14B1DEB72021-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: 8V0909852S  0001
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
24320 - Steering
          C10AC 07 [00001001] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                    Reset counter: 172
                    Mileage: 27647 km
                    Date: 2024.07.14
                    Time: 11:09:18
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 63.0 °C
                    KFC: 5F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 12.22 V
                    uAdSensI_SwitchedKl30_xdu16: 12.21 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F016PK2 Dataset Number: 8V0909510G  0007
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI_AU37.rod
   VCID: 241A804DAE53CC4A1BB-8070
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 29121710523123 Dataset Number: 8V0909583C  0008
   Coding: 000000050100143206112300040000000000000000000000000000000000
   VCID: 72B6B615242712FA597-8026
   Serial number: 171217ELH02824 Dataset Number: 8V0909873J  0040
   Coding: 005F13205E00048000000002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 880 D    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1196
   Serial number: A702A0JS006070 Dataset Number: 8V2909545P  0028
   Coding: 017361020000000011220002041A00102F0028E5017001047E
   Subsystem 1 - Part No SW: V03 959 803 AG    HW: -----------
   Component: NAR 2020/2021  --- 0079
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y081DX
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL104121700050018
   Compact disc data bank:
   Component: Gracenote2  --- 3012
                    Reset counter: 172
                    Mileage: 27647 km
                    Date: 2024.07.14
                    Time: 18:49:37
                    Voltage terminal 30: 14.4 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   VCID: 3924413939D1A1A258D-806C
   Serial number: 281117EKR21365 Dataset Number: 8V0909897H  0028
   Coding: 000E13204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   Serial number: 281117EKR21362 Dataset Number: 8V0909896H  0028
   ROD: EV_DCURearPasseMAXKLO.rod
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   Dataset Number: 8V0909471E  0008
   VCID: 1760A7816F0597D28E9-8042
   Dataset Number: 8V0909472E  0008
End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.1V. VIgn 11.8V)-----
AINils
Germany (AIB)
C?ID=56975
There's no mod possible in this case. Never seen an option do mod this. Except maybe an FPA/Drive Select dataset mod, which isn't a VCDS thing
iichel
Netherlands, Operation Market Garden
C?ID=284912
you could try to modify the ESP block behaviour to have it at ON or ESC sport.
This is for the regular 3Q0 and 5Q0 blocks but you could try it on 8V0
