I have reinstalled the mech unit, new filters, o rings, pipes and original audi fluid (G 052 529 A2), final fill between 30-50C (plug back when it drips out) and adaptations at 40-60C (only one Distance sensor calibration successful, rest stopped or error message). Mech unit rebuild has been done in a reputable/professional shop (https://mlreng.com/). Most recent Scan attached. I have 1 code, adaptation at it s limit. Is it safe to say dual clutch is worn and that s the issue? How can I test or check the clutch wear ? Knowing the above, what s the best next step ? Thank you
Friday,19,July,2024,22:45:24:04637
VCDS Version: 24.5.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: WAUCGAFH0CN000645 License Plate: RECENT SEPT 5 2024
Mileage: 232760km-144630mi Repair Order: 4
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 26 2E 36 42 46 47 52 53 55
56 62 72 77
VIN: WAUCGAFH0CN000645 Mileage: 232760km-144630miles
09-Cent. Elect. -- Status: Malfunction 1010
26-Auto Roof -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H07 0003
Revision: --H07--- CVN: BC966676
Coding: 011C000A240F0128
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 3236720E14AE404A917-8066
VINID: 9D19535D1598013780000184142A80733A
Readiness: 1110 0001
Part No SW: 8K2 927 156 S HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0001
Revision: --H10--- Serial number: 0000001676 CVN: 0000D9F8
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 46DE3EDE8826CCEA2DF-8012
8022 - Clutch
P2789 00 [01100101] - Adaptive Learning at Limit
Mileage: 232766 km
Date: 2010.01.22
Time: 04:44:22
Engine RPM: 678 /min
Transmission input speed: 678 /min
Engine torque: 4 Nm
ATF temperature: 55 C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D18
Shop #: WSC 02391 823 56573
VCID: 0256E2CEE40E30CA417-8056
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 76BE8E1EB8C61C6A7DF-8022
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000073916012
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000119323007
Fault Status: 00101101
Reset counter: 69
Mileage: 232766 km
Date: 2010.01.22
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 D HW: 8T0 959 760 D
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00000006112913
Coding: C80170250D2400001000
VCID: 44DA24D6BE9AFEFA33B-8010
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AL HW: 8T1 820 043 AL
Revision: C3000000 Serial number: 01240520111206
Coding: 6603200E
VCID: 7BA89F2A83E44102021-802E
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:41
03220 - Stop Valve for Coolant for Climatronic (N422)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 25
Mileage: 232766 km
Date: 2010.01.22
Time: 00:26:41
Reset counter: 72
Mileage: 232766 km
Date: 2010.02.16
Time: 01:10:44
Voltage: 12.70 V
Temperature: 32.0 C
Temperature: 27.0 C
Count: 10000
Count: 9696
Bin. Bits: 01000000
Bin. Bits: 00001011
Time: 13.00 s
01187 - Rear Temperature Flap Positioning Motor (V137)
Fault Status: 01100010
Reset counter: 29
Mileage: 232766 km
Date: 2010.01.25
Time: 18:55:54
Voltage: 12.80 V
Temperature: 46.0 C
Temperature: 31.0 C
Count: 10000
Count: 8588
Bin. Bits: 01000000
Bin. Bits: 00000111
Time: 9.00 s
00710 - Defroster Flap Positioning Motor (V107)
Fault Status: 00100011
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.22
Time: 00:37:44
Voltage: 13.30 V
Temperature: 31.0 C
Temperature: 37.0 C
Count: 10702
Bin. Bits: 01000000
Bin. Bits: 10000011
Time: 40.00 s
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000927894
Coding: 26001091063CAF010000080000003D3D0F1C528802010161000003
VCID: 3C2A5C36C66A863A4BB-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200511 H07 0021
Serial number: SWF11050205302
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11471563
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000002004111891
Fault Status: 00101100
Reset counter: 64
Mileage: 232766 km
Date: 2010.01.22
Time: 00:39:00
Fault Status: 01101101
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:00
02258 - Door Opener Transmitter
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:00
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H11 0430
Serial number: 003A5D7029NT Dataset Number: 8F0909602B0020
Coding: 303737353631303030304A55304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 363E4E1EF8C65C6ABDF-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1100002UGS
Serial number: 6334MSME60045108/
Serial number: 6344MSME60127A7FM
Serial number: 6352QSME3C1D0272H
Serial number: 6362QSME7E2E4D54+
Serial number: 63732SME400B3D74+
Serial number: 63832SME400B3E7EA
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KEM00050
Coding: 000036
VCID: 3D2C5132DD708F327C5-8068
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 983 D HW: 8T0 920 983 D
Component: KOMBIINSTR. H42 0258
Revision: 00000000 Serial number: EI130CW5C
Coding: 8B1719000300D705020000
VCID: 3FD02B3AD77C9D226E9-806A
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1152880B6
Coding: 00C303
VCID: 0154EDC2E1082BD258D-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1101ECEF170511
02078 - Media Player Position 3 (R120)
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:47
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Reset counter: 32
Mileage: 232766 km
Date: 2010.01.22
Time: 00:20:40
Bin. Bits: 11111
Voltage: 13.70 V
Count: 6
Text: FF33756C80A20000
Inj. Quantity: -9.18 mg/str
Reset counter: 69
Mileage: 232766 km
Date: 2010.01.22
Time: 06:08:00
Bin. Bits: 00000
Voltage: 12.40 V
Count: 17
Reset counter: 69
Mileage: 232766 km
Date: 2010.01.22
Time: 00:00:01
Bin. Bits: 00000
Voltage: 12.60 V
Count: 7
Bin. Bits: 10000
Time: 0.90 s
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
VCID: 71B4BD02D1283B52A8D-8024
0004 - Switch for Convertible Top
B11A0 02 [00001001] - Signal Failure
Reset counter: 28
Mileage: 232766 km
Date: 2010.01.22
Time: 00:04:19
Address 2E: Media Player 3
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00000006112906
Coding: C81973250D2400001000
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C43724E08332C03
VCID: 53F8178A4BF46942BA1-8006
Revision: 00002001 Serial number: 0150901814
Coding: 010602BA00FA442080B0033200000000
014 - Defective
Fault Status: 01101110
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:45
03233 - Controls for Garage Door Opener (E284)
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:45
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 68
Mileage: 232766 km
Date: 2010.01.25
Time: 23:00:47
Reset counter: 69
Mileage: 232766 km
Date: 2010.01.22
03020 - Local databus 2
Reset counter: 71
Mileage: 232766 km
Date: 2010.01.22
Time: 00:00:05
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74BAB416AEBA0E7A43B-8020
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Fault Status: 00101011
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.26
Time: 00:05:44
Voltage: 12.50 V
Temperature: 18.0 C
Bin. Bits: 00000001
00417 - Left Front DSP Mid-Bass Speaker (R101)
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.26
Time: 00:05:44
Voltage: 12.50 V
Temperature: 18.0 C
Bin. Bits: 00000001
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.26
Time: 00:05:44
Voltage: 12.50 V
Temperature: 18.0 C
Bin. Bits: 00000001
00418 - Front Right DSP Mid-Bass Speaker (R102)
Reset counter: 72
Mileage: 232766 km
Date: 2010.01.26
Time: 00:05:44
Voltage: 12.50 V
Temperature: 18.0 C
Bin. Bits: 00000001
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C43324E08332C03
VCID: 52F6128E74EE604AB17-8006
00379 - Terminal 58s
Fault Status: 01101100
Reset counter: 24
Mileage: 232766 km
Date: 2010.01.22
Time: 00:39:41
02123 - Door Warning Light / Entry Light
Reset counter: 27
Mileage: 232766 km
Date: 2010.02.17
Time: 00:28:24
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000953143
VCID: 343A7416EE3A4E7A83B-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000002
VCID: 39244522C558B31250D-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000008 Serial number: AUZ5Z6J1351292
Coding: 05020000010305004159070000
VCID: 46DE3EDE88A6CCEA2DF-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 23
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:42
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010C03324008372C03
VCID: 54FA14964EFA6E7AA3B-8000
Fault Frequency: 12
Reset counter: 32
Mileage: 232766 km
Date: 2010.01.22
Time: 00:10:42
03531 - Belt Assistant
Fault Status: 01100011
Reset counter: 32
Mileage: 232766 km
Date: 2010.01.22
Time: 00:19:38
Component: TSG HR H07 1501
Reset counter: 71
Mileage: 232766 km
Date: 2010.01.25
Time: 23:47:08
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005230054
Coding: 0010300
Shop #: WSC 02335 785 00200
VCID: 3E2E563EDC76942A65F-806A
End----------(Elapsed Time: 01:42, VBatt start/end: 13.5V/13.7V)-----------
