Switch off speed for park assist 2020 Audi Q8
hcuorg
C?ID=405860
Been trying to follow the Audi Q7 and OBD11 for the Q8:
Change the Parking Assist shutdown speed threshold - Camera will stay on until 12-MPH instead of 6-MPH
1. Instruments 09 - Adaptation
2. ORIGINAL - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 10
2a. MOD - UDS Adaptation Channel: IDE03782-Switch-off speed for parking assist
Stored value 20 - (20 IS MAX VALUE ACCEPTED = 12MPH)
But I keep receiving "conditions not correct or request sequence error."
Westbury, UK
If you're using OBDeleven then you should ask for support on their forums, if you're using VCDS then please post an Auto-Scan.
  • Agree
hcuorg
C?ID=405860
I'm using VCDS. Here is my auto-scan.
Monday,16,September,2024,11:02:19:10341
VIN: WA1EVAF17LD002364   License Plate:
Mileage: 61131km-37985mi   Repair Order:
Chassis Type: F1-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 36 3C 42 44 46 47 52 5F 61 69 6D
          74 75 81 A5 BB BC C4 CA CC CF D6 D7 DB DC DE
VIN: WA1EVAF17LD002364   Mileage: 61131km-37985miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DCBD)       Labels: None
   Part No SW: 4M8 907 559 A    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0003
   Revision: B8H11000    CVN: 95C3336B
   Coding: 2A2A00122576010E34286000000400000000000000000000
   Shop #: WSC 33167 004 1048576
   ASAM Dataset: EV_ECM30TFS0114M8907559A 001003
   ROD: EV_ECM30TFS0114M8907559A.rod
   VCID: 3D273C9B7DF328B27C5-8068
   VINID: 9D10559915811DC5000020C610F603912C
   Part No SW: 4M0 927 158 AM    HW: 0D5 927 156 P
   Component: 0D5 30TFSINAR H05 1004
   Revision: --H05---    CVN: 434FF4CE00005592
   Coding: 100000
   Shop #: WSC 31414 041 00001
   ASAM Dataset: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011.rod
   VCID: 7F5B0693377FFAA22E9-802A
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H02 0810
   Serial number: 1906260128
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Dataset Number: 4M8909504K  0004 CVN: A91158B2
   Coding: 28AA149631A20B9893A15C97088152E2F53A8914288CD0C93A104A47AF5C91
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 7EA5FB973075F3AA25F-802A
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Dataset Number: 4M8909514C  0018
   Coding: 07000363E0691CCD070E57889CFE9C38130B37110406009701000A0019331601086308024010000000000100004308185802000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7BA3F2832367E682021-802E
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0301911302969
   Coding: 7DC727
   Serial number: 23358624X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K1 941 501 B    HW: 4K1 941 501 B
   Component: E1 - LTM  H05 0053
   Serial number: 16S21.06.1900300387
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z014402
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE105031923610632
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0415
   Serial number: Q00780926
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA138239000069958860
   Coding: 0A0100
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BJ17754375
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ17774553
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ17854732
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ17754357
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 M    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Dataset Number: 4M8909863K  0004
   Coding: D6659F5C58082C00010360E10000003E4A1246484401009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X.rod
   VCID: 3A2D37876CDD1F8A597-806E
   Part No SW: 4N0 959 655 K    HW: 4N0 959 655 K
   Component: AirbagVW31    H02 2720
   Serial number: 003YUM00EF0W Dataset Number: 4M8909602AE 0002
   Coding: AECCFCC000C00000A000003FF20D410000C5
   Shop #: WSC 31414 032 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 44D1497F1E19597A33B-8010
   Left seat belt tensioner:
   Serial number: 00AI2019177636400000
   Coding: 02F001
   Right seat belt tensioner:
   Serial number: 00AI2019176742600000
   Coding: 02F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000BW9NK0Z
   Coding: 303037
   Subsystem 4 - Part No SW: -----------    HW: 480 000 807 19
   Serial number: 3570000000038A20BD3M
   Subsystem 5 - Part No SW: -----------    HW: 480 000 807 19
   Serial number: 358000000000F921BD3R
   Subsystem 6 - Part No SW: -----------    HW: 480 030 507 19
   Serial number: 351001C2450D0EA089CD
   Subsystem 7 - Part No SW: -----------    HW: 480 030 507 19
   Serial number: 352001C20014F020EF9%
   Subsystem 8 - Part No SW: -----------    HW: 480 032 406 19
   Serial number: 355001C208E0F410A813
   Subsystem 9 - Part No SW: -----------    HW: 480 031 806 19
   Serial number: 356001C2002A3260AA4X
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 030 507 19
   Component: SideSens_B_Df  002 0149
   Serial number: I0P001C2450D06A0AA2W
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 030 507 19
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q001C2001CB0C11CD-
   Part No SW: 4N0 907 129 Q    HW: 4N0 907 129 Q
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 3FDB469377FF3AA26E9-806A
7340544 - Heated Steering Wheel
          B1538 13 [00001001] - Open Circuit
                    Reset counter: 46
                    Mileage: 60524 km
                    Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 126306 min
                    Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
                    Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 12351.56 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 0.00 V
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
   Part No SW: 4K0 920 890 B    HW: 4K0 920 890 B
   Component: FBenUSAACC--- H12 0208
   Dataset Number: 4M8909525D  0019
   Coding: 8BC610C77C88D7050283E16098806B0008003000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2D070CDBAD93B832CC5-8078
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Reset counter: 103
                    Mileage: 60600 km
                    Date: 2024.09.09
                    Time: 11:08:33
   Part No SW: 4K0 907 468 L    HW: 4K0 907 468 C
   Component: Gateway       H06 0262
   Serial number: 1YF03068149701 Dataset Number: 4K0909515E  0036
   Coding: 020100050004064054960000005B0132DC9A004710000000097D078E10000000
   GVL: F1513C000800000082DC88008000C800110C0070000000000000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H07 0004
   Serial number: 20190605062718 30660
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 75885202001907180EDC
131687 - Control Module for Emergency Call and Communications
          U1421 00 [00001000] - No Communication
          [Timeout_Node_0x67_DiagAdress_0075_ConBox]
                    Reset counter: 101
                    Mileage: 60566 km
                    Date: 2024.09.07
                    Time: 23:00:00
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000381316174 Dataset Number: 4M8909856VB 0001
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Dataset Number: 4M8909535C  0014
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 3B23328363E72682421-806E
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0421
   Serial number: YE007SFN01396 Dataset Number: 4M8909872B  0021
   Coding: 001DDB4252001480A001A432
   Shop #: WSC 31414 043 00001
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 46D5537728256B6A2DF-8012
   Dataset Number: 4M8909852F  0004
   Coding: B8000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1FA7B4ADE7CA917-8066
   Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0542
   Dataset Number: 4M8909501E  0026
   Coding: 013400004FB100C0650FA0046C01C80203004000810426502F0400200F04823F001E0101010F11
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU58.rod
   VCID: 0B43A24373C7D602321-805E
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY191750HX6
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000474725
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4M8 945 069 A    HW: 4M8 945 069 A
   Component: SHL_li1  H04 0004
   Serial number: 069A1906200000070523
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11791970
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4M8 945 217 E    HW: 4M8 945 217 E
   Component: SHL_li2  H04 0004
   Serial number: 217E1905240000062233
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4M8 945 070 A    HW: 4M8 945 070 A
   Component: SHL_re1  H04 0004
   Serial number: 070A1906200000070670
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4M8 945 218 E    HW: 4M8 945 218 E
   Component: SHL_re2  H04 0004
   Serial number: 218E1905240000062233
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D01Y1B0 Dataset Number: 4M8909510B  0005
   Coding: 0135360A00AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E9FFFE59797A13B-8070
0600 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [00001001] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 59
                    Mileage: 60524 km
                    Date: 2024.09.07
                    Time: 14:02:41
                    Voltage terminal 30: 12.1 V
0605 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [00001001] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 59
                    Mileage: 60524 km
                    Date: 2024.09.07
                    Time: 14:02:41
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0421
   Serial number: YE007SFM12753 Dataset Number: 4M8909873B  0021
   Coding: 001DDB025E001480A001A430
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 45D7547B15236072245-8010
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 084 F    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   054 2873
   Dataset Number: 4M8909545E  0030
   Coding: 0135360200000000C1220002061C00302F0001E403F008048E
   Shop #: WSC 11455 006 1048576
   VCID: 290FF8CB997BA41220D-807C
   Subsystem 1 - Part No: V03 959 804 LM
   Component: MIB2P_NA_Q219  0377
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M8 919 605 L    HW: 4M8 919 605 F
   Component: DU AU536 Top  H32 0053
   Serial number: INX00128051900150013
   Compact disc data bank:
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004419000077147027
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 L    HW: 4N0 919 603 F
   Component: DU AU651 Bot  H32 0053
   Serial number: INX00114051900170214
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900428619009
                    Reset counter: 46
                    Mileage: 60524 km
                    Date: 2024.09.07
                    Time: 14:02:46
                    Satellite radio tuner status-Antenna current: 107 mA
                    Satellite radio tuner status-Reception quality: No_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
0023 - Tuner for Satellite Radio
          B11CF 96 [00001000] - Component Internal Failure
                    Reset counter: 96
                    Mileage: 60807 km
                    Date: 2024.09.12
                    Time: 15:25:16
                    Voltage terminal 30: 13.1 V
                    Malfunction status: 00 00
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0520982817 Dataset Number: 4M8909527A  0005
   Coding: 0210000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 343119BF4EB9E9FA83B-8060
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4 Dataset Number: 4M8909541C  0007
   Coding: 28B0
Address 74: Chassis Control (J775)       Labels:* Redir Fail!
   Part No SW: 4M8 907 777 CB    HW: 4M8 907 777 D
   Component: Fahrwerk-SG   H52 2135
   Serial number: 0207190141  Dataset Number: 4M8909576J  0010
   Coding: 985C30387844
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 03538A635B979E424A1-8056
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120640 Dataset Number: 4K0909612D  0016
   Coding: 01C020FF4040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FDCF82719D1A3F3-807C
          U1101 00 [00001000] - Active
          [KS_Active]
                    Reset counter: 88
                    Mileage: 60566 km
                    Date: 2024.09.07
                    Time: 19:52:54
458759 - Control Module Incorrectly Coded
          U1014 00 [00001000] - -
          [ECU_coded_wrong]
                    Fault Frequency: 238
                    Reset counter: 103
                    Mileage: 60524 km
                    Date: 2024.09.07
                    Time: 14:04:10
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 19060452873826
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736_AU58.rod
   VCID: 270BFEF38F6F9262369-8072
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Dataset Number: 4M8909466K  0040
   Coding: 020182000000000000FBD60000B0470C139F5600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000072040080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001006
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F7BB65307DFEA22DE9-805A
2117692 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Databus_Ethernet_missing_PDU]
                    Reset counter: 96
                    Mileage: 60807 km
                    Date: 2024.09.12
                    Time: 15:25:29
                    Ethernet signal quality: good: link available
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0421
   Serial number: YE007SFL23475 Dataset Number: 4M8909897B  0021
   Coding: 000DDB0200001480E000A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: 48C95D4F22317D1ADF3-801C
   Component: TSG HBFS004 0421
   Serial number: YE007SFL22892 Dataset Number: 4M8909896B  0021
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC19284000210 Dataset Number: 4M8909475B  0005
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75B7E4BB0543B0F2745-8020
   Dataset Number: 4M8909469C  0011
   Coding: 228040053632
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N1 903 028     HW: 4N1 903 028
   Component: BSG-HP1-65    H18 0562
   Serial number: 19022400020511
   Coding: 20000400000000
   Shop #: WSC 13424 004 1048576
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
   VCID: 698FB8CB59FB6412E0D-803C
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Dataset Number: 4M8909468C  0014
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MLBevo    H06 0031
   Dataset Number: 4M8909471D  0012
   ROD: EV_LMSLeftHELLAAU58X_AU58.rod
   VCID: 71BFD0AB712B9CD2A8D-8024
   Dataset Number: 4M8909472D  0012
   ROD: EV_LMSRightHELLAAU58X_AU58.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Component: MRR_VR H12 0266
   Dataset Number: 4M8909482C  0012
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0266
   Dataset Number: 4M8909483C  0013
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: 2313EAE3FB577E426A1-8076
End----------(Elapsed Time: 02:15, VBatt start/end: 12.7V/12.8V)-----------
Log-WA1EVAF17LD002364-61131km-37985mi.txt
Displaying Log-WA1EVAF17LD002364-61131km-37985mi.txt.
Hi Calvin,
I located your customer file, switched your status to Verified VCDS user and I'll move this to the Tweaks sub-forum.
I'll report back if I have any suggestions.
-Dana
I'm not entirely sure if this applies but I wanted to be able to use my cameras at a higher speed than the factory limit on my e-tron 55 (full original condition maps/scan here: https://forums.ross-tech.com/index.php?threads/32223/ )
.. and that was achieved by changing address A5-Frt Sens. Drv. Assist
IDE03782-Switch-off speed for parking assist,150 km/h
To:
IDE03782-Switch-off speed for parking assist,140 km/h
I don't believe any other changes were needed but keep in mind this was so the Park button in the console will let you turn the cameras on. I don't recall if it also activates the parking system sensors.
hcuorg
C?ID=405860
Thank you Dana! I will try that and report back.
I used the e-tron the other day wanted to report back.
I pressed the button at speed before I pulled into the driveway. The 360 cameras came on as usual but the parking aid showed a muted state until I slowed down while pulling in. I wasn't watching the speed but my guess is under 12 mph. In any event when I got to the lower speed the parking aid sensors immediately started freaking out (as expected) because there's a hitch mount bike rack on it.
The bikes on the back was the point of that tweak so we can check them on occasion. Likewise, looking back at a hitched trailer on occasion is nice as well... but I'm not sure if that really changed the parking sensor activation threshold.
hcuorg
C?ID=405860
I think it worked! Thank you again. My VCDS, it didn't show 150 km/h, just said 10 so I switched it to 20 which I guess is the max limit according to the post I found on Audiworld.
