2022 Skoda Superb iV: display both mileage and ACC icon on the virtual cockpit
mne
Romania
C?ID=579365
Hi,
For my Skoda Superb iV, 2022, my virtual cockpit usually looks like this:
and when ACC (Adaptive Cruise Control) is enabled it looks like this:
As may be seen, at the bottom of the image, the ACC icon overlaps the mileage counter (basically, when ACC is ON the mileage counter can't be read). Is there any way to make the ACC icon be displayed aside from the mileage counter, so that both will be displayed? Something like this:
Here is also the auto-scan:
Saturday,07,September,2024,01:59:51:00048
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: TMBAW7NP6P7017663   License Plate:
Mileage: 23274km-14461mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 18 19 23 2B 36 42 44 4B 51
          52 5F 6C 6D 75 8C A5 BB BC C0 C6 D6 D7
VIN: TMBAW7NP6P7017663   Mileage: 23274km-14461miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGEB)       Labels: None
   Part No SW: 04E 906 024 CA    HW: 04E 907 309 CG
   Component: R4 1.4l TFS   H20 1791
   Revision: DCH20000    CVN: D581EE5E
   Coding: 011D001A636405083008
   Shop #: WSC 00033 790 00157
   ASAM Dataset: EV_ECM14TFS01104E906024CA 002002
   ROD: EV_ECM14TFS011_VW48.rod
   VCID: 629DBD15D4CFB21A297-8036
   VINID: 91D4919C77A01A01C00471860C831BC4A6
   Part No SW: 0DD 300 046 P    HW: 0DD 927 770 E
   Component: GSG DQ400E    H32 2301
   Revision: 00032120    Serial number: 5ZV02206280710 CVN: 0B595D88
   Shop #: WSC 00033 790 00108
   ROD: EV_TCMDQ400021.rod
   VCID: 3537364935C175A2BC5-8060
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 HB    HW: 5QM 614 517
   Component: ESC           H26 0157
   Revision: 00000000    Serial number: 60702000000385 Dataset Number: V03935353T  0001 CVN: 34230982
   Coding: 2807729C33213B73477D060668C648144ECCDCE26016127538A1F5F8D2224A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060_AU37.rod
   VCID: 78A9FF7D625348CA673-802C
16401 - Tire Pressure Warning
          C102D 00 [00101100] - -
                    Mileage: 17104 km
                    Date: 2024.04.05
                    Time: 16:19:54
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0605715511 Dataset Number: V03935332UP 0001
   Coding: 0F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C94FBD5233F84AD73-801C
12786210 - Databus
          U1122 00 [00001000] - Implausible Message
          [Errorvalue Messagecounter Klemmen_Status_01]
                    Reset counter: 83
                    Mileage: 21026 km
                    Date: 2024.07.20
                    Time: 16:28:36
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 13.178 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle locked externally
                    Coding information: coded
                    Actuation to the outside: active
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Entry_Exit_Scan_2
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: Authenticated
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 3V5 907 044 L    HW: 3V5 907 044 L
   Component: Climatronic   H04 2301
   Revision: 00001K00    Dataset Number: V03935340DL 0001
   Coding: 110110040001110D0805000000101030
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 42DD5D95740FD21A097-8016
   Subsystem 3 - Part No SW: 3Q0 963 231 F    HW: 3Q0 963 231 F
   Serial number: -00103.6Z.5A20340248
   Air quality sensor:
   Subsystem 4 - Part No SW: 5Q0 907 659 E    HW: 5Q0 907 659 E
   Component: G238 _AQS  H32 0120
   Serial number: 149630245
   A/C compressor sub:
H03
   Part No SW: 5Q0 937 084 EB    HW: 5Q0 937 084 EB
   Component: BCM MQBAB M+  H44 0511
   Serial number: 01102225200526 Dataset Number: V03935362PR 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW37.rod
   VCID: 7CA1E36D566B64EA03B-8028
   Subsystem 1 - Part No SW: 3V1 955 119 A    HW: 3V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 130722  039 0122
   Serial number: 00000002207110304791
   Coding: 164DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: S6Y22M09D26H10M13S55
   Coding: 00084D
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 JE    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100120920220C100657
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058022256 Dataset Number: V03935314JL 0001
   Coding: 9471151851
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 53F368D19B754B92B21-8006
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3Q0 907 567 B
   Component: ACC BOSCH MQB H03 0780
   Dataset Number: V03935324MH 0001
   Coding: 52017FC25DFFC728949C812481400680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CB4C815F2DF732DE9-8012
   Serial number: 10092241350496 Dataset Number: V03935307L  0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38293F7D22D388CAA73-806C
   Part No SW: 5Q0 959 655 CD    HW: 5Q0 959 655 CD
   Component: AirbagVW21    010 0421
   Serial number: 003J6R8JC3U+ Dataset Number: V03935331UD 0001
   Coding: 98CCC0C0002000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 04519B8D2E9B1C2A7BB-8050
   Subsystem 1 - Part No SW: -----------    HW: 480 001 509 22
   Serial number: 35700000000F1049A16I
   Subsystem 2 - Part No SW: -----------    HW: 480 001 509 22
   Serial number: 3580000000078249A16K
   Subsystem 3 - Part No SW: -----------    HW: 480 401 908 22
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A0C8C2735C959
   Subsystem 4 - Part No SW: -----------    HW: 480 401 908 22
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B2C8C27346585
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 22
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A6C8C27362A6C
   Part No SW: 3V0 920 794 F    HW: 3V0 920 794 F
   Component: KOMBI         526 6220
   Dataset Number: V03935374KH 0001
   Coding: 05A5031A7F840008018C62531001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001048
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 3E25296500F7B6FA6DF-806A
1048578 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuerger\E4t keine oder falsche Grundeinstellung]
                    Reset counter: 10
                    Mileage: 18476 km
                    Date: 2024.05.25
                    Time: 20:47:52
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 102
                    Mileage: 17041 km
                    Date: 2024.04.02
                    Time: 09:06:07
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 88
                    Mileage: 21328 km
                    Date: 2024.07.30
                    Time: 16:21:46
16777022 - Function Restricted due to Interrupted Communications
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Fault Frequency: 89
                    Reset counter: 105
                    Mileage: 17025 km
                    Date: 2024.04.01
                    Time: 12:57:25
16777030 - Function Restricted due to Interrupted Communications
          [BAP_TEL2_0x29 keine Kommunikation]
                    Reset counter: 88
                    Mileage: 17324 km
                    Date: 2024.04.10
                    Time: 19:26:58
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 5WA 963 272 B    HW: 5WA 963 272 B
   Component: STH-VW37x     006 0012
   Serial number: 000000000000235
   Coding: 250A045B5C25172CE44D19
   ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
   ROD: EV_AuxilHeateWOSVW38X_002_VW27.rod
   VCID: 4CC173AD464B146AF3B-8018
   Auxiliary heating remote control:
   Part No SW: 3Q0 907 530 AS    HW: 3Q0 907 530 F
   Component: GW MQB EV     624 6502
   Serial number: 16072211601386 Dataset Number: V03935378VY 0001
   Coding: 0A0900172CE21000BB00425AD81D00000001070100010000000300000000
   GVL: 01463C0008000608509C80009006CC1800000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 0059979D3A83000A5F3-8054
   Subsystem 1 - Part No SW: 5E3 919 719 L    HW: 5E3 919 719 L
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440062234221140
   Coding: 250000
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 0291980306
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2330834
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
                    Reset counter: 69
                    Mileage: 19840 km
                    Date: 2024.06.29
                    Time: 14:29:28
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
197225 - Voltage Converter with Outlet
          U1109 00 [00001000] - No Communications
          [DCAC (LIN#1) Timeout]
                    Reset counter: 71
                    Mileage: 19963 km
                    Date: 2024.07.02
                    Time: 19:44:44
                    Terminal 30 power supply: 13.0 V
                    Terminal 15: On
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AF    HW: 3Q0 909 059 C
   Component: EBKV          H09 0209
   Serial number: BPA085160922013 Dataset Number: V03935367PB 0001
   Coding: 0202C504300000DE7BEFBDF7000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
   VCID: 7BA3E071536563D20A1-802E
108416 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00100000] - -
          [ComScl_Motor_20_Timeout]
108560 - No Communication with Transmission Control Module
          U0101 00 [00101000] - -
          [ComScl_CAN_Getriebe_11_Timeout]
                    Reset counter: 37
                    Mileage: 22809 km
                    Date: 2024.08.20
                    Time: 02:45:07
108592 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_CAN_Getriebe_11_GE_Fahrstufe_Error]
369232 - Control Module Improper Shut Down
          U3001 00 [00101000] - -
                    Mileage: 19751 km
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 22000208910005 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_SK48.rod
   VCID: 323D0D55C4AF629A997-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007VI828961 Dataset Number: V03935343ZD 0001
   Coding: 0010000000000500018280808080000000008181000000D440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 40D9579D7A03C00A1F3-8014
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000479813047  Dataset Number: V03935378DE 0001
   Coding: 00110F20DE00020000001100
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 52FD6DD5A46F429AB97-8006
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000062993178
   Coding: 110200
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 276025 00  Dataset Number: V03935310FE 0001
   Coding: 0100001100410110
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B031031E3853352DA1-807E
   Part No SW: 3Q0 907 338 G    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0382
   Serial number: 10092210804039 Dataset Number: V03935355YQ 0001
   Coding: 00000007090008EA06003D10010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 004006
   ROD: EV_MultiModulContiVW48X_004_VW37.rod
   VCID: 392F3A7919D991C258D-806C
   Part No SW: 3G0 907 080 J    HW: 3G0 907 080 J
   Component: LE Gen 3.3H20 0100
   Revision: 00H20000    CVN: C0320D25
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530113G0907080J 001021
   ROD: EV_DMCM08530113G0907080J.rod
   VCID: 2C01132DE68B346AD3B-8078
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000479681124  Dataset Number: V03935378DD 0001
   Coding: 00110120DE00020000001100
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 51FF62D9A169398280D-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000063023548
   Coding: 090200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 K    HW: 3V0 035 820 K
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0421412  Dataset Number: V03935377LP 0001
   Coding: 34810020008020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK48.rod
   VCID: 3635314528C77EBAB5F-8062
12301 - Ethernet Databus Branch 4
          U122F 00 [00001000] - No Communication
                    Reset counter: 25
                    Mileage: 19826 km
                    Date: 2024.06.27
                    Time: 17:41:46
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 1
12291 - Ethernet Databus Branch 4
          U11BE 00 [00001000] - Electrical Malfunction
                    Reset counter: 25
                    Mileage: 19826 km
                    Date: 2024.06.27
                    Time: 17:41:47
   Dataset Number: V03935342ZE 0001
   Coding: 04840101A2002017000041
   Part No SW: 5WB 959 107 A    HW: 5WB 959 107 A
   Component: HDSG-Modul    H05 0433
   Revision: --------    Serial number: A2-C767-1200-8 Dataset Number: V03935356FX 0001
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_VW37.rod
   VCID: 4EC579A5B057267A9DF-801A
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000209VIWP2 Dataset Number: V03935383VW 0001
   Coding: 034810101969A8819005460161052E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW41.rod
   VCID: 4ACD75B54C3F0A5AC17-801E
7259 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Road Experience Management (0x5B) - Funktionseinschr\E4nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Reset counter: 23
                    Mileage: 21299 km
                    Date: 2024.07.29
                    Time: 14:16:08
                    Voltage terminal 30: 13.6 V
9457171 - Audio signal output 1
          B14F1 13 [00001000] - Open Circuit
                    Reset counter: 4
                    Mileage: 19840 km
                    Date: 2024.06.29
                    Time: 14:29:28
                    Voltage terminal 30: 12.3 V
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 183 E    HW: 3Q0 915 183 D
   Component: J840 K8C  BMC 004 0940
   Serial number: 000000130622080 CVN: D33F78A5062B94111DF230341DF230341DF230341DF230341DF230341DF23034
   ASAM Dataset: EV_BMCeVWBSMQB48 001007
   ROD: EV_BMCeVWBSMQB48_VW41.rod
   VCID: 34310B4D3EBB6CAA8BB-8060
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Component: CMC            H04 0340
   Serial number: 21615B28AH0403405566
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405839
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405571
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403404835
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405149
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405846
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21612B28AH0403403727
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405849
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567404222690 Dataset Number: V03935404MX 0001
   Coding: 00020888114E4020089F10001030008001418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW41.rod
Address C0: Act. for Ext. Noise (----)       Labels:* None
   Part No SW: 3V0 035 335 A    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0361
   Serial number: E2231097660000 Dataset Number: V03935279JS 0001
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_VW38.rod
   VCID: 2D071E29DD913D62C45-8078
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H63 4031
   Revision: --------    Serial number: 150822REO01280 Dataset Number: V03935359SS 0001
   Coding: 115069222004
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001.rod
   VCID: 1D67CEE9AD31CDE2545-8048
12583680 - Function Restricted due to Missing Message(s)
          [BapErr_Timeout_Heartbeat]
                    Fault Frequency: 15
                    Reset counter: 105
                    Mileage: 17093 km
                    Date: 2024.04.05
                    Time: 12:47:45
12583681 - Function Restricted due to Missing Message(s)
          [BapErr_RetryNotSuccessful]
                    Reset counter: 85
14745868 - Discrepancy between Specified and Measured Current
          P33E0 00 [00001000] - Too High
                    Fault Frequency: 67
                    Reset counter: 105
                    Mileage: 17281 km
                    Date: 2024.04.07
                    Time: 20:35:18
1060353 - Charging Cover A; Locking Detection
          P31CF 00 [00001000] - Electrical Malfunction
          [Socket_A_Lock_2_Check_circuit_range/performance]
                    Reset counter: 85
                    Mileage: 17324 km
                    Date: 2024.04.10
                    Time: 20:07:59
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_SK48.rod
   VCID: 619FB219D1C9A90230D-8034
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:20, VBatt start/end: 13.2V/13.2V)-----------
Thanks in advance!
TTT
C?ID=547002
I doubt it.
  • Agree
Westbury, UK
The VC firmware uses the same screen position for both, so to see both at the same time would require VC firmware change I reckon.
BTW it's the same on non-VC instruments - ACC and total mileage use the same display position.
  • Agree
mne
Romania
C?ID=579365
Oh :cry:, I was hoping that the display position of that icon/indicator would have been configurable through an adaptation, or something similar!
Westbury, UK
You could try making an adaptation channel map of the VC and see if there's any channel mentioning VC and/or total mileage display position - but I would be amazed if there is as it would be a significant UI change which is unlikely to have been considered during the firmware design by VAG.
  • Agree
mne
Romania
C?ID=579365
So, you suggest creating a channel map, dumping all the available adaptations, along with their current values, but I'm not sure for which controller (module)?! What "VC" mean? Judging from the names of various controllers, the "17 Instruments" would be the most appealing one, but this is the one you're referring at?
Yup. I don't recall exactly which vehicle in the fleet it is, but I've seen that as well. When I first saw it, I was scratching my head over that design choice since there's plenty of unused rear estate on the screen.
