2022 Skoda Superb iV: unfold mirrors on ignition, rather than doors unlocking
mne
Romania
C?ID=579365
Hi,
For a Skoda Superb iV, 2022, with KESSY, I'm trying to set the mirrors unfolding on the ignition, rather than unlocking (it's a "religion war", I know, but, please, let's not get into that). Currently, the car folds the mirrors automatically when locking it and unfolds them when unlocking.
I've been to module 42-Door Elect, Driver, entered the security code (which, by the way, for this car is 20103), and then Adaption but there I can't find any "(9)-System_Parameter_0-System Parameter Byte8" nor "(2)-System_Parameter_14-System Parameter Byte1" channels, as instructed by various posts. The only possible settings may be seen in the following channel map:
;SW:5Q4-959-593-P   HW:5Q4-959-593-P ---  Door Elect, Driver
;Component:TSG FS        011 0912, Coding:00110F20DE00020000001100
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_AU49.rod
;Saturday,27,July,2024,13:56:57:00048
;VCDS Version: Release 24.5.0 (x64)  Data version: 20240429 DS355.0
;VCID: 52FD6DD5A46F429AB17-8006
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,00 00 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,0D B8 ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,02 8A 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 3C 02 12 19 0A 00 05 F1 1E 1E 0F 00 05 FB 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 00 19 1E 20 1E FA D8 C4 F6 FB 28 1E 32 0A 1E 00 00 32 03 19 0C 12 10 FA EC D8 F6 FB 1E 14 32 00 0C 00 00 82 02 19 0E 16 14 FA D8 C4 F6 FB 28 1E 32 08 0E 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,10 BD ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 1E 00 32 32 01 90 00 00 00 00 00 00 00 AF 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 CD 6D C6 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 37 34 32 31 01 00 00 00 00 00 00 00 00 00 F6 DE ,88
In the Coding section, the only interesting byte would be:
but no trace of unfolding settings.
Any ideas on how this adaptation can be done?
Please also see also the auto-scan log:
Saturday,07,September,2024,01:59:51:00048
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: TMBAW7NP6P7017663   License Plate:
Mileage: 23274km-14461mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 18 19 23 2B 36 42 44 4B 51
          52 5F 6C 6D 75 8C A5 BB BC C0 C6 D6 D7
VIN: TMBAW7NP6P7017663   Mileage: 23274km-14461miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGEB)       Labels: None
   Part No SW: 04E 906 024 CA    HW: 04E 907 309 CG
   Component: R4 1.4l TFS   H20 1791
   Revision: DCH20000    CVN: D581EE5E
   Coding: 011D001A636405083008
   Shop #: WSC 00033 790 00157
   ASAM Dataset: EV_ECM14TFS01104E906024CA 002002
   ROD: EV_ECM14TFS011_VW48.rod
   VCID: 629DBD15D4CFB21A297-8036
   VINID: 91D4919C77A01A01C00471860C831BC4A6
   Part No SW: 0DD 300 046 P    HW: 0DD 927 770 E
   Component: GSG DQ400E    H32 2301
   Revision: 00032120    Serial number: 5ZV02206280710 CVN: 0B595D88
   Shop #: WSC 00033 790 00108
   ROD: EV_TCMDQ400021.rod
   VCID: 3537364935C175A2BC5-8060
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 HB    HW: 5QM 614 517
   Component: ESC           H26 0157
   Revision: 00000000    Serial number: 60702000000385 Dataset Number: V03935353T  0001 CVN: 34230982
   Coding: 2807729C33213B73477D060668C648144ECCDCE26016127538A1F5F8D2224A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060_AU37.rod
   VCID: 78A9FF7D625348CA673-802C
16401 - Tire Pressure Warning
          C102D 00 [00101100] - -
                    Mileage: 17104 km
                    Date: 2024.04.05
                    Time: 16:19:54
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0605715511 Dataset Number: V03935332UP 0001
   Coding: 0F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C94FBD5233F84AD73-801C
12786210 - Databus
          U1122 00 [00001000] - Implausible Message
          [Errorvalue Messagecounter Klemmen_Status_01]
                    Reset counter: 83
                    Mileage: 21026 km
                    Date: 2024.07.20
                    Time: 16:28:36
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 13.178 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle locked externally
                    Coding information: coded
                    Actuation to the outside: active
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Entry_Exit_Scan_2
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: Authenticated
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 3V5 907 044 L    HW: 3V5 907 044 L
   Component: Climatronic   H04 2301
   Revision: 00001K00    Dataset Number: V03935340DL 0001
   Coding: 110110040001110D0805000000101030
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 42DD5D95740FD21A097-8016
   Subsystem 3 - Part No SW: 3Q0 963 231 F    HW: 3Q0 963 231 F
   Serial number: -00103.6Z.5A20340248
   Air quality sensor:
   Subsystem 4 - Part No SW: 5Q0 907 659 E    HW: 5Q0 907 659 E
   Component: G238 _AQS  H32 0120
   Serial number: 149630245
   A/C compressor sub:
H03
   Part No SW: 5Q0 937 084 EB    HW: 5Q0 937 084 EB
   Component: BCM MQBAB M+  H44 0511
   Serial number: 01102225200526 Dataset Number: V03935362PR 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW37.rod
   VCID: 7CA1E36D566B64EA03B-8028
   Subsystem 1 - Part No SW: 3V1 955 119 A    HW: 3V1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 130722  039 0122
   Serial number: 00000002207110304791
   Coding: 164DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: S6Y22M09D26H10M13S55
   Coding: 00084D
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 JE    HW: 5Q1 953 569 J
   Component: Lenks.Modul  H14 0190
   Serial number: 0100120920220C100657
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H10 0075
   Serial number: 000150058022256 Dataset Number: V03935314JL 0001
   Coding: 9471151851
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 53F368D19B754B92B21-8006
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3Q0 907 567 B
   Component: ACC BOSCH MQB H03 0780
   Dataset Number: V03935324MH 0001
   Coding: 52017FC25DFFC728949C812481400680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CB4C815F2DF732DE9-8012
   Serial number: 10092241350496 Dataset Number: V03935307L  0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38293F7D22D388CAA73-806C
   Part No SW: 5Q0 959 655 CD    HW: 5Q0 959 655 CD
   Component: AirbagVW21    010 0421
   Serial number: 003J6R8JC3U+ Dataset Number: V03935331UD 0001
   Coding: 98CCC0C0002000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 04519B8D2E9B1C2A7BB-8050
   Subsystem 1 - Part No SW: -----------    HW: 480 001 509 22
   Serial number: 35700000000F1049A16I
   Subsystem 2 - Part No SW: -----------    HW: 480 001 509 22
   Serial number: 3580000000078249A16K
   Subsystem 3 - Part No SW: -----------    HW: 480 401 908 22
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A0C8C2735C959
   Subsystem 4 - Part No SW: -----------    HW: 480 401 908 22
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B2C8C27346585
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 22
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A6C8C27362A6C
   Part No SW: 3V0 920 794 F    HW: 3V0 920 794 F
   Component: KOMBI         526 6220
   Dataset Number: V03935374KH 0001
   Coding: 05A5031A7F840008018C62531001000800600000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001048
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 3E25296500F7B6FA6DF-806A
1048578 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuerger\E4t keine oder falsche Grundeinstellung]
                    Reset counter: 10
                    Mileage: 18476 km
                    Date: 2024.05.25
                    Time: 20:47:52
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 102
                    Mileage: 17041 km
                    Date: 2024.04.02
                    Time: 09:06:07
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 88
                    Mileage: 21328 km
                    Date: 2024.07.30
                    Time: 16:21:46
16777022 - Function Restricted due to Interrupted Communications
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Fault Frequency: 89
                    Reset counter: 105
                    Mileage: 17025 km
                    Date: 2024.04.01
                    Time: 12:57:25
16777030 - Function Restricted due to Interrupted Communications
          [BAP_TEL2_0x29 keine Kommunikation]
                    Reset counter: 88
                    Mileage: 17324 km
                    Date: 2024.04.10
                    Time: 19:26:58
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 5WA 963 272 B    HW: 5WA 963 272 B
   Component: STH-VW37x     006 0012
   Serial number: 000000000000235
   Coding: 250A045B5C25172CE44D19
   ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
   ROD: EV_AuxilHeateWOSVW38X_002_VW27.rod
   VCID: 4CC173AD464B146AF3B-8018
   Auxiliary heating remote control:
   Part No SW: 3Q0 907 530 AS    HW: 3Q0 907 530 F
   Component: GW MQB EV     624 6502
   Serial number: 16072211601386 Dataset Number: V03935378VY 0001
   Coding: 0A0900172CE21000BB00425AD81D00000001070100010000000300000000
   GVL: 01463C0008000608509C80009006CC1800000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 0059979D3A83000A5F3-8054
   Subsystem 1 - Part No SW: 5E3 919 719 L    HW: 5E3 919 719 L
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440062234221140
   Coding: 250000
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 0291980306
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2330834
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuerger\E4t f\FCr Informationselektronik 1]
                    Reset counter: 69
                    Mileage: 19840 km
                    Date: 2024.06.29
                    Time: 14:29:28
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
197225 - Voltage Converter with Outlet
          U1109 00 [00001000] - No Communications
          [DCAC (LIN#1) Timeout]
                    Reset counter: 71
                    Mileage: 19963 km
                    Date: 2024.07.02
                    Time: 19:44:44
                    Terminal 30 power supply: 13.0 V
                    Terminal 15: On
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AF    HW: 3Q0 909 059 C
   Component: EBKV          H09 0209
   Serial number: BPA085160922013 Dataset Number: V03935367PB 0001
   Coding: 0202C504300000DE7BEFBDF7000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
   VCID: 7BA3E071536563D20A1-802E
108416 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00100000] - -
          [ComScl_Motor_20_Timeout]
108560 - No Communication with Transmission Control Module
          U0101 00 [00101000] - -
          [ComScl_CAN_Getriebe_11_Timeout]
                    Reset counter: 37
                    Mileage: 22809 km
                    Date: 2024.08.20
                    Time: 02:45:07
108592 - Transmission Control Module
          U14E4 00 [00100000] - Received Malfunction Value
          [Scl_CAN_Getriebe_11_GE_Fahrstufe_Error]
369232 - Control Module Improper Shut Down
          U3001 00 [00101000] - -
                    Mileage: 19751 km
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 22000208910005 Dataset Number: V03935342UT 0001
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_SK48.rod
   VCID: 323D0D55C4AF629A997-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007VI828961 Dataset Number: V03935343ZD 0001
   Coding: 0010000000000500018280808080000000008181000000D440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 40D9579D7A03C00A1F3-8014
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000479813047  Dataset Number: V03935378DE 0001
   Coding: 00110F20DE00020000001100
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 52FD6DD5A46F429AB97-8006
   Subsystem 1 - Part No SW: 5Q0 959 407 E    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000062993178
   Coding: 110200
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 276025 00  Dataset Number: V03935310FE 0001
   Coding: 0100001100410110
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B031031E3853352DA1-807E
   Part No SW: 3Q0 907 338 G    HW: 3Q0 907 338 K
   Component: FCM MQB Low   005 0382
   Serial number: 10092210804039 Dataset Number: V03935355YQ 0001
   Coding: 00000007090008EA06003D10010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 004006
   ROD: EV_MultiModulContiVW48X_004_VW37.rod
   VCID: 392F3A7919D991C258D-806C
   Part No SW: 3G0 907 080 J    HW: 3G0 907 080 J
   Component: LE Gen 3.3H20 0100
   Revision: 00H20000    CVN: C0320D25
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530113G0907080J 001021
   ROD: EV_DMCM08530113G0907080J.rod
   VCID: 2C01132DE68B346AD3B-8078
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000479681124  Dataset Number: V03935378DD 0001
   Coding: 00110120DE00020000001100
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 51FF62D9A169398280D-8004
   Subsystem 1 - Part No SW: 5Q0 959 408 E    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000063023548
   Coding: 090200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3V0 035 820 K    HW: 3V0 035 820 K
   Component: MU-O-ND-EU    H22 0306
   Serial number: SKZAZ2A0421412  Dataset Number: V03935377LP 0001
   Coding: 34810020008020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_SK48.rod
   VCID: 3635314528C77EBAB5F-8062
12301 - Ethernet Databus Branch 4
          U122F 00 [00001000] - No Communication
                    Reset counter: 25
                    Mileage: 19826 km
                    Date: 2024.06.27
                    Time: 17:41:46
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 1
12291 - Ethernet Databus Branch 4
          U11BE 00 [00001000] - Electrical Malfunction
                    Reset counter: 25
                    Mileage: 19826 km
                    Date: 2024.06.27
                    Time: 17:41:47
   Dataset Number: V03935342ZE 0001
   Coding: 04840101A2002017000041
   Part No SW: 5WB 959 107 A    HW: 5WB 959 107 A
   Component: HDSG-Modul    H05 0433
   Revision: --------    Serial number: A2-C767-1200-8 Dataset Number: V03935356FX 0001
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_VW37.rod
   VCID: 4EC579A5B057267A9DF-801A
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000209VIWP2 Dataset Number: V03935383VW 0001
   Coding: 034810101969A8819005460161052E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW41.rod
   VCID: 4ACD75B54C3F0A5AC17-801E
7259 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Road Experience Management (0x5B) - Funktionseinschr\E4nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Reset counter: 23
                    Mileage: 21299 km
                    Date: 2024.07.29
                    Time: 14:16:08
                    Voltage terminal 30: 13.6 V
9457171 - Audio signal output 1
          B14F1 13 [00001000] - Open Circuit
                    Reset counter: 4
                    Mileage: 19840 km
                    Date: 2024.06.29
                    Time: 14:29:28
                    Voltage terminal 30: 12.3 V
Address 8C: HV Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 183 E    HW: 3Q0 915 183 D
   Component: J840 K8C  BMC 004 0940
   Serial number: 000000130622080 CVN: D33F78A5062B94111DF230341DF230341DF230341DF230341DF230341DF23034
   ASAM Dataset: EV_BMCeVWBSMQB48 001007
   ROD: EV_BMCeVWBSMQB48_VW41.rod
   VCID: 34310B4D3EBB6CAA8BB-8060
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Component: CMC            H04 0340
   Serial number: 21615B28AH0403405566
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405839
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405571
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403404835
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405149
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405846
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21612B28AH0403403727
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 21615B28AH0403405849
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567404222690 Dataset Number: V03935404MX 0001
   Coding: 00020888114E4020089F10001030008001418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW41.rod
Address C0: Act. for Ext. Noise (----)       Labels:* None
   Part No SW: 3V0 035 335 A    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0361
   Serial number: E2231097660000 Dataset Number: V03935279JS 0001
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_VW38.rod
   VCID: 2D071E29DD913D62C45-8078
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H63 4031
   Revision: --------    Serial number: 150822REO01280 Dataset Number: V03935359SS 0001
   Coding: 115069222004
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001.rod
   VCID: 1D67CEE9AD31CDE2545-8048
12583680 - Function Restricted due to Missing Message(s)
          [BapErr_Timeout_Heartbeat]
                    Fault Frequency: 15
                    Reset counter: 105
                    Mileage: 17093 km
                    Date: 2024.04.05
                    Time: 12:47:45
12583681 - Function Restricted due to Missing Message(s)
          [BapErr_RetryNotSuccessful]
                    Reset counter: 85
14745868 - Discrepancy between Specified and Measured Current
          P33E0 00 [00001000] - Too High
                    Fault Frequency: 67
                    Reset counter: 105
                    Mileage: 17281 km
                    Date: 2024.04.07
                    Time: 20:35:18
1060353 - Charging Cover A; Locking Detection
          P31CF 00 [00001000] - Electrical Malfunction
          [Socket_A_Lock_2_Check_circuit_range/performance]
                    Reset counter: 85
                    Mileage: 17324 km
                    Date: 2024.04.10
                    Time: 20:07:59
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_SK48.rod
   VCID: 619FB219D1C9A90230D-8034
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:20, VBatt start/end: 13.2V/13.2V)-----------
Thanks in advance!
TTT
C?ID=547002
Shouldn’t be something in the 09 adaptations?
2kaa52
Ceska Republica, Praha
C?ID=319193
You can adjust it in Dataset of Modul 42
mne
Romania
C?ID=579365
What is "09 adaptations"? In VCDS I see a button, but it's called "Adaptation - 10", as in the following screenshot:
If that's what you refer to, then the possible adaptations are in the channel map, from the original post. In VCDS they look like this:
On YouTube, I've seen that some VW vehicles have many more other entries on that list!
Can you, please, be more specific? I've looked in the manual but couldn't find any reference about how to adjust the dataset of a module.
Judging from the fact that this module uses a different secret key, the manufacturing year is newer (2022), and, maybe, because it's a Skoda, I'm thinking that this adaptation (and maybe others) might been stripped off, from the factory; or maybe they've been moved elsewhere?!
mathi9020010
C?ID=573263
09 is general electics module
> What happens with ZV is controlled there
Going to Door Modules is completely wrong
Reactions: TTT
mne
Romania
C?ID=579365
Ah, it makes sense now. 2kaa52 was referring to the "09 Cent. Elect." module's adaptations. I've been fiddling with that module, as well, but with no success. All the current adaptation channels, along with their current values, may be seen in the following channel map:
;SW:5Q0-937-084-EB   HW:5Q0-937-084-EB ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+  H44 0511, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,022001,EV_BCMBOSCH_022_VW37.rod
;Sunday,08,September,2024,12:01:21:00048
;VCDS Version: Release 24.7.0 (x64)  Data version: 20240715 DS356.3
;VCID: 7CA1E36D566B64EA03B-8028
IDE01550-Service position,157.494349 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,3
IDE02711-ENG112304-Rear wiper-Heckwischer,not installed ,8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,not active ,8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,45.0 %/s,16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-50.0 °C,11
IDE04928-MAS01577-Anti-theft protection-Parking heater,installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35 52 00 5D 52 00 7F 08 09 7F 00 00 00 00 00 00 35 53 00 5E 52 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 38 00 24 12 16 64 00 00 00 00 00 00 00 00 00 04 42 00 25 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,224
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,23.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,23.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13129-Button in center console-Function of button 2,GTE ,8
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,not_active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,not_active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,not_active ,8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung,not active ,8
IDE07356-Position during interval mode,29.999970 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,6
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,6
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,6
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,6
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,6
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,6
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,6
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,6
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,6
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,6
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,6
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,6
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,6
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,6
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,6
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,6
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,6
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,6
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,6
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,6
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,6
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,6
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,not installed ,9
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multicontour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,0 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,40 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,40 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,40 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,40 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,40 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,40 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,70 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,70 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,40 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,40 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,100 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,100 %,17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,24.494481 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,127 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,1.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG281099-Keyless access and start authorization-Kessy Einzeltuerentriegelung NAR,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG281087-Keyless access and start authorization-Kessy Toggle Taster (NAR),not installed ,3
IDE11944-ENG281074-Keyless access and start authorization-Komfort_oeffnen_ueber_Toggle_Taster,not active ,3
IDE11944-ENG281094-Keyless access and start authorization-Komfort_schliessen_ueber_Toggle_Taster,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE11944-ENG281083-Keyless access and start authorization-Verriegeln über Toggle nur bei geschlossener Außenhaut,not active ,3
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,3
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,3
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,3
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,30
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,30
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,30
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,30
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,30
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,30
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,30
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,30
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,30
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,30
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,30
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,30
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,30
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,30
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,30
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,30
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,30
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,30
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,30
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,30
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,30
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,30
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,30
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,30
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,30
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,30
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,30
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,30
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,30
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,30
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,30
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,30
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,30
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,30
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,30
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,30
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,30
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,30
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,30
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,30
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,30
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,30
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,30
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,30
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,30
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,30
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,30
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,30
IDE80016-Analysis 16,No Response From Subnet Component,30
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,30
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,30
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,30
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,30
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,30
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,30
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,30
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,30
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,30
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,30
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,30
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,30
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,30
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,30
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,30
IDE80017-ENG133480-Analysis 17-OffsetPP1,No Response From Subnet Component,30
IDE80017-ENG133481-Analysis 17-OffsetPP2,No Response From Subnet Component,30
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,30
IDE80017-ENG133478-Analysis 17-OffsetT1,No Response From Subnet Component,30
IDE80017-ENG133479-Analysis 17-OffsetT2,No Response From Subnet Component,30
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,30
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,30
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,30
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,30
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,30
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,30
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,30
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,30
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,30
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,30
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,30
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,30
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,30
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,30
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,30
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,30
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,30
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,30
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,30
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,30
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,30
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,30
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,30
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,30
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,30
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,30
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,30
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,30
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,30
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,30
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,30
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,30
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,30
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,30
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,30
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,30
IDE80018-ENG133480-Analysis 18-OffsetPP1,No Response From Subnet Component,30
IDE80018-ENG133481-Analysis 18-OffsetPP2,No Response From Subnet Component,30
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,30
IDE80018-ENG133478-Analysis 18-OffsetT1,No Response From Subnet Component,30
IDE80018-ENG133479-Analysis 18-OffsetT2,No Response From Subnet Component,30
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,30
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,30
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,30
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,30
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,30
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,30
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,30
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,30
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,30
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,30
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,30
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,30
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,30
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,30
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,30
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,30
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,30
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,30
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,30
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,30
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,30
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,30
MAS01490-ENG141950-Energy management-Hybrid vehicle,Yes ,5
MAS05055-lower turn position,29.999970 °,2
MAS05056-upper turn position,157.494349 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,50 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,50 km/h,9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lamps ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,3000 ms,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_SL ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,696 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,800 lx,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,18
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,18
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,18
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,18
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,18
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,18
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,18
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,18
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,18
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,18
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,18
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,18
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,18
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,18
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,18
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,18
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,18
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,active ,3
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,6
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,6
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,6
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,6
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,6
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,6
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,6
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,6
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,6
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,6
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,6
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,6
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,6
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,6
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,6
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,6
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,6
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,6
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,6
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,6
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,6
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,6
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,6
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,6
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,6
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,6
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,6
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,6
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,6
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,6
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,6
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,6
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,6
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,6
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,6
ENG122934-erase_error_table,00 00 00 ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141685-Front_wash_function,17 ,2
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,6
ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,8
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,8
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,8
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,8
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,8
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,8
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,8
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,8
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,8
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,8
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,8
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,8
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,8
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,8
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,8
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,8
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,8
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,8
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,8
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,8
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,8
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,83.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,67.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,50.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,33.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,17.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-0.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-0.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-0.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,63.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,60.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,57.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,54.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,51.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,45.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,40.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,40.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,36 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,24 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,25 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,22 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,38 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Nebellicht links ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Abbiegelicht links ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,23 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,42 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Nebellicht rechts ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Abbiegelicht rechts ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,minimize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,80 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,127 ,16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,80 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,3C ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,22 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,4 - LED Tagfahrlichtmodul Signal ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Blinken links aktiv (beide Phasen) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Blinken rechts aktiv (beide Phasen) ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Coming Home oder Leaving Home aktiv ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,Rear lid open ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,5D ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,52 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,53 - LED LeiMo3G o Open Load ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,5E ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,53 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,53 - LED LeiMo3G o Open Load ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,Parking light right ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1A 00 E4 00 00 00 00 00 00 00 00 00 04 22 00 3C 06 07 50 1E 00 7F 3F 00 80 21 00 50 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,01 38 00 22 12 16 7F 00 00 00 00 00 00 00 00 00 01 42 00 23 13 17 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,62.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,0.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,1000.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,0.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,20 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Horn operation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,not installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,20
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,20
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,20
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,20
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,20
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,20
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,20
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,20
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,20
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,20
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,20
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,20
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,20
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,20
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,20
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,20
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,20
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,20
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,20
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,20
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,8
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,8
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,8
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,8
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,8
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,8
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,8
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,8
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,8
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,8
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,8
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,8
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,8
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,8
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,8
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,8
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,8
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,8
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,8
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,8
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,8
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,8
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,8
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,8
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,8
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,8
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,8
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,8
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,8
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,8
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,8
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,8
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,8
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,7 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 2.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A58 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,installed ,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1500 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1000 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,100 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,1000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,200 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,300 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,400 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,500 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,600 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,700 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,800 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,900 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,78.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,59.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,44.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,33.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,24.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,17.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,12.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,7.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,3.0 %,22
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,20.0 %,21
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,100 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,1000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,200 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,300 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,400 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,500 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,600 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,700 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,800 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,900 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,3.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,7.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,12.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,17.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,24.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,33.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,44.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,59.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,78.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,installed ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_pin ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.6 s,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
Elapsed Time: 01:46
What needs to be changed, to what values?
By the way, that "ZV" means?
mathi9020010
C?ID=573263
Central locking
  • Agree
