Resolved ABS Controller No Comms, K-Line fail
Resolved
TrekyBob
Aargau, Switzerland
C?ID=590165
On my other A4 B6 3.0 I had to fit used ABS Controller, bought one (same model numbers Bosch 5.7) and installed it but it won't code due K-Line Fail. Any ideas anyone? Here is the Auto Scan.
Thanks have a nice weekend!
Friday,06,September,2024,16:20:37:30198
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZ8E62A102446   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E62A102446   Mileage: 327990km-203803miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559     HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0003
   Coding: 0011751
   Shop #: WSC 63351 000 00000
   VCID: 72BCDCD4A8B87EFA597-5160
   VINID: 9D196AAAA21518244100210418E2A2411F
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 G
   Component: AG5 01V 3.0l5V  RdW 0808
   Coding: 0000001
   VCID: 323C1CD468383EFA997-5160
18161 - Tiptronic Switch (F189)
            P1753 - 003 - Implausible Signal - Intermittent
                    RPM: 1664 /min
                    RPM: 1152 /min
                    RPM: 448 /min
                    (no units): 0.0
                    Torque: 92.0 Nm
                    Temperature: 83.0°C
                    T.B. Angle: 21.6°
                    (no units): 1.0
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 A
   Component: ABS/ESP allrad      4529
   Coding: 00000
   VCID: 2614F08451F0525A05F-51CE
            35-00 - -
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
            66-10 - Not Matched - Intermittent
   Part No: 8E0 820 043 A
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: 1F1AE5600EAA8392469-5160
            41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 D
   Component: int. Lastmodul  RDW 0102
   Coding: 00101
   Shop #: WSC 63351
   VCID: 333219D0922237F2921-4B00
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655
   Component: Airbag 8.4E         3001
   Coding: 0010602
   VCID: 74B0DACCD2AC70CA4BB-5160
   Part No: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00022
   Shop #: WSC 63351
   VCID: 3C2032ECBF7CF88A43B-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8E0 920 900 H
   Component: KOMBI+WEGFAHRS. RB4 D22
   Coding: 01100
   Shop #: WSC 11111
   VCID: 290EFBB840EE7D2228D-5160
   WAUZZZ8E62A102446     AUZ6Z0A0228577
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0202
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BED3D8A88E45E2A0D-4B1E
   Part No: 8E0 959 433 AF
   Component: Komfortgerát T03    0315
   Coding: 06976
   Shop #: WSC 63351
   VCID: 75B6E7C8DCD669C27C5-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 4.22
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 4.22
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
            37-00 - Faulty
01561 - Rear left door
            61-00 - Won't De-Safe
End----(Elapsed Time: 05:34, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Hi Philip,
If the K-line was down entirely you would not have any communication. The scan you posted appears to be fine so I hope the new/used unit was installed at that time.
If you haven't done so already please try the steps here with the engine running at idle in a ventilated place or a battery charger connected:
Based on PR-Codes you would use:
Login
09397
Coding
04497
Make sure G85 calibrates in the same session as the above steps or it will revert back to all zeros. The video at the bottom of that Wiki page should be helpful.
Vehicle Identification No. WAUZZZ8E62A102446
Model audi a4 av. qu. 3.0A4
Date of production 17.09.2001
Year 2002
Sales type 8E50FZ
Engine Code ASN
Transmission Code FLC
G0Q 5-speed automatic transmission forfour-wheel drive
1LT Disc brakes in front
TrekyBob
Aargau, Switzerland
C?ID=590165
Hi Philip,
Login
09397
Coding
04497
Year 2002
Sales type 8E50FZ
Engine Code ASN
Thanks Dana! it worked immediately! A pleasant weekend to you. Phil.
Nice! Thanks for the update and now that I think about it Bosch 5.3 and 5.7 get grumpy and drop communication when you enter an incorrect Login. It could be confused with a communication problem (i.e. like a K-line failure).
I'll mark this solved and have a great weekend as well.
