2013 Golf TDI no start
DEMON-S8
NY. USA
C?ID=56124
Hello all,
Recently purchased a 2013 golf TDI, DSG. The original claimed that while driving in heavy rain the horn activated, and the radio stop working. He then pulled into a parking lot and turned the car off. When he went to restart the vehicle it refused to start. He then noticed that the driver side carpet was soaked. I advised him to remove the battery terminal and have the vehicle towed.
Upon closer review water penitrated the cabin through both the air inlet paas side, and blocking plate driverside under the windshield.
The BCM was removed and dried, along with carpet , etc.
All relays and fuses are good.
The vehicle is push start. When I go to start I hear a relay engage under BCM but no luck.
The starter is not engaging
The engine is not seized.
Although im able to correspond with the BCM, I'm wondering if it still the culprit. With my no crank/start issue.
Tuesday,20,August,2024,18:31:16:39494
VCDS Version: 19.6.2.2
Workshop Code: 444 08310 000118
VIN: WVWBM7AJ8CW283276   License Plate:
Mileage: 119200km-74067mi   Repair Order: tdi  1st
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
          56
VIN: WVWBM7AJ8CW283276   Mileage: 119200km-74067miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
   Part No SW: 03L 906 019 HG    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  2261
   Revision: 12H14---    Serial number: 00000000000000
   Coding: 0050078
   VCID: F7F7C162865782F714-80A2
000401 - Fuel Pressure Sensor (G247)
               P0191 - 000 - Implausible Signal - Intermittent
                    Mileage: 119036 km
                    Date: 2019.01.11
                    Time: 14:48:02
                    RPM: 1265 /min
                    Speed: 24.0 km/h
                    Lambda: 17.4 %
                    Pressure: 616.0 bar
                    Pressure: 528.0 bar
                    Pressure: 472.0 bar
                    Temperature: 30.6°C
054282 - Terminal 30
               U140A - 000 - Open Circuit
                    Voltage: 11.78 V
                    Temperature: -90.0°C
                    Pressure: 0.0 mbar
                    Torque: 0.0 Nm
Readiness: 0 1 0 0 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3102
   Revision: 05551213    Serial number: 00001202240220
   VCID: A649DC26117DCB7F7F-80F2
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Fault Frequency: 255
                    Mileage: 119204 km
                    Date: 2019.01.11
                    Time: 17:22:55
   Revision: 00H31001
   Coding: 114B400C492A00FD880D02EB921F0042B70000
   VCID: FBFFDD527A7FA69770-80AE
                    Reset counter: 49
                    Mileage: 119204 km
                    Date: 2019.01.11
                    Time: 17:19:60
                    Count: 14
                    Count: 4096
                    Count: 166
                    Count: 42496
                    Count: 512
                    Count: 1277
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.11
                    Time: 00:00:54
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 42240
                    Count: 510
                    Count: 256
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0169043623
   Coding: 030C0C
   VCID: B46D366E1FA1A9EFF1-80E0
9 Faults Found:
132356 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
                    Reset counter: 89
132366 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0010 00 [024] - Malfunction
                    Reset counter: 89
132612 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:14
132868 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:38
133124 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:17
1052945 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B F0 [008] - Short Between Poles
                    Reset counter: 72
                    Mileage: 118989 km
                    Date: 2024.08.20
                    Time: 09:17:59
1053201 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C F0 [008] - Short Between Poles
                    Reset counter: 72
                    Mileage: 118989 km
                    Date: 2024.08.20
                    Time: 09:17:59
1057543 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 11 [008] - Short to Ground
                    Reset counter: 76
1057799 - Antenna for Keyless Entry System in Trunk
          B1173 11 [008] - Short to Ground
                    Reset counter: 76
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001018
   Coding: 0000001002
   VCID: 8005AABE1B99C54F25-80D4
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:14
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 88
                    Mileage: 119202 km
                    Date: 2024.08.20
                    Time: 17:09:21
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272A04108800C170008D4448052086574D85B0E48420248040
   VCID: BD7B134A24EB68A70E-80E8
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 23021  26  0512
   Coding: 009795
                    Fault Status: 01101100
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.11
                    Time: 00:00:33
                    Voltage: 11.85 V
                        Term 50 Off
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.11
                    Time: 00:00:33
                    Voltage: 11.85 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.11
                    Time: 00:00:37
                    Voltage: 11.80 V
                        Term 50 Off
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1NGYW
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: BF87694226E77AB71C-80EA
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00002RF700
   Serial number: 3572MSME4E42656AZZZ1
   Serial number: 3582MSME19594063ZZZV
   Serial number: 3512QSME46536D00ZZZS
   Serial number: 3522QSME46566D47ZZZ0
   Serial number: 35527SME3333632BZZZA
   Serial number: 35627SME5E29632BZZZT
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20120229101409
   Coding: 101A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDFBD34A6C6BA8A74E-80A8
   Coding: E30000
117012 - Databus
                    Fault Frequency: 14
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:17
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Coding: 270F01
   VCID: B0653A7EEBB995CF95-80E4
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 34
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:13
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 119204 km
                    Date: 2024.08.20
                    Time: 17:22:55
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:51
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 280212F2001455
   Coding: 350000
   VCID: BA71185635C55F9F2B-80EE
                    Fault Status: 00101110
                    Mileage: 119204 km
                    Date: 2019.01.11
                    Time: 17:22:53
                    Fault Status: 00110100
                    Fault Frequency: 20
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2019.01.11
                    Time: 17:05:18
                    Fault Frequency: 20
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2019.01.11
                    Time: 17:05:18
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EAD1E8160DE52F1F9B-80BE
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 12000024707002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: AE592406F18D833F87-80FA
7 Faults Found:
1048845 - Starter Control; Returned Message
          P3052 00 [008] - 50 Short to Plus
                    Reset counter: 89
                    Mileage: 119204 km
                    Date: 2024.08.20
                    Time: 17:19:13
                    ELV State: 2D
                    Information Clamps: 22 30
                    CoCo State: F0 01
                    WFS State: 67 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 69
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
                    Reset counter: 89
                    Mileage: 119204 km
                    Date: 2024.08.20
                    Time: 17:22:49
                    ELV State: 0A
                    Information Clamps: 00 10
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 67
12665088 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:17
                    ELV State: 04
                    Information Clamps: BB 68
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 1.39 km/h
                    Voltage: 7C
          U1111 00 [008] - -
                    Fault Frequency: 26
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:13
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 1.51 km/h
                    Voltage: 7B
12665089 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:17
                    ELV State: 04
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 7C
12666368 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 119204 km
                    Date: 2024.08.20
                    Time: 17:22:49
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 67
12666369 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 119204 km
                    Date: 2024.08.20
                    Time: 17:22:49
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 67
   Revision: A1001003    Serial number: 7662004628
   Coding: 020000
   VCID: A953D71AC063E40752-80FC
                    Fault Frequency: 8
                    Reset counter: 89
                    Mileage: 119201 km
                    Date: 2019.01.11
                    Time: 17:06:50
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M4203739
   Coding: 04050001010005000000100A
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: A34FC532AA4F3E5718-80F6
   Component: NAR_V2  0002
1048656 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 89
                    Mileage: 119201 km
                    Date: 2024.08.20
                    Time: 17:06:49
          B11CF 53 [009] - Deactivated
                    Reset counter: 175
                    Mileage: 92613 km
                    Date: 2021.12.11
                    Time: 00:16:59
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0001076
   VCID: B7770162C6D742F7D4-80E2
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 26.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0016186
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: A953D71AC863E40752-80FC
          U1111 00 [008] - -
                    Fault Frequency: 15
                    Reset counter: 89
                    Mileage: 119200 km
                    Date: 2024.08.20
                    Time: 17:05:17
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: B26130762DB5A7DFE3-80E6
   Coding: 1446940
   VCID: B46D366ED7A1A9EFF1-80E0
   Component: AFS-Lst.-Modul l    0005
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000022
                    Reset counter: 89
                    Mileage: 119201 km
                    Date: 2019.01.11
                    Time: 17:06:46
                    Voltage: 13.35 V
                        ABS 1
End-------------------------(Elapsed Time: 02:57)--------------------------
Jef
HQ
Flood cars are always... fun.:eek:
Whole lot of "Intermittent" fault codes. Clear them out, lets see what might come back.
Connect to Address 05: Acc/Start Auth. (J518), go into Advance Measuring Values and take a look at "IDE01716-MAS01632-Terminal 50 status-Status". What do you see when trying to start the engine? Hold the key up to the steering column where a normal twist key ignition switch would be and see if that helps anything.
DEMON-S8
NY. USA
C?ID=56124
Will do, 👍
Thanks.
Dr Sheldon
Windsor UK
C?ID=334979
MVB's and Ebay will be your best friends here !!
DEMON-S8
NY. USA
C?ID=56124
Thanks.
Two questions. If I'm unable to find a used BCM with same part#/ HW/ SW specifics, am I able to utilize an alternative from another platform, perhaps an "upgrade", if there is a high line variant.
Secondly, would I need to marry said BCM to the vehicle for proper functionality?
Thanks again.
DEMON-S8
NY. USA
C?ID=56124
Hello all, had a little free time today. Please see scan below.
Also Terminal 15 & Terminal S - Status "on" .
Thanks!!!
Still no start 😕
Monday,09,September,2024,16:23:01:39494
VCDS Version: 24.7.0.0
VIN: WVWBM7AJ8CW283276   License Plate: TDI
          56
2E-Media Player 3 -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
   Coding: 0050078
   VCID: F7F7C1628657822E72-80A2
   VINID: 9E69D274745A2139C22030871804DD7344
   VCID: A649DC26117DCBA619-80F2
   Revision: 00H31001
   VCID: FBFFDD527A7FA64E16-80AE
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:03:33
                    Count: 7
                    Count: 15
                    Count: 20480
                    Count: 128
                    Count: 28928
                    Count: 1
                    Count: 254
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:10:16
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 40704
                    Count: 254
   Revision: 00085000    Serial number: 0169043623 Dataset Number: 5K0116v____ 5K0C
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: B46D366E1FA1A93697-80E0
65813 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:20
   Revision: 00001018
   Coding: 0000001002
   VCID: 8005AABE1B99C59643-80D4
   Revision: 00110 AC
   VCID: BD7B134A24EB687E68-80E8
   Coding: 009795
                    Fault Status: 01100010
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:00:02
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:01:21
                    Voltage: 11.60 V
                        Term 50 Off
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:01:21
                    Voltage: 11.60 V
                        Term 50 Off
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:01:25
                    Voltage: 12.05 V
                        Term 50 Off
   Serial number: 003GVRA1NGYW   Dataset Number: 5K0003v__B_ 0068
   Coding: 00003131
   VCID: BF87694226E77A6E7A-80EA
8 Faults Found:
9440027 - Driver's side; side-airbag igniter
          B100B 1B [10001001] - Resistance Too High
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [10001001] - Resistance Too High
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001001] - Open or Short to Ground
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:17
9445937 - Seat occupied recognition control module
          B1022 31 [10001001] - No Signal
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:24
9444629 - Safety belt switch - passenger side
          B101D 15 [10001001] - Open or Short to Plus
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:17
9444885 - Driver's seat position sensor
          B101E 15 [10001001] - Open or Short to Plus
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:17
13635840 - Supply voltage
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:45
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:01
   Coding: 101A140000
   VCID: FDFBD34A6C6BA87E28-80A8
   Coding: E30000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:35
136194 - Supply voltage
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:29
   Coding: 270F01
   VCID: B0653A7EEBB99516F3-80E4
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:19
   Coding: 350000
   VCID: BA71185635C55F464D-80EE
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:10:20
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:04:19
03272 - Control Module for Audio Interface
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:10:20
   Coding: 000007
   VCID: EAD1E8160DE52FC6FD-80BE
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: AE592406F18D83E6E1-80FA
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:04:04
                    ELV State: 04
                    CoCo State: F0 01
                    WFS State: 67 1A
                    Vehicle speed: 327.25 km/h
                    Voltage: 3D
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:01
                    ELV State: 04
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 4B
   ROD: EV_RNS315NARV2UDS_VW36.rod
   VCID: A34FC532AA4F3E8E7E-80F6
10 Faults Found:
1048578 - Supply voltage
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:18
1048580 - Function Restricted due to Insufficient Voltage
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:03:06
1048613 - Front Left Audio Signal Output
          B1105 13 [00001001] - Open Circuit
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
1048614 - Front Right Audio Signal Output
          B1106 13 [00001001] - Open Circuit
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
1048615 - Rear Left Audio Signal Output
          B1108 13 [00001001] - Open Circuit
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
1048616 - Rear Right Audio Signal Output
          B1107 13 [00001001] - Open Circuit
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:16
1048629 - Aux IN Socket
          B1104 13 [00001001] - Open Circuit
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:17
1048662 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:19
1048660 - Function Restricted due to Missing Message(s)
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:19
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.09.
                    Time: 00:10:14
   Coding: 0001076
   VCID: B7770162C6D7422EB2-80E2
   Revision: 00H22000
            000 - - - MIL ON
                    Mileage: 119205 km
                    Date: 2019.01.31.
                    Time: 00:10:15
                    Battery Volts: 11.6 V
                        DD
                    Temperature: 22.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0001076
   VCID: B26130762DB5A70685-80E6
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1446940
   VCID: B46D366ED7A1A93697-80E0
   Coding: 00000022
   Coding: 00000022
End-------------------------(Elapsed Time: 03:18)--------------------------
Gateway Installation List:  7N0 907 530 M
Still no start 😕
I don't see an obvious reason for it, other than perhaps "Supply voltage -- Voltage too Low" in the 05 - Acc/Start Auth module.
Westbury, UK
Missing/corroded/blown fuse or a water corroded connector/splice?
DEMON-S8
NY. USA
C?ID=56124
Weird... I've even attached a battery booster. And still ,No luck.
DEMON-S8
NY. USA
C?ID=56124
Does anyone know if the BCM not only controls but communicates voltage values to the other control modules? Perhaps I do have proper voltage, but the BCM is only recognizing and distributing low voltage. Would the BCM tell other modules not to proceed with the start sequence/ authorization due to its interpretation of low voltage although the proper voltage is present?
No, it doesn't work that way.
The BCM could prevent a start (actually any cranking by interrupting the starter control circuit) if it believes the car has been broken into.
DEMON-S8
NY. USA
C?ID=56124
Low voltage is most likely the culprit... Weird though as a draw test on the battery did not show the battery to be too much out of CCA specifications.
I will get another battery and advise.
Question... if the BCM believes the vehicle had been broken into due to the water mishap, would there be a code associated with a security no start issue?
Thanks.
DEMON-S8
NY. USA
C?ID=56124
So I think I found the issue. The PCB felt warm to the touch. Upon completion of disassembling , I observed a portion of the contol board partially scorched at the top right hand side near the boards + supply.
IC tested hard short across all pins, whick appeared to be the source of the heat (labeled 66417)...
Is there an upgrade PCB, for this vehicle? My original equipment is # 1K0 937 086 P.
Thanks.
DEMON-S8
NY. USA
C?ID=56124
So, I replaced the BCM, and still no start. I also am now no longer plagued with low voltage codes in most modules. Making progress. The relay to start the vehicle does engage when the button is depressed, but still no start.
Steering lock module J764 now generates P3053 code.
Thanks in advance for any assistance.
          56
   Coding: 0050078
   Revision: 00H31001
                    Fault Status: 00101101
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.02.07.
                    Time: 00:00:15
                    Count: 2
                    Count: 14
                    Count: 20736
                    Count: 8196
                    Count: 44032
                    Count: 254
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.02.07.
                    Time: 00:00:15
                    Count: 2
                    Count: 14
                    Count: 20736
                    Count: 16390
                    Count: 44032
                    Count: 254
   Coding: 030C0C
   Revision: 00001018
   Coding: 0000001002
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AB111709
   Shop #: WSC 08310 444 00118
   VCID: B56B0B6A1CDBB03EA0-80E0
   Coding: 009795
   Coding: 00003131
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:46
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:46
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:46
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:54
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:46
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:46
   Coding: 101A140000
   Coding: E30000
   Coding: 270F01
   Coding: 350000
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.02.07.
                    Time: 00:06:45
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2019.02.07.
                    Time: 00:06:45
   Coding: 000007
1048846 - Starter Control; Returned Message
          P3053 00 [00001000] - 50 Short to Ground
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:07
                    ELV State: 05
                    Information Clamps: 77 67
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 6A
          U1111 00 [00001000] - -
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:04
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6C
                    Reset counter: 89
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:05
                    ELV State: 04
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6C
8 Faults Found:
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:45
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:45
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:45
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:45
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:48
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:48
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:48
                    Reset counter: 49
                    Mileage: 119205 km
                    Date: 2024.09.16.
                    Time: 00:08:43
   Coding: 0001076
   Revision: 00H22000
            000 - - - MIL ON
                    Mileage: 119205 km
                    Date: 2019.02.07.
                    Time: 00:08:45
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 21.0°C
                    Count: 2
                        SteerAng n.Init
   Coding: 0001076
   Coding: 1446940
   Coding: 00000022
   Coding: 00000022
End-------------------------(Elapsed Time: 02:51)--------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Chase that fault code !!
It is for Starter Control !!
It is telling you that Terminal 50 (Starter Exciter) is short to ground !!
Time for Erwin and WD
Jef
HQ
DEMON-S8
NY. USA
C?ID=56124
Initially, I was chasing an electrical issue, as the BCM failed due to failed IC... water damage.
It now appears as if the starter has also STB. I'll swap the starter out this weekend and advise.
There is constant 12v at the starter & 12v at the olenoid when start button depressed, also have good ground...
Dr Sheldon
Windsor UK
C?ID=334979
. There is constant 12v at the starter & 12v at the olenoid when start button depressed, also have good ground...
Not much more it can be - Have you smacked the starter and solenoid full in the face with a hammer / heavy bar as someone turns the key ??
DEMON-S8
NY. USA
C?ID=56124
***Resolved***
Got her started. Thanks to all who assisted.
This particular no start issue was 2 fold.
Bad BCM
Bad Starter
My only task is to program the remote to BCM...
Dr Sheldon
Windsor UK
C?ID=334979
***Resolved***
Bad BCM
Bad Starter
Thank you for the feedback - Enjoy !!
