Wednesday,18,September,2024,17:19:01:02953
VCDS Version: 24.7.0.0 (x64) HEX-NET2 CB: 0.4643.5
VIN: TMBMK7NS3J8067161 License Plate:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 22 2B 36 42 44 4B 52
5F 69 6D 75 D6 D7
VIN: TMBMK7NS3J8067161 Mileage: 126118km-78366miles
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3916
Revision: B4H25--- CVN: D61F7E1537C5C2A2
Coding: 0125001204371D083000
Shop #: WSC 33361 790 00133
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: 76BE8B414847852A75F-8022
VINID: 91D49D6C77A30DA20018704604CEC409CA
Part No SW: 0DL 300 012 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07 CVN: 897AC4DE
VCID: 343A71491EBBD73A8BB-8060
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 50358000000899
Coding: 6007929F54260B734778070662C44906492AD0E2E046927D30615078E2094200002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0469705181 Dataset Number: V03935268ZS 0001
Coding: 032C0C070F
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E2E536120F70D6A6DF-806A
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0023
Serial number: Y0006RAV13847
Coding: 0014000000000500018481818181000000008181000000D400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3D2C546D2DF11672745-8068
Part No SW: 565 907 044 BG HW: 565 907 044 BG
Component: Climatronic H04 2001
Revision: 00001K00
Coding: 16110104002110011005000800101022
Shop #: WSC 33361 790 00119
VCID: 6194C81DF1C9129230D-8034
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 62749958
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: 865803021801VC Dataset Number: V03935276ST 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 065EFB8138A795AA65F-8052
Subsystem 1 - Part No SW: 567 955 119 HW: 567 955 119
Component: WWS326 171224 051 0907
Serial number: 887253F0401735803519
Coding: 164DDD
Component: RLHS 047 0105
Serial number: S4Y18M02D08H03M06S37
Coding: 00885D
Serial number: 000000000ZY173551DEF
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223973535214
Humidity sensor: interior:
U1101 00 [00001001] - Active
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.9 V
Outside temperature: 18.0 C
Part No SW: 3Q0 919 294 B HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0029
Serial number: 000301187478061 Dataset Number: V03935257YW 0001
Coding: 0071451111
ASAM Dataset: EV_EPHBO18VW3260000 007018
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 3822457902D3335AA73-806C
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Dataset Number: V03935259TS 0001
Coding: 3200608950FF8728749C8145004087
ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
[FAULT_THP_EC_INVALID_IKA]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Voltage terminal 15: 11.7 V
Control Module temperature: 62 C
Longitudinal_acceleration_vehicle_reference: -0.13 m/s
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W4P2LKG2$ Dataset Number: V03935257XC 0001
Coding: 98CCC0C0000000005C5400CF008840000065
VCID: 055CFC8D05A19EB26C5-8050
Subsystem 1 - Part No SW: ----------- HW: 454 001 801 18
Serial number: 357000000009F7693C2Z
Subsystem 2 - Part No SW: ----------- HW: 454 001 701 18
Serial number: 358000000001E73CAC2Y
Subsystem 3 - Part No SW: ----------- HW: 454 802 501 18
Serial number: 35100836A4D13000000E
Subsystem 4 - Part No SW: ----------- HW: 454 802 501 18
Serial number: 352005D374D13000000G
Subsystem 5 - Part No SW: ----------- HW: 454 801 801 18
Serial number: 35500BE8B8A12000000Z
B1000 1B [10001001] - Resistance Too High
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
U1101 00 [10001001] - Active
[ATP Error Counter]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Part No SW: 5Q0 953 521 ER HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20180203500422 Dataset Number: V03935264HH 0001
Coding: 1414
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 565 920 951 A HW: 565 920 951 A
Component: KOMBI 304 0312
Coding: 27AC001CAB80A600018D6A011001000800000000
Shop #: WSC 73430 031 00133
VCID: 1B68BAF593257842AA1-804E
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007123073 Dataset Number: V03935268GC 0001
Coding: 030100045F086800FB00005C1C0F00010001070000000000000000000000
GVL: 01D43C0008000600C03C80008000C80000000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
Generator:
Subsystem 2 - Part No SW: 5QA 915 181 C HW: 5QA 915 181 C
Serial number: 75886100001802010226
66304 - Databus
U1124 00 [00001001] - Additional Installations Detected
[Mehrverbau CAN]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 30 power supply: 11.5 V
Terminal 15: On
197169 - Controls in Steering Wheel
U108E 00 [00001001] - No Communications
[MFL (LIN#2) Timeout]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 15: On
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 15: On
15360768 - Component Protection
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 15: On
8526363 - Crash Shut-Down
B189C F0 [00001001] - Active
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00028.11.17 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CCA09A9664BAFFAF3B-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 17000397610015
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 333872551BB5D002921-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006RAV23361
ASAM Dataset: EV_SeatMemorDriveSide 002021
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000304110180 Dataset Number: V03935262NS 0001
Coding: 00150820DE01040000001100
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 47C036857F2D4CA2DE9-8012
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018888949
Coding: 1D0200
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Dataset Number: V03935273NC 0001
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B8B2555B359002521-8026
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01021810522233 Dataset Number: V03935265KZ 0001
Coding: 000000070100037600002D01190000000000000000000000000000000000
VCID: 72B6B751242F990A597-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000303823312 Dataset Number: V03935262NT 0001
Coding: 00150020DE01040000001100
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 46DE3B81782755AA25F-8012
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000018967120
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 565 035 021 B HW: 565 035 021
Component: MU-H-LND-EU H54 1240
Serial number: A853A0JS026940 Dataset Number: V03935274SJ 0001
Coding: 03231601FF00000041111201008808102F0108C601208500DE
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 0D4CC4AD5DD1E6F2245-8058
Subsystem 1 - Part No SW: 565 919 606 D HW: 565 919 606 D
Component: ABT_High-2 H50 9130
Serial number: SKZ6ZHV0252694
Subsystem 2 - Part No SW: V03 959 801 JP HW: -----------
Component: ECE 2018 --- 0166
Compact disc data bank:
Component: Gracenote2 --- 1017
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:46
Voltage terminal 30: 11.9 V
0012 - Digital Radio Antenna
B1103 11 [00001001] - Short to Ground
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:46
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Short circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0469212924 Dataset Number: 55A124t____ 0002
Coding: 0100000202000000
Shop #: WSC 33361 790 00167
VCID: 42D62791540F698A097-8016
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31767018000000 Dataset Number: V03935259NH 0001
Coding: 1B88
VCID: 41D4289D5109729210D-8014
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: -------- Dataset Number: V03935277FY 0001
Coding: 03231601EA421A0D3B1C9E020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C2A596936EB1F7A43B-8068
12866049 - Databus
[Airbag: Error value received]
Reset counter: 192
Mileage: 126118 km
Date: 2024.09.04
Time: 22:30:43
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EAE93616077CD6A2DF-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LEDPLUSRightKEBODVW416.rod
End----(Elapsed Time: 01:50, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
