R8 Cruise Control Coding - Instrument Cluster
Volkswizard
Warwickshire, UK
C?ID=55393
First post but long time lurker having used VCDS for well over two decades now (first job was an ABS issue on a Mk3 Golf VR6!);
I've installed cruise control on my 2014 Gen 1 Audi R8 using VCDS to code as required, as shown in my video below;
It all works fine but unlike my old 2014 R8 which came with cruise, it doesn't display the cruise control speed in the DIS which is a bit annoying. Obviously some coding would fix this but it's not documented in VCDS so easy to put a foot wrong. However I've just found a scan from my old R8 which shows the instrument cluster coding (same part number) as 0069428 as opposed to my current 0000428. Does anybody know for certain what the correct coding should be to just enable cruise and what the 69 in the factory cruise car represent? My old car also had automatic main beam just in case that's relevant but otherwise was identical.
Thanks;
Andrew
Full scan of my current car here;
Tuesday,26,December,2023,17:54:37:44744
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WUAZZZ427EN002581   License Plate:
Chassis Type: 42-AU35 (7N0)
Scan: 01 02 03 08 09 10 11 31 15 16 17 19 25 26 2E 37 3D 42 46 47
          52 56 61 77 A6 C2
VIN: WUAZZZ427EN002581   Mileage: 42290km-26277miles
3D-Special Function -- Status: OK 0000
A6-Microphone -- Status: Malfunction 0010
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (CND)       Labels: None
   Part No SW: 424 910 560 K    HW: 420 907 560 C
   Component: 4.2L V8HDZ/4V FS   ª0010
   Revision: F6H10---    Serial number: AUX7Z0N2FN500P
   Coding: 0110000C240F0020
   Shop #: WSC 55169 001 1048576
   VCID: 1A6C2980A095555AC17-804E
   VINID: 9E546AAAA1021D578000214804598E1C77
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 420 927 155 F    HW: 0BH 927 711 C
   Component: 0BZ_42FSI_RdW H08 1708
   Revision: 00H08V01    CVN: 39B8319B
   ASAM Dataset: EV_TCMDL800041 001006
   ROD: EV_TCMDL800041_AU35.rod
   VCID: 196E368CA9135E42C8D-804C
   Selector lever:
   Subsystem 1 - Part No: 420 713 041 E
   Component: SCHALTBETAET.  C05 0A13
   Serial number: 00000000001203143637
Address 03: ABS Brakes        Labels: 420-910-517.lbl
   Part No SW: 420 910 379 A    HW: 420 614 517 F
   Component: ESP8 quattro    H01 0300
   Coding: 0004356
   Shop #: WSC 02391 785 00200
   VCID: 147047B84271632A9BB-8040
Address 08: Auto HVAC        Labels: 420-820-043.clb
   Part No SW: 420 820 043 J    HW: 420 820 043 J
   Component: J255  Klima 1 Zone  0100
   Revision: 00H06008    Serial number: 00000001254178
   Coding: 1573896
   VCID: 117E4EAC7D639602B0D-8044
   Part No SW: 8P0 907 063 AD    HW: 8P0 907 063 AD
   Component: BCM PQ35  H   113 0771
   Revision: AE113771
   Coding: 47000A20A805F120207068E021200048D2F2AB00B120C92ADC0806140045
   VCID: 76B41D3078CDD13A05F-8022
   Subsystem 1 - Part No SW: 427 955 114 A    HW: 427 955 114 A
   Component: Wischer AudiR  H23 0011
   Coding: 005912
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 025B32
   Subsystem 3 - Part No: 8J0 951 177
   Component: DWA-Sensor H0  H03 0030
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101100
                    Reset counter: 65
                    Mileage: 41917 km
                    Date: 2023.12.18
                    Time: 18:07:58
                    Voltage: 11.30 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 Q    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0150
   Revision: 11001001    Serial number: 12561409100017
   Coding: 10010E
   VCID: 4CC09FD856C1FBEA83B-8018
Address 11: Engine II        Labels: None
Address 15: Airbags        Labels: None
   Part No SW: 427 959 655     HW: 427 959 655
   Component: 13 Airbag 9.43  H02 0030
   Revision: 93H02003    Serial number: 003B80005WT2
   Coding: 0012595
   VCID: 64905778D25153AAABB-8030
   Subsystem 1 - Serial number: 63328RB406E6708FY
   Subsystem 2 - Serial number: 63428RB406E6708CW
   Subsystem 3 - Serial number: 63747RB4072237509
   Subsystem 4 - Serial number: 63847RB4072227B7M
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H38 0070
   Coding: 0004111
   VCID: 41DEBEEC6D83268260D-8014
   Component: E0221           H06 0040
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981 N    HW: 420 920 981 N
   Component: KOMBIINSTR. VDO H05 0793
   Revision: D0H05008    Serial number: 2242N008000202
   Coding: 0000428
   Shop #: WSC 58785 004 1048576
   VCID: 211E1E6C8DC3068200D-8074
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 020414F1003801
   Coding: 355109
   VCID: 7AAC09004CD5B55A617-802E
                    Fault Frequency: 23
                    Reset counter: 31
                    Mileage: 41916 km
                    Date: 2023.10.06
                    Time: 16:11:21
   Revision: D0H05008    Serial number: AUX7Z0N2FN500P
Address 26: Auto Roof (J256)       Labels:| 427-959-255.clb
   Part No SW: 427 959 255 B    HW: 427 959 255 B
   Component: VSG-AU715     H05 0100
   ASAM Dataset: EV_ElectRoofContrAU715 001006
   ROD: EV_ElectRoofContrAU715.rod
   VCID: 221C116084451D9A197-8076
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 420 035 785     HW: 420 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020202
   VCID: 52FC81A0B4E5AD1AC97-8006
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 424 035 192 J    HW: 424 035 192 J
   Component: RNS-E PU EU     H09 0220
   Revision: 0000015S    Serial number: AUZBZ7S5100012
   Coding: 0730725
   Shop #: WSC 07214 003 1048576
   VCID: 186833885E99474AF73-804C
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 A    HW: 8K0 907 440
   Component: STS             H04 0030
   Revision: S0H04000    Serial number: 00000000099511
   Coding: 01010101000000000000000102
   VCID: 2C00FF58FA01DBEAA3B-8078
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 427 959 801 E    HW: 427 959 801 E
   Component: Tuer-SG         H05 0107
   Coding: 0021117
   VCID: 221C116088C51D9A197-8076
Address 47: Sound System        Labels: None
   Part No SW: 427 035 223 A    HW: 427 035 223 A
   Component: J525 Amp High   H05 0110
   Revision: 00H05001    Serial number: 94845028390103
   Coding: 0246122
   VCID: 0D4652DC615BB2E2545-8058
Address 52: Door Elect, Pass.        Labels: None
   Part No SW: 427 959 802 E    HW: 427 959 802 E
   Coding: 0021117
   VCID: 2312146497DF1492121-8076
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0730725
   Component: Batt.regelung H58 1642
   Coding: F32E1146
   VCID: 71BE2E2C11A3F602D0D-8024
   Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
   Component: J367-BDM  H07 0140
   Serial number: 41086537125041981164
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005650905
   Coding: 0011402
   VCID: 3536DA3C294B9A22CC5-8060
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394     HW: 420 907 394
   Component: BELTMICBOX    H09 0060
   Coding: 0100010202
   ASAM Dataset: EV_BeltMicAU715 002011
   ROD: EV_BeltMicAU715_002.rod
   VCID: 56F47DB0988DB13A25F-8002
0080 - Microphone 1 for Drivers Side
          B1203 13 [00001001] - Open Circuit
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 420 927 109 B    HW: 420 927 109 B
   Component: 0BZ DL800     H04 0011
   Revision: --H04---    Serial number: 0000000062 CVN: 0000DF28
   ASAM Dataset: EV_TCMDL800421 001010
   ROD: EV_TCMDL800.rod
   VCID: 147047B84EF1632A9BB-8040
End----------(Elapsed Time: 01:36, VBatt start/end: 12.1V/12.1V)----
