- Apr 9, 2024
- 108
- 3
- California, USA
- C?ID=423275
As per suggestion, I'm starting from scratch from previous thread. I got car back and did autoscan. I will start by checking at lift pump and work upwards from there. On previous thread mentioned DPF Regen frequency fault which has not re-appeared. I did add a dpf cleaner additive and not sure if that did the trick but for the last month or so that code has not retrned. UNfortunately, there is now an EGR code. Last thing that was done was a fuel injector replacement that had higher than normal return. The new injector seems to have solved high return issue, but this EGR code popped up and still low fuel pressure.
Wednesday,04,September,2024,11:18:32:01454
VCDS Version: Release 24.7.0 (x64) Running on Windows 11 x64
Address 01: Engine Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 997 009 J HW: 03L 907 309 S
Component and/or Version: R4 2.0l TDI H23 9982
Software Coding: 001D0012042400000000
Work Shop Code: WSC 22194 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005 (VW41)
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B233CC303E5FA324A1-806E
5211 - Fuel Rail/System Pressure
P0087 00 [10100111] - Too Low
Mileage: 224081 km
Date: 2127.14.31
Time: 23:00:43
Engine RPM: 1783.50 /min
Normed load value: 62.7 %
Vehicle speed: 58 km/h
Coolant temperature: 101 °C
Intake air temperature: 46 °C
Voltage terminal 30: 14.060 V
Unlearning counter according OBD: 80
Fuel temperature: 47.2 °C
Mean injection quantity: 28.64 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1438200 hPa
High fuel pressure: specified value: 1640200 hPa
Pressure control valve adaptation factor: 1.2196
Fuel level: 51.00 l
5212 - Fuel Rail/System Pressure
Mileage: 224081 km
Date: 2127.14.31
Time: 23:00:51
Engine RPM: 1942.50 /min
Normed load value: 99.6 %
Vehicle speed: 63 km/h
Coolant temperature: 102 °C
Voltage terminal 30: 14.100 V
Fuel temperature: 48.7 °C
Mean injection quantity: 22.67 mg/stroke
Fuel high-pressure: actual value: 1435700 hPa
High fuel pressure: specified value: 1591000 hPa
Fuel level: 51.00 l
4881 - EGR Valve (N18)
P1440 00 [00100111] - Open Circuit
Mileage: 224079 km
Date: 2127.14.31
Time: 22:55:20
Engine RPM: 831.00 /min
Normed load value: 26.3 %
Coolant temperature: 98 °C
Intake air temperature: 47 °C
Voltage terminal 30: 13.880 V
Air mass: actual value (mg/stroke): 486.3 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
EGR Solen.val.: actual value: 100.00 %
EGR valve: offset closed: 0.00 %
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 3
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 2
High press EGR actuator: actual unconditioned volt val: 1.8 mV
4900 - EGR Sensor 1
P0405 00 [00100111] - Signal too Low
Mileage: 224079 km
Date: 2127.14.31
Time: 22:55:20
Engine RPM: 828.50 /min
Air mass: actual value (mg/stroke): 488.8 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
High press EGR actuator: actual unconditioned volt val: 2.8 mV
Readiness: 0 0 0 1 1
