Vcds mobile does not show correct description
Ionut198902
Romania
C?ID=593143
Does not show correct description of the errors and measuring of values , I use a iPhone 14 with it .Do you know what is the problem ?
  • Agree
Reactions: TTT
Westbury, UK
Since we have no idea what vehicle you are scanning and there are many thousand errors and measured values you have to give more information.
You can start helping us to help you if you post an Auto-Scan.
Ionut198902
Romania
C?ID=593143
Hello , I will post the log from a Skoda Scout.if I want to make a graph with 2 measure I can not rich to see them.This app is working 100% ? It is a phone problem ?
Wed,Sep,04,2024,18:36:17 VCDS Mobile 0.4643.0.5
Address 01: Engine (CUNA J623) Labels:04L-907-309-V1.clb
Part No SW: 04L-906-021-ER HW: 04L-907-309-A
Component: R4 2.0l TDI H22 9972
Revision: 81H22--- VCID: 79B54EE71D5FDAA86BAF15-802C
e+^L·¸ü~hð×̬vþ
Mileage: 274036 km
Date: 2024.06.07
Time: 00:40:44
Õ_u¨Ø/ÍNbòº1Sʪ/D¿ÆµãMBþÊ9
Mileage: 274036 km
Date: 2024.06.07
Time: 00:04:56
Ionut198902
Romania
C?ID=593143
When it tries to make update ASAM dataset it’s stoping with the message please check you network , but my network is ok .
  • Agree
Reactions: TTT
Shaun
You need to be able to get the rod/ASAM data for this to work, try connecting the interface to a PC with USB and then check for updates using VCIConfig.
Ionut198902
Romania
C?ID=593143
I tried like you said but unfurtunately it is the same problem , it is a software problem , or mobile phone , or internet - I use it for pc an it’s working good .
  • Agree
Reactions: TTT
Shaun
You might want to try switching your interface to the beta channel via the advanced tab of VCIConfig and then check for updates to download the newer dataset that is there which might have better coverage. You may need to do another autoscan and check for updates again to get the newer rod data for this dataset.
Ionut198902
Romania
C?ID=593143
I do like you said in the last message , it starts to decode the error description , it does not work like the pc aplication , it has a lag of functionality , sometimes u need to go back and enter again to acces the module. Probably it’s a beta , maiby in the future we will have a better aplication for mobile.Do you use the mobile aplication daily ? It is ok with the functionality? Thank you
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I will speak on my own behalf.
I always work with PC and Windows. I use the mobile application only for demonstration purposes to customers.
Shaun
The mobile functionality is not at the same level of support as PC, but it should be able to decode fault codes, do you still have issues with this?
