Is it possible to deactivate DRL when the headlights come on in Auto mode or if they're manually turned on? They are always on unless I have the dial turned to "O".
2011 Audi TTS in the USA.
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
VIN: TRUK1AFK9B1017516 License Plate:
Mileage: 77161 Repair Order:
Chassis Type: FK (8P0)
Scan: 01 02 03 08 09 0F 10 14 15 16 17 19 22 25 2E 37 42 44 46 47
4C 52 55 56 61 77
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CDM) Labels:. 06F-907-115-CDL.clb
Part No SW: 8J0 907 115 BA HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH20--- Serial number: AUX7Z0K0FNE08R
Coding: 0113010A1C0F0160
Shop #: WSC 01236 785 00200
VCID: 6C81D4257A8D2BDAE3B-8038
VINID: 92295B05159B252040047141183544DE8D
012423 - Voltage Supply Relay for Engine Components
P3087 - 004 - Electrical Malfunction - Intermittent
RPM: 1436 /min
Load: 24.7 %
Temperature: -4.0°C
Temperature: -4.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.795 V
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
Mileage: 123566 km
Date: 2024.01.12
Time: 13:38:21
RPM: 3249 /min
Load: 20.8 %
Speed: 58.0 km/h
Temperature: 75.0°C
Temperature: 12.0°C
Voltage: 14.605 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0001
Part No SW: 02E 300 013 S HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2741
Revision: 05351112 Serial number: 00001012202144
VCID: 211FF511CDCF36B200D-8074
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 B HW: 8J0 614 517 B
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0618294
VCID: 2C011425BA0DEBDAA3B-8078
Reset counter: 56
Mileage: 123872 km
Count: 128
Count: 11073
Count: 297
Count: 30720
Address 08: Auto HVAC Labels: 8J0-820-043.clb
Part No SW: 8J0 820 043 BD HW: 8J0 820 043 BD
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001174520
Coding: 1572900
VCID: 698FAD31757F3EF298D-803C
Reset counter: 47
Mileage: 123566 km
Date: 2024.01.12
Time: 13:38:27
Reset counter: 56
Mileage: 123936 km
Date: 2024.01.22
Time: 00:21:18
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 L HW: 8P0 907 063 L
Component: BCM PQ35 H 108 0615
Revision: 00108 AE
Coding: 6E000B0FA01336242074C9E001100D4D507E77AA3020D928DC000A440041
Shop #: WSC 01236 758 00200
VCID: 3D2729615D777252045-8068
Subsystem 1 - Part No SW: 8J1 955 119 A HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H07 0070
Coding: 00FD10
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02492C
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
Reset counter: 48
Mileage: 123625 km
Date: 2024.01.16
Time: 17:04:56
Voltage: 14.35 V
Term 50 Off
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7K0593932
Coding: 0000100
VCID: 3635364D7441A10AC5F-8062
Reset counter: 237
Mileage: 122972 km
Date: 2023.12.24
Time: 16:12:15
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36891035020798
Coding: 00010B
VCID: 48C948B502B527FAA73-801C
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 F HW: 8J0 907 376 F
Component: J250 Raddaempfung 0110
Revision: --H22--- Serial number: 190DPH 0361153
Coding: 0000232
VCID: 323D0A5D9829BD2AE97-8066
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: 20 Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K0050584
Coding: 0012848
VCID: 79AFFD7105DF8E7268D-802C
Subsystem 1 - Part No: 8J0 910 339 A
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 05EDM
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ63
Subsystem 4 - Serial number: 000000ÿ6332DRB40D3B88980ÿ63
Subsystem 5 - Serial number: B88980ÿ6342DRB40D3C09AE2ÿ63
Subsystem 6 - Serial number: C09AE2ÿ63747RB405C75C39-ÿ63
Subsystem 7 - Serial number: 75C39-ÿ63847RB405C75C65-ÿ
Subsystem 8 - Serial number: 75C65-ÿ
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014141
VCID: 46D5468D04A1318A55F-8012
Component: E0221 H06 0030
Address 17: Instruments
Part No SW: 8P0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H43 0311
Revision: H43 Serial number: 160111F2000818
Coding: 354100
VCID: 33330F596B33B422E21-8066
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44D15C85329D039A4BB-8010
Part No SW: 8J0 920 990 N HW: 8J0 920 990 N
Component: KOMBIINSTR. VDO H01 0591
Revision: D0H01004 Serial number: AUX7Z0K0FNE08R
VCID: 3D27296151777252045-8068
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020302
VCID: 74B1CC452EBDF31A3BB-8020
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 F HW: 8J0 035 193 F
Component: RNS-E PU US H06 0200
Revision: 0000012S Serial number: AUZBZ7LD800052
Coding: 0619645
VCID: 2D0719218117E2D2B45-8078
Reset counter: 64
Mileage: 117141 km
Date: 2023.07.07
Time: 01:20:29
Voltage: 12.50 V
Reset counter: 64
Mileage: 117141 km
Date: 2023.07.07
Time: 00:41:25
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
02446 - Disk Drive Mechanical Malfunction
Fault Status: 00100011
Fault Frequency: 8
Reset counter: 26
Mileage: 116968 km
Date: 2023.04.27
Time: 14:02:01
Fault Frequency: 45
Reset counter: 56
Mileage: 113876 km
Date: 2022.12.06
Time: 08:02:06
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
Component: Tuer-SG H04 0101
Coding: 0001149
Part No: 8J0 909 144 M
Component: EPS_ZFLS Kl. 241 3201
Revision: 00H20000
VCID: 3A2D227D4059456A217-806E
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000023540
Coding: 0246316
VCID: 2517E101D9E7DA927C5-8070
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H03 0190
Revision: 00000275 Serial number: 00002750052233
Coding: 0614600
Fault Status: 00101101
Reset counter: 56
Mileage: 123936 km
Date: 2024.01.22
Time: 00:21:17
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.20 V
Temperature: 5.0°C
(no units): 0.0
Reset counter: 56
Mileage: 123936 km
Date: 2024.01.22
Time: 00:21:17
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 10.50 V
Temperature: 5.0°C
(no units): 0.0
Part No SW: 8J8 959 802 J HW: 8J8 959 802 J
Coding: 0001148
VCID: 45D7418139A73A925C5-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 M
Component: Dynamische LWR H02 0010
Coding: 0000011
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619645
Reset counter: 64
Mileage: 117141 km
Date: 2023.07.07
Time: 01:20:29
Voltage: 12.50 V
Reset counter: 64
Mileage: 117141 km
Date: 2023.07.07
Time: 00:41:25
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Fault Frequency: 8
Reset counter: 26
Mileage: 116968 km
Date: 2023.04.27
Time: 14:02:01
Fault Frequency: 45
Reset counter: 56
Mileage: 113876 km
Date: 2022.12.06
Time: 08:02:06
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 0311
Coding: F32011FE
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650459324
Part No SW: 8P1 862 336 HW: 8P1 862 336
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005043814
Coding: 0011477
VCID: 75B7F14129C7EA120C5-8020
End----------(Elapsed Time: 01:50, VBatt start/end: 12.3V/12.2V)-----------
