VCDS for 2024+ Cars
halfmillion
Italy
C?ID=305511
I could, but I'm not going to do so in public at this time.
I have a brand-new EU Kodiaq with a lot of options (active suspensions, etcetera) and I could possibly help as a tester if I receive instructions :o
   #22
tkpeters
C?ID=15125
Actually it will if you know the proper sequence of things, and you'll need more than one token.
I have recently purchased a MY2025 Cupra Born & Audi A1, if you would like a complete scan
25.3 will only allow fault code clearing on these models, as it won't even allow access to most of the modules
Cannot even reset the service data, which has nothing to do with cyber-hacking
What were they thinking???
   #23
halfmillion
Italy
C?ID=305511
@Uwe …..I confirm my humble proposal 😎
BrendanS
Canada
C?ID=186795
Many 2024 models need the beta 24.8 due to VAG introducing yet another level of "diagnostic protection"!
Had a 2024 Tiguan this morning that we were unable to reset maintenance warnings on or complete a scan on almost any of the modules. I'm on release 25.3.0, is there anything I can try to reset his oil change warning?
No auto scan :/
TIA
   #26
Westbury, UK
No auto scan :/
TIA
It's probable that SRI reset is protected by SFD on a 2024 model, we need an Auto-Scan to confirm if that is the case here.
   #27
BrendanS
Canada
C?ID=186795
I did save an autoscan but it didnt save on my computer somehow.... Gave the car to customer and he is gone.
I did try it on my autel scanner as well and it said the module was SFD locked and required a paid subscription. Not sure if that helps
   #28
Westbury, UK
Look in the folder C:\Ross-Tech\VCDS\Scans where VCDS auto saves all scans...
BrendanS
Canada
C?ID=186795
Thanks!
Don't know why it didn't save where it normally does in our log folder.
Friday,28,March,2025,09:33:29:59330
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: 3VV8B7AX1RM119561   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 42 4B 52 75
VIN: 3VV8B7AX1RM119561   Mileage: 14280km-8873miles
   Part No SW: 5Q4 959 393 Q    HW: 5Q4 959 393 Q
   Component: TSG FS        016 0920
   Serial number: 28045408501818 Dataset Number: V03935393ED 0001
   Coding: 003E1B200000048008000000
   Shop #: WSC 00066 790 00247
   VCID: D1F49970C167C6A2D09-8084
   Subsystem 1 - Part No SW: 5Q6 959 811 B    HW: 5Q6 959 811 B  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  001 0006
   Serial number: 00000000000019264323
   Coding: 011000
No ASAM data for: "Unknown" (VW37)
   Part No SW: 3Q0 907 338 P    HW: 3Q0 907 338 R
   Component: FCM MQB High  H09 0408
   Serial number: 22032400840253 Dataset Number: V03935418CN 0001
   Coding: 0000000008001D5202010000000000000000000000000000000000000000
   Shop #: WSC 00066 790 00443
   ASAM Dataset: EV_MultiModulContiMQBCl 001009
   ROD: EV_MultiModulContiMQBCl_VW27.rod
   VCID: C2D6A63C14012D3A593-8096
   Part No SW: 5Q4 959 392 Q    HW: 5Q4 959 392 Q
   Component: TSG BFS       016 0920
   Serial number: 29045409301787 Dataset Number: V03935387VV 0001
   Coding: 003E13200000048000000000
   VCID: D0F29C74CA6DCFAADF7-8084
   Subsystem 1 - Part No SW: 5Q6 959 812 B    HW: 5Q6 959 812 B  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  001 0006
   Serial number: 00000000000019326743
   Coding: 091000
   Part No SW: 5WA 035 285 C    HW: 5WA 035 285
   Component: OCUGen3High   H14 0322
   Serial number: 0000000312VIQSG Dataset Number: V03935369LE 0001
   Coding: 023260201968AC209005460160102607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: C7C0B7283F2308128ED-8092
No ASAM data for: "EV_OCUGen3High" (VW37)
0081 - ROD - Unknown Error Code
          - 00 [00001000]
                    Fault Frequency: 142
                    Reset counter: 36
                    Mileage: 545 km
                    Date: 2024.06.04
                    Time: 07:41:44
End-----(Elapsed Time: 01:27, VBatt start/end: 11.8V/0.0V. VIgn 0.0V)------
------------------------------11 Faults Found------------------------------
   #30
Westbury, UK
That's a very weird partial scan, which doesn't show the address of interest i.e the instruments!?
   #31
BrendanS
Canada
C?ID=186795
Yea, only communicated with 4 modules. I did try to "select a control module" as well and it only showed those 4 under the "installed" tab.
   #32
Westbury, UK
@Uwe Any ideas why only those modules show in the scan? I'm wondering if this is SFD2 related?
   #33
Eric
HC800000
That scan would make Dr Lexus proud. Do you happen to have very bad wifi signal? Could you try with USB and make sure the ignition is ON (or even better, engine running) please?
   #34
BrendanS
Canada
C?ID=186795
I thought it was odd, so i tried to system scan it multiple times... same result. Did not show any other modules installed on vehicle. Ignition was on. Car is no longer here so i cannot try with USB but if he returns i will try it.
