VCDS for 2024+ Cars
warpnet
Istanbul, Turkey
C?ID=568249
Hello.
After learning about the UNECE (SFD2) issue, I and maybe many users like me who have vehicles after 2024 are excitedly waiting for the new VCDS version to work in a way that will overcome this situation.
Therefore, I wish the RossTech team good luck :)
When I first connected my new 2024 superb vehicle to VCDS 24.7 with HexV2, 8-9 warning sensor lights came on in the vehicle. VCDS could only read one module at that moment, the others were naturally locked. The only way to turn off the sensor warnings was to remove the battery terminals and reconnect them, but from that moment on, the vehicle did not start at all. When I called roadside assistance and asked for support, the team came and they were also surprised because the vehicle was new and they did not have much information. They connected to the company via the internet with a diag. laptop and applied a software update from Skoda, and the vehicle then started. I do not think that the problem of the vehicle not starting after removing and reconnecting the battery terminals was related to VCDS.
When I removed and reattached the battery terminals, HEXv2 was not installed in the vehicle at that time. However, before car’s malfunction issue, I saw that after installing HEXv2 while the vehicle was off and starting the vehicle, the sensor errors I mentioned above occurred. After removing and reattaching the battery terminals and clearing the errors, I saw that the warnings did not come when connecting HEXv2 while the vehicle was running.
I am currently anxiously waiting for the new version of vcds and hex firmware to come out instead of using the product, because I am afraid of experiencing the same things. I shared it for you to know. The explanation above may seem confusing, if you want detailed information, I can provide it separately.
Eric
HC800000
Should this happen again (or if you want to try again), use Beta 24.8 . It should connect to the other modules and let you see why the warnings came on. I can't really see how a scan tool just reading things would trigger a malfunction like that, but then again we're talking about buggy 2024 VAG cars ;)
warpnet
Istanbul, Turkey
C?ID=568249
:) thanks.
When I disconnected the battery terminal of the vehicle and reconnected it, the place where the vehicle got confused was the garage in the basement of the building. Under no circumstances could a vehicle rescuer come and tow the vehicle. Thank God, a Skoda technician came there and started the vehicle with the software update. My next attempt will actually be to disconnect and reconnect the battery terminal of the vehicle normally, while the hexv2 is not plugged, and I will be on the road so that it can be connected to the tow truck in case of a possible situation.
after making sure that car is behaving normally with battery disconneciton/reconnection, then I will test 24.8 and will share over here.
kiripe
Norway
C?ID=50542
I myself also experienced some issues with the new "UNECE " ME4.0 Enyaq (MY2024). What happened is that after detecting the modules through the gateway it seemed to get "locked" and didn't close the session properly leaving the CAN in a "not ready" state. Both of the times I had to remove ground terminal and engage the brake pedal to "start" the car, and really force the ECU´s to cold boot once I re-attached the ground terminal. I also tried unlocking the gateway with the SFD code first, but it kept the CAN busy.
Only way was ODIS for this car. This was back in spring so probably on sw 23.11. Interesting to see the new beta, will definitely try it when I have time :)
  • Informative
Eric
HC800000
Was that with a hex-v2, HN1, or HN2?
kiripe
Norway
C?ID=50542
It was with one of my Hex-V2´s, don't remember which one of them but both of them H11-xxxxx. Didn't try with my HN2.
Dr Sheldon
Windsor UK
C?ID=334979
Very much doubt that "Luck" is what they need !! Clearly VCDS is what it is through eerm ?? NOT LUCK !!
Time, data, then more time is what they need - Just take it that the task in hand is no walk in the park !
SpeedRacerAZ
C?ID=312337
We bought a 2024 Q5 Hybrid and tried to scan it with the Hex-V2 using the latest firmware and software. Autoscan runs and shows which modules have errors. (Yes, day 1 and 60 miles I already have a CEL) I'm unable to click on modules individually like the Engine, they don't seem to initialize. Any thoughts on this one?
VDCS did ask me to register the VIN, so I was able to license the car even though it can't do anything... I'll try the Beta and see what happens. I'm willing to help test if you need someone.
warpnet
Istanbul, Turkey
C?ID=568249
we are not talking each other on our same native lang. so I only can say the word " luck " with an optimistic approach, and you can easily understand what should be behind that word.
kczach
C?ID=123637
The 24.8 Beta works!!! Thx!!!
I've tried to make some coding changes and getting rejected for workshop codes not being accepted. What was your secret?
kczach
C?ID=123637
Thursday,06,June,2024,20:19:56:18027
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Dealer/Shop Name: CZ
VIN: WUAPDBF2XRN902360 License Plate:
Chassis Type: F2-AU58 (4KL)
Scan: 01 02 03 09 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 61 65 6D
74 75 81 82 A5 A9 BB BC C4 CA CB CC CF D6 D7 DB DC DE 8107
VIN: WUAPDBF2XRN902360 Mileage: 3306km-2054miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DYGA) Labels: Redir Fail!
Part No SW: 4K0 907 557 Q HW: 0P2 907 309 A
Component: V8 4.0l TFSI H31 0001
Revision: 72H31000 CVN: 91663BF7
Coding: 1A2A0012256E010E342C6000000000000000000000000000
Shop #: WSC 02664 785 00200
ASAM Dataset: EV_ECM40TFS0114K0907557Q 001001
ROD: EV_ECM40TFS0114K0907557Q.rod
VCID: 41DF4D17910DACB218D-8014
VINID: 9E5460512582A227890020C60065775E86
Readiness: 1110 0101
Part No SW: 4K0 927 158 BR HW: 0D6 927 156 H
Component: 0D6 40FSINAR H06 0001
Revision: --H06--- CVN: 5B0812A5D85BE3D8
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011.rod
VCID: 0353871FCB917EA24A1-8056
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AB HW: 0D7 321 281 D
Component: V552 ATFP H02 0623
Serial number: 2307142820
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M8 907 379 G HW: 4M8 907 379 G
Component: ESP9 Premium H06 0051
Dataset Number: 4K8909504DB 0003 CVN: C4AC1D44
Coding: 34AA6A9731A20B9813A14D975A7D91E3F43A892C568CD0C8B25A89C72F5C91
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 43D3471F8B11BEA20A1-8016
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 NE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H11 0775
Dataset Number: 4K0909514T 0056
Coding: 07000363C0291CDD170E57881CEF9C28130B37D10426009701051A001B33168108490A028010000000000303004308180802000044010100000000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_BCM1BOSCHAU651 020007
ROD: EV_BCM1BOSCHAU651_020.rod
VCID: 7EA5F6EBA073134A25F-802A
Subsystem 1 - Part No SW: 4K1 955 119 B HW: 4K1 955 119
Component: J400FRWISCH 065 0760
Serial number: 00000002309100401126
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 45043469X81A955555B0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 A HW: 4K1 941 501 A
Component: E1 - LTM H10 0090
Serial number: 19S13.09.2300692747
Subsystem 4 - Part No SW: 4N0 907 410 D HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600400Z00ZW02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR101092323310584
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 AH HW: 4K0 947 135 AH
Component: Dachmodul H42 0419
Serial number: A01497941
Coding: 0D0104
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H09 0210
Serial number: WA164554000141617759
Coding: 0A0700
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BP26338449
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BP26327005
Subsystem 10 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BP26338450
Subsystem 11 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BP26327001
Address 15: Airbags (J234) Labels:. 80A-959-655.clb
Part No SW: 4M0 959 655 AJ HW: 4M0 959 655 AJ
Component: AirbagVW33 H05 4428
Serial number: 00387M002PWD Dataset Number: 4K0909602DA 0011
Coding: BFFCFCC000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 003003
ROD: EV_AirbaVW31SMEAU65x_003_VW53.rod
VCID: 0353871FCB917EA24A1-8056 SFD
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2023264035600000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2023264034400000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H15 0022
Serial number: IBH0000D23000L7YZA0%
Coding: 303233
Subsystem 4 - Part No SW: ----------- HW: 480 002 609 23
Serial number: 3570000000071310CB6D
Subsystem 5 - Part No SW: ----------- HW: 480 002 209 23
Serial number: 35800000000C73D4AA6
Subsystem 6 - Part No SW: ----------- HW: 480 031 710 22
Component: SideSensor_Dr 002 0149
Serial number: 351003C0C109D58158FF
Subsystem 7 - Part No SW: ----------- HW: 480 031 710 22
Component: SideSensor_Pr 002 0149
Serial number: 352003C0CE50D580BE7S
Subsystem 8 - Part No SW: ----------- HW: 480 032 009 23
Component: FrontSensor_D 002 0149
Serial number: 355004C002A10110FBC$
Subsystem 9 - Part No SW: ----------- HW: 480 032 009 23
Component: FrontSensor_P 002 0149
Serial number: 356004C002A0CE208C15
Part No SW: 4N0 907 129 PA HW: 4N0 907 129 PA
Component: Lenks.Modul H03 0011
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 7F5B0BEFA7791A422E9-802A
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 890 G HW: 4K0 920 890 G
Component: FBenUSA------ H29 0262
Coding: 0B4F54F17EA8CF05029067649800D31008402000
ASAM Dataset: EV_DashBoardAU65X 002039
ROD: EV_DashBoardAU65X_002_AU58.rod
VCID: 323D12DB24AB072A917-8066
Part No SW: 4KL 907 468 M HW: 4KL 907 468 L
Component: Gateway H06 0025
Serial number: F0979374960721 Dataset Number: 4K0909515Q 0073
Coding: 02030001000406405496000000590132FC9A00C898000200090000CE04030000
GVL: F1597C580800000002DC88008100C800110C0070000000040000000000006700
ASAM Dataset: EV_Gatew31xUNECE 005014
ROD: EV_Gatew31xUNECE_VW53.rod
VCID: 5AED9A7B1C9B1F6A797-800E SFD
Subsystem 1 - Part No SW: 4K0 951 523 P HW: 4K0 951 523 P
Component: E221__MFL H06 0010
Subsystem 2 - Part No SW: 4K0 915 181 D HW: 4K0 915 181 D
Component: J367-BDMConti H05 1076
Serial number: 785688000023092503E7
Subsystem 3 - Part No SW: 4K0 419 508 D HW: 4K0 419 508 D
Component: J1158 KLR H03 0020
Serial number: 23146005804S0020H032
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 G HW: 8W0 907 144 D
Component: SCU_MLBevo H04 0810
Serial number: 30303030303030
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 B HW: 8W0 907 163 B
Component: QSP QCU Gen2 H08 0080
Revision: A2C74525 Serial number: 605340418201607
Coding: 0300
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 3B233FFFF3E1C662421-806E
Part No SW: 4K0 959 760 HW: 4K0 959 760
Component: MEM-FS 011 0071
Serial number: 00000508841505 Dataset Number: 4K8909856F 0021
Coding: 015C1A400000B4010083010101010000000000000000000000000000004000
VCID: 73B3D7DF9B314E225A1-8026
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 AM HW: 4N0 907 566 A
Component: MRR_HR H28 0588
Dataset Number: 4K8909535G 0028
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001022
ROD: EV_RearRadarS1DelphAU651.rod
VCID: 015F8D17D18D6CB258D-8054
Part No SW: 4M1 959 793 K HW: 4M1 959 793 K
Component: TSG FS 004 0463
Serial number: YE007WIR06006 Dataset Number: 4K8909872D 0048
Coding: 001DCB4352001280A009A432
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 47CB530FBF299282D69-8012
Part No SW: 4N0 909 144 H HW: 4N0 909 144 D
Component: EPS_MLBEVO2BS H24 0512
Dataset Number: 4K8909852BB 0003
Coding: E1132301010001
ASAM Dataset: EV_SteerAssisUNECEAU651 001003
ROD: EV_SteerAssisUNECEAU651.rod
VCID: 353729C7D5C51012B45-8060 SFD
Part No SW: 4N0 907 064 HD HW: 4N0 907 064 HD
Component: BCM2 MLBevo H19 0285
Dataset Number: 4K8909501BA 0004
Coding: 013463004FB100C0650FA0066C09080203004001810426502F0400040F04823F151E06810D1F350200000000000000000000
ASAM Dataset: EV_BCM2CONTIAU651 014010
ROD: EV_BCM2CONTIAU651_014.rod
VCID: 78A9E0F382572D7A6F3-802C SFD
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 C HW: 5Q0 951 172 C
Component: Sensor, DWA 006 0501
Serial number: 0000000000000Q3G1LSR
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000051970582
left tail lamp 1:
Subsystem 4 - Part No SW: 4K8 945 069 C HW: 4K8 945 069 C
Component: Slali1AU583 H04 0404
Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 5 - Part No SW: 80A 962 243 HW: 80A 962 243
Component: GEB.F.Heckoef H17 0911
Serial number: 40296602
Rear spoiler control module:
Subsystem 6 - Part No SW: 4K8 959 252 HW: 4K8 959 252
Component: J223 HSP 0204 H02 0200
Serial number: WA164614000142056245
Coding: 00FF00
left tail lamp 2:
Subsystem 7 - Part No SW: 4K8 945 217 C HW: 4K8 945 217 C
Component: Slali2AU583 H04 0404
Right rear tail lamp 1:
Subsystem 8 - Part No SW: 4K8 945 070 C HW: 4K8 945 070 C
Component: Slare1AU583 H04 0404
Right rear tail lamp 2:
Subsystem 9 - Part No SW: 4K8 945 218 C HW: 4K8 945 218 C
Component: Slare2AU583 H04 0404
65673 - Sensor for Rear Lid/Hatch Opening
B1303 4A [00001001] - Incorrect Component(s) Installed
Reset counter: 127
Mileage: 3306 km
Date: 2024.06.06
Time: 20:16:42
Supply voltages-Terminal 30 power supply: 11.991 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.935 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.998 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 60
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Part No SW: 4M1 959 792 K HW: 4M1 959 792 K
Component: TSG BFS 004 0463
Serial number: YE007WIL17872 Dataset Number: 4K8909873D 0048
Coding: 001DCB035E001280A009A430
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 46D55E0BB8238B8A2DF-8012
Part No SW: 4M2 035 092 G HW: 4M2 035 092 B
Component: MU-TP-NS-US 045 4014
Serial number: GRO-63331.08.23 Dataset Number: 4K1909545J 0044
Coding: 15830000804100000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU37.rod
VCID: 2D0701A73D9558D2CC5-8078 SFD
Multimedia System 1:
Subsystem 1 - Part No SW: 4K0 919 605 M HW: 4K0 919 605 M
Component: DU AU58x Top H41 0060
Serial number: INX00106072300220211
Subsystem 2 - Part No: V03 959 822 HC
Component: MIB3_NA_ 1166
Compact disc data bank:
Component: Gracenote2 3008
Multimedia System 5:
Subsystem 4 - Part No SW: 4K0 919 603 M HW: 4K0 919 603 M
Component: DU AU58x Bot H41 0060
Serial number: INX00114062300240408
Volume Control 1:
Subsystem 5 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00008323000132467054
Android control module:
Subsystem 6 - Part No SW: 8W0 919 806 HW: 8W0 919 806
Component: AED2-EU H54 0527
Serial number: YD700226092303191778
Media socket:
Subsystem 7 - Part No: 4N1 035 736
007 0007
Digital Sound System Control Module 2:
Subsystem 8 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: HHA-07331.08.2334860
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 F HW: 4N0 915 105 F
Component: BMS_48V_LiIon H09 0211
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000229322 Dataset Number: 4K8909850A 0014
ROD: EV_RDKHUFAU736_AU58.rod
VCID: 2F3B1BAF37992AC2FE9-807A
Address 6D: Trunk Elect. (J605) Labels:* None
Part No SW: 89A 959 107 HW: 89A 959 107
Component: HDSG-Modul H02 0711
Revision: -------- Serial number: A2-C786-3760-1 Dataset Number: 4K8909541G 0010
Coding: 1620
ASAM Dataset: EV_DeckLidCONTIAU536 001008
ROD: EV_DeckLidCONTIAU536_VW49.rod
VCID: 71BFDDD7E12D7C32A8D-8024
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4K0 907 777 CA HW: 4K0 907 777 C
Component: Fahrwerk-SG H53 2135
Serial number: 2309232107 Dataset Number: 4K8909576S 0001
Coding: 746C5843FA64
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002.rod
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 A HW: 4M0 907 778
Component: V66LFKompOLV H06 0015
Serial number: 00000000004133357099
Coding: 303030
Part No SW: 4KE 035 283 L HW: 4KE 035 283 E
Component: CB_H_NAR 043 0595
Serial number: A971I0PS395623 Dataset Number: 4K0909612N 0026
Coding: 01E0E0F9C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X.rod
VCID: 45D7590785258092245-8010 SFD
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 L HW: 4K1 713 041 H
Component: GSM-LL H17 0056
Serial number: 23.268 41173
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 2C010CA3068F51DADBB-8078
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4K8 919 617 K HW: 4K8 919 617 K
Component: HeadupDisplay H20 7232
Coding: 4700E2
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4K4 907 117 P HW: 4K4 907 117 B
Component: zFAS Var C H10 0394
Dataset Number: 4K0909466VT 0048
Coding: 020188000000000000FBD60000FCD54E139FD200000000D8000000000096D40101BBB8008000000000000080C00000000000000000000000F980400000000000000098D0008000B000800080000000000080E08000E0
ASAM Dataset: EV_ZFASAU516 004016
ROD: EV_ZFASAU516.rod
VCID: 3C213CE3F6EFC15A4BB-8068
Part No SW: 4K0 907 159 J HW: 81A 907 159 A
Component: SAS-GEN 2.5 H08 0001
Serial number: 230928290848
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
VCID: 382920F3C2D7ED7AAF3-806C
Part No SW: 4M1 959 795 K HW: 4M1 959 795 K
Component: TSG HFS 006 0463
Serial number: YE007WIK19633 Dataset Number: 4K8909897F 0050
Coding: 000DC90300001280E008A020
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
VCID: 49CF5537A93D64F2C0D-801C
Component: TSG HBFS 006 0463
Serial number: YE007WIK22934 Dataset Number: 4K8909896F 0050
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 663 B HW: 4K0 959 663 B
Component: DCDC_GEN_2 H26 0501
Serial number: DC23397000519 Dataset Number: 4K0909475C 0014
ASAM Dataset: EV_DCDC48VFLEXAU581 005014
ROD: EV_DCDC48VFLEXAU581_005_AU49.rod
VCID: 372B23CFCFC9E202A69-8062
Address CA: Sunroof (J245) Labels:* None
Part No SW: 4K8 907 594 AA HW: 4K0 907 594
Component: SAD_STG_1 010 0010
Dataset Number: 4K0909469K 0024
Coding: 268040058301
VCID: 7BA3FFFFB3610662021-802E
Address CB: Rear Axle Steering (J1019) Labels:* 4M0-909-145.clb
Part No SW: 4N0 909 145 R HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0339
Revision: -------- Serial number: CCC_039_B_9061_ Dataset Number: 4KF909904L 0002
Coding: 4224C200
ASAM Dataset: EV_HALUNECEAU536 001004
ROD: EV_HALUNECEAU536.rod
VCID: 40D948139A07A5BA173-8014 SFD
Address CC: Starter-Generator (C29) Labels:* None
Part No SW: 4N1 903 028 B HW: 4N1 903 028 B
Component: BSG-HP1-65 H20 0562
Serial number: 08102300030151 Dataset Number: 4K0909490A 0007
Coding: 30000400000000
ASAM Dataset: EV_Start48VAU651 002007
ROD: EV_Start48VAU651_002.rod
VCID: 2B030FBF038156E2D21-807E
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H28 0588
Dataset Number: 4K8909468G 0028
Coding: 0FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001022
ROD: EV_RearRadarS2DelphAU651.rod
Part No SW: 4K0 941 592 AG HW: 4K0 941 592 A
Component: LMS_MLBevo H20 0132
Dataset Number: 4K0909471L 0021
ROD: EV_LMSLeftHELLAAU58X_AU58.rod
VCID: 75B7E9C795455012745-8020
Dataset Number: 4K0909472L 0021
ROD: EV_LMSRightHELLAAU58X_AU58.rod
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 AM HW: 4N0 907 669 A
Component: MRR_VR H28 0588
Dataset Number: 4K8909482E 0025
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
ROD: EV_FrontCorneRadarS1AU651.rod
VCID: 05579907C5A54092645-8050
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H28 0588
Dataset Number: 4K8909483E 0026
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Coding: 400000
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 2019E8937A4785BA773-8074
Address 8107: Antenna (JX3) Labels:* None
Part No SW: 4N0 035 503 BK HW: 4N0 035 503 BK
Component: DDA_Gen2 H04 0310
Dataset Number: 4K0909484C 0010
Coding: E2D2
ASAM Dataset: EV_DigitRoofAntenAU651 003005
ROD: EV_DigitRoofAntenAU651_003.rod
VCID: 6FBBDBAFF7196AC2BE9-803A SFD
End----(Elapsed Time: 02:30, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Sent from Mail for Windows
grant@gendan
Many of the modules in your scan have SFD protection (SFD shown in VCID). You need to unlock the module's SFD protection before you can make coding changes.
SFD unlock codes can be provided by companies such as PCI in Germany:
Craig.
Cardiff(ish), South Wales, UK.
C?ID=288281
This won't work for SFD2 2024+ cars
Actually it will if you know the proper sequence of things, and you'll need more than one token.
Craig.
C?ID=288281
Fab, so we can change coding in SFD2 locked modules using multiple tokens and a correct sequence! That's great news!
Could you elaborate so others can do this?
