2012 VW CC manual swap cruise control inop.
JustinK25
C?ID=593651
Apologies for posting in the new users thread, I currently don't have the ability to post in the retrofit forum and wanted to see if I could get some help with a vehicle I just purchased.
So long story short, I bought a 2012 CC last week from someone who did a manual swap on the vehicle. The vehicle runs so well that I almost couldn't believe it was a swap. The only giveaway is that the cruise control doesn't work for some reason. The confusing thing to me though is that when monitoring the cruise control switch in VCDS, all buttons are working correctly and the instrument cluster will even show that the cruise is turned on and set. Unfortunately, the vehicle won't maintain speed at all. When scanning the vehicle I found 03182 - Clutch Position Sensor (G476) 010 - Open or Short to Plus.
Now firmly under the impression that this is my issue, and after looking at the block info for the clutch switch on VCDS, I can confirm that there is no change when the clutch pedal is depressed. This has further confused me since the clutch switch seems to be working normally, as the car won't start without the clutch pedal depressed (or there is a redundancy that I'm unaware of). I've inspected the wiring for any problems and haven't noticed any issues visually.
At this point, I'm wondering if somehow the clutch wiring hasn't been done correctly, or if there is a coding issue that I'm not seeing. Any help would be greatly appreciated. Thanks!
Saturday,17,August,2024,20:14:18:11561
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.5
VIN: WVWNP7AN5CE531206   License Plate:
Mileage: 184860km-114866mi   Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 53 56 62 65
          72 77
VIN: WVWNP7AN5CE531206   Mileage: 184860km-114866miles
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 997 029 F    HW: 06J 907 309 B
   Component: MED17.5.2        03 1511
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010818070160
   Shop #: WSC 52021 001 1048576
   VCID: 3A2AEB00705D4B4A517-806E
   VINID: 9E69DE80745E1535450C1080183E97E92A
005924 - Starter Interlock Signal
               P1724 - 000 - Short to Ground - Intermittent
                    Mileage: 184414 km
                    Date: 2019.01.07.
                    Time: 03:32:02
                    Temperature: 42.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.319 V
001056 - Catalyst System; Bank 1
               P0420 - 000 - Efficiency Below Threshold - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 184518 km
                    Date: 2019.01.07.
                    Time: 07:06:27
                    RPM: 2838 /min
                    Load: 29.8 %
                    Speed: 117.0 km/h
                    Temperature: 98.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.970 V
   Part No SW: 3AA 614 109 AB    HW: 3AA 614 109 AB
   Component: J104   C2 450M V41B 0022
   Revision: --H07---    Serial number: 00000004315845
   Coding: 0004492
   Shop #: WSC 05311 000 00000
   VCID: 6D80105C71932CF2845-8038
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000001002
   Shop #: WSC 00015 115 00000
   ROD: EV_ACManueBHBVW36X_VW46.rod
   VCID: 005E59E85A81D19A5F3-8054
Address 09: Cent. Elect.
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__30S VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPB2U0NJ
   Coding: 0012371
   VCID: 4BC4BEC42FC7C2C2FA1-801E
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000058UK
   Subsystem 3 - Serial number: 0003.05.110000300000630048ÿ†63
   Subsystem 4 - Serial number: 630048ÿ†6332MTS633211421 ÿ†63
   Subsystem 5 - Serial number: 11421 ÿ†6342MTS655751411 ÿ†63
   Subsystem 6 - Serial number: 51411 ÿ†6351HTS6GFBI5AKR ÿ†63
   Subsystem 7 - Serial number: I5AKR ÿ†6361HTS6JOLG5AKJ ÿ†63
   Subsystem 8 - Serial number: G5AKJ ÿ†63727TS656CO2AKJ ÿ†63
   Subsystem 9 - Serial number: O2AKJ ÿ†63827TS6CI6AV9KJ ÿ
   Subsystem 10 - Serial number: AV9KJ ÿ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110607201598
   Coding: 018A270000
   Shop #: WSC 00015 115 12345
   VCID: 6B841E44430722C29A1-803E
   Coding: E20000
   Part No SW: 3C8 920 970 T    HW: 3C8 920 970 T
   Component: KOMBI         H04 0607
   Coding: 240A00
   Shop #: WSC 05314 115 12345
   VCID: 3D20E01C6DF37C72745-8068
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 060611F2000039
   Coding: 469006
   Shop #: WSC 05314 123 12345
   VCID: 3928F40C795B405258D-806C
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128R2PDK03
   Coding: 0000002
   Shop #: WSC 05314 000 00000
   VCID: 75B0383C19C3E4327C5-8020
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   Shop #: WSC 23389 004 1048576
   VCID: 372CF234434F5622AE9-8062
   Revision: A1001003    Serial number: 7660246962
   VCID: 2908244C89FBF0D228D-807C
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0501
   Revision: 12110009    Serial number: 0002992569
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X_VW46.rod
   VCID: 6D80105C7D132CF2845-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000002225187
   Coding: 000490
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.140 0703
   Revision: 1AH03256    Serial number: 00091180065202
   Coding: 0000258
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001862E521204141FF08A0F0E085801
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FBC0A54779FDEE2B69-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0501
   Revision: 14110009    Serial number: 0003001320
   Coding: 0004B6
   VCID: 6E8217507015D7EABDF-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000002227570
   Coding: 000490
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000130756
   Coding: 0022157
   VCID: 3530F83C5943A432BC5-8060
                    Fault Status: 01111010
                    Reset counter: 27
                    Mileage: 184867 km
                    Date: 2019.01.08.
                    Time: 08:12:07
                    Voltage: 12.30 V
                    Count: 55
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L1121457
   Coding: 0100040004000F
   VCID: 63947664AB576A82221-8036
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000037939
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 3334C6245BB7BA02921-8066
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660180016 Dataset Number: 7P6035730F  0001
   Coding: 0A00000000010100
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 3530F83C55C3A432BC5-8060
End----------(Elapsed Time: 01:26, VBatt start/end: 12.2V/12.2V)-----------
NZDubNurd
New Zealand
C?ID=230482
The problem with conversions, is that SOOO many people do a crappy job on them... I wonder if it's just had an incorrect clutch switch fitted to the auto starter interlock wiring, instead of being wired to the ECU and the appropriate coding and wiring changes made. It's not even hard, but people bypass stuff like this a lot, and do it half-assed.
At least it appears to have the correct ECU fitted and things seems coded correctly! So it can't be too badly done.
Regardless, I'd certainly be testing and inspecting the clutch switch wiring. I believe it should have a hall-type sensor? The ECU should be able to see when the clutch is down, but also when it is very slightly depressed - The Cruise Control will disengage the instant the pedal is moved, but it shouldn't start, unless right down.
Nothing from the auto wiring should have been bodged - it's pretty easy to disable it all and make the corrections for the manual trans.
Dr Sheldon
Windsor UK
C?ID=334979
Why would you do that ??
So it seems - Just the CC not working and just a Clutch Switch issue !! I seriously am impressed - Whoever did that work will never be unemployed whilst I am alive :p :p
I just cannot fathom why one would invest so much talent and time into a task like this ??
If those hours and talent were converted to Dollars and Cents he could easily have bought a far better engineered and more reliable vehicle than a VW !!
The mind Boggles !
JustinK25
C?ID=593651
I make terrible automotive decisions. My previous car was a Mazdaspeed6 and I wanted to get into something that would take up less of my time... so naturally I purchased a manual swapped VW...
This is where I left off yesterday. The clutch switch is a hall-type and is the correct part number. A visual check of all the wiring and all seems solid. It looks like it's been tapped into the ECU and all the wiring looks to be in the right spot based loosely on the small amount of info I've gathered over hours of searching the internet. The issue I'm having is without having the correct info for what wiring needs to be tapped into the system and in what circuits, I'm a bit at a standstill. I'm also curious as to how the clutch switch is very obviously working when I start the vehicle without there being any indication through VCDS that the clutch pedal is actually being depressed.
I've found a couple of videos explaining how the wiring should be tapped in on other VAG models so I reckon I'll start there. If anyone could help me out with a diagram more specific to my vehicle or something similar it would be greatly appreciated. At the very least a rundown of what readings I should have at the connector pins.
I appreciate any and all help.
NZDubNurd
New Zealand
C?ID=230482
There's a few of us in that club... I was awarded lifetime membership...
Get an Erwin subscription and download the diagrams for the car and one with manual trans.
JustinK25
C?ID=593651
Perfect. This is exactly what I need. Thank you!
JustinK25
C?ID=593651
So just an update on this. I got an Erwin subscription and downloaded all the available manuals for my car. After checking over the wiring done by the previous owner, everything appears to be done correctly. The wire running from the clutch sensor to the EPB module does not appear to be shorted or damaged at any point. Unfortunately I still can't seem to figure out why the parking brake module is still complaining about the clutch sensor. The clutch and switch itself are the correct part number according to the VIN per VW. The module itself is correct, although it's an older part number. Looking at the data blocks for clutch position through the EPB module, it's stuck on 100% no matter what position the clutch is in. Again, this makes no sense to me since the clutch behaves completely normal when starting the car (only starts with clutch pedal to the floor). I replaced the clutch position sensor just to see if anything would change, but to no avail.
I'm currently just pissing in the wind with this, so figured I'd update the thread in hopes that someone will come along with some info that may help, and before I start firing the parts cannon.
Thanks.
Westbury, UK
Is G476 the clutch fully pressed or clutch just pressed sensor?
The fully pressed sensor is what's needed to start the engine, but the just pressed sensor is used for other conditions (such as cruise control).
JustinK25
C?ID=593651
Apologies for the confusion. My car uses the hall type sensor for the clutch, not the dual switch type.
Now you do, and I've moved it there.
Better (and cheaper) than making bad decisions when it comes to women!
JustinK25
C?ID=593651
Lucky for me, I like to do both of those things. Now that I've now spent countless hours poking and prodding around in this car in search of the all-elusive cruise control, I've hit the point of maybe giving up and have contemplated insurance fraud to get myself out from under my financial mistake (kidding).
I now have more questions than I did before I started this endeavor, and again am purely commenting in hopes that someone who is smarter than I am can point me in the right direction. I've quadruple checked that this is the correct diagram for the vehicle I have, 2.0L gasoline engine CBFA 7L3:
I know without a doubt that G476 is wired correctly into J623 and J540. I also know that I have (at the very least) tied into the correct circuit to pin 5 of G476. What I don't know is if this wire absolutely needs to be tied into B585, because I cant find an illustration anywhere in the document that shows exactly where this connection is. The same goes for the ground wire from pin 1 of the G476 and if it absolutely needs to be tied into 398, because again, there is no illustration as to where in the harness this connection is made unless I'm just not reading the diagram correctly. Currently the ground is bolted down to metal in the engine bay.
The other extremely puzzling thing I figured out today was the complete lack of what this said ground wire is supposed to be shared with. following the diagram down I can see that this is supposed to be connected with the oil level thermal sensor:
Problem is, The wiring for the G266 is completely gone. Not like it was removed, but like it never existed in this vehicle. The wiring doesn't exist in T6e or even T32c. I can see the sensor and plug sticking out of the bottom of the engine, with nothing plugged into it, and no fault code for anything even being wrong with it. So now I'm wondering how this is even possible if both the donor and recipient car build sheets are almost identical with the exception of the manual trans. That, on top of the fact that a diagram doesn't exist for this car without the thermal sensor (if I'm looking specifically at CBFA diagrams). Am I missing something here? I mean, apart from an entire circuit. Do I even need to worry about this? Could the ground point even really be an issue? I feel like it can't be this hard to wire in a correctly functioning clutch position sensor and I'm just completely overlooking something.
I'm open to any ideas, thanks in advance.
JustinK25
C?ID=593651
Hello again and please disregard the last incoherent post. I'm back again, again asking for your support.
I recently figured out why the EPB was complaining about the clutch position sensor. It was because the pin that was previously installed wasn't pushed in all the way. So after feeling like an idiot for a few minutes, I test drove the car and found out that the cruise control is still not working. The vehicle is not complaining about any issues with the cruise control. The EPC and brake lights are no longer illuminated. The cruise indicator shows up in the center screen, but the cruise control just flat out won't set. VCDS is showing the ECM as recognizing the cruise switch inputs, and still nothing happens.
I have checked every sing wire in the cruise system and everything is wired correctly. The instrument cluster, cruise switch, J519, and even the throttle body and throttle pedal seem to be correct parts when checking with VW parts. I have gone through all of the coding and checked everything I can think of to make sure correct coding, and everything seems to be done correctly.
I have to be missing something. Something just has to be coded wrong, or something is not activated the way it should be at this point. I've already read through everything I could find on these forums and in the coding help sections and I've not been able to fix the issue. So here I am, just one last time, posting a scan and asking for advice on what I can try to get this thing sorted. I'll try anything at this point, and if it doesn't work, at least I can say I tried. Any pointers are appreciated. Thanks!
Tuesday,22,October,2024,13:32:57:11561
VCDS Version: 24.7.1.0  HEX-V2 CB: 0.4643.5
          72 77
VIN: WVWNP7AN5CE531206   Mileage: 192080km-119352miles
   Shop #: WSC 57995 004 104857
   VCID: 3A2AEB00705D4B4A51F-806E
               P0420 - 000 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100000
                    Mileage: 191333 km
                    Date: 2019.03.11.
                    Time: 00:18:23
                    RPM: 2885 /min
                    Load: 34.9 %
                    Speed: 121.0 km/h
                    Temperature: 95.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
   Component: J104   C2 450M V477 0022
   Coding: 0004492
   VCID: 6D80105C71932CF284D-8038
   Revision: 00001015
   Coding: 0000001002
   VCID: 005E59E85A81D19A5FB-8054
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 D    HW: 3AA 937 087 D
   Component: BCM PQ47 H    413 0455
   Revision: BB413001
   Coding: 000000000000000000980201940080044051008850208D605C8060200040
   Shop #: WSC 05311 123 12345
   VCID: 3B24EE04736772424A9-806E
   Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 10051  10  0603
   Coding: 00B795
                    Reset counter: 119
                    Mileage: 192081 km
                    Date: 2019.03.15.
                    Time: 21:13:42
                    Voltage: 12.20 V
   Coding: 0012371
   VCID: 4BC4BEC42FC7C2C2FA9-801E
   Coding: 018A270000
   VCID: 6B841E44430722C29A9-803E
   Coding: E20000
   Coding: 210E01
   VCID: 3D20E01C6DF37C7274D-8068
   Coding: 461002
   Shop #: WSC 12345 960 150854
   VCID: 3928F40C795B4052585-806C
   Coding: 0000002
   VCID: 75B0383C19C3E4327CD-8020
   VCID: 372CF234434F5622AE1-8062
   VCID: 2908244C89FBF0D2285-807C
03138 - Input AUX IN
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 119
                    Mileage: 192081 km
                    Date: 2019.03.15.
                    Time: 21:18:01
   Coding: 0004B7
   VCID: 6D80105C7D132CF284D-8038
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 1B910F8001862E521204141FF08A0F0E085C01
   Coding: 00000008
   VCID: 6FBC0A54779FDEE2B61-803A
   Coding: 0004B6
   VCID: 6E8217507015D7EABD7-803A
   Slave Passenger:
   Coding: 000490
   Coding: 0022157
   VCID: 3530F83C5943A432BCD-8060
   VCID: 63947664AB576A82229-8036
   VCID: 3334C6245BB7BA02929-8066
   ROD: UHVNA.rod
   VCID: 3530F83C55C3A432BCD-8060
End----------(Elapsed Time: 01:27, VBatt start/end: 12.2V/12.2V)-----------
teal2
C?ID=578564
go into your SWCM (Address 16) and then go into “adv measuring blocks” or if you have the regular ones and then check the output of the cruise sensors and get back to me, I have ha d faulty SWCM’s ruin many days.
JustinK25
C?ID=593651
Looks like SWCM is recognizing all of the cruise control inputs. Curious what station coding means though. Also looking through the scan again, I'm wondering why instruments' serial number is all 0's and whether this is normal
teal2
C?ID=578564
   Coding: 018A270000
   Coding: E20000
so this is your SWCM. It looks good as its a -T variant (pretty much universal for PQ VAG), its coding also seems fine. Hmph
did you check ECM Codings in Lcode.
JustinK25
C?ID=593651
   Coding: 018A270000
   Coding: E20000
Yes as far as I can see, there is only one option that relates to my issue and that's the transmission and cruise control portion of the long code and it appears to be coded correctly. 6-speed manual and cruise control options checked.
teal2
C?ID=578564
Try coding to automatic and see how it goes, it will not impact functionality
JustinK25
C?ID=593651
I've actually already done that with no success.
